[U-Boot-Users] [PATCH] ata: update the libata.h from ata.h of linux kernel
Current libata.h of u-boot is out of sync from linux kernel, this patch make it be consistent with linux kernel.
Signed-off-by: Dave Liu daveliu@freescale.com Signed-off-by: Tor Krill tor@excito.com --- drivers/block/fsl_sata.c | 14 +- include/libata.h | 644 +++++++++++++++++++++++++++++++++++++++------- 2 files changed, 561 insertions(+), 97 deletions(-)
diff --git a/drivers/block/fsl_sata.c b/drivers/block/fsl_sata.c index 7436c4d..d14f5bc 100644 --- a/drivers/block/fsl_sata.c +++ b/drivers/block/fsl_sata.c @@ -600,7 +600,7 @@ static u32 fsl_sata_rw_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_wr
cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; cfis->pm_port_c = 0x80; /* is command */ - cfis->command = (is_write) ? ATA_CMD_WRITE_DMA : ATA_CMD_READ_DMA; + cfis->command = (is_write) ? ATA_CMD_WRITE : ATA_CMD_READ; cfis->device = ATA_LBA;
cfis->device |= (block >> 24) & 0xf; @@ -625,7 +625,7 @@ void fsl_sata_flush_cache(int dev)
cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; cfis->pm_port_c = 0x80; /* is command */ - cfis->command = ATA_CMD_FLUSH_CACHE; + cfis->command = ATA_CMD_FLUSH;
fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); } @@ -645,8 +645,8 @@ static u32 fsl_sata_rw_cmd_ext(int dev, u32 start, u32 blkcnt, u8 *buffer, int i cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; cfis->pm_port_c = 0x80; /* is command */
- cfis->command = (is_write) ? ATA_CMD_WRITE_DMA_EXT - : ATA_CMD_READ_DMA_EXT; + cfis->command = (is_write) ? ATA_CMD_WRITE_EXT + : ATA_CMD_READ_EXT;
cfis->lba_high_exp = (block >> 40) & 0xff; cfis->lba_mid_exp = (block >> 32) & 0xff; @@ -683,8 +683,8 @@ u32 fsl_sata_rw_ncq_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; cfis->pm_port_c = 0x80; /* is command */
- cfis->command = (is_write) ? ATA_CMD_WRITE_FPDMA_QUEUED - : ATA_CMD_READ_FPDMA_QUEUED; + cfis->command = (is_write) ? ATA_CMD_FPDMA_WRITE + : ATA_CMD_FPDMA_READ;
cfis->lba_high_exp = (block >> 40) & 0xff; cfis->lba_mid_exp = (block >> 32) & 0xff; @@ -719,7 +719,7 @@ void fsl_sata_flush_cache_ext(int dev)
cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; cfis->pm_port_c = 0x80; /* is command */ - cfis->command = ATA_CMD_FLUSH_CACHE_EXT; + cfis->command = ATA_CMD_FLUSH_EXT;
fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); } diff --git a/include/libata.h b/include/libata.h index aedba74..62a1760 100644 --- a/include/libata.h +++ b/include/libata.h @@ -1,4 +1,6 @@ /* + * Copyright 2003-2004 Red Hat, Inc. All rights reserved. + * Copyright 2003-2004 Jeff Garzik * Copyright (C) 2008 Freescale Semiconductor, Inc. * Dave Liu daveliu@freescale.com * port from libata of linux kernel @@ -25,33 +27,180 @@
#include <common.h>
-/* command - */ -enum ata_cmd { - /* non-NCQ command */ - ATA_CMD_DEV_RESET = 0x08, /* ATAPI device reset */ - ATA_CMD_FLUSH_CACHE = 0xE7, - ATA_CMD_FLUSH_CACHE_EXT = 0xEA, - ATA_CMD_ID_ATA = 0xEC, - ATA_CMD_ID_ATAPI = 0xA1, - ATA_CMD_READ_DMA = 0xC8, - ATA_CMD_READ_DMA_EXT = 0x25, - ATA_CMD_WRITE_DMA = 0xCA, - ATA_CMD_WRITE_DMA_EXT = 0x35, - ATA_CMD_PIO_READ = 0x20, - ATA_CMD_PIO_READ_EXT = 0x24, - ATA_CMD_PIO_WRITE = 0x30, - ATA_CMD_PIO_WRITE_EXT = 0x34, - ATA_CMD_SET_FEATURES = 0xEF, - - /* NCQ command */ - ATA_CMD_READ_FPDMA_QUEUED = 0x60, - ATA_CMD_WRITE_FPDMA_QUEUED = 0x61, -}; +enum { + /* various global constants */ + ATA_MAX_DEVICES = 2, /* per bus/port */ + ATA_MAX_PRD = 256, /* we could make these 256/256 */ + ATA_SECT_SIZE = 512, + ATA_MAX_SECTORS_128 = 128, + ATA_MAX_SECTORS = 256, + ATA_MAX_SECTORS_LBA48 = 65535, + ATA_MAX_SECTORS_TAPE = 65535, + + ATA_ID_WORDS = 256, + ATA_ID_SERNO = 10, + ATA_ID_FW_REV = 23, + ATA_ID_PROD = 27, + ATA_ID_OLD_PIO_MODES = 51, + ATA_ID_FIELD_VALID = 53, + ATA_ID_LBA_SECTORS = 60, + ATA_ID_MWDMA_MODES = 63, + ATA_ID_PIO_MODES = 64, + ATA_ID_EIDE_DMA_MIN = 65, + ATA_ID_EIDE_PIO = 67, + ATA_ID_EIDE_PIO_IORDY = 68, + ATA_ID_PIO4 = (1 << 1), + ATA_ID_QUEUE_DEPTH = 75, + ATA_ID_SATA_CAP = 76, + ATA_ID_SATA_FEATURES = 78, + ATA_ID_SATA_FEATURES_EN = 79, + ATA_ID_MAJOR_VER = 80, + ATA_ID_MINOR_VER = 81, + ATA_ID_UDMA_MODES = 88, + ATA_ID_LBA48_SECTORS = 100, + + ATA_ID_SERNO_LEN = 20, + ATA_ID_FW_REV_LEN = 8, + ATA_ID_PROD_LEN = 40, + + ATA_PCI_CTL_OFS = 2, + + ATA_PIO0 = (1 << 0), + ATA_PIO1 = ATA_PIO0 | (1 << 1), + ATA_PIO2 = ATA_PIO1 | (1 << 2), + ATA_PIO3 = ATA_PIO2 | (1 << 3), + ATA_PIO4 = ATA_PIO3 | (1 << 4), + ATA_PIO5 = ATA_PIO4 | (1 << 5), + ATA_PIO6 = ATA_PIO5 | (1 << 6), + + ATA_SWDMA0 = (1 << 0), + ATA_SWDMA1 = ATA_SWDMA0 | (1 << 1), + ATA_SWDMA2 = ATA_SWDMA1 | (1 << 2), + + ATA_SWDMA2_ONLY = (1 << 2), + + ATA_MWDMA0 = (1 << 0), + ATA_MWDMA1 = ATA_MWDMA0 | (1 << 1), + ATA_MWDMA2 = ATA_MWDMA1 | (1 << 2), + + ATA_MWDMA12_ONLY = (1 << 1) | (1 << 2), + ATA_MWDMA2_ONLY = (1 << 2), + + ATA_UDMA0 = (1 << 0), + ATA_UDMA1 = ATA_UDMA0 | (1 << 1), + ATA_UDMA2 = ATA_UDMA1 | (1 << 2), + ATA_UDMA3 = ATA_UDMA2 | (1 << 3), + ATA_UDMA4 = ATA_UDMA3 | (1 << 4), + ATA_UDMA5 = ATA_UDMA4 | (1 << 5), + ATA_UDMA6 = ATA_UDMA5 | (1 << 6), + ATA_UDMA7 = ATA_UDMA6 | (1 << 7), + /* ATA_UDMA7 is just for completeness... doesn't exist (yet?). */ + + ATA_UDMA_MASK_40C = ATA_UDMA2, /* udma0-2 */ + + /* DMA-related */ + ATA_PRD_SZ = 8, + ATA_PRD_TBL_SZ = (ATA_MAX_PRD * ATA_PRD_SZ), + ATA_PRD_EOT = (1 << 31), /* end-of-table flag */ + + ATA_DMA_TABLE_OFS = 4, + ATA_DMA_STATUS = 2, + ATA_DMA_CMD = 0, + ATA_DMA_WR = (1 << 3), + ATA_DMA_START = (1 << 0), + ATA_DMA_INTR = (1 << 2), + ATA_DMA_ERR = (1 << 1), + ATA_DMA_ACTIVE = (1 << 0), + + /* bits in ATA command block registers */ + ATA_HOB = (1 << 7), /* LBA48 selector */ + ATA_NIEN = (1 << 1), /* disable-irq flag */ + ATA_LBA = (1 << 6), /* LBA28 selector */ + ATA_DEV1 = (1 << 4), /* Select Device 1 (slave) */ + ATA_DEVICE_OBS = (1 << 7) | (1 << 5), /* obs bits in dev reg */ + ATA_DEVCTL_OBS = (1 << 3), /* obsolete bit in devctl reg */ + ATA_BUSY = (1 << 7), /* BSY status bit */ + ATA_DRDY = (1 << 6), /* device ready */ + ATA_DF = (1 << 5), /* device fault */ + ATA_DRQ = (1 << 3), /* data request i/o */ + ATA_ERR = (1 << 0), /* have an error */ + ATA_SRST = (1 << 2), /* software reset */ + ATA_ICRC = (1 << 7), /* interface CRC error */ + ATA_UNC = (1 << 6), /* uncorrectable media error */ + ATA_IDNF = (1 << 4), /* ID not found */ + ATA_ABORTED = (1 << 2), /* command aborted */ + + /* ATA command block registers */ + ATA_REG_DATA = 0x00, + ATA_REG_ERR = 0x01, + ATA_REG_NSECT = 0x02, + ATA_REG_LBAL = 0x03, + ATA_REG_LBAM = 0x04, + ATA_REG_LBAH = 0x05, + ATA_REG_DEVICE = 0x06, + ATA_REG_STATUS = 0x07, + + ATA_REG_FEATURE = ATA_REG_ERR, /* and their aliases */ + ATA_REG_CMD = ATA_REG_STATUS, + ATA_REG_BYTEL = ATA_REG_LBAM, + ATA_REG_BYTEH = ATA_REG_LBAH, + ATA_REG_DEVSEL = ATA_REG_DEVICE, + ATA_REG_IRQ = ATA_REG_NSECT, + + /* ATA device commands */ + ATA_CMD_DEV_RESET = 0x08, /* ATAPI device reset */ + ATA_CMD_CHK_POWER = 0xE5, /* check power mode */ + ATA_CMD_STANDBY = 0xE2, /* place in standby power mode */ + ATA_CMD_IDLE = 0xE3, /* place in idle power mode */ + ATA_CMD_EDD = 0x90, /* execute device diagnostic */ + ATA_CMD_FLUSH = 0xE7, + ATA_CMD_FLUSH_EXT = 0xEA, + ATA_CMD_ID_ATA = 0xEC, + ATA_CMD_ID_ATAPI = 0xA1, + ATA_CMD_READ = 0xC8, + ATA_CMD_READ_EXT = 0x25, + ATA_CMD_WRITE = 0xCA, + ATA_CMD_WRITE_EXT = 0x35, + ATA_CMD_WRITE_FUA_EXT = 0x3D, + ATA_CMD_FPDMA_READ = 0x60, + ATA_CMD_FPDMA_WRITE = 0x61, + ATA_CMD_PIO_READ = 0x20, + ATA_CMD_PIO_READ_EXT = 0x24, + ATA_CMD_PIO_WRITE = 0x30, + ATA_CMD_PIO_WRITE_EXT = 0x34, + ATA_CMD_READ_MULTI = 0xC4, + ATA_CMD_READ_MULTI_EXT = 0x29, + ATA_CMD_WRITE_MULTI = 0xC5, + ATA_CMD_WRITE_MULTI_EXT = 0x39, + ATA_CMD_WRITE_MULTI_FUA_EXT = 0xCE, + ATA_CMD_SET_FEATURES = 0xEF, + ATA_CMD_SET_MULTI = 0xC6, + ATA_CMD_PACKET = 0xA0, + ATA_CMD_VERIFY = 0x40, + ATA_CMD_VERIFY_EXT = 0x42, + ATA_CMD_STANDBYNOW1 = 0xE0, + ATA_CMD_IDLEIMMEDIATE = 0xE1, + ATA_CMD_SLEEP = 0xE6, + ATA_CMD_INIT_DEV_PARAMS = 0x91, + ATA_CMD_READ_NATIVE_MAX = 0xF8, + ATA_CMD_READ_NATIVE_MAX_EXT = 0x27, + ATA_CMD_SET_MAX = 0xF9, + ATA_CMD_SET_MAX_EXT = 0x37, + ATA_CMD_READ_LOG_EXT = 0x2f, + ATA_CMD_PMP_READ = 0xE4, + ATA_CMD_PMP_WRITE = 0xE8, + ATA_CMD_CONF_OVERLAY = 0xB1, + ATA_CMD_SEC_FREEZE_LOCK = 0xF5, + + /* READ_LOG_EXT pages */ + ATA_LOG_SATA_NCQ = 0x10, + + /* READ/WRITE LONG (obsolete) */ + ATA_CMD_READ_LONG = 0x22, + ATA_CMD_READ_LONG_ONCE = 0x23, + ATA_CMD_WRITE_LONG = 0x32, + ATA_CMD_WRITE_LONG_ONCE = 0x33,
-/* SETFEATURES stuff - */ -enum ata_set_features { /* SETFEATURES stuff */ SETFEATURES_XFER = 0x03, XFER_UDMA_7 = 0x47, @@ -62,13 +211,16 @@ enum ata_set_features { XFER_UDMA_2 = 0x42, XFER_UDMA_1 = 0x41, XFER_UDMA_0 = 0x40, - XFER_MW_DMA_4 = 0x24, /* CFA only */ - XFER_MW_DMA_3 = 0x23, /* CFA only */ + XFER_MW_DMA_4 = 0x24, /* CFA only */ + XFER_MW_DMA_3 = 0x23, /* CFA only */ XFER_MW_DMA_2 = 0x22, XFER_MW_DMA_1 = 0x21, XFER_MW_DMA_0 = 0x20, - XFER_PIO_6 = 0x0E, /* CFA only */ - XFER_PIO_5 = 0x0D, /* CFA only */ + XFER_SW_DMA_2 = 0x12, + XFER_SW_DMA_1 = 0x11, + XFER_SW_DMA_0 = 0x10, + XFER_PIO_6 = 0x0E, /* CFA only */ + XFER_PIO_5 = 0x0D, /* CFA only */ XFER_PIO_4 = 0x0C, XFER_PIO_3 = 0x0B, XFER_PIO_2 = 0x0A, @@ -80,17 +232,122 @@ enum ata_set_features { SETFEATURES_WC_OFF = 0x82, /* Disable write cache */
SETFEATURES_SPINUP = 0x07, /* Spin-up drive */ + + SETFEATURES_SATA_ENABLE = 0x10, /* Enable use of SATA feature */ + SETFEATURES_SATA_DISABLE = 0x90, /* Disable use of SATA feature */ + + /* SETFEATURE Sector counts for SATA features */ + SATA_AN = 0x05, /* Asynchronous Notification */ + SATA_DIPM = 0x03, /* Device Initiated Power Management */ + + /* feature values for SET_MAX */ + ATA_SET_MAX_ADDR = 0x00, + ATA_SET_MAX_PASSWD = 0x01, + ATA_SET_MAX_LOCK = 0x02, + ATA_SET_MAX_UNLOCK = 0x03, + ATA_SET_MAX_FREEZE_LOCK = 0x04, + + /* feature values for DEVICE CONFIGURATION OVERLAY */ + ATA_DCO_RESTORE = 0xC0, + ATA_DCO_FREEZE_LOCK = 0xC1, + ATA_DCO_IDENTIFY = 0xC2, + ATA_DCO_SET = 0xC3, + + /* ATAPI stuff */ + ATAPI_PKT_DMA = (1 << 0), + ATAPI_DMADIR = (1 << 2), /* ATAPI data dir: + 0=to device, 1=to host */ + ATAPI_CDB_LEN = 16, + + /* PMP stuff */ + SATA_PMP_MAX_PORTS = 15, + SATA_PMP_CTRL_PORT = 15, + + SATA_PMP_GSCR_DWORDS = 128, + SATA_PMP_GSCR_PROD_ID = 0, + SATA_PMP_GSCR_REV = 1, + SATA_PMP_GSCR_PORT_INFO = 2, + SATA_PMP_GSCR_ERROR = 32, + SATA_PMP_GSCR_ERROR_EN = 33, + SATA_PMP_GSCR_FEAT = 64, + SATA_PMP_GSCR_FEAT_EN = 96, + + SATA_PMP_PSCR_STATUS = 0, + SATA_PMP_PSCR_ERROR = 1, + SATA_PMP_PSCR_CONTROL = 2, + + SATA_PMP_FEAT_BIST = (1 << 0), + SATA_PMP_FEAT_PMREQ = (1 << 1), + SATA_PMP_FEAT_DYNSSC = (1 << 2), + SATA_PMP_FEAT_NOTIFY = (1 << 3), + + /* cable types */ + ATA_CBL_NONE = 0, + ATA_CBL_PATA40 = 1, + ATA_CBL_PATA80 = 2, + ATA_CBL_PATA40_SHORT = 3, /* 40 wire cable to high UDMA spec */ + ATA_CBL_PATA_UNK = 4, /* don't know, maybe 80c? */ + ATA_CBL_PATA_IGN = 5, /* don't know, ignore cable handling */ + ATA_CBL_SATA = 6, + + /* SATA Status and Control Registers */ + SCR_STATUS = 0, + SCR_ERROR = 1, + SCR_CONTROL = 2, + SCR_ACTIVE = 3, + SCR_NOTIFICATION = 4, + + /* SError bits */ + SERR_DATA_RECOVERED = (1 << 0), /* recovered data error */ + SERR_COMM_RECOVERED = (1 << 1), /* recovered comm failure */ + SERR_DATA = (1 << 8), /* unrecovered data error */ + SERR_PERSISTENT = (1 << 9), /* persistent data/comm error */ + SERR_PROTOCOL = (1 << 10), /* protocol violation */ + SERR_INTERNAL = (1 << 11), /* host internal error */ + SERR_PHYRDY_CHG = (1 << 16), /* PHY RDY changed */ + SERR_PHY_INT_ERR = (1 << 17), /* PHY internal error */ + SERR_COMM_WAKE = (1 << 18), /* Comm wake */ + SERR_10B_8B_ERR = (1 << 19), /* 10b to 8b decode error */ + SERR_DISPARITY = (1 << 20), /* Disparity */ + SERR_CRC = (1 << 21), /* CRC error */ + SERR_HANDSHAKE = (1 << 22), /* Handshake error */ + SERR_LINK_SEQ_ERR = (1 << 23), /* Link sequence error */ + SERR_TRANS_ST_ERROR = (1 << 24), /* Transport state trans. error */ + SERR_UNRECOG_FIS = (1 << 25), /* Unrecognized FIS */ + SERR_DEV_XCHG = (1 << 26), /* device exchanged */ + + /* struct ata_taskfile flags */ + ATA_TFLAG_LBA48 = (1 << 0), /* enable 48-bit LBA and "HOB" */ + ATA_TFLAG_ISADDR = (1 << 1), /* enable r/w to nsect/lba regs */ + ATA_TFLAG_DEVICE = (1 << 2), /* enable r/w to device reg */ + ATA_TFLAG_WRITE = (1 << 3), /* data dir: host->dev==1 (write) */ + ATA_TFLAG_LBA = (1 << 4), /* enable LBA */ + ATA_TFLAG_FUA = (1 << 5), /* enable FUA */ + ATA_TFLAG_POLLING = (1 << 6), /* set nIEN to 1 and use polling */ + + /* protocol flags */ + ATA_PROT_FLAG_PIO = (1 << 0), /* is PIO */ + ATA_PROT_FLAG_DMA = (1 << 1), /* is DMA */ + ATA_PROT_FLAG_DATA = ATA_PROT_FLAG_PIO | ATA_PROT_FLAG_DMA, + ATA_PROT_FLAG_NCQ = (1 << 2), /* is NCQ */ + ATA_PROT_FLAG_ATAPI = (1 << 3), /* is ATAPI */ };
-enum ata_protocol { - ATA_PROT_UNKNOWN, /* unknown */ +enum ata_tf_protocols { + /* ATA taskfile protocols */ + ATA_PROT_UNKNOWN, /* unknown/invalid */ ATA_PROT_NODATA, /* no data */ ATA_PROT_PIO, /* PIO data xfer */ ATA_PROT_DMA, /* DMA */ ATA_PROT_NCQ, /* NCQ */ - ATA_PROT_ATAPI, /* packet command, PIO data xfer */ - ATA_PROT_ATAPI_NODATA, /* packet command, no data */ - ATA_PROT_ATAPI_DMA, /* packet command, DMA */ + ATAPI_PROT_NODATA, /* packet command, no data */ + ATAPI_PROT_PIO, /* packet command, PIO data xfer*/ + ATAPI_PROT_DMA, /* packet command with special DMA sauce */ +}; + +enum ata_ioctls { + ATA_IOC_GET_IO32 = 0x309, + ATA_IOC_SET_IO32 = 0x324, };
enum ata_dev_typed { @@ -100,73 +357,94 @@ enum ata_dev_typed { ATA_DEV_UNKNOWN, /* unknown */ };
-enum { - ATA_SECT_SIZE = 512, - ATA_MAX_SECTORS_128 = 128, - ATA_MAX_SECTORS = 256, - ATA_MAX_SECTORS_LBA48 = 65535, +struct ata_taskfile { + unsigned long flags; /* ATA_TFLAG_xxx */ + u8 protocol; /* ATA_PROT_xxx */
- /* bits in ATA command block registers */ - ATA_HOB = (1 << 7), /* LBA48 selector */ - ATA_NIEN = (1 << 1), /* disable-irq flag */ - ATA_LBA = (1 << 6), /* LBA28 selector */ - ATA_DEV1 = (1 << 4), /* Select Device 1 (slave) */ - ATA_BUSY = (1 << 7), /* BSY status bit */ - ATA_DRDY = (1 << 6), /* device ready */ - ATA_DF = (1 << 5), /* device fault */ - ATA_DRQ = (1 << 3), /* data request i/o */ - ATA_ERR = (1 << 0), /* have an error */ - ATA_SRST = (1 << 2), /* software reset */ - ATA_ICRC = (1 << 7), /* interface CRC error */ - ATA_UNC = (1 << 6), /* uncorrectable media error */ - ATA_IDNF = (1 << 4), /* ID not found */ - ATA_ABORTED = (1 << 2), /* command aborted */ + u8 ctl; /* control reg */
- ATA_ID_WORDS = 256, - ATA_ID_SERNO = 10, - ATA_ID_FW_REV = 23, - ATA_ID_PROD = 27, - ATA_ID_FIELD_VALID = 53, - ATA_ID_LBA_SECTORS = 60, - ATA_ID_MWDMA_MODES = 63, - ATA_ID_PIO_MODES = 64, - ATA_ID_QUEUE_DEPTH = 75, - ATA_ID_SATA_CAP = 76, - ATA_ID_SATA_FEATURES = 78, - ATA_ID_SATA_FEATURES_EN = 79, - ATA_ID_MAJOR_VER = 80, - ATA_ID_MINOR_VER = 81, - ATA_ID_UDMA_MODES = 88, - ATA_ID_LBA48_SECTORS = 100, + u8 hob_feature; /* additional data */ + u8 hob_nsect; /* to support LBA48 */ + u8 hob_lbal; + u8 hob_lbam; + u8 hob_lbah;
- ATA_ID_SERNO_LEN = 20, - ATA_ID_FW_REV_LEN = 8, - ATA_ID_PROD_LEN = 40, + u8 feature; + u8 nsect; + u8 lbal; + u8 lbam; + u8 lbah;
- ATA_PIO3 = (1 << 0), - ATA_PIO4 = ATA_PIO3 | (1 << 1), + u8 device;
- ATA_UDMA0 = (1 << 0), - ATA_UDMA1 = ATA_UDMA0 | (1 << 1), - ATA_UDMA2 = ATA_UDMA1 | (1 << 2), - ATA_UDMA3 = ATA_UDMA2 | (1 << 3), - ATA_UDMA4 = ATA_UDMA3 | (1 << 4), - ATA_UDMA5 = ATA_UDMA4 | (1 << 5), - ATA_UDMA6 = ATA_UDMA5 | (1 << 6), - ATA_UDMA7 = ATA_UDMA6 | (1 << 7), + u8 command; /* IO operation */ };
+/* + * protocol tests + */ +static inline unsigned int ata_prot_flags(u8 prot) +{ + switch (prot) { + case ATA_PROT_NODATA: + return 0; + case ATA_PROT_PIO: + return ATA_PROT_FLAG_PIO; + case ATA_PROT_DMA: + return ATA_PROT_FLAG_DMA; + case ATA_PROT_NCQ: + return ATA_PROT_FLAG_DMA | ATA_PROT_FLAG_NCQ; + case ATAPI_PROT_NODATA: + return ATA_PROT_FLAG_ATAPI; + case ATAPI_PROT_PIO: + return ATA_PROT_FLAG_ATAPI | ATA_PROT_FLAG_PIO; + case ATAPI_PROT_DMA: + return ATA_PROT_FLAG_ATAPI | ATA_PROT_FLAG_DMA; + } + return 0; +} + +static inline int ata_is_atapi(u8 prot) +{ + return ata_prot_flags(prot) & ATA_PROT_FLAG_ATAPI; +} + +static inline int ata_is_nodata(u8 prot) +{ + return !(ata_prot_flags(prot) & ATA_PROT_FLAG_DATA); +} + +static inline int ata_is_pio(u8 prot) +{ + return ata_prot_flags(prot) & ATA_PROT_FLAG_PIO; +} + +static inline int ata_is_dma(u8 prot) +{ + return ata_prot_flags(prot) & ATA_PROT_FLAG_DMA; +} + +static inline int ata_is_ncq(u8 prot) +{ + return ata_prot_flags(prot) & ATA_PROT_FLAG_NCQ; +} + +static inline int ata_is_data(u8 prot) +{ + return ata_prot_flags(prot) & ATA_PROT_FLAG_DATA; +} + +/* + * id tests + */ #define ata_id_is_ata(id) (((id)[0] & (1 << 15)) == 0) -#define ata_id_wcache_enabled(id) ((id)[85] & (1 << 5)) -#define ata_id_has_fua(id) ((id)[84] & (1 << 6)) -#define ata_id_has_flush(id) ((id)[83] & (1 << 12)) -#define ata_id_has_flush_ext(id) ((id)[83] & (1 << 13)) -#define ata_id_has_lba48(id) ((id)[83] & (1 << 10)) -#define ata_id_has_wcache(id) ((id)[82] & (1 << 5)) #define ata_id_has_lba(id) ((id)[49] & (1 << 9)) #define ata_id_has_dma(id) ((id)[49] & (1 << 8)) #define ata_id_has_ncq(id) ((id)[76] & (1 << 8)) #define ata_id_queue_depth(id) (((id)[75] & 0x1f) + 1) +#define ata_id_removeable(id) ((id)[0] & (1 << 7)) +#define ata_id_iordy_disable(id) ((id)[49] & (1 << 10)) +#define ata_id_has_iordy(id) ((id)[49] & (1 << 11))
#define ata_id_u32(id,n) \ (((u32) (id)[(n) + 1] << 16) | ((u32) (id)[(n)])) @@ -176,6 +454,80 @@ enum { ((u64) (id)[(n) + 1] << 16) | \ ((u64) (id)[(n) + 0]) )
+#define ata_id_cdb_intr(id) (((id)[0] & 0x60) == 0x20) + +static inline int ata_id_has_fua(const u16 *id) +{ + if ((id[84] & 0xC000) != 0x4000) + return 0; + return id[84] & (1 << 6); +} + +static inline int ata_id_has_flush(const u16 *id) +{ + if ((id[83] & 0xC000) != 0x4000) + return 0; + return id[83] & (1 << 12); +} + +static inline int ata_id_has_flush_ext(const u16 *id) +{ + if ((id[83] & 0xC000) != 0x4000) + return 0; + return id[83] & (1 << 13); +} + +static inline int ata_id_has_lba48(const u16 *id) +{ + if ((id[83] & 0xC000) != 0x4000) + return 0; + if (!ata_id_u64(id, 100)) + return 0; + return id[83] & (1 << 10); +} + +static inline int ata_id_hpa_enabled(const u16 *id) +{ + /* Yes children, word 83 valid bits cover word 82 data */ + if ((id[83] & 0xC000) != 0x4000) + return 0; + /* And 87 covers 85-87 */ + if ((id[87] & 0xC000) != 0x4000) + return 0; + /* Check command sets enabled as well as supported */ + if ((id[85] & ( 1 << 10)) == 0) + return 0; + return id[82] & (1 << 10); +} + +static inline int ata_id_has_wcache(const u16 *id) +{ + /* Yes children, word 83 valid bits cover word 82 data */ + if ((id[83] & 0xC000) != 0x4000) + return 0; + return id[82] & (1 << 5); +} + +static inline int ata_id_has_pm(const u16 *id) +{ + if ((id[83] & 0xC000) != 0x4000) + return 0; + return id[82] & (1 << 3); +} + +static inline int ata_id_rahead_enabled(const u16 *id) +{ + if ((id[87] & 0xC000) != 0x4000) + return 0; + return id[85] & (1 << 6); +} + +static inline int ata_id_wcache_enabled(const u16 *id) +{ + if ((id[87] & 0xC000) != 0x4000) + return 0; + return id[85] & (1 << 5); +}
static inline unsigned int ata_id_major_version(const u16 *id) { @@ -195,6 +547,118 @@ static inline int ata_id_is_sata(const u16 *id) return ata_id_major_version(id) >= 5 && id[93] == 0; }
+static inline int ata_id_has_tpm(const u16 *id) +{ + /* The TPM bits are only valid on ATA8 */ + if (ata_id_major_version(id) < 8) + return 0; + if ((id[48] & 0xC000) != 0x4000) + return 0; + return id[48] & (1 << 0); +} + +static inline int ata_id_has_dword_io(const u16 *id) +{ + /* ATA 8 reuses this flag for "trusted" computing */ + if (ata_id_major_version(id) > 7) + return 0; + if (id[48] & (1 << 0)) + return 1; + return 0; +} + +static inline int ata_id_current_chs_valid(const u16 *id) +{ + /* For ATA-1 devices, if the INITIALIZE DEVICE PARAMETERS command + has not been issued to the device then the values of + id[54] to id[56] are vendor specific. */ + return (id[53] & 0x01) && /* Current translation valid */ + id[54] && /* cylinders in current translation */ + id[55] && /* heads in current translation */ + id[55] <= 16 && + id[56]; /* sectors in current translation */ +} + +static inline int ata_id_is_cfa(const u16 *id) +{ + u16 v = id[0]; + if (v == 0x848A) /* Standard CF */ + return 1; + /* Could be CF hiding as standard ATA */ + if (ata_id_major_version(id) >= 3 && id[82] != 0xFFFF && + (id[82] & ( 1 << 2))) + return 1; + return 0; +} + +static inline int ata_drive_40wire(const u16 *dev_id) +{ + if (ata_id_is_sata(dev_id)) + return 0; /* SATA */ + if ((dev_id[93] & 0xE000) == 0x6000) + return 0; /* 80 wire */ + return 1; +} + +static inline int ata_drive_40wire_relaxed(const u16 *dev_id) +{ + if ((dev_id[93] & 0x2000) == 0x2000) + return 0; /* 80 wire */ + return 1; +} + +static inline int atapi_cdb_len(const u16 *dev_id) +{ + u16 tmp = dev_id[0] & 0x3; + switch (tmp) { + case 0: return 12; + case 1: return 16; + default: return -1; + } +} + +static inline int atapi_command_packet_set(const u16 *dev_id) +{ + return (dev_id[0] >> 8) & 0x1f; +} + +static inline int atapi_id_dmadir(const u16 *dev_id) +{ + return ata_id_major_version(dev_id) >= 7 && (dev_id[62] & 0x8000); +} + +static inline int is_multi_taskfile(struct ata_taskfile *tf) +{ + return (tf->command == ATA_CMD_READ_MULTI) || + (tf->command == ATA_CMD_WRITE_MULTI) || + (tf->command == ATA_CMD_READ_MULTI_EXT) || + (tf->command == ATA_CMD_WRITE_MULTI_EXT) || + (tf->command == ATA_CMD_WRITE_MULTI_FUA_EXT); +} + +static inline int ata_ok(u8 status) +{ + return ((status & (ATA_BUSY | ATA_DRDY | ATA_DF | ATA_DRQ | ATA_ERR)) + == ATA_DRDY); +} + +static inline int lba_28_ok(u64 block, u32 n_block) +{ + /* check the ending block number */ + return ((block + n_block - 1) < ((u64)1 << 28)) && (n_block <= 256); +} + +static inline int lba_48_ok(u64 block, u32 n_block) +{ + /* check the ending block number */ + return ((block + n_block - 1) < ((u64)1 << 48)) && (n_block <= 65536); +} + +#define sata_pmp_gscr_vendor(gscr) ((gscr)[SATA_PMP_GSCR_PROD_ID] & 0xffff) +#define sata_pmp_gscr_devid(gscr) ((gscr)[SATA_PMP_GSCR_PROD_ID] >> 16) +#define sata_pmp_gscr_rev(gscr) (((gscr)[SATA_PMP_GSCR_REV] >> 8) & 0xff) +#define sata_pmp_gscr_ports(gscr) ((gscr)[SATA_PMP_GSCR_PORT_INFO] & 0xf) + u64 ata_id_n_sectors(u16 *id); u32 ata_dev_classify(u32 sig); void ata_id_c_string(const u16 *id, unsigned char *s,
Applied, thanks.
Dave Liu
