[U-Boot] [PATCH 4/4] UBI/UBIFS: Automatically unmount UBIFS volume upon UBI partition change
Automatically unmount UBIFS partition when user changes the UBI device. Otherwise the following UBIFS commands will crash.
Signed-off-by: Stefan Roese sr@denx.de --- This patch replaces the patch [UBI/UBIFS: Prevent UBI partition change while UBIFS is mounted].
common/cmd_ubi.c | 11 +++++++++++ common/cmd_ubifs.c | 26 ++++++++++++++++++++------ 2 files changed, 31 insertions(+), 6 deletions(-)
diff --git a/common/cmd_ubi.c b/common/cmd_ubi.c index 7692ac7..0ec87e2 100644 --- a/common/cmd_ubi.c +++ b/common/cmd_ubi.c @@ -42,6 +42,9 @@ struct selected_dev {
static struct selected_dev ubi_dev;
+int ubifs_is_mounted(void); +void cmd_ubifs_umount(void); + static void ubi_dump_vol_info(const struct ubi_volume *vol) { ubi_msg("volume information dump:"); @@ -472,6 +475,14 @@ static int do_ubi(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) if (argc < 3) return cmd_usage(cmdtp);
+ /* + * Automatically unmount UBIFS partition when user + * changes the UBI device. Otherwise the following + * UBIFS commands will crash. + */ + if (ubifs_is_mounted()) + cmd_ubifs_umount(); + /* todo: get dev number for NAND... */ ubi_dev.nr = 0;
diff --git a/common/cmd_ubifs.c b/common/cmd_ubifs.c index 9526780..3cd2d8f 100644 --- a/common/cmd_ubifs.c +++ b/common/cmd_ubifs.c @@ -72,6 +72,25 @@ int do_ubifs_mount(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+int ubifs_is_mounted(void) +{ + return ubifs_mounted; +} + +void cmd_ubifs_umount(void) +{ + + if (ubifs_sb) { + printf("Unmounting UBIFS volume %s!\n", + ((struct ubifs_info *)(ubifs_sb->s_fs_info))->vi.name); + ubifs_umount(ubifs_sb->s_fs_info); + } + + ubifs_sb = NULL; + ubifs_mounted = 0; + ubifs_initialized = 0; +} + int do_ubifs_umount(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { if (argc != 1) @@ -82,12 +101,7 @@ int do_ubifs_umount(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return -1; }
- if (ubifs_sb) - ubifs_umount(ubifs_sb->s_fs_info); - - ubifs_sb = NULL; - ubifs_mounted = 0; - ubifs_initialized = 0; + cmd_ubifs_umount();
return 0; }
Applied to u-boot-ubi/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
