[U-Boot] [PATCH v3 3/7] arm: omap-common: adds secure image name common to, OMAP and keystone
As K2 can directly boot u-boot, add u-boot_HS_MLO as the secure image while booting secure K2 devicesr, for all boot modes other than SPI flash.
Signed-off-by: Madan Srinivas madans@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Changes in v3: None Changes in v2: - Adds a new name for the signed output image in config_secure.mk to keep it in line with the image name used by non-secure keystone devices.
arch/arm/cpu/armv7/omap-common/config_secure.mk | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/config_secure.mk b/arch/arm/cpu/armv7/omap-common/config_secure.mk index 1122439..0ece3f8 100644 --- a/arch/arm/cpu/armv7/omap-common/config_secure.mk +++ b/arch/arm/cpu/armv7/omap-common/config_secure.mk @@ -76,6 +76,12 @@ u-boot-spl_HS_ISSW: $(obj)/u-boot-spl.bin u-boot-spl_HS_SPI_X-LOADER: $(obj)/u-boot-spl.bin $(call if_changed,mkomapsecimg)
+# For supporting single stage boot on keystone, the image is a full u-boot +# file, not an SPL. This will work for all boot devices, other than SPI +# flash +u-boot_HS_MLO: $(obj)/u-boot.bin + $(call if_changed,mkomapsecimg) + # For supporting single stage XiP QSPI on AM43xx, the image is a full u-boot # file, not an SPL. In this case the mkomapsecimg command looks for a # u-boot-HS_* prefix
Srinivas, Madan
