[U-Boot] [PATCH] USB: Add dcache support to the EHCI driver
This patch adds routines to handle (flush/invalidate) the dcache for the QH and qTD structures and data buffers. This is needed on platforms using this EHCI support with dcache enabled (like the MIPS VCT board port).
Signed-off-by: Stefan Roese sr@denx.de --- drivers/usb/usb_ehci.h | 5 ++ drivers/usb/usb_ehci_core.c | 98 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 103 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/usb_ehci.h b/drivers/usb/usb_ehci.h index b72498b..b3c1d5d 100644 --- a/drivers/usb/usb_ehci.h +++ b/drivers/usb/usb_ehci.h @@ -180,6 +180,11 @@ struct QH { uint32_t qh_endpt2; uint32_t qh_curtd; struct qTD qh_overlay; + /* + * Add dummy fill value to make the size of this struct + * aligned to 32 bytes + */ + uint8_t fill[16]; };
/* Low level init functions */ diff --git a/drivers/usb/usb_ehci_core.c b/drivers/usb/usb_ehci_core.c index 2f38f33..813f64a 100644 --- a/drivers/usb/usb_ehci_core.c +++ b/drivers/usb/usb_ehci_core.c @@ -106,6 +106,99 @@ static struct descriptor { #define ehci_is_TDI() (0) #endif
+#if defined(CONFIG_EHCI_DCACHE) +/* + * Routines to handle (flush/invalidate) the dcache for the QH and qTD + * structures and data buffers. This is needed on platforms using this + * EHCI support with dcache enabled. + */ +static void flush_invalidate(u32 addr, int size, int flush) +{ + if (flush) + flush_dcache_range(addr, addr + size); + else + invalidate_dcache_range(addr, addr + size); +} + +static void cache_qtd(struct qTD *qtd, int flush) +{ + u32 *ptr = (u32 *)qtd->qt_buffer[0]; + int len = (qtd->qt_token & 0x7fff0000) >> 16; + + flush_invalidate((u32)qtd, sizeof(struct qTD), flush); + if (ptr && len) + flush_invalidate((u32)ptr, len, flush); +} + + +static inline struct QH *qh_addr(struct QH *qh) +{ + return (struct QH *)((u32)qh & 0xffffffe0); +} + +static void cache_qh(struct QH *qh, int flush) +{ + struct qTD *qtd; + struct qTD *next; + static struct qTD *first_qtd; + + /* + * Walk the QH list and flush/invalidate all entries + */ + while (1) { + flush_invalidate((u32)qh_addr(qh), sizeof(struct QH), flush); + if ((u32)qh & QH_LINK_TYPE_QH) + break; + qh = qh_addr(qh); + qh = (struct QH *)qh->qh_link; + } + qh = qh_addr(qh); + + /* + * Save first qTD pointer, needed for invalidating pass on this QH + */ + if (flush) + first_qtd = qtd = (struct qTD *)(*(u32 *)&qh->qh_overlay & + 0xffffffe0); + else + qtd = first_qtd; + + /* + * Walk the qTD list and flush/invalidate all entries + */ + while (1) { + if (qtd == NULL) + break; + cache_qtd(qtd, flush); + next = (struct qTD *)((u32)qtd->qt_next & 0xffffffe0); + if (next == qtd) + break; + qtd = next; + } +} + +static inline void ehci_flush_dcache(struct QH *qh) +{ + cache_qh(qh, 1); +} + +static inline void ehci_invalidate_dcache(struct QH *qh) +{ + cache_qh(qh, 0); +} +#else /* CONFIG_EHCI_DCACHE */ +/* + * + */ +static inline void ehci_flush_dcache(struct QH *qh) +{ +} + +static inline void ehci_invalidate_dcache(struct QH *qh) +{ +} +#endif /* CONFIG_EHCI_DCACHE */ + static int handshake(uint32_t *ptr, uint32_t mask, uint32_t done, int usec) { uint32_t result; @@ -331,6 +424,9 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer,
qh_list.qh_link = cpu_to_hc32((uint32_t) qh | QH_LINK_TYPE_QH);
+ /* Flush dcache */ + ehci_flush_dcache(&qh_list); + usbsts = ehci_readl(&hcor->or_usbsts); ehci_writel(&hcor->or_usbsts, (usbsts & 0x3f));
@@ -350,6 +446,8 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, ts = get_timer(0); vtd = td; do { + /* Invalidate dcache */ + ehci_invalidate_dcache(&qh_list); token = hc32_to_cpu(vtd->qt_token); if (!(token & 0x80)) break;
Stefan Roese
