[U-Boot] [PATCH v4 1/1] imx: Get fec mac address from fuse
The patch is to support getting FEC MAC address from fuse bank.
Signed-off-by: Jason Liu r64343@freescale.com
--- Changes for v2: - correct the mac address byte order according to review comments - add memset(edev, 0. sizeof(*edev)) when do fec_probe, - fix some code comments Changes for v3: - rebase - address the comments of Stefano, make the imx_get_mac_from_fuse(), declared independently inside each imx-regs.h to make it specific for each processor, because it accesses to different structures. - address the comments of Wolfgang and Stefano, use struct to access mac_addr fuse. Changes for v4: - Address the comments of Wolfgang, use fuse_regs instead of bank addres and change from fuse1_6 to fuse0_5 naming convention and use fuse_bank0_regs instead of fuse_bank0 to kill misleading. --- arch/arm/cpu/arm926ejs/mx25/generic.c | 12 ++++++++++ arch/arm/cpu/arm926ejs/mx27/generic.c | 12 ++++++++++ arch/arm/cpu/armv7/mx5/soc.c | 14 ++++++++++++ arch/arm/include/asm/arch-mx25/imx-regs.h | 19 +++++++++------ arch/arm/include/asm/arch-mx27/imx-regs.h | 18 ++++++++++----- arch/arm/include/asm/arch-mx5/imx-regs.h | 34 +++++++++++++++++++++++++++++ drivers/net/fec_mxc.c | 15 +------------ 7 files changed, 96 insertions(+), 28 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index b80a389..4ac7bbb 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -260,4 +260,16 @@ void mx25_fec_init_pins (void) writel (outpadctl, &padctl->pad_fec_tdata1);
} + +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[i] = readl(&fuse->mac_addr[i]); +} #endif /* CONFIG_FEC_MXC */ diff --git a/arch/arm/cpu/arm926ejs/mx27/generic.c b/arch/arm/cpu/arm926ejs/mx27/generic.c index ae2ce58..ceaac48 100644 --- a/arch/arm/cpu/arm926ejs/mx27/generic.c +++ b/arch/arm/cpu/arm926ejs/mx27/generic.c @@ -313,6 +313,18 @@ void mx27_fec_init_pins(void) for (i = 0; i < ARRAY_SIZE(mode); i++) imx_gpio_mode(mode[i]); } + +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[6-1-i] = readl(&fuse->mac_addr[i]); +} #endif /* CONFIG_FEC_MXC */
#ifdef CONFIG_MXC_MMC diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 7c7a565..c22d6dc 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -100,6 +100,20 @@ int cpu_eth_init(bd_t *bis) return rc; }
+#if defined(CONFIG_FEC_MXC) +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[i] = readl(&fuse->mac_addr[i]); +} +#endif + /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index f5a2929..55ad115 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -36,6 +36,7 @@ #ifndef __ASSEMBLY__ #ifdef CONFIG_FEC_MXC extern void mx25_fec_init_pins(void); +extern void imx_get_mac_from_fuse(unsigned char *mac); #endif
/* Clock Control Module (CCM) registers */ @@ -129,12 +130,17 @@ struct iim_regs { u32 iim_srev; u32 iim_prog_p; u32 res1[0x1f5]; - u32 iim_bank_area0[0x20]; - u32 res2[0xe0]; - u32 iim_bank_area1[0x20]; - u32 res3[0xe0]; - u32 iim_bank_area2[0x20]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[3]; }; + +struct fuse_bank0_regs { + u32 fuse0_25[0x1a]; + u32 mac_addr[6]; +}; + #endif
/* AIPS 1 */ @@ -312,7 +318,4 @@ struct iim_regs { #define WSR_UNLOCK1 0x5555 #define WSR_UNLOCK2 0xAAAA
-/* FUSE bank offsets */ -#define IIM0_MAC 0x1a - #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx27/imx-regs.h b/arch/arm/include/asm/arch-mx27/imx-regs.h index 6ecddaa..3095839 100644 --- a/arch/arm/include/asm/arch-mx27/imx-regs.h +++ b/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -34,6 +34,7 @@ extern void mx27_uart_init_pins(void);
#ifdef CONFIG_FEC_MXC extern void mx27_fec_init_pins(void); +extern void imx_get_mac_from_fuse(unsigned char *mac); #endif /* CONFIG_FEC_MXC */
#ifdef CONFIG_MXC_MMC @@ -203,8 +204,18 @@ struct iim_regs { u32 iim_scs2; u32 iim_scs3; u32 res[0x1F0]; - u32 iim_bank_area0[0x100]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[1]; }; + +struct fuse_bank0_regs { + u32 fuse0_3[4]; + u32 mac_addr[6]; + u32 fuse10_31[0x16]; +}; + #endif
#define IMX_IO_BASE 0x10000000 @@ -512,9 +523,4 @@ struct iim_regs { #define IIM_ERR_SNSE (1 << 2) #define IIM_ERR_PARITYE (1 << 1)
-/* Definitions for i.MX27 TO2 */ -#define IIM0_MAC 5 -#define IIM0_SCC_KEY 11 -#define IIM1_SUID 1 - #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 0b6249a..934a20e 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -205,9 +205,13 @@ #define BOARD_REV_1_0 0x0 #define BOARD_REV_2_0 0x1
+#define IMX_IIM_BASE (IIM_BASE_ADDR) + #if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) #include <asm/types.h>
+extern void imx_get_mac_from_fuse(unsigned char *mac); + #define __REG(x) (*((volatile u32 *)(x))) #define __REG16(x) (*((volatile u16 *)(x))) #define __REG8(x) (*((volatile u8 *)(x))) @@ -275,6 +279,36 @@ struct src { u32 sisr; u32 simr; }; + +struct iim_regs { + u32 stat; + u32 statm; + u32 err; + u32 emask; + u32 fctl; + u32 ua; + u32 la; + u32 sdat; + u32 prev; + u32 srev; + u32 preg_p; + u32 scs0; + u32 scs1; + u32 scs2; + u32 scs3; + u32 res0[0x1f1]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[4]; +}; + +struct fuse_bank1_regs { + u32 fuse0_8[9]; + u32 mac_addr[6]; + u32 fuse5_31[0x11]; +}; + #endif /* __ASSEMBLER__*/
#endif /* __ASM_ARCH_MXC_MX51_H__ */ diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index c17f937..0013ab4 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -312,21 +312,8 @@ static void fec_rbd_clean(int last, struct fec_bd *pRbd)
static int fec_get_hwaddr(struct eth_device *dev, unsigned char *mac) { -/* - * The MX27 can store the mac address in internal eeprom - * This mechanism is not supported now by MX51 or MX25 - */ -#if defined(CONFIG_MX51) || defined(CONFIG_MX25) - return -1; -#else - struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; - int i; - - for (i = 0; i < 6; i++) - mac[6-1-i] = readl(&iim->iim_bank_area0[IIM0_MAC + i]); - + imx_get_mac_from_fuse(mac); return !is_valid_ether_addr(mac); -#endif }
static int fec_set_hwaddr(struct eth_device *dev)
Dear Jason Liu,
- u32 fuse0_8[9];
- u32 mac_addr[6];
- u32 fuse5_31[0x11];
This looks wrong to me. It's 0...8, 9...14, 15...31 o the last field's name should be fuse15_31 ?
2010/11/18 Wolfgang Denk wd@denx.de:
Dear Jason Liu,
- u32 fuse0_8[9];
- u32 mac_addr[6];
Sorry, typo error, it should be fuse15_31[0x11]; Thanks for your good review.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Nearly everyone is in favor of going to heaven but too many are hoping they'll live long enough to see an easing of the entrance requirements. Never appeal to a man's "better nature." he might not have one. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Jason Liu
Jason Liu
