[U-Boot] [PATCH v2 3/7] LCD: add data structure for EXYNOS display driver
Add vidinfo data structure for EXYNOS display driver
Signed-off-by: Donghwa Lee dh09.lee@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Inki Dae inki.dae@samsung.com --- include/lcd.h | 64 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 64 insertions(+), 0 deletions(-)
diff --git a/include/lcd.h b/include/lcd.h index d95feeb..3d9ef16 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -183,6 +183,70 @@ typedef struct vidinfo { u_long mmio; /* Memory mapped registers */ } vidinfo_t;
+#elif defined(CONFIG_EXYNOS_FB) + +enum { + FIMD_RGB_INTERFACE = 1, + FIMD_CPU_INTERFACE = 2, +}; + +typedef struct vidinfo { + ushort vl_col; /* Number of columns (i.e. 640) */ + ushort vl_row; /* Number of rows (i.e. 480) */ + ushort vl_width; /* Width of display area in millimeters */ + ushort vl_height; /* Height of display area in millimeters */ + + /* LCD configuration register */ + u_char vl_freq; /* Frequency */ + u_char vl_clkp; /* Clock polarity */ + u_char vl_oep; /* Output Enable polarity */ + u_char vl_hsp; /* Horizontal Sync polarity */ + u_char vl_vsp; /* Vertical Sync polarity */ + u_char vl_dp; /* Data polarity */ + u_char vl_bpix; /* Bits per pixel */ + + /* Horizontal control register. Timing from data sheet */ + u_char vl_hspw; /* Horz sync pulse width */ + u_char vl_hfpd; /* Wait before of line */ + u_char vl_hbpd; /* Wait end of line */ + + /* Vertical control register. */ + u_char vl_vspw; /* Vertical sync pulse width */ + u_char vl_vfpd; /* Wait before of frame */ + u_char vl_vbpd; /* Wait end of frame */ + u_char vl_cmd_allow_len; /* Wait end of frame */ + + void (*cfg_gpio)(void); + void (*backlight_on)(unsigned int onoff); + void (*reset_lcd)(void); + void (*lcd_power_on)(void); + void (*cfg_ldo)(void); + void (*enable_ldo)(unsigned int onoff); + void (*mipi_power)(void); + void (*backlight_reset)(void); + + unsigned int win_id; + unsigned int init_delay; + unsigned int power_on_delay; + unsigned int reset_delay; + unsigned int interface_mode; + unsigned int mipi_enabled; + unsigned int cs_setup; + unsigned int wr_setup; + unsigned int wr_act; + unsigned int wr_hold; + + /* parent clock name(MPLL, EPLL or VPLL) */ + unsigned int pclk_name; + /* ratio value for source clock from parent clock. */ + unsigned int sclk_div; + + unsigned int dual_lcd_enabled; + +} vidinfo_t; + +void init_panel_info(vidinfo_t *vid); + #else
Acked-by: Anatolij Gustschin agust@denx.de
Thanks, Anatolij
Anatolij Gustschin
Donghwa Lee
