[PATCH v3 0/7] phy: generic: add error trace to detect PHY issue in uclass
it is a V3 serie for [1].
After rebase 2 patches are no more needed: [v2,2/8] usb: gadget: dwc2: change trace level for phy errors managed by uclass [v2,6/8] usb: dwc3: change trace level for phy errors managed by uclass
And I add a patch in this V3 serie: [PATCH v3 7/7] arm: meson: change trace level for phy errors managed
Regards,
Patrick
[1] [v2,1/8] phy: generic: add error trace to detect PHY issue in uclass http://patchwork.ozlabs.org/project/uboot/list/?series=159187&state=*
Changes in v3: - rebase on next branch - removed added dm/device_compat.h include after rebase - simplify test on ops presence after Marek review - add update for mach-meson board-gx: new generic_phy API usage
Changes in v2: - Rebase and add include dm/device_compat.h - Added patch after rebase: new generic_phy API usage
Patrick Delaunay (7): phy: generic: add error trace to detect PHY issue in uclass board: sunxi: change trace level for phy errors managed by uclass usb: host: ohci: change trace level for phy errors managed by uclass usb: host: ehci-hcd: change trace level for phy errors managed by uclass ata: dwc-ahci: change trace level for phy errors managed by uclass usb: musb-new: sunxi: change trace level for phy errors managed by uclass arm: meson: change trace level for phy errors managed by uclass
arch/arm/mach-meson/board-gx.c | 8 +++--- board/sunxi/board.c | 2 +- drivers/ata/dwc_ahci.c | 4 +-- drivers/phy/phy-uclass.c | 45 +++++++++++++++++++++++++++++---- drivers/usb/host/ehci-hcd.c | 8 +++--- drivers/usb/host/ohci-generic.c | 8 +++--- drivers/usb/musb-new/sunxi.c | 8 +++--- 7 files changed, 59 insertions(+), 24 deletions(-)
Add an error trace for PHY errors directly in generic phy functions provided by PHY uclass.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
This patch is requested by Marek Vasut to avoid code duplication in usb host serie for dwc2:
See http://patchwork.ozlabs.org/patch/1176048/#2297595 [U-Boot,RESEND,1/5] usb: host: dwc2: add phy support
drivers/phy/phy-uclass.c | 45 +++++++++++++++++++++++++++++++++++----- 1 file changed, 40 insertions(+), 5 deletions(-)
diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index db7f39cd0b..8f456f33d2 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -117,56 +117,91 @@ int generic_phy_get_by_name(struct udevice *dev, const char *phy_name, int generic_phy_init(struct phy *phy) { struct phy_ops const *ops; + int ret;
if (!generic_phy_valid(phy)) return 0; ops = phy_dev_ops(phy->dev); + if (!ops->init) + return 0; + ret = ops->init(phy); + if (ret) + dev_err(phy->dev, "PHY: Failed to init %s: %d.\n", + phy->dev->name, ret);
- return ops->init ? ops->init(phy) : 0; + return ret; }
int generic_phy_reset(struct phy *phy) { struct phy_ops const *ops; + int ret;
if (!generic_phy_valid(phy)) return 0; ops = phy_dev_ops(phy->dev); + if (!ops->reset) + return 0; + ret = ops->reset(phy); + if (ret) + dev_err(phy->dev, "PHY: Failed to reset %s: %d.\n", + phy->dev->name, ret);
- return ops->reset ? ops->reset(phy) : 0; + return ret; }
int generic_phy_exit(struct phy *phy) { struct phy_ops const *ops; + int ret;
if (!generic_phy_valid(phy)) return 0; ops = phy_dev_ops(phy->dev); + if (!ops->exit) + return 0; + ret = ops->exit(phy); + if (ret) + dev_err(phy->dev, "PHY: Failed to exit %s: %d.\n", + phy->dev->name, ret);
- return ops->exit ? ops->exit(phy) : 0; + return ret; }
int generic_phy_power_on(struct phy *phy) { struct phy_ops const *ops; + int ret;
if (!generic_phy_valid(phy)) return 0; ops = phy_dev_ops(phy->dev); + if (!ops->power_on) + return 0; + ret = ops->power_on(phy); + if (ret) + dev_err(phy->dev, "PHY: Failed to power on %s: %d.\n", + phy->dev->name, ret);
- return ops->power_on ? ops->power_on(phy) : 0; + return ret; }
int generic_phy_power_off(struct phy *phy) { struct phy_ops const *ops; + int ret;
if (!generic_phy_valid(phy)) return 0; ops = phy_dev_ops(phy->dev); + if (!ops->power_off) + return 0; + ret = ops->power_off(phy); + if (ret) + dev_err(phy->dev, "PHY: Failed to power off %s: %d.\n", + phy->dev->name, ret);
- return ops->power_off ? ops->power_off(phy) : 0; + return ret; }
int generic_phy_get_bulk(struct udevice *dev, struct phy_bulk *bulk)
As the error message is now displayed by generic phy functions, the pr_err can be change to pr_idebug.
(no changes since v1)
board/sunxi/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index f32e8f582f..f1925f032d 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -711,7 +711,7 @@ int g_dnl_board_usb_cable_connected(void)
ret = generic_phy_init(&phy); if (ret) { - pr_err("failed to init %s USB PHY\n", dev->name); + pr_debug("failed to init %s USB PHY\n", dev->name); return ret; }
As the error message is now displayed by generic phy functions, the dev_err can be change to dev_dbg.
drivers/usb/host/ohci-generic.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index 631711a9e8..f1e5b4e769 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -41,13 +41,13 @@ static int ohci_setup_phy(struct udevice *dev, int index) } else { ret = generic_phy_init(&priv->phy); if (ret) { - dev_err(dev, "failed to init usb phy\n"); + dev_dbg(dev, "failed to init usb phy\n"); return ret; }
ret = generic_phy_power_on(&priv->phy); if (ret) { - dev_err(dev, "failed to power on usb phy\n"); + dev_dbg(dev, "failed to power on usb phy\n"); return generic_phy_exit(&priv->phy); } } @@ -63,13 +63,13 @@ static int ohci_shutdown_phy(struct udevice *dev) if (generic_phy_valid(&priv->phy)) { ret = generic_phy_power_off(&priv->phy); if (ret) { - dev_err(dev, "failed to power off usb phy\n"); + dev_dbg(dev, "failed to power off usb phy\n"); return ret; }
ret = generic_phy_exit(&priv->phy); if (ret) { - dev_err(dev, "failed to power off usb phy\n"); + dev_dbg(dev, "failed to power off usb phy\n"); return ret; } }
As the error message is now displayed by generic phy functions, the pr_err can be change to pr_debug.
drivers/usb/host/ehci-hcd.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index f79f06320b..8933f60843 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -1762,13 +1762,13 @@ int ehci_setup_phy(struct udevice *dev, struct phy *phy, int index) } else { ret = generic_phy_init(phy); if (ret) { - dev_err(dev, "failed to init usb phy\n"); + dev_dbg(dev, "failed to init usb phy\n"); return ret; }
ret = generic_phy_power_on(phy); if (ret) { - dev_err(dev, "failed to power on usb phy\n"); + dev_dbg(dev, "failed to power on usb phy\n"); return generic_phy_exit(phy); } } @@ -1786,13 +1786,13 @@ int ehci_shutdown_phy(struct udevice *dev, struct phy *phy) if (generic_phy_valid(phy)) { ret = generic_phy_power_off(phy); if (ret) { - dev_err(dev, "failed to power off usb phy\n"); + dev_dbg(dev, "failed to power off usb phy\n"); return ret; }
ret = generic_phy_exit(phy); if (ret) { - dev_err(dev, "failed to power off usb phy\n"); + dev_dbg(dev, "failed to power off usb phy\n"); return ret; } }
drivers/ata/dwc_ahci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/ata/dwc_ahci.c b/drivers/ata/dwc_ahci.c index 017650ae46..3c2a3ac201 100644 --- a/drivers/ata/dwc_ahci.c +++ b/drivers/ata/dwc_ahci.c @@ -62,13 +62,13 @@ static int dwc_ahci_probe(struct udevice *dev)
ret = generic_phy_init(&phy); if (ret) { - pr_err("unable to initialize the sata phy\n"); + pr_debug("unable to initialize the sata phy\n"); return ret; }
ret = generic_phy_power_on(&phy); if (ret) { - pr_err("unable to power on the sata phy\n"); + pr_debug("unable to power on the sata phy\n"); return ret; }
As the error message is now displayed by generic phy functions, the dev_err/pr_err can be change to dev_dbg/pr_debug.
(no changes since v2)
Changes in v2: - Added patch after rebase: new generic_phy API usage
drivers/usb/musb-new/sunxi.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 53c336fc3f..06a55bf6ee 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -257,7 +257,7 @@ static int sunxi_musb_enable(struct musb *musb)
ret = generic_phy_power_on(&glue->phy); if (ret) { - pr_err("failed to power on USB PHY\n"); + pr_debug("failed to power on USB PHY\n"); return ret; } } @@ -281,7 +281,7 @@ static void sunxi_musb_disable(struct musb *musb) if (is_host_enabled(musb)) { ret = generic_phy_power_off(&glue->phy); if (ret) { - pr_err("failed to power off USB PHY\n"); + pr_debug("failed to power off USB PHY\n"); return; } } @@ -315,7 +315,7 @@ static int sunxi_musb_init(struct musb *musb)
ret = generic_phy_init(&glue->phy); if (ret) { - dev_err(dev, "failed to init USB PHY\n"); + dev_dbg(dev, "failed to init USB PHY\n"); goto err_rst; }
@@ -352,7 +352,7 @@ static int sunxi_musb_exit(struct musb *musb) if (generic_phy_valid(&glue->phy)) { ret = generic_phy_exit(&glue->phy); if (ret) { - dev_err(dev, "failed to power off usb phy\n"); + dev_dbg(dev, "failed to power off usb phy\n"); return ret; } }
Changes in v3: - add update for mach-meson board-gx: new generic_phy API usage
arch/arm/mach-meson/board-gx.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index c4cc11f1de..b4fde46fcb 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -196,8 +196,8 @@ int board_usb_init(int index, enum usb_init_type init) for (i = 0; i < 2; i++) { ret = generic_phy_init(&usb_phys[i]); if (ret) { - pr_err("Can't init USB PHY%d for %s\n", - i, ofnode_get_name(dwc2_node)); + pr_debug("Can't init USB PHY%d for %s\n", + i, ofnode_get_name(dwc2_node)); return ret; } } @@ -205,8 +205,8 @@ int board_usb_init(int index, enum usb_init_type init) for (i = 0; i < 2; i++) { ret = generic_phy_power_on(&usb_phys[i]); if (ret) { - pr_err("Can't power USB PHY%d for %s\n", - i, ofnode_get_name(dwc2_node)); + pr_debug("Can't power USB PHY%d for %s\n", + i, ofnode_get_name(dwc2_node)); return ret; } }
Changes in v3:
} }i, ofnode_get_name(dwc2_node)); return ret;
Acked-by: Neil Armstrong narmstrong@baylibre.com
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Acked-by: Neil Armstrong narmstrong@baylibre.com
Neil Armstrong
Patrick Delaunay
