[U-Boot] [PATCH] MIPS: remove Micronas VCT boards
The deadline for migration to CONFIG_DM is v2020.01. The VCT baords would need an almost complete rewrite of all drivers to support driver model.
Unless someone has access to the hardware and volunteers to do the migration, the board should be scheduled for removal.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
board/micronas/vct/Kconfig | 52 -- board/micronas/vct/MAINTAINERS | 17 - board/micronas/vct/Makefile | 12 - board/micronas/vct/bcu.h | 156 ----- board/micronas/vct/dcgu.c | 244 ------- board/micronas/vct/dcgu.h | 165 ----- board/micronas/vct/ebi.c | 34 - board/micronas/vct/ebi.h | 81 --- board/micronas/vct/ebi_nor_flash.c | 117 ---- board/micronas/vct/ebi_onenand.c | 185 ----- board/micronas/vct/ebi_smc911x.c | 94 --- board/micronas/vct/ehci.c | 96 --- board/micronas/vct/gpio.c | 74 -- board/micronas/vct/scc.c | 657 ------------------ board/micronas/vct/scc.h | 191 ----- board/micronas/vct/smc_eeprom.c | 394 ----------- board/micronas/vct/top.c | 275 -------- board/micronas/vct/vct.c | 119 ---- board/micronas/vct/vct.h | 92 --- board/micronas/vct/vcth/reg_dcgu.h | 22 - board/micronas/vct/vcth/reg_ebi.h | 228 ------ board/micronas/vct/vcth/reg_fwsram.h | 59 -- board/micronas/vct/vcth/reg_gpio.h | 18 - board/micronas/vct/vcth/reg_scc.h | 88 --- board/micronas/vct/vcth/reg_usbh.h | 19 - board/micronas/vct/vcth/reg_wdt.h | 10 - board/micronas/vct/vcth2/reg_ebi.h | 276 -------- board/micronas/vct/vctv/reg_dcgu.h | 11 - board/micronas/vct/vctv/reg_ebi.h | 276 -------- board/micronas/vct/vctv/reg_gpio.h | 18 - board/micronas/vct/vctv/reg_wdt.h | 10 - configs/vct_platinum_defconfig | 27 - configs/vct_platinum_onenand_defconfig | 33 - configs/vct_platinum_onenand_small_defconfig | 33 - configs/vct_platinum_small_defconfig | 27 - configs/vct_platinumavc_defconfig | 19 - configs/vct_platinumavc_onenand_defconfig | 25 - .../vct_platinumavc_onenand_small_defconfig | 33 - configs/vct_platinumavc_small_defconfig | 27 - configs/vct_premium_defconfig | 27 - configs/vct_premium_onenand_defconfig | 33 - configs/vct_premium_onenand_small_defconfig | 33 - configs/vct_premium_small_defconfig | 27 - include/configs/vct.h | 202 ------ 44 files changed, 4636 deletions(-) delete mode 100644 board/micronas/vct/Kconfig delete mode 100644 board/micronas/vct/MAINTAINERS delete mode 100644 board/micronas/vct/Makefile delete mode 100644 board/micronas/vct/bcu.h delete mode 100644 board/micronas/vct/dcgu.c delete mode 100644 board/micronas/vct/dcgu.h delete mode 100644 board/micronas/vct/ebi.c delete mode 100644 board/micronas/vct/ebi.h delete mode 100644 board/micronas/vct/ebi_nor_flash.c delete mode 100644 board/micronas/vct/ebi_onenand.c delete mode 100644 board/micronas/vct/ebi_smc911x.c delete mode 100644 board/micronas/vct/ehci.c delete mode 100644 board/micronas/vct/gpio.c delete mode 100644 board/micronas/vct/scc.c delete mode 100644 board/micronas/vct/scc.h delete mode 100644 board/micronas/vct/smc_eeprom.c delete mode 100644 board/micronas/vct/top.c delete mode 100644 board/micronas/vct/vct.c delete mode 100644 board/micronas/vct/vct.h delete mode 100644 board/micronas/vct/vcth/reg_dcgu.h delete mode 100644 board/micronas/vct/vcth/reg_ebi.h delete mode 100644 board/micronas/vct/vcth/reg_fwsram.h delete mode 100644 board/micronas/vct/vcth/reg_gpio.h delete mode 100644 board/micronas/vct/vcth/reg_scc.h delete mode 100644 board/micronas/vct/vcth/reg_usbh.h delete mode 100644 board/micronas/vct/vcth/reg_wdt.h delete mode 100644 board/micronas/vct/vcth2/reg_ebi.h delete mode 100644 board/micronas/vct/vctv/reg_dcgu.h delete mode 100644 board/micronas/vct/vctv/reg_ebi.h delete mode 100644 board/micronas/vct/vctv/reg_gpio.h delete mode 100644 board/micronas/vct/vctv/reg_wdt.h delete mode 100644 configs/vct_platinum_defconfig delete mode 100644 configs/vct_platinum_onenand_defconfig delete mode 100644 configs/vct_platinum_onenand_small_defconfig delete mode 100644 configs/vct_platinum_small_defconfig delete mode 100644 configs/vct_platinumavc_defconfig delete mode 100644 configs/vct_platinumavc_onenand_defconfig delete mode 100644 configs/vct_platinumavc_onenand_small_defconfig delete mode 100644 configs/vct_platinumavc_small_defconfig delete mode 100644 configs/vct_premium_defconfig delete mode 100644 configs/vct_premium_onenand_defconfig delete mode 100644 configs/vct_premium_onenand_small_defconfig delete mode 100644 configs/vct_premium_small_defconfig delete mode 100644 include/configs/vct.h
diff --git a/board/micronas/vct/Kconfig b/board/micronas/vct/Kconfig deleted file mode 100644 index df7c0296c7..0000000000 --- a/board/micronas/vct/Kconfig +++ /dev/null @@ -1,52 +0,0 @@ -if TARGET_VCT - -config SYS_BOARD - default "vct" - -config SYS_VENDOR - default "micronas" - -config SYS_CONFIG_NAME - default "vct" - -config SYS_TEXT_BASE - default 0x87000000 - -config SYS_DCACHE_SIZE - default 16384 - -config SYS_DCACHE_LINE_SIZE - default 32 - -config SYS_ICACHE_SIZE - default 16384 - -config SYS_ICACHE_LINE_SIZE - default 32 - -menu "vct board options" - -choice - prompt "Board variant" - optional - -config VCT_PLATINUM - bool "Enable VCT_PLATINUM" - -config VCT_PLATINUMAVC - bool "Enable VCT_PLATINUMAVC" - -config VCT_PREMIUM - bool "Enable VCT_PLATINUMAVC" - -endchoice - -config VCT_ONENAND - bool "Enable VCT_ONENAND" - -config VCT_SMALL_IMAGE - bool "Enable VCT_SMALL_IMAGE" - -endmenu - -endif diff --git a/board/micronas/vct/MAINTAINERS b/board/micronas/vct/MAINTAINERS deleted file mode 100644 index cbaa585134..0000000000 --- a/board/micronas/vct/MAINTAINERS +++ /dev/null @@ -1,17 +0,0 @@ -VCT BOARD -#M: - -S: Maintained -F: board/micronas/vct/ -F: include/configs/vct.h -F: configs/vct_platinum_defconfig -F: configs/vct_platinum_onenand_defconfig -F: configs/vct_platinum_onenand_small_defconfig -F: configs/vct_platinum_small_defconfig -F: configs/vct_platinumavc_defconfig -F: configs/vct_platinumavc_onenand_defconfig -F: configs/vct_platinumavc_onenand_small_defconfig -F: configs/vct_platinumavc_small_defconfig -F: configs/vct_premium_defconfig -F: configs/vct_premium_onenand_defconfig -F: configs/vct_premium_onenand_small_defconfig -F: configs/vct_premium_small_defconfig diff --git a/board/micronas/vct/Makefile b/board/micronas/vct/Makefile deleted file mode 100644 index d82c28d224..0000000000 --- a/board/micronas/vct/Makefile +++ /dev/null @@ -1,12 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - -obj-y := vct.o -obj-y += ebi.o -obj-$(CONFIG_VCT_NOR) += ebi_nor_flash.o -obj-$(CONFIG_VCT_ONENAND) += ebi_onenand.o -obj-$(CONFIG_DRIVER_SMC911X) += ebi_smc911x.o smc_eeprom.o -obj-y += gpio.o -obj-y += top.o -obj-$(CONFIG_USB_EHCI_VCT) += dcgu.o ehci.o scc.o diff --git a/board/micronas/vct/bcu.h b/board/micronas/vct/bcu.h deleted file mode 100644 index f52833ab92..0000000000 --- a/board/micronas/vct/bcu.h +++ /dev/null @@ -1,156 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _BCU_H -#define _BCU_H - -enum bcu_tags { - BCU_VBV1 = 0, - BCU_VBV2 = 1, - BCU_BSS1 = 2, - BCU_BSS2 = 3, - BCU_TSD_TXT = 4, - BCU_TSD_SUBTITLES = 5, - BCU_TSD_PES_0 = 6, - BCU_TSD_PES_1 = 7, - BCU_TSD_PES_2 = 8, - BCU_TSD_PES_3 = 9, - BCU_TSIO_RECORD_0 = 10, - BCU_TSIO_RECORD_1 = 11, - BCU_TSIO_PLAYBACK_0 = 12, - BCU_TSIO_PLAYBACK_1 = 13, - BCU_SECURE_BUFFER = 14, - BCU_PCM1 = 15, - BCU_PCM2 = 16, - BCU_BSS_COPY = 17, - BCU_BSS_EXT1 = 18, - BCU_BSS_EXT2 = 19, - BCU_PCM_JINGLE = 20, - BCU_EBI_CPU_BUFFER = 21, - BCU_PCM_DELAY = 22, - BCU_FH_BUFFER_0 = 23, - BCU_FH_BUFFER_1 = 24, - BCU_TSD_SECTION_0 = 25, - BCU_TSD_SECTION_1 = 26, - BCU_TSD_SECTION_2 = 27, - BCU_TSD_SECTION_3 = 28, - BCU_TSD_SECTION_4 = 29, - BCU_TSD_SECTION_5 = 30, - BCU_TSD_SECTION_6 = 31, - BCU_TSD_SECTION_7 = 32, - BCU_TSD_SECTION_8 = 33, - BCU_TSD_SECTION_9 = 34, - BCU_TSD_SECTION_10 = 35, - BCU_TSD_SECTION_11 = 36, - BCU_TSD_SECTION_12 = 37, - BCU_TSD_SECTION_13 = 38, - BCU_TSD_SECTION_14 = 39, - BCU_TSD_SECTION_15 = 40, - BCU_TSD_SECTION_16 = 41, - BCU_TSD_SECTION_17 = 42, - BCU_TSD_SECTION_18 = 43, - BCU_TSD_SECTION_19 = 44, - BCU_TSD_SECTION_20 = 45, - BCU_TSD_SECTION_21 = 46, - BCU_TSD_SECTION_22 = 47, - BCU_TSD_SECTION_23 = 48, - BCU_TSD_SECTION_24 = 49, - BCU_TSD_SECTION_25 = 50, - BCU_TSD_SECTION_26 = 51, - BCU_TSD_SECTION_27 = 52, - BCU_TSD_SECTION_28 = 53, - BCU_TSD_SECTION_29 = 54, - BCU_TSD_SECTION_30 = 55, - BCU_TSD_SECTION_31 = 56, - BCU_TSD_SECTION_32 = 57, - BCU_TSD_SECTION_33 = 58, - BCU_TSD_SECTION_34 = 59, - BCU_TSD_SECTION_35 = 60, - BCU_TSD_SECTION_36 = 61, - BCU_TSD_SECTION_37 = 62, - BCU_TSD_SECTION_38 = 63, - BCU_TSD_SECTION_39 = 64, - BCU_TSD_SECTION_40 = 65, - BCU_TSD_SECTION_41 = 66, - BCU_TSD_SECTION_42 = 67, - BCU_TSD_SECTION_43 = 68, - BCU_TSD_SECTION_44 = 69, - BCU_TSD_SECTION_45 = 70, - BCU_TSD_SECTION_46 = 71, - BCU_TSD_SECTION_47 = 72, - BCU_TSD_SECTION_48 = 73, - BCU_TSD_SECTION_49 = 74, - BCU_TSD_SECTION_50 = 75, - BCU_TSD_SECTION_51 = 76, - BCU_TSD_SECTION_52 = 77, - BCU_TSD_SECTION_53 = 78, - BCU_TSIO_RECORD_2 = 79, - BCU_TSIO_RECORD_3 = 80, - BCU_TSIO_RECORD_4 = 81, - BCU_TSIO_RECORD_5 = 82, - BCU_TSIO_RECORD_6 = 83, - BCU_TSIO_RECORD_7 = 84, - BCU_TSIO_RECORD_8 = 85, - BCU_TSIO_RECORD_9 = 86, - BCU_PCM_DELAY_LINEAR = 87, - BCU_VD_MASTER_USER_DATA = 88, - BCU_VD_SLAVE_USER_DATA = 89, - BCU_VD_MASTER_REF0 = 90, - BCU_VD_MASTER_REF1 = 91, - BCU_VD_SLAVE_REF0 = 92, - BCU_VD_SLAVE_REF1 = 93, - BCU_VD_MASTER_DISP0_Y = 94, - BCU_VD_MASTER_DISP1_Y = 95, - BCU_VD_MASTER_DISP2_Y = 96, - BCU_VD_MASTER_DISP0_C = 97, - BCU_VD_MASTER_DISP1_C = 98, - BCU_VD_MASTER_DISP2_C = 99, - BCU_VD_SLAVE_DISP0_Y = 100, - BCU_VD_SLAVE_DISP1_Y = 101, - BCU_VD_SLAVE_DISP2_Y = 102, - BCU_VD_SLAVE_DISP0_C = 103, - BCU_VD_SLAVE_DISP1_C = 104, - BCU_VD_SLAVE_DISP2_C = 105, - BCU_CLUT_BUFFER_0 = 106, - BCU_CLUT_BUFFER_1 = 107, - BCU_OSD_FRAME_BUFFER_0 = 108, - BCU_OSD_FRAME_BUFFER_1 = 109, - BCU_GRAPHIC_FRAME_BUFFER0 = 110, - BCU_GRAPHIC_FRAME_BUFFER1 = 111, - BCU_DVP_VBI_REINSERTION = 112, - BCU_DVP_OSD_FRAME_BUFFER0 = 113, - BCU_DVP_OSD_FRAME_BUFFER1 = 114, - BCU_GAI_BUFFER = 115, - BCU_GA_SRC_BUFFER_0 = 116, - BCU_GA_SRC_BUFFER_1 = 117, - BCU_USB_BUFFER_0 = 118, - BCU_USB_BUFFER_1 = 119, - BCU_FE_3DCOMB_0 = 120, - BCU_FE_3DCOMB_1 = 121, - BCU_FE_3DCOMB_2 = 122, - BCU_FE_3DCOMB_3 = 123, - BCU_TNR_BUFFER_0 = 124, - BCU_TNR_BUFFER_1 = 125, - BCU_TNR_BUFFER_2 = 126, - BCU_MVAL_BUFFER = 127, - BCU_RC_BUFFER_0 = 128, - BCU_RC_BUFFER_1 = 129, - BCU_RC_BUFFER_2 = 130, - BCU_RC_BUFFER_3 = 131, - BCU_PIP_BUFFER_0 = 132, - BCU_PIP_BUFFER_1 = 133, - BCU_PIP_BUFFER_2 = 134, - BCU_PIP_BUFFER_3 = 135, - BCU_EWARP_BUFFER = 136, - BCU_OSD_BUFFER_0 = 137, - BCU_OSD_BUFFER_1 = 138, - BCU_GLOBAL_BUFFER_0 = 139, - BCU_GLOBAL_BUFFER_1 = 140, - BCU_MAX = 141 -}; - -#endif /* _BCU_H */ diff --git a/board/micronas/vct/dcgu.c b/board/micronas/vct/dcgu.c deleted file mode 100644 index e72d57f0e0..0000000000 --- a/board/micronas/vct/dcgu.c +++ /dev/null @@ -1,244 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Original Author Guenter Gebhardt - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> -#include <linux/errno.h> - -#include "vct.h" - -int dcgu_set_clk_switch(enum dcgu_hw_module module, enum dcgu_switch setup) -{ - u32 enable; - union dcgu_clk_en1 en1; - union dcgu_clk_en2 en2; - - switch (setup) { - case DCGU_SWITCH_ON: - enable = 1; - break; - case DCGU_SWITCH_OFF: - enable = 0; - break; - default: - printf("%s:%i:Invalid clock switch: %i\n", __FILE__, __LINE__, - setup); - return -EINVAL; - } - - if (module == DCGU_HW_MODULE_CPU) - en2.reg = reg_read(DCGU_CLK_EN2(DCGU_BASE)); - else - en1.reg = reg_read(DCGU_CLK_EN1(DCGU_BASE)); - - switch (module) { - case DCGU_HW_MODULE_MSMC: - en1.bits.en_clkmsmc = enable; - break; - case DCGU_HW_MODULE_SSI_S: - en1.bits.en_clkssi_s = enable; - break; - case DCGU_HW_MODULE_SSI_M: - en1.bits.en_clkssi_m = enable; - break; - case DCGU_HW_MODULE_SMC: - en1.bits.en_clksmc = enable; - break; - case DCGU_HW_MODULE_EBI: - en1.bits.en_clkebi = enable; - break; - case DCGU_HW_MODULE_USB_PLL: - en1.bits.en_usbpll = enable; - break; - case DCGU_HW_MODULE_USB_60: - en1.bits.en_clkusb60 = enable; - break; - case DCGU_HW_MODULE_USB_24: - en1.bits.en_clkusb24 = enable; - break; - case DCGU_HW_MODULE_UART_2: - en1.bits.en_clkuart2 = enable; - break; - case DCGU_HW_MODULE_UART_1: - en1.bits.en_clkuart1 = enable; - break; - case DCGU_HW_MODULE_PERI: - en1.bits.en_clkperi20 = enable; - break; - case DCGU_HW_MODULE_CPU: - en2.bits.en_clkcpu = enable; - break; - case DCGU_HW_MODULE_I2S: - en1.bits.en_clk_i2s_dly = enable; - break; - case DCGU_HW_MODULE_ABP_SCC: - en1.bits.en_clk_scc_abp = enable; - break; - case DCGU_HW_MODULE_SPDIF: - en1.bits.en_clk_dtv_spdo = enable; - break; - case DCGU_HW_MODULE_AD: - en1.bits.en_clkad = enable; - break; - case DCGU_HW_MODULE_MVD: - en1.bits.en_clkmvd = enable; - break; - case DCGU_HW_MODULE_TSD: - en1.bits.en_clktsd = enable; - break; - case DCGU_HW_MODULE_GA: - en1.bits.en_clkga = enable; - break; - case DCGU_HW_MODULE_DVP: - en1.bits.en_clkdvp = enable; - break; - case DCGU_HW_MODULE_MR2: - en1.bits.en_clkmr2 = enable; - break; - case DCGU_HW_MODULE_MR1: - en1.bits.en_clkmr1 = enable; - break; - default: - printf("%s:%i:Invalid hardware module: %i\n", __FILE__, - __LINE__, module); - return -EINVAL; - } - - /* - * The reg_read() following the reg_write() below forces the write to - * be really done on the bus. - * Otherwise the clock may not be switched on when this API function - * returns, which may cause an bus error if a registers of the hardware - * module connected to the clock is accessed. - */ - if (module == DCGU_HW_MODULE_CPU) { - reg_write(DCGU_CLK_EN2(DCGU_BASE), en2.reg); - en2.reg = reg_read(DCGU_CLK_EN2(DCGU_BASE)); - } else { - reg_write(DCGU_CLK_EN1(DCGU_BASE), en1.reg); - en1.reg = reg_read(DCGU_CLK_EN1(DCGU_BASE)); - } - - return 0; -} - -int dcgu_set_reset_switch(enum dcgu_hw_module module, enum dcgu_switch setup) -{ - union dcgu_reset_unit1 val; - u32 enable; - - switch (setup) { - case DCGU_SWITCH_ON: - enable = 1; - break; - case DCGU_SWITCH_OFF: - enable = 0; - break; - default: - printf("%s:%i:Invalid reset switch: %i\n", __FILE__, __LINE__, - setup); - return -EINVAL; - } - - val.reg = reg_read(DCGU_RESET_UNIT1(DCGU_BASE)); - switch (module) { - case DCGU_HW_MODULE_MSMC: - val.bits.swreset_clkmsmc = enable; - break; - case DCGU_HW_MODULE_SSI_S: - val.bits.swreset_clkssi_s = enable; - break; - case DCGU_HW_MODULE_SSI_M: - val.bits.swreset_clkssi_m = enable; - break; - case DCGU_HW_MODULE_SMC: - val.bits.swreset_clksmc = enable; - break; - case DCGU_HW_MODULE_EBI: - val.bits.swreset_clkebi = enable; - break; - case DCGU_HW_MODULE_USB_60: - val.bits.swreset_clkusb60 = enable; - break; - case DCGU_HW_MODULE_USB_24: - val.bits.swreset_clkusb24 = enable; - break; - case DCGU_HW_MODULE_UART_2: - val.bits.swreset_clkuart2 = enable; - break; - case DCGU_HW_MODULE_UART_1: - val.bits.swreset_clkuart1 = enable; - break; - case DCGU_HW_MODULE_PWM: - val.bits.swreset_pwm = enable; - break; - case DCGU_HW_MODULE_GPT: - val.bits.swreset_gpt = enable; - break; - case DCGU_HW_MODULE_I2C2: - val.bits.swreset_i2c2 = enable; - break; - case DCGU_HW_MODULE_I2C1: - val.bits.swreset_i2c1 = enable; - break; - case DCGU_HW_MODULE_GPIO2: - val.bits.swreset_gpio2 = enable; - break; - case DCGU_HW_MODULE_GPIO1: - val.bits.swreset_gpio1 = enable; - break; - case DCGU_HW_MODULE_CPU: - val.bits.swreset_clkcpu = enable; - break; - case DCGU_HW_MODULE_I2S: - val.bits.swreset_clk_i2s_dly = enable; - break; - case DCGU_HW_MODULE_ABP_SCC: - val.bits.swreset_clk_scc_abp = enable; - break; - case DCGU_HW_MODULE_SPDIF: - val.bits.swreset_clk_dtv_spdo = enable; - break; - case DCGU_HW_MODULE_AD: - val.bits.swreset_clkad = enable; - break; - case DCGU_HW_MODULE_MVD: - val.bits.swreset_clkmvd = enable; - break; - case DCGU_HW_MODULE_TSD: - val.bits.swreset_clktsd = enable; - break; - case DCGU_HW_MODULE_TSIO: - val.bits.swreset_clktsio = enable; - break; - case DCGU_HW_MODULE_GA: - val.bits.swreset_clkga = enable; - break; - case DCGU_HW_MODULE_MPC: - val.bits.swreset_clkmpc = enable; - break; - case DCGU_HW_MODULE_CVE: - val.bits.swreset_clkcve = enable; - break; - case DCGU_HW_MODULE_DVP: - val.bits.swreset_clkdvp = enable; - break; - case DCGU_HW_MODULE_MR2: - val.bits.swreset_clkmr2 = enable; - break; - case DCGU_HW_MODULE_MR1: - val.bits.swreset_clkmr1 = enable; - break; - default: - printf("%s:%i:Invalid hardware module: %i\n", __FILE__, - __LINE__, module); - return -EINVAL; - } - reg_write(DCGU_RESET_UNIT1(DCGU_BASE), val.reg); - - return 0; -} diff --git a/board/micronas/vct/dcgu.h b/board/micronas/vct/dcgu.h deleted file mode 100644 index 0f2277f61a..0000000000 --- a/board/micronas/vct/dcgu.h +++ /dev/null @@ -1,165 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _DCGU_H -#define _DCGU_H - -enum dcgu_switch { - DCGU_SWITCH_OFF, /* Switch off */ - DCGU_SWITCH_ON /* Switch on */ -}; - -enum dcgu_hw_module { - DCGU_HW_MODULE_DCGU, /* Selects digital clock gen. unit */ - - DCGU_HW_MODULE_MIC32_SCI, /* Selects MIC32 SoC interface */ - DCGU_HW_MODULE_SCI, /* Selects SCI target agent port modules*/ - - DCGU_HW_MODULE_MR1, /* Selects first MPEG reader module */ - DCGU_HW_MODULE_MR2, /* Selects second MPEG reader module */ - DCGU_HW_MODULE_MVD, /* Selects MPEG video decoder module */ - DCGU_HW_MODULE_DVP, /* Selects dig video processing module */ - DCGU_HW_MODULE_CVE, /* Selects color video encoder module */ - DCGU_HW_MODULE_VID_ENC, /* Selects video encoder module */ - - DCGU_HW_MODULE_SSI_S, /* Selects slave sync serial interface */ - DCGU_HW_MODULE_SSI_M, /* Selects master sync serial interface */ - - DCGU_HW_MODULE_GA, /* Selects graphics accelerator module */ - DCGU_HW_MODULE_DGPU, /* Selects digital graphics processing */ - - DCGU_HW_MODULE_UART_1, /* Selects first UART module */ - DCGU_HW_MODULE_UART_2, /* Selects second UART module */ - - DCGU_HW_MODULE_AD, /* Selects audio decoder module */ - DCGU_HW_MODULE_ABP_DTV, /* Selects audio baseband processing */ - DCGU_HW_MODULE_ABP_SCC, /* Selects audio base band processor SCC*/ - DCGU_HW_MODULE_SPDIF, /* Selects sony philips digital interf. */ - - DCGU_HW_MODULE_TSIO, /* Selects trasnport stream input/output*/ - DCGU_HW_MODULE_TSD, /* Selects trasnport stream decoder */ - DCGU_HW_MODULE_TSD_KEY, /* Selects trasnport stream decoder key */ - - DCGU_HW_MODULE_USBH, /* Selects USB hub module */ - DCGU_HW_MODULE_USB_PLL, /* Selects USB phase locked loop module */ - DCGU_HW_MODULE_USB_60, /* Selects USB 60 module */ - DCGU_HW_MODULE_USB_24, /* Selects USB 24 module */ - - DCGU_HW_MODULE_PERI, /* Selects all mod connected to clkperi20*/ - DCGU_HW_MODULE_WDT, /* Selects wtg timer mod con to clkperi20*/ - DCGU_HW_MODULE_I2C1, /* Selects first I2C mod con to clkperi20*/ - DCGU_HW_MODULE_I2C2, /* Selects 2nd I2C mod con to clkperi20 */ - DCGU_HW_MODULE_GPIO1, /* Selects gpio module 1 */ - DCGU_HW_MODULE_GPIO2, /* Selects gpio module 2 */ - - DCGU_HW_MODULE_GPT, /* Selects gpt mod connected to clkperi20*/ - DCGU_HW_MODULE_PWM, /* Selects pwm mod connected to clkperi20*/ - - DCGU_HW_MODULE_MPC, /* Selects multi purpose cipher module */ - DCGU_HW_MODULE_MPC_KEY, /* Selects multi purpose cipher key */ - - DCGU_HW_MODULE_COM, /* Selects COM unit module */ - DCGU_HW_MODULE_VCTY_CORE, /* Selects VCT-Y core module */ - DCGU_HW_MODULE_FWSRAM, /* Selects firmware SRAM module */ - - DCGU_HW_MODULE_EBI, /* Selects external bus interface module*/ - DCGU_HW_MODULE_I2S, /* Selects integrated interchip sound */ - DCGU_HW_MODULE_MSMC, /* Selects memory stick and mmc module */ - DCGU_HW_MODULE_SMC, /* Selects smartcard interface module */ - - DCGU_HW_MODULE_IRQC, /* Selects interrupt C module */ - DCGU_HW_MODULE_TOP, /* Selects top level pinmux module */ - DCGU_HW_MODULE_SRAM, /* Selects SRAM module */ - DCGU_HW_MODULE_EIC, /* Selects External Interrupt controller*/ - DCGU_HW_MODULE_CPU, /* Selects CPU subsystem module */ - DCGU_HW_MODULE_SCC, /* Selects SCC module */ - DCGU_HW_MODULE_MM, /* Selects Memory Manager module */ - DCGU_HW_MODULE_BCU, /* Selects Buffer Configuration Unit */ - DCGU_HW_MODULE_FH, /* Selects FIFO Handler module */ - DCGU_HW_MODULE_IMU, /* Selects Interrupt Management Unit */ - DCGU_HW_MODULE_MDU, /* Selects MCI Debug Unit module */ - DCGU_HW_MODULE_SI2OCP /* Selects Standard Interface to OCP bridge*/ -}; - -union dcgu_clk_en1 { - u32 reg; - struct { - u32 res1:8; /* reserved */ - u32 en_clkmsmc:1; /* Enable bit for clkmsmc (#) */ - u32 en_clkssi_s:1; /* Enable bit for clkssi_s (#) */ - u32 en_clkssi_m:1; /* Enable bit for clkssi_m (#) */ - u32 en_clksmc:1; /* Enable bit for clksmc (#) */ - u32 en_clkebi:1; /* Enable bit for clkebi (#) */ - u32 en_usbpll:1; /* Enable bit for the USB PLL */ - u32 en_clkusb60:1; /* Enable bit for clkusb60 (#) */ - u32 en_clkusb24:1; /* Enable bit for clkusb24 (#) */ - u32 en_clkuart2:1; /* Enable bit for clkuart2 (#) */ - u32 en_clkuart1:1; /* Enable bit for clkuart1 (#) */ - u32 en_clkperi20:1; /* Enable bit for clkperi20 (#) */ - u32 res2:3; /* reserved */ - u32 en_clk_i2s_dly:1; /* Enable bit for clk_scc_abp */ - u32 en_clk_scc_abp:1; /* Enable bit for clk_scc_abp */ - u32 en_clk_dtv_spdo:1; /* Enable bit for clk_dtv_spdo */ - u32 en_clkad:1; /* Enable bit for clkad (#) */ - u32 en_clkmvd:1; /* Enable bit for clkmvd (#) */ - u32 en_clktsd:1; /* Enable bit for clktsd (#) */ - u32 en_clkga:1; /* Enable bit for clkga (#) */ - u32 en_clkdvp:1; /* Enable bit for clkdvp (#) */ - u32 en_clkmr2:1; /* Enable bit for clkmr2 (#) */ - u32 en_clkmr1:1; /* Enable bit for clkmr1 (#) */ - } bits; -}; - -union dcgu_clk_en2 { - u32 reg; - struct { - u32 res1:31; /* reserved */ - u32 en_clkcpu:1; /* Enable bit for clkcpu */ - } bits; -}; - -union dcgu_reset_unit1 { - u32 reg; - struct { - u32 res1:1; - u32 swreset_clkmsmc:1; - u32 swreset_clkssi_s:1; - u32 swreset_clkssi_m:1; - u32 swreset_clksmc:1; - u32 swreset_clkebi:1; - u32 swreset_clkusb60:1; - u32 swreset_clkusb24:1; - u32 swreset_clkuart2:1; - u32 swreset_clkuart1:1; - u32 swreset_pwm:1; - u32 swreset_gpt:1; - u32 swreset_i2c2:1; - u32 swreset_i2c1:1; - u32 swreset_gpio2:1; - u32 swreset_gpio1:1; - u32 swreset_clkcpu:1; - u32 res2:2; - u32 swreset_clk_i2s_dly:1; - u32 swreset_clk_scc_abp:1; - u32 swreset_clk_dtv_spdo:1; - u32 swreset_clkad:1; - u32 swreset_clkmvd:1; - u32 swreset_clktsd:1; - u32 swreset_clktsio:1; - u32 swreset_clkga:1; - u32 swreset_clkmpc:1; - u32 swreset_clkcve:1; - u32 swreset_clkdvp:1; - u32 swreset_clkmr2:1; - u32 swreset_clkmr1:1; - } bits; -}; - -int dcgu_set_clk_switch(enum dcgu_hw_module module, enum dcgu_switch setup); -int dcgu_set_reset_switch(enum dcgu_hw_module module, enum dcgu_switch setup); - -#endif /* _DCGU_H */ diff --git a/board/micronas/vct/ebi.c b/board/micronas/vct/ebi.c deleted file mode 100644 index 8a73086695..0000000000 --- a/board/micronas/vct/ebi.c +++ /dev/null @@ -1,34 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> -#include <asm/io.h> -#include "vct.h" - -int ebi_initialize(void) -{ -#if defined(CONFIG_VCT_NOR) - if (ebi_init_nor_flash()) - return -1; -#endif - -#if defined(CONFIG_VCT_ONENAND) - if (ebi_init_onenand()) - return -1; -#endif - -#if defined(CONFIG_DRIVER_SMC911X) - if (ebi_init_smc911x()) - return -1; -#endif - - reg_write(EBI_CTRL_SIG_ACTLV(EBI_BASE), 0x00004100); - - ebi_wait(); - - return 0; -} diff --git a/board/micronas/vct/ebi.h b/board/micronas/vct/ebi.h deleted file mode 100644 index ea5b5cf5ad..0000000000 --- a/board/micronas/vct/ebi.h +++ /dev/null @@ -1,81 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#ifndef __EBI__ -#define __EBI__ - -#include <common.h> -#include <asm/io.h> -#include "vct.h" - -#define EXT_DEVICE_CHANNEL_3 (0x30000000) -#define EXT_DEVICE_CHANNEL_2 (0x20000000) -#define EXT_DEVICE_CHANNEL_1 (0x10000000) -#define EXT_CPU_ACCESS_ACTIVE (0x00000001) -#define EXT_DMA_ACCESS_ACTIVE (1 << 14) -#define EXT_CPU_IORDY_SL (0x00000001) - -#define EBI_CPU_WRITE (1 << 31) -#define EBI_CPU_ID_SHIFT (28) -#define EBI_CPU_ADDR_MASK ~(~0UL << EBI_CPU_ID_SHIFT) - -/* position of various bit slices in timing register EBI_DEV[01]_TIM1_RD1 */ -#define ADDR_LATCH_ENABLE 0 -#define ADDR_ACTIVATION 4 -#define CHIP_SELECT_START 8 -#define OUTPUT_ENABLE_START 12 -#define WAIT_TIME 28 -#define READ_DURATION 20 - -/* position of various bit slices in timing register EBI_DEV[01]_TIM1_RD2 */ -#define OUTPUT_ENABLE_END 0 -#define CHIP_SELECT_END 4 -#define ADDR_DEACTIVATION 8 -#define RECOVER_TIME 12 -#define ACK_TIME 20 - -/* various bits in configuration register EBI_DEV[01]_CONFIG1 */ -#define EBI_EXTERNAL_DATA_8 (1 << 8) -#define EBI_EXT_ADDR_SHIFT (1 << 22) -#define EBI_EXTERNAL_DATA_16 EBI_EXT_ADDR_SHIFT -#define EBI_CHIP_SELECT_1 0x2 -#define EBI_CHIP_SELECT_2 0x4 -#define EBI_BUSY_EN_RD (1 << 12) -#define DIR_ACCESS_WRITE (1 << 20) -#define DIR_ACCESS_MASK (1 << 20) - -/* various bits in configuration register EBI_DEV[01]_CONFIG2 */ -#define ADDRESS_INCREMENT_ON 0x0 -#define ADDRESS_INCREMENT_OFF 0x100 -#define QUEUE_LENGTH_1 0x40 -#define QUEUE_LENGTH_2 0x80 -#define QUEUE_LENGTH_3 0xC0 -#define QUEUE_LENGTH_4 0 -#define CPU_TRANSFER_SIZE_32 0 -#define CPU_TRANSFER_SIZE_16 0x10 -#define CPU_TRANSFER_SIZE_8 0x20 -#define READ_ENDIANNESS_ABCD 0 -#define READ_ENDIANNESS_DCBA 0x4 -#define READ_ENDIANNESS_BADC 0x8 -#define READ_ENDIANNESS_CDAB 0xC -#define WRITE_ENDIANNESS_ABCD 0 -#define WRITE_ENDIANNESS_DCBA 0x1 -#define WRITE_ENDIANNESS_BADC 0x2 -#define WRITE_ENDIANNESS_CDAB 0x3 - -/* various bits in configuration register EBI_CTRL_SIG_ACTLV */ -#define IORDY_ACTIVELEVEL_HIGH (1 << 14) -#define ALE_ACTIVELEVEL_HIGH (1 << 8) - -/* bits in register EBI_SIG_LEVEL */ -#define IORDY_LEVEL_MASK 1 - -static inline void ebi_wait(void) -{ - while (reg_read(EBI_STATUS(EBI_BASE)) & EXT_CPU_ACCESS_ACTIVE) - ; /* wait */ -} - -#endif diff --git a/board/micronas/vct/ebi_nor_flash.c b/board/micronas/vct/ebi_nor_flash.c deleted file mode 100644 index 548443e35a..0000000000 --- a/board/micronas/vct/ebi_nor_flash.c +++ /dev/null @@ -1,117 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#include <common.h> -#include <asm/io.h> -#include "vct.h" - -static u32 ebi_read(u32 addr) -{ - addr &= ~0xFC000000; - - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), EXT_DEVICE_CHANNEL_2 | addr); - ebi_wait(); - - return reg_read(EBI_IO_ACCS_DATA(EBI_BASE)); -} - -static int ebi_write_u16(u32 addr, u32 data, int fetchIO) -{ - u32 val = (data << 16); - - addr &= ~0xFC000000; - - ebi_wait(); - - reg_write(EBI_IO_ACCS_DATA(EBI_BASE), val); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), - EXT_DEVICE_CHANNEL_2 | EBI_CPU_WRITE | addr); - ebi_wait(); - - if (fetchIO) { - u32 counter = 0; - while (!(reg_read(EBI_SIG_LEVEL(EBI_BASE)) & EXT_CPU_IORDY_SL)) { - if (counter++ > 0xFFFFFF) - return 1; - } - } - - return 0; -} - -static u16 ebi_read_u16(u32 addr) -{ - return ((ebi_read(addr) >> 16) & 0xFFFF); -} - -static u8 ebi_read_u8(u32 addr) -{ - u32 val = ebi_read(addr) >> 16; - - if (addr & 0x1) - return val & 0xff; - else - return (val >> 8) & 0xff; -} - -/* - * EBI initialization for NOR FLASH access - */ -int ebi_init_nor_flash(void) -{ - reg_write(EBI_DEV1_CONFIG1(EBI_BASE), 0x83000); - - reg_write(EBI_DEV2_CONFIG1(EBI_BASE), 0x400002); - reg_write(EBI_DEV2_CONFIG2(EBI_BASE), 0x50); - - reg_write(EBI_DEV2_TIM1_RD1(EBI_BASE), 0x409113); - reg_write(EBI_DEV2_TIM1_RD2(EBI_BASE), 0xFF01000); - reg_write(EBI_DEV2_TIM1_WR1(EBI_BASE), 0x04003113); - reg_write(EBI_DEV2_TIM1_WR2(EBI_BASE), 0x3FC12011); - reg_write(EBI_DEV2_TIM_EXT(EBI_BASE), 0xFFF00000); - - return 0; -} - -/* - * Accessor functions replacing the "weak" functions in - * drivers/mtd/cfi_flash.c - */ -void flash_write8(u8 value, void *addr) -{ - ebi_write_u16((u32)addr, value, 0); -} - -void flash_write16(u16 value, void *addr) -{ - ebi_write_u16((u32)addr, value, 0); -} - -u8 flash_read8(void *addr) -{ - return ebi_read_u8((u32)addr); -} - -u16 flash_read16(void *addr) -{ - return ebi_read_u16((u32)addr); -} - -u32 flash_read32(void *addr) -{ - return ((u32)ebi_read_u16((u32)addr) << 16) | - ebi_read_u16((u32)addr + 2); -} - -void *board_flash_read_memcpy(void *dest, const void *src, size_t count) -{ - u16 *tmp = (u16 *)dest, *s = (u16 *)src; - int i; - - for (i = 0; i < count; i += 2) - *tmp++ = flash_read16(s++); - - return dest; -} diff --git a/board/micronas/vct/ebi_onenand.c b/board/micronas/vct/ebi_onenand.c deleted file mode 100644 index 862ce2682e..0000000000 --- a/board/micronas/vct/ebi_onenand.c +++ /dev/null @@ -1,185 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#include <common.h> -#include <asm/io.h> -#include <linux/mtd/mtd.h> -#include <linux/mtd/onenand.h> -#include "vct.h" - -#define BURST_SIZE_WORDS 4 - -static u16 ebi_nand_read_word(void __iomem *addr) -{ - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), (EXT_DEVICE_CHANNEL_2 | (u32)addr)); - ebi_wait(); - - return reg_read(EBI_IO_ACCS_DATA(EBI_BASE)) >> 16; -} - -static void ebi_nand_write_word(u16 data, void __iomem * addr) -{ - ebi_wait(); - reg_write(EBI_IO_ACCS_DATA(EBI_BASE), (data << 16)); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), - EXT_DEVICE_CHANNEL_2 | EBI_CPU_WRITE | (u32)addr); - ebi_wait(); -} - -/* - * EBI initialization for OneNAND FLASH access - */ -int ebi_init_onenand(void) -{ - reg_write(EBI_DEV1_CONFIG1(EBI_BASE), 0x83000); - - reg_write(EBI_DEV2_CONFIG1(EBI_BASE), 0x00403002); - reg_write(EBI_DEV2_CONFIG2(EBI_BASE), 0x50); - - reg_write(EBI_DEV3_CONFIG1(EBI_BASE), 0x00403002); - reg_write(EBI_DEV3_CONFIG2(EBI_BASE), 0x0); /* byte/word ordering */ - - reg_write(EBI_DEV2_TIM1_RD1(EBI_BASE), 0x00504000); - reg_write(EBI_DEV2_TIM1_RD2(EBI_BASE), 0x00001000); - reg_write(EBI_DEV2_TIM1_WR1(EBI_BASE), 0x12002223); - reg_write(EBI_DEV2_TIM1_WR2(EBI_BASE), 0x3FC02220); - reg_write(EBI_DEV3_TIM1_RD1(EBI_BASE), 0x00504000); - reg_write(EBI_DEV3_TIM1_RD2(EBI_BASE), 0x00001000); - reg_write(EBI_DEV3_TIM1_WR1(EBI_BASE), 0x05001000); - reg_write(EBI_DEV3_TIM1_WR2(EBI_BASE), 0x00010200); - - reg_write(EBI_DEV2_TIM_EXT(EBI_BASE), 0xFFF00000); - reg_write(EBI_DEV2_EXT_ACC(EBI_BASE), 0x0FFFFFFF); - - reg_write(EBI_DEV3_TIM_EXT(EBI_BASE), 0xFFF00000); - reg_write(EBI_DEV3_EXT_ACC(EBI_BASE), 0x0FFFFFFF); - - /* prepare DMA configuration for EBI */ - reg_write(EBI_DEV3_FIFO_CONFIG(EBI_BASE), 0x0101ff00); - - /* READ only no byte order change, TAG 1 used */ - reg_write(EBI_DEV3_DMA_CONFIG2(EBI_BASE), 0x00000004); - - reg_write(EBI_TAG1_SYS_ID(EBI_BASE), 0x0); /* SCC DMA channel 0 */ - reg_write(EBI_TAG2_SYS_ID(EBI_BASE), 0x1); - reg_write(EBI_TAG3_SYS_ID(EBI_BASE), 0x2); - reg_write(EBI_TAG4_SYS_ID(EBI_BASE), 0x3); - - return 0; -} - -static void *memcpy_16_from_onenand(void *dst, const void *src, unsigned int len) -{ - void *ret = dst; - u16 *d = dst; - u16 *s = (u16 *)src; - - len >>= 1; - while (len-- > 0) - *d++ = ebi_nand_read_word(s++); - - return ret; -} - -static void *memcpy_32_from_onenand(void *dst, const void *src, unsigned int len) -{ - void *ret = dst; - u32 *d = (u32 *)dst; - u32 s = (u32)src; - u32 bytes_per_block = BURST_SIZE_WORDS * sizeof(int); - u32 n_blocks = len / bytes_per_block; - u32 block = 0; - u32 burst_word; - - for (block = 0; block < n_blocks; block++) { - /* Trigger read channel 3 */ - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), - (EXT_DEVICE_CHANNEL_3 | (s + (block * bytes_per_block)))); - /* Poll status to see whether read has finished */ - ebi_wait(); - - /* Squirrel the data away in a safe place */ - for (burst_word = 0; burst_word < BURST_SIZE_WORDS; burst_word++) - *d++ = reg_read(EBI_IO_ACCS_DATA(EBI_BASE)); - } - - return ret; -} - -static void *memcpy_16_to_onenand(void *dst, const void *src, unsigned int len) -{ - void *ret = dst; - u16 *d = dst; - u16 *s = (u16 *)src; - - len >>= 1; - while (len-- > 0) - ebi_nand_write_word(*s++, d++); - - return ret; -} - -static inline int onenand_bufferram_offset(struct mtd_info *mtd, int area) -{ - struct onenand_chip *this = mtd->priv; - - if (ONENAND_CURRENT_BUFFERRAM(this)) { - if (area == ONENAND_DATARAM) - return mtd->writesize; - if (area == ONENAND_SPARERAM) - return mtd->oobsize; - } - - return 0; -} - -static int ebi_read_bufferram(struct mtd_info *mtd, loff_t addr, int area, - unsigned char *buffer, int offset, - size_t count) -{ - struct onenand_chip *this = mtd->priv; - void __iomem *bufferram; - - bufferram = this->base + area; - bufferram += onenand_bufferram_offset(mtd, area); - - if (count < 4) - memcpy_16_from_onenand(buffer, bufferram + offset, count); - else - memcpy_32_from_onenand(buffer, bufferram + offset, count); - - return 0; -} - -static int ebi_write_bufferram(struct mtd_info *mtd, loff_t addr, int area, - const unsigned char *buffer, int offset, - size_t count) -{ - struct onenand_chip *this = mtd->priv; - void __iomem *bufferram; - - bufferram = this->base + area; - bufferram += onenand_bufferram_offset(mtd, area); - - memcpy_16_to_onenand(bufferram + offset, buffer, count); - - return 0; -} - -int onenand_board_init(struct mtd_info *mtd) -{ - struct onenand_chip *chip = mtd->priv; - - /* - * Insert board specific OneNAND access functions - */ - chip->read_word = ebi_nand_read_word; - chip->write_word = ebi_nand_write_word; - - chip->read_bufferram = ebi_read_bufferram; - chip->write_bufferram = ebi_write_bufferram; - - return 0; -} diff --git a/board/micronas/vct/ebi_smc911x.c b/board/micronas/vct/ebi_smc911x.c deleted file mode 100644 index 9e59f0a2de..0000000000 --- a/board/micronas/vct/ebi_smc911x.c +++ /dev/null @@ -1,94 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#include <common.h> -#include <netdev.h> -#include <asm/io.h> -#include "vct.h" - -/* - * EBI initialization for SMC911x access - */ -int ebi_init_smc911x(void) -{ - reg_write(EBI_DEV1_CONFIG1(EBI_BASE), 0x00003020); - reg_write(EBI_DEV1_CONFIG2(EBI_BASE), 0x0000004F); - - reg_write(EBI_DEV1_TIM1_RD1(EBI_BASE), 0x00501100); - reg_write(EBI_DEV1_TIM1_RD2(EBI_BASE), 0x0FF02111); - - reg_write(EBI_DEV1_TIM_EXT(EBI_BASE), 0xFFF00000); - reg_write(EBI_DEV1_EXT_ACC(EBI_BASE), 0x0FFFFFFF); - - reg_write(EBI_DEV1_TIM1_WR1(EBI_BASE), 0x05001100); - reg_write(EBI_DEV1_TIM1_WR2(EBI_BASE), 0x3FC21110); - - return 0; -} - -/* - * Accessor functions replacing the "weak" functions in - * drivers/net/smc911x.c - */ -u32 smc911x_reg_read(struct eth_device *dev, u32 addr) -{ - volatile u32 data; - - addr += dev->iobase; - reg_write(EBI_DEV1_CONFIG2(EBI_BASE), 0x0000004F); - ebi_wait(); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), (EXT_DEVICE_CHANNEL_1 | addr)); - ebi_wait(); - data = reg_read(EBI_IO_ACCS_DATA(EBI_BASE)); - - return (data); -} - -void smc911x_reg_write(struct eth_device *dev, u32 addr, u32 data) -{ - addr += dev->iobase; - reg_write(EBI_DEV1_CONFIG2(EBI_BASE), 0x0000004F); - ebi_wait(); - reg_write(EBI_IO_ACCS_DATA(EBI_BASE), data); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), - EXT_DEVICE_CHANNEL_1 | EBI_CPU_WRITE | addr); - ebi_wait(); -} - -void pkt_data_push(struct eth_device *dev, u32 addr, u32 data) -{ - addr += dev->iobase; - reg_write(EBI_DEV1_CONFIG2(EBI_BASE), 0x0000004A); - ebi_wait(); - reg_write(EBI_IO_ACCS_DATA(EBI_BASE), data); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), - EXT_DEVICE_CHANNEL_1 | EBI_CPU_WRITE | addr); - ebi_wait(); - - return; -} - -u32 pkt_data_pull(struct eth_device *dev, u32 addr) -{ - volatile u32 data; - - addr += dev->iobase; - reg_write(EBI_DEV1_CONFIG2(EBI_BASE), 0x0000004A); - ebi_wait(); - reg_write(EBI_CPU_IO_ACCS(EBI_BASE), (EXT_DEVICE_CHANNEL_1 | addr)); - ebi_wait(); - data = reg_read(EBI_IO_ACCS_DATA(EBI_BASE)); - - return data; -} - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC911X - rc = smc911x_initialize(0, CONFIG_DRIVER_SMC911X_BASE); -#endif - return rc; -} diff --git a/board/micronas/vct/ehci.c b/board/micronas/vct/ehci.c deleted file mode 100644 index 2d6966c2ae..0000000000 --- a/board/micronas/vct/ehci.c +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Original Author Guenter Gebhardt - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> - -#include "vct.h" - -int vct_ehci_hcd_init(u32 *hccr, u32 *hcor) -{ - int retval; - u32 val; - u32 addr; - - dcgu_set_reset_switch(DCGU_HW_MODULE_USB_24, DCGU_SWITCH_ON); - dcgu_set_reset_switch(DCGU_HW_MODULE_USB_60, DCGU_SWITCH_ON); - dcgu_set_clk_switch(DCGU_HW_MODULE_USB_24, DCGU_SWITCH_ON); - dcgu_set_clk_switch(DCGU_HW_MODULE_USB_PLL, DCGU_SWITCH_ON); - dcgu_set_reset_switch(DCGU_HW_MODULE_USB_24, DCGU_SWITCH_OFF); - - /* Wait until (DCGU_USBPHY_STAT == 7) */ - addr = DCGU_USBPHY_STAT(DCGU_BASE); - val = reg_read(addr); - while (val != 7) - val = reg_read(addr); - - dcgu_set_clk_switch(DCGU_HW_MODULE_USB_60, DCGU_SWITCH_ON); - dcgu_set_reset_switch(DCGU_HW_MODULE_USB_60, DCGU_SWITCH_OFF); - - retval = scc_reset(SCC_USB_RW, 0); - if (retval) { - printf("scc_reset(SCC_USB_RW, 0) returned: 0x%x\n", retval); - return retval; - } else { - retval = scc_reset(SCC_CPU1_SPDMA_RW, 0); - if (retval) { - printf("scc_reset(SCC_CPU1_SPDMA_RW, 0) returned: 0x%x\n", - retval); - return retval; - } - } - - if (!retval) { - /* - * For the AGU bypass, where the SCC client provides full - * physical address - */ - scc_set_usb_address_generation_mode(1); - scc_setup_dma(SCC_USB_RW, BCU_USB_BUFFER_1, DMA_LINEAR, - USE_NO_FH, DMA_READ, 0); - scc_setup_dma(SCC_CPU1_SPDMA_RW, BCU_USB_BUFFER_1, DMA_LINEAR, - USE_NO_FH, DMA_WRITE, 0); - scc_setup_dma(SCC_USB_RW, BCU_USB_BUFFER_0, DMA_LINEAR, - USE_NO_FH, DMA_WRITE, 0); - scc_setup_dma(SCC_CPU1_SPDMA_RW, BCU_USB_BUFFER_0, DMA_LINEAR, - USE_NO_FH, DMA_READ, 0); - - /* Enable memory interface */ - scc_enable(SCC_USB_RW, 1); - - /* Start (start_cmd=0) DMAs */ - scc_dma_cmd(SCC_USB_RW, DMA_START, 0, DMA_READ); - scc_dma_cmd(SCC_USB_RW, DMA_START, 0, DMA_WRITE); - } else { - printf("Cannot configure USB memory channel.\n"); - printf("USB can not access RAM. SCC configuration failed.\n"); - return retval; - } - - /* Wait a short while */ - udelay(300000); - - reg_write(USBH_BURSTSIZE(USBH_BASE), 0x00001c1c); - - /* Set EHCI structures and DATA in RAM */ - reg_write(USBH_USBHMISC(USBH_BASE), 0x00840003); - /* Set USBMODE to bigendian and set host mode */ - reg_write(USBH_USBMODE(USBH_BASE), 0x00000007); - - /* - * USBH_BURSTSIZE MUST EQUAL 0x00001c1c in order for - * 512 byte USB transfers on the bulk pipe to work properly. - * Set USBH_BURSTSIZE to 0x00001c1c - */ - reg_write(USBH_BURSTSIZE(USBH_BASE), 0x00001c1c); - - /* Insert access register addresses */ - *hccr = REG_GLOBAL_START_ADDR + USBH_CAPLENGTH(USBH_BASE); - *hcor = REG_GLOBAL_START_ADDR + USBH_USBCMD(USBH_BASE); - - return 0; -} diff --git a/board/micronas/vct/gpio.c b/board/micronas/vct/gpio.c deleted file mode 100644 index 776bb2d91c..0000000000 --- a/board/micronas/vct/gpio.c +++ /dev/null @@ -1,74 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#include <common.h> -#include <asm/io.h> -#include "vct.h" - -/* - * Find out to which of the 2 gpio modules the pin specified in the - * argument belongs: - * GPIO_MODULE yields 0 for pins 0 to 31, - * 1 for pins 32 to 63 - */ -#define GPIO_MODULE(pin) ((pin) >> 5) - -/* - * Bit position within a 32-bit peripheral register (where every - * bit is one bitslice) - */ -#define MASK(pin) (1 << ((pin) & 0x1F)) -#define BASE_ADDR(mod) module_base[mod] - -/* - * Lookup table for transforming gpio module number 0 to 2 to - * address offsets - */ -static u32 module_base[] = { - GPIO1_BASE, - GPIO2_BASE -}; - -static void clrsetbits(u32 addr, u32 and_mask, u32 or_mask) -{ - reg_write(addr, (reg_read(addr) & ~and_mask) | or_mask); -} - -int vct_gpio_dir(int pin, int dir) -{ - u32 gpio_base; - - gpio_base = BASE_ADDR(GPIO_MODULE(pin)); - - if (dir == 0) - clrsetbits(GPIO_SWPORTA_DDR(gpio_base), MASK(pin), 0); - else - clrsetbits(GPIO_SWPORTA_DDR(gpio_base), 0, MASK(pin)); - - return 0; -} - -void vct_gpio_set(int pin, int val) -{ - u32 gpio_base; - - gpio_base = BASE_ADDR(GPIO_MODULE(pin)); - - if (val == 0) - clrsetbits(GPIO_SWPORTA_DR(gpio_base), MASK(pin), 0); - else - clrsetbits(GPIO_SWPORTA_DR(gpio_base), 0, MASK(pin)); -} - -int vct_gpio_get(int pin) -{ - u32 gpio_base; - u32 value; - - gpio_base = BASE_ADDR(GPIO_MODULE(pin)); - value = reg_read(GPIO_EXT_PORTA(gpio_base)); - - return ((value & MASK(pin)) ? 1 : 0); -} diff --git a/board/micronas/vct/scc.c b/board/micronas/vct/scc.c deleted file mode 100644 index 6621231b07..0000000000 --- a/board/micronas/vct/scc.c +++ /dev/null @@ -1,657 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> -#include <linux/errno.h> - -#include "vct.h" - -/* - * List of statically defined buffers per SCC. - * The first entry in the table is the number of fixed buffers - * followed by the list of buffer IDs - */ -static u32 buffer_list_0[] = { 6, 120, 121, 122, 123, 139, 140 }; -static u32 buffer_list_1[] = { 6, 120, 121, 122, 123, 139, 140 }; -static u32 buffer_list_2[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_3[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_4[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_5[] = { 3, 127, 139, 140 }; -static u32 buffer_list_6[] = { 3, 127, 139, 140 }; -static u32 buffer_list_7[] = { 6, 128, 129, 130, 131, 139, 140 }; -static u32 buffer_list_8[] = { 6, 128, 129, 130, 131, 139, 140 }; -static u32 buffer_list_9[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_10[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_11[] = { 5, 124, 125, 126, 139, 140 }; -static u32 buffer_list_12[] = { 6, 132, 133, 134, 135, 139, 140 }; -static u32 buffer_list_13[] = { 6, 132, 133, 134, 135, 139, 140 }; -static u32 buffer_list_14[] = { 4, 137, 138, 139, 140 }; -static u32 buffer_list_15[] = { 6, 136, 136, 137, 138, 139, 140 }; - -/** Issue#7674 (new) - DP/DVP buffer assignment */ -static u32 buffer_list_16[] = { 6, 106, 108, 109, 107, 139, 140 }; -static u32 buffer_list_17[] = { 6, 106, 110, 107, 111, 139, 140 }; -static u32 buffer_list_18[] = { 6, 106, 113, 107, 114, 139, 140 }; -static u32 buffer_list_19[] = { 3, 112, 139, 140 }; -static u32 buffer_list_20[] = { 35, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 79, 80, 81, 82, 83, 84, 85, 86, 139, 140 }; -static u32 buffer_list_21[] = { 27, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 139, 140 }; -static u32 buffer_list_22[] = { 81, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, - 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, - 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, - 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, - 73, 74, 75, 76, 77, 78, 139, 140 }; -static u32 buffer_list_23[] = { 29, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 88, 89, 139, 140 }; -static u32 buffer_list_24[] = { 6, 90, 91, 92, 93, 139, 140 }; -static u32 buffer_list_25[] = { 18, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, - 100, 101, 102, 103, 104, 105, 139, 140 }; -static u32 buffer_list_26[] = { 5, 94, 95, 96, 139, 140 }; -static u32 buffer_list_27[] = { 5, 97, 98, 99, 139, 140 }; -static u32 buffer_list_28[] = { 5, 100, 101, 102, 139, 140 }; -static u32 buffer_list_29[] = { 5, 103, 104, 105, 139, 140 }; -static u32 buffer_list_30[] = { 10, 108, 109, 110, 111, 113, 114, 116, 117, - 139, 140 }; -static u32 buffer_list_31[] = { 13, 106, 107, 108, 109, 110, 111, 113, 114, - 115, 116, 117, 139, 140 }; -static u32 buffer_list_32[] = { 13, 106, 107, 108, 109, 110, 111, 113, 114, - 115, 116, 117, 139, 140 }; -static u32 buffer_list_33[] = { 27, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 139, 140 }; -static u32 buffer_list_34[] = { 27, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 139, 140 }; -static u32 buffer_list_35[] = { 28, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 87, 139, 140 }; -static u32 buffer_list_36[] = { 28, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 87, 139, 140 }; -static u32 buffer_list_37[] = { 27, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 139, 140 }; -static u32 buffer_list_38[] = { 29, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 118, 119, 139, 140 }; -static u32 buffer_list_39[] = { 91, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, - 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, - 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, - 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, - 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, - 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, - 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, - 85, 86, 118, 119, 139, 140 }; -static u32 buffer_list_40[] = { 0 }; - -/* - * List of statically defined vcid.csize values. - * The first entry in the table is the number of possible csize values - * followed by the list of data path values in bits. - */ -static u32 csize_list_0[] = { 2, 0, 1 }; -static u32 csize_list_1[] = { 2, 0, 1 }; -static u32 csize_list_2[] = { 1, 1 }; -static u32 csize_list_3[] = { 1, 1 }; -static u32 csize_list_4[] = { 1, 1 }; -static u32 csize_list_5[] = { 1, 0 }; -static u32 csize_list_6[] = { 1, 0 }; -static u32 csize_list_7[] = { 1, 1 }; -static u32 csize_list_8[] = { 1, 1 }; -static u32 csize_list_9[] = { 1, 1 }; -static u32 csize_list_10[] = { 1, 1 }; -static u32 csize_list_11[] = { 1, 1 }; -static u32 csize_list_12[] = { 1, 1 }; -static u32 csize_list_13[] = { 1, 1 }; -static u32 csize_list_14[] = { 1, 2 }; -static u32 csize_list_15[] = { 1, 4 }; -static u32 csize_list_16[] = { 3, 0, 1, 2 }; -static u32 csize_list_17[] = { 3, 0, 1, 2 }; -static u32 csize_list_18[] = { 3, 0, 1, 2 }; -static u32 csize_list_19[] = { 1, 2 }; -static u32 csize_list_20[] = { 1, 0 }; -static u32 csize_list_21[] = { 1, 0 }; -static u32 csize_list_22[] = { 1, 2 }; -static u32 csize_list_23[] = { 1, 3 }; -static u32 csize_list_24[] = { 1, 3 }; -static u32 csize_list_25[] = { 1, 3 }; -static u32 csize_list_26[] = { 1, 0 }; -static u32 csize_list_27[] = { 1, 0 }; -static u32 csize_list_28[] = { 1, 0 }; -static u32 csize_list_29[] = { 1, 0 }; -static u32 csize_list_30[] = { 1, 2 }; -static u32 csize_list_31[] = { 1, 2 }; -static u32 csize_list_32[] = { 1, 2 }; -static u32 csize_list_33[] = { 1, 2 }; -static u32 csize_list_34[] = { 1, 2 }; -static u32 csize_list_35[] = { 1, 2 }; -static u32 csize_list_36[] = { 1, 2 }; -static u32 csize_list_37[] = { 2, 0, 1 }; -static u32 csize_list_38[] = { 1, 2 }; -static u32 csize_list_39[] = { 1, 3 }; -static u32 csize_list_40[] = { 1, 3 }; - -/* - * SCC_Configuration table - */ -static const struct scc_descriptor scc_descriptor_table[] = { -/* scn scc_name profile SCC scc_id mci_id rd wr m p fh si cfg sta */ - {"fe_", "fe_3dcomb_wr", STRM_P, SCC0_BASE, 0, 0, 0, 4, 1, 1, 0, 0, 0, 1, - buffer_list_0, csize_list_0}, - {"fe_", "fe_3dcomb_rd", STRM_P, SCC1_BASE, 1, 18, 4, 0, 1, 1, 0, 1, 0, - 1, buffer_list_1, csize_list_1}, - {"di_", "di_tnr_wr", STRM_P, SCC2_BASE, 2, 1, 0, 3, 1, 1, 0, 2, 0, 1, - buffer_list_2, csize_list_2}, - {"di_", "di_tnr_field_rd", STRM_P, SCC3_BASE, 3, 19, 3, 0, 1, 1, 0, 3, - 0, 1, buffer_list_3, csize_list_3}, - {"di_", "di_tnr_frame_rd", STRM_P, SCC4_BASE, 4, 20, 3, 0, 1, 1, 0, 4, - 0, 1, buffer_list_4, csize_list_4}, - {"di_", "di_mval_wr", STRM_P, SCC5_BASE, 5, 2, 0, 1, 1, 1, 0, 5, 0, 1, - buffer_list_5, csize_list_5}, - {"di_", "di_mval_rd", STRM_P, SCC6_BASE, 6, 21, 1, 0, 1, 1, 0, 6, 0, 1, - buffer_list_6, csize_list_6}, - {"rc_", "rc_frame_wr", STRM_P, SCC7_BASE, 7, 3, 0, 4, 1, 1, 0, 7, 0, 1, - buffer_list_7, csize_list_7}, - {"rc_", "rc_frame0_rd", STRM_P, SCC8_BASE, 8, 22, 4, 0, 1, 1, 0, 8, 0, - 1, buffer_list_8, csize_list_8}, - {"opt", "opt_field0_rd", STRM_P, SCC9_BASE, 9, 23, 3, 0, 1, 1, 0, 9, 0, - 1, buffer_list_9, csize_list_9}, - {"opt", "opt_field1_rd", STRM_P, SCC10_BASE, 10, 24, 3, 0, 1, 1, 0, 10, - 0, 1, buffer_list_10, csize_list_10}, - {"opt", "opt_field2_rd", STRM_P, SCC11_BASE, 11, 25, 3, 0, 1, 1, 0, 11, - 0, 1, buffer_list_11, csize_list_11}, - {"pip", "pip_frame_wr", STRM_P, SCC12_BASE, 12, 4, 0, 4, 1, 1, 0, 12, 0, - 1, buffer_list_12, csize_list_12}, - {"pip", "pip_frame_rd", STRM_P, SCC13_BASE, 13, 26, 4, 0, 1, 1, 0, 13, - 0, 1, buffer_list_13, csize_list_13}, - {"dp_", "dp_agpu_rd", STRM_P, SCC14_BASE, 14, 27, 2, 0, 2, 1, 0, 14, 0, - 1, buffer_list_14, csize_list_14}, - {"ewa", "ewarp_rw", SRMD, SCC15_BASE, 15, 11, 1, 1, 0, 0, 0, -1, 0, 0, - buffer_list_15, csize_list_15}, - {"dp_", "dp_osd_rd", STRM_P, SCC16_BASE, 16, 28, 3, 0, 2, 1, 0, 15, 0, - 1, buffer_list_16, csize_list_16}, - {"dp_", "dp_graphic_rd", STRM_P, SCC17_BASE, 17, 29, 3, 0, 2, 1, 0, 16, - 0, 1, buffer_list_17, csize_list_17}, - {"dvp", "dvp_osd_rd", STRM_P, SCC18_BASE, 18, 30, 2, 0, 2, 1, 0, 17, 0, - 1, buffer_list_18, csize_list_18}, - {"dvp", "dvp_vbi_rd", STRM_D, SCC19_BASE, 19, 31, 1, 0, 0, 1, 0, -1, 0, - 0, buffer_list_19, csize_list_19}, - {"tsi", "tsio_wr", STRM_P, SCC20_BASE, 20, 5, 0, 8, 2, 1, 1, -1, 0, 0, - buffer_list_20, csize_list_20}, - {"tsi", "tsio_rd", STRM_P, SCC21_BASE, 21, 32, 4, 0, 2, 1, 1, -1, 0, 0, - buffer_list_21, csize_list_21}, - {"tsd", "tsd_wr", SRMD, SCC22_BASE, 22, 6, 0, 64, 0, 0, 1, -1, 0, 0, - buffer_list_22, csize_list_22}, - {"vd_", "vd_ud_st_rw", SRMD, SCC23_BASE, 23, 12, 2, 2, 0, 0, 1, -1, 0, - 0, buffer_list_23, csize_list_23}, - {"vd_", "vd_frr_rd", SRMD, SCC24_BASE, 24, 33, 4, 0, 0, 0, 0, -1, 0, 0, - buffer_list_24, csize_list_24}, - {"vd_", "vd_frw_disp_wr", SRMD, SCC25_BASE, 25, 7, 0, 16, 0, 0, 0, -1, - 0, 0, buffer_list_25, csize_list_25}, - {"mr_", "mr_vd_m_y_rd", STRM_P, SCC26_BASE, 26, 34, 3, 0, 2, 1, 0, 18, - 0, 1, buffer_list_26, csize_list_26}, - {"mr_", "mr_vd_m_c_rd", STRM_P, SCC27_BASE, 27, 35, 3, 0, 2, 1, 0, 19, - 0, 1, buffer_list_27, csize_list_27}, - {"mr_", "mr_vd_s_y_rd", STRM_P, SCC28_BASE, 28, 36, 3, 0, 2, 1, 0, 20, - 0, 1, buffer_list_28, csize_list_28}, - {"mr_", "mr_vd_s_c_rd", STRM_P, SCC29_BASE, 29, 37, 3, 0, 2, 1, 0, 21, - 0, 1, buffer_list_29, csize_list_29}, - {"ga_", "ga_wr", STRM_P, SCC30_BASE, 30, 8, 0, 1, 1, 1, 0, -1, 1, 1, - buffer_list_30, csize_list_30}, - {"ga_", "ga_src1_rd", STRM_P, SCC31_BASE, 31, 38, 1, 0, 1, 1, 0, -1, 1, - 1, buffer_list_31, csize_list_31}, - {"ga_", "ga_src2_rd", STRM_P, SCC32_BASE, 32, 39, 1, 0, 1, 1, 0, -1, 1, - 1, buffer_list_32, csize_list_32}, - {"ad_", "ad_rd", STRM_D, SCC33_BASE, 33, 40, 2, 0, 0, 1, 1, -1, 0, 0, - buffer_list_33, csize_list_33}, - {"ad_", "ad_wr", STRM_D, SCC34_BASE, 34, 9, 0, 3, 0, 1, 1, -1, 0, 0, - buffer_list_34, csize_list_34}, - {"abp", "abp_rd", STRM_D, SCC35_BASE, 35, 41, 5, 0, 0, 1, 1, -1, 0, 0, - buffer_list_35, csize_list_35}, - {"abp", "abp_wr", STRM_D, SCC36_BASE, 36, 10, 0, 3, 0, 1, 1, -1, 0, 0, - buffer_list_36, csize_list_36}, - {"ebi", "ebi_rw", STRM_P, SCC37_BASE, 37, 13, 4, 4, 2, 1, 1, -1, 0, 0, - buffer_list_37, csize_list_37}, - {"usb", "usb_rw", SRMD, SCC38_BASE, 38, 14, 1, 1, 0, 0, 1, -1, 0, 0, - buffer_list_38, csize_list_38}, - {"cpu", "cpu1_spdma_rw", SRMD, SCC39_BASE, 39, 15, 1, 1, 0, 0, 1, -1, 0, - 0, buffer_list_39, csize_list_39}, - {"cpu", "cpu1_bridge_rw", SRMD, SCC40_BASE, 40, 16, 0, 0, 0, 0, 0, -1, - 0, 0, buffer_list_40, csize_list_40}, -}; - -/* DMA state structures for read and write channels for each SCC */ - -static struct scc_dma_state scc_state_rd_0[] = { {-1} }; -static struct scc_dma_state scc_state_wr_0[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_1[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_1[] = { {-1} }; -static struct scc_dma_state scc_state_rd_2[] = { {-1} }; -static struct scc_dma_state scc_state_wr_2[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_3[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_3[] = { {-1} }; -static struct scc_dma_state scc_state_rd_4[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_4[] = { {-1} }; -static struct scc_dma_state scc_state_rd_5[] = { {-1} }; -static struct scc_dma_state scc_state_wr_5[] = { {0} }; -static struct scc_dma_state scc_state_rd_6[] = { {0} }; -static struct scc_dma_state scc_state_wr_6[] = { {-1} }; -static struct scc_dma_state scc_state_rd_7[] = { {-1} }; -static struct scc_dma_state scc_state_wr_7[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_8[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_8[] = { {-1} }; -static struct scc_dma_state scc_state_rd_9[] = { {0}, {0}, {0}, }; -static struct scc_dma_state scc_state_wr_9[] = { {-1} }; -static struct scc_dma_state scc_state_rd_10[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_10[] = { {-1} }; -static struct scc_dma_state scc_state_rd_11[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_11[] = { {-1} }; -static struct scc_dma_state scc_state_rd_12[] = { {-1} }; -static struct scc_dma_state scc_state_wr_12[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_13[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_13[] = { {-1} }; -static struct scc_dma_state scc_state_rd_14[] = { {0}, {0} }; -static struct scc_dma_state scc_state_wr_14[] = { {-1} }; -static struct scc_dma_state scc_state_rd_15[] = { {0} }; -static struct scc_dma_state scc_state_wr_15[] = { {0} }; -static struct scc_dma_state scc_state_rd_16[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_16[] = { {-1} }; -static struct scc_dma_state scc_state_rd_17[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_17[] = { {-1} }; -static struct scc_dma_state scc_state_rd_18[] = { {0}, {0} }; -static struct scc_dma_state scc_state_wr_18[] = { {-1} }; -static struct scc_dma_state scc_state_rd_19[] = { {0} }; -static struct scc_dma_state scc_state_wr_19[] = { {-1} }; -static struct scc_dma_state scc_state_rd_20[] = { {-1} }; -static struct scc_dma_state scc_state_wr_20[] = { - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_21[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_21[] = { {-1} }; -static struct scc_dma_state scc_state_rd_22[] = { {-1} }; -static struct scc_dma_state scc_state_wr_22[] = { - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_23[] = { {0}, {0} }; -static struct scc_dma_state scc_state_wr_23[] = { {0}, {0} }; -static struct scc_dma_state scc_state_rd_24[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_24[] = { {-1} }; -static struct scc_dma_state scc_state_rd_25[] = { {-1} }; -static struct scc_dma_state scc_state_wr_25[] = { - {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, {0}, - {0}, {0} }; -static struct scc_dma_state scc_state_rd_26[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_26[] = { {-1} }; -static struct scc_dma_state scc_state_rd_27[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_27[] = { {-1} }; -static struct scc_dma_state scc_state_rd_28[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_28[] = { {-1} }; -static struct scc_dma_state scc_state_rd_29[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_29[] = { {-1} }; -static struct scc_dma_state scc_state_rd_30[] = { {-1} }; -static struct scc_dma_state scc_state_wr_30[] = { {0} }; -static struct scc_dma_state scc_state_rd_31[] = { {0} }; -static struct scc_dma_state scc_state_wr_31[] = { {-1} }; -static struct scc_dma_state scc_state_rd_32[] = { {0} }; -static struct scc_dma_state scc_state_wr_32[] = { {-1} }; -static struct scc_dma_state scc_state_rd_33[] = { {0}, {0} }; -static struct scc_dma_state scc_state_wr_33[] = { {-1} }; -static struct scc_dma_state scc_state_rd_34[] = { {-1} }; -static struct scc_dma_state scc_state_wr_34[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_35[] = { {0}, {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_35[] = { {-1} }; -static struct scc_dma_state scc_state_rd_36[] = { {-1} }; -static struct scc_dma_state scc_state_wr_36[] = { {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_37[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_wr_37[] = { {0}, {0}, {0}, {0} }; -static struct scc_dma_state scc_state_rd_38[] = { {0} }; -static struct scc_dma_state scc_state_wr_38[] = { {0} }; -static struct scc_dma_state scc_state_rd_39[] = { {0} }; -static struct scc_dma_state scc_state_wr_39[] = { {0} }; -static struct scc_dma_state scc_state_rd_40[] = { {-1} }; -static struct scc_dma_state scc_state_wr_40[] = { {-1} }; - -/* DMA state references to access from the driver */ -static struct scc_dma_state *scc_state_rd[] = { - scc_state_rd_0, - scc_state_rd_1, - scc_state_rd_2, - scc_state_rd_3, - scc_state_rd_4, - scc_state_rd_5, - scc_state_rd_6, - scc_state_rd_7, - scc_state_rd_8, - scc_state_rd_9, - scc_state_rd_10, - scc_state_rd_11, - scc_state_rd_12, - scc_state_rd_13, - scc_state_rd_14, - scc_state_rd_15, - scc_state_rd_16, - scc_state_rd_17, - scc_state_rd_18, - scc_state_rd_19, - scc_state_rd_20, - scc_state_rd_21, - scc_state_rd_22, - scc_state_rd_23, - scc_state_rd_24, - scc_state_rd_25, - scc_state_rd_26, - scc_state_rd_27, - scc_state_rd_28, - scc_state_rd_29, - scc_state_rd_30, - scc_state_rd_31, - scc_state_rd_32, - scc_state_rd_33, - scc_state_rd_34, - scc_state_rd_35, - scc_state_rd_36, - scc_state_rd_37, - scc_state_rd_38, - scc_state_rd_39, - scc_state_rd_40, -}; - -static struct scc_dma_state *scc_state_wr[] = { - scc_state_wr_0, - scc_state_wr_1, - scc_state_wr_2, - scc_state_wr_3, - scc_state_wr_4, - scc_state_wr_5, - scc_state_wr_6, - scc_state_wr_7, - scc_state_wr_8, - scc_state_wr_9, - scc_state_wr_10, - scc_state_wr_11, - scc_state_wr_12, - scc_state_wr_13, - scc_state_wr_14, - scc_state_wr_15, - scc_state_wr_16, - scc_state_wr_17, - scc_state_wr_18, - scc_state_wr_19, - scc_state_wr_20, - scc_state_wr_21, - scc_state_wr_22, - scc_state_wr_23, - scc_state_wr_24, - scc_state_wr_25, - scc_state_wr_26, - scc_state_wr_27, - scc_state_wr_28, - scc_state_wr_29, - scc_state_wr_30, - scc_state_wr_31, - scc_state_wr_32, - scc_state_wr_33, - scc_state_wr_34, - scc_state_wr_35, - scc_state_wr_36, - scc_state_wr_37, - scc_state_wr_38, - scc_state_wr_39, - scc_state_wr_40, -}; - -static u32 scc_takeover_mode = SCC_TO_IMMEDIATE; - -/* Change mode of the SPDMA for given direction */ -static u32 scc_agu_mode_sp = AGU_BYPASS; - -/* Change mode of the USB for given direction */ -static u32 scc_agu_mode_usb = AGU_BYPASS; - -static union scc_softwareconfiguration scc_software_configuration[SCC_MAX]; - -static u32 dma_fsm[4][4] = { - /* DMA_CMD_RESET DMA_CMD_SETUP DMA_CMD_START DMA_CMD_STOP */ - /* DMA_STATE_RESET */ - {DMA_STATE_RESET, DMA_STATE_SETUP, DMA_STATE_ERROR, DMA_STATE_ERROR}, - /* DMA_STATE_SETUP */ - {DMA_STATE_RESET, DMA_STATE_SETUP, DMA_STATE_START, DMA_STATE_SETUP}, - /* DMA_STATE_START */ - {DMA_STATE_RESET, DMA_STATE_ERROR, DMA_STATE_START, DMA_STATE_SETUP}, - /* DMA_STATE_ERROR */ - {DMA_STATE_RESET, DMA_STATE_ERROR, DMA_STATE_ERROR, DMA_STATE_ERROR}, -}; - -static void dma_state_process(struct scc_dma_state *dma_state, u32 cmd) -{ - dma_state->dma_status = dma_fsm[dma_state->dma_status][cmd]; - dma_state->dma_cmd = cmd; -} - -static void dma_state_process_dma_command(struct scc_dma_state *dma_state, - u32 dma_cmd) -{ - dma_state->dma_cmd = dma_cmd; - switch (dma_cmd) { - case DMA_START: - case DMA_START_FH_RESET: - dma_state_process(dma_state, DMA_CMD_START); - break; - case DMA_STOP: - dma_state_process(dma_state, DMA_CMD_STOP); - break; - default: - break; - } -} - -static void scc_takeover_dma(enum scc_id id, u32 dma_id, u32 drs) -{ - union scc_cmd dma_cmd; - - dma_cmd.reg = 0; - - /* Prepare the takeover for the DMA channel */ - dma_cmd.bits.action = DMA_TAKEOVER; - dma_cmd.bits.id = dma_id; - dma_cmd.bits.rid = TO_DMA_CFG; /* this is DMA_CFG register takeover */ - if (drs == DMA_WRITE) - dma_cmd.bits.drs = DMA_WRITE; - - reg_write(SCC_CMD(scc_descriptor_table[id].base_address), dma_cmd.reg); -} - -int scc_dma_cmd(enum scc_id id, u32 cmd, u32 dma_id, u32 drs) -{ - union scc_cmd dma_cmd; - struct scc_dma_state *dma_state; - - if ((id >= SCC_MAX) || (id < 0)) - return -EINVAL; - - dma_cmd.reg = 0; - - /* Prepare the takeover for the DMA channel */ - dma_cmd.bits.action = cmd; - dma_cmd.bits.id = dma_id; - if (drs == DMA_WRITE) { - dma_cmd.bits.drs = DMA_WRITE; - dma_state = &scc_state_wr[id][dma_id]; - } else { - dma_state = &scc_state_rd[id][dma_id]; - } - - dma_state->scc_id = id; - dma_state->dma_id = dma_id; - dma_state_process_dma_command(dma_state, cmd); - - reg_write(SCC_CMD(scc_descriptor_table[id].base_address), dma_cmd.reg); - - return 0; -} - -int scc_set_usb_address_generation_mode(u32 agu_mode) -{ - if (AGU_ACTIVE == agu_mode) { - /* Ensure both DMAs are stopped */ - scc_dma_cmd(SCC_USB_RW, DMA_STOP, 0, DMA_WRITE); - scc_dma_cmd(SCC_USB_RW, DMA_STOP, 0, DMA_READ); - } else { - agu_mode = AGU_BYPASS; - } - - scc_agu_mode_usb = agu_mode; - - return 0; -} - -int scc_setup_dma(enum scc_id id, u32 buffer_tag, - u32 type, u32 fh_mode, u32 drs, u32 dma_id) -{ - struct scc_dma_state *dma_state; - int return_value = 0; - union scc_dma_cfg dma_cfg; - u32 *buffer_tag_list; - u32 tag_count, t, t_valid; - - if ((id >= SCC_MAX) || (id < 0)) - return -EINVAL; - - buffer_tag_list = scc_descriptor_table[id].buffer_tag_list; - - /* if the register is only configured by hw, cannot write! */ - if (1 == scc_descriptor_table[id].hw_dma_cfg) - return -EACCES; - - if (DMA_WRITE == drs) { - if (dma_id >= scc_descriptor_table[id].p_dma_channels_wr) - return -EINVAL; - dma_state = &scc_state_wr[id][dma_id]; - } else { - if (dma_id >= scc_descriptor_table[id].p_dma_channels_rd) - return -EINVAL; - dma_state = &scc_state_rd[id][dma_id]; - } - - /* Compose the DMA configuration register */ - tag_count = buffer_tag_list[0]; - t_valid = 0; - for (t = 1; t <= tag_count; t++) { - if (buffer_tag == buffer_tag_list[t]) { - /* Tag found - validate */ - t_valid = 1; - break; - } - } - - if (!t_valid) - return -EACCES; - - /* - * Read the register first -- two functions write into the register - * it does not make sense to read the DMA config back, because there - * are two register configuration sets (drs) - */ - dma_cfg.reg = 0; - dma_cfg.bits.buffer_id = buffer_tag; - dma_state_process(dma_state, DMA_CMD_SETUP); - - /* - * This is Packet CFG set select - usable for TSIO, EBI and those SCCs - * which habe 2 packet configs - */ - dma_cfg.bits.packet_cfg_id = - scc_software_configuration[id].bits.packet_select; - - if (type == DMA_CYCLIC) - dma_cfg.bits.buffer_type = 1; - else - dma_cfg.bits.buffer_type = 0; - - if (fh_mode == USE_FH) - dma_cfg.bits.fh_mode = 1; - else - dma_cfg.bits.fh_mode = 0; - - if (id == SCC_CPU1_SPDMA_RW) - dma_cfg.bits.agu_mode = scc_agu_mode_sp; - - if (id == SCC_USB_RW) - dma_cfg.bits.agu_mode = scc_agu_mode_usb; - - reg_write(SCC_DMA_CFG(scc_descriptor_table[id].base_address), - dma_cfg.reg); - - /* The DMA_CFG needs a takeover! */ - if (SCC_TO_IMMEDIATE == scc_takeover_mode) - scc_takeover_dma(id, dma_id, drs); - - /* if (buffer_tag is not used) */ - dma_state->buffer_tag = buffer_tag; - - dma_state->scc_id = id; - dma_state->dma_id = dma_id; - - return return_value; -} - -int scc_enable(enum scc_id id, u32 value) -{ - if ((id >= SCC_MAX) || (id < 0)) - return -EINVAL; - - if (value == 0) { - scc_software_configuration[id].bits.enable_status = 0; - } else { - value = 1; - scc_software_configuration[id].bits.enable_status = 1; - } - reg_write(SCC_ENABLE(scc_descriptor_table[id].base_address), value); - - return 0; -} - -static inline void ehb(void) -{ - __asm__ __volatile__( - " .set mips32r2 \n" - " ehb \n" - " .set mips0 \n"); -} - -int scc_reset(enum scc_id id, u32 value) -{ - if ((id >= SCC_MAX) || (id < 0)) - return -EINVAL; - - /* Invert value to the strait logic from the negative hardware logic */ - if (value == 0) - value = 1; - else - value = 0; - - /* Write the value to the register */ - reg_write(SCC_RESET(scc_descriptor_table[id].base_address), value); - - /* sync flush */ - asm("sync"); /* request bus write queue flush */ - ehb(); /* wait until previous bus commit instr has finished */ - asm("nop"); /* wait for flush to occur */ - asm("nop"); /* wait for flush to occur */ - - udelay(100); - - return 0; -} diff --git a/board/micronas/vct/scc.h b/board/micronas/vct/scc.h deleted file mode 100644 index 48cae55eee..0000000000 --- a/board/micronas/vct/scc.h +++ /dev/null @@ -1,191 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _SCC_H -#define _SCC_H - -#define DMA_READ 0 /* SCC read DMA */ -#define DMA_WRITE 1 /* SCC write DMA */ - -#define DMA_LINEAR 0 /* DMA linear buffer access method */ -#define DMA_CYCLIC 1 /* DMA cyclic buffer access method */ - -#define DMA_START 0 /* DMA command - start DMA */ -#define DMA_STOP 1 /* DMA command - stop DMA */ -#define DMA_START_FH_RESET 2 /* DMA command - start DMA reset FH */ -#define DMA_TAKEOVER 15 /* DMA command - commit the DMA conf */ - -#define AGU_ACTIVE 0 /* enable AGU address calculation */ -#define AGU_BYPASS 1 /* set AGU to bypass mode */ - -#define USE_NO_FH 0 /* order the DMA to not use FH */ -#define USE_FH 1 /* order the DMA to work with FH*/ - -#define SCC_DBG_IDLE 0 /* DEBUG status (idle interfaces) */ -#define SCC_DBG_SYNC_RES 0x0001 /* synchronuous reset */ - -#define SCC_TO_IMMEDIATE 1 /* takeover command issued immediately*/ -#define TO_DMA_CFG 2 /* takeover command for the DMA config*/ - -#define DMA_CMD_RESET 0 -#define DMA_CMD_SETUP 1 -#define DMA_CMD_START 2 -#define DMA_CMD_STOP 3 - -#define DMA_STATE_RESET 0 -#define DMA_STATE_SETUP 1 -#define DMA_STATE_START 2 -#define DMA_STATE_ERROR 3 - -#define SRMD 0 -#define STRM_D 1 -#define STRM_P 2 - -/* - * Slowest Monterey domain is DVP 27 MHz (324/27 = 12; 12*16 = 192 CPU clocks) - */ -#define RESET_TIME 2 /* cycle calc see in SCC_Reset */ - -struct scc_descriptor { - char *pu_name; /* PU identifier */ - char *scc_instance; /* SCC Name */ - u32 profile; /* SCC VCI_D profile */ - - u32 base_address; /* base address of the SCC unit reg shell*/ - - /* SCS Interconnect configuration */ - u32 p_scc_id; /* instance number of SCC unit */ - u32 p_mci_id; /* memory channel ID */ - - /* DMA Registers configuration */ - u32 p_dma_channels_rd; /* Number of Read DMA channels */ - u32 p_dma_channels_wr; /* Number of Write DMA channels */ - - u32 p_dma_packet_desc; /* Number of packet descriptors */ - u32 p_dma_mci_desc; /* Number of MCI_CFG Descriptors */ - - int use_fh; /* the flag tells if SCC uses an FH */ - - int p_si2ocp_id; /* instance number of SI2OCP unit */ - int hw_dma_cfg; /* HW or SW DMA config flag */ - int hw_dma_start; /* HW or SW DMA start/stop flag */ - - u32 *buffer_tag_list; /* list of the buffer tags available */ - u32 *csize_list; /* list of the valid CSIZE values */ -}; - -struct scc_dma_state { - u32 scc_id:8; /* SCC id */ - u32 dma_id:8; /* DMA id, used for match with array idx*/ - u32 buffer_tag:8; /* mem buf tag, assigned to this DMA */ - u32 dma_status:2; /* state of DMA, of the DMA_STATE_ const*/ - u32 dma_drs:2; /* DMA dir, either DMA_READ or DMA_WRITE*/ - u32 dma_cmd:4; /* last executed command on this DMA */ -}; - -union scc_cmd { - u32 reg; - struct { - u32 res1:19; /* reserved */ - u32 drs:1; /* DMA Register Set */ - u32 rid:2; /* Register Identifier */ - u32 id:6; /* DMA Identifier */ - u32 action:4; /* DMA Command encoding */ - } bits; -}; - -union scc_dma_cfg { - u32 reg; - struct { - u32 res1:17; /* reserved */ - u32 agu_mode:1; /* AGU Mode */ - u32 res2:1; /* reserved */ - u32 fh_mode:1; /* Fifo Handler */ - u32 buffer_type:1; /* Defines type of mem buffers */ - u32 mci_cfg_id:1; /* MCI_CFG register selector */ - u32 packet_cfg_id:1; /* PACKET_CFG register selector */ - u32 buffer_id:8; /* DMA Buffer Identifier */ - } bits; -}; - -union scc_debug { - u32 reg; - struct { - u32 res1:20; /* reserved */ - u32 arg:8; /* SCC Debug Command Argument (#) */ - u32 cmd:4; /* SCC Debug Command Register */ - } bits; -}; - -union scc_softwareconfiguration { - u32 reg; - struct { - u32 res1:28; /* reserved */ - u32 clock_status:1; /* clock on/off */ - u32 packet_select:1; /* active SCC packet id */ - u32 enable_status:1; /* enabled [1/0] */ - u32 active_status:1; /* 1=active 0=reset */ - } bits; -}; - -/* - * System on Chip Channel ID - */ -enum scc_id { - SCC_NULL = -1, /* illegal SCC identifier */ - SCC_FE_3DCOMB_WR, /* SCC_FE_3DCOMB Write channel */ - SCC_FE_3DCOMB_RD, /* SCC_FE_3DCOMB Read channel */ - SCC_DI_TNR_WR, /* SCC_DI_TNR Write channel */ - SCC_DI_TNR_FIELD_RD, /* SCC_DI_TNR_FIELD Read channel */ - SCC_DI_TNR_FRAME_RD, /* SCC_DI_TNR_FRAME Read channel */ - SCC_DI_MVAL_WR, /* SCC_DI_MVAL Write channel */ - SCC_DI_MVAL_RD, /* SCC_DI_MVAL Read channel */ - SCC_RC_FRAME_WR, /* SCC_RC_FRAME Write channel */ - SCC_RC_FRAME0_RD, /* SCC_RC_FRAME0 Read channel */ - SCC_OPT_FIELD0_RD, /* SCC_OPT_FIELD0 Read channel */ - SCC_OPT_FIELD1_RD, /* SCC_OPT_FIELD1 Read channel */ - SCC_OPT_FIELD2_RD, /* SCC_OPT_FIELD2 Read channel */ - SCC_PIP_FRAME_WR, /* SCC_PIP_FRAME Write channel */ - SCC_PIP_FRAME_RD, /* SCC_PIP_FRAME Read channel */ - SCC_DP_AGPU_RD, /* SCC_DP_AGPU Read channel */ - SCC_EWARP_RW, /* SCC_EWARP Read/Write channel */ - SCC_DP_OSD_RD, /* SCC_DP_OSD Read channel */ - SCC_DP_GRAPHIC_RD, /* SCC_DP_GRAPHIC Read channel */ - SCC_DVP_OSD_RD, /* SCC_DVP_OSD Read channel */ - SCC_DVP_VBI_RD, /* SCC_DVP_VBI Read channel */ - SCC_TSIO_WR, /* SCC_TSIO Write channel */ - SCC_TSIO_RD, /* SCC_TSIO Read channel */ - SCC_TSD_WR, /* SCC_TSD Write channel */ - SCC_VD_UD_ST_RW, /* SCC_VD_UD_ST Read/Write channel */ - SCC_VD_FRR_RD, /* SCC_VD_FRR Read channel */ - SCC_VD_FRW_DISP_WR, /* SCC_VD_FRW_DISP Write channel */ - SCC_MR_VD_M_Y_RD, /* SCC_MR_VD_M_Y Read channel */ - SCC_MR_VD_M_C_RD, /* SCC_MR_VD_M_C Read channel */ - SCC_MR_VD_S_Y_RD, /* SCC_MR_VD_S_Y Read channel */ - SCC_MR_VD_S_C_RD, /* SCC_MR_VD_S_C Read channel */ - SCC_GA_WR, /* SCC_GA Write channel */ - SCC_GA_SRC1_RD, /* SCC_GA_SRC1 Read channel */ - SCC_GA_SRC2_RD, /* SCC_GA_SRC2 Read channel */ - SCC_AD_RD, /* SCC_AD Read channel */ - SCC_AD_WR, /* SCC_AD Write channel */ - SCC_ABP_RD, /* SCC_ABP Read channel */ - SCC_ABP_WR, /* SCC_ABP Write channel */ - SCC_EBI_RW, /* SCC_EBI Read/Write channel */ - SCC_USB_RW, /* SCC_USB Read/Write channel */ - SCC_CPU1_SPDMA_RW, /* SCC_CPU1_SPDMA Read/Write channel */ - SCC_CPU1_BRIDGE_RW, /* SCC_CPU1_BRIDGE Read/Write channel */ - SCC_MAX /* maximum limit on the SCC id */ -}; - -int scc_set_usb_address_generation_mode(u32 agu_mode); -int scc_dma_cmd(enum scc_id id, u32 cmd, u32 dma_id, u32 drs); -int scc_setup_dma(enum scc_id id, u32 buffer_tag, - u32 type, u32 fh_mode, u32 drs, u32 dma_id); -int scc_enable(enum scc_id id, u32 value); -int scc_reset(enum scc_id id, u32 value); - -#endif /* _SCC_H */ diff --git a/board/micronas/vct/smc_eeprom.c b/board/micronas/vct/smc_eeprom.c deleted file mode 100644 index b5a552134e..0000000000 --- a/board/micronas/vct/smc_eeprom.c +++ /dev/null @@ -1,394 +0,0 @@ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright 2005, Seagate Technology LLC - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -#undef DEBUG - -#include <common.h> -#include <command.h> -#include <config.h> -#include <net.h> - -#include "vct.h" - -#define SMSC9118_BASE CONFIG_DRIVER_SMC911X_BASE -#define BYTE_TEST (SMSC9118_BASE + 0x64) -#define GPIO_CFG (SMSC9118_BASE + 0x88) -#define MAC_CSR_CMD (SMSC9118_BASE + 0xA4) -#define MAC_CSR_CMD_CSR_BUSY (0x80000000) -#define MAC_CSR_CMD_RNW (0x40000000) -#define MAC_RD_CMD(reg) ((reg & 0x000000FF) | \ - (MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_RNW)) -#define MAC_WR_CMD(reg) ((reg & 0x000000FF) | \ - (MAC_CSR_CMD_CSR_BUSY)) -#define MAC_CSR_DATA (SMSC9118_BASE + 0xA8) -#define E2P_CMD (SMSC9118_BASE + 0xB0) -#define E2P_CMD_EPC_BUSY_ (0x80000000UL) /* Self Clearing */ -#define E2P_CMD_EPC_CMD_ (0x70000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_READ_ (0x00000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_EWDS_ (0x10000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_EWEN_ (0x20000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_WRITE_ (0x30000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_WRAL_ (0x40000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_ERASE_ (0x50000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_ERAL_ (0x60000000UL) /* R/W */ -#define E2P_CMD_EPC_CMD_RELOAD_ (0x70000000UL) /* R/W */ -#define E2P_CMD_EPC_TIMEOUT_ (0x00000200UL) /* R */ -#define E2P_CMD_MAC_ADDR_LOADED_ (0x00000100UL) /* RO */ -#define E2P_CMD_EPC_ADDR_ (0x000000FFUL) /* R/W */ -#define E2P_DATA (SMSC9118_BASE + 0xB4) - -#define MAC_ADDRH (0x2) -#define MAC_ADDRL (0x3) - -#define MAC_TIMEOUT 200 - -#define HIBYTE(word) ((u8)(((u16)(word)) >> 8)) -#define LOBYTE(word) ((u8)(((u16)(word)) & 0x00FFU)) -#define HIWORD(dword) ((u16)(((u32)(dword)) >> 16)) -#define LOWORD(dword) ((u16)(((u32)(dword)) & 0x0000FFFFUL)) - -static int mac_busy(int req_to) -{ - int timeout = req_to; - - while (timeout--) { - if (!(smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY)) - goto done; - } - return 1; /* Timeout */ - -done: - return 0; /* No timeout */ -} - -static ulong get_mac_reg(int reg) -{ - ulong reg_val = 0xffffffff; - - if (smc911x_reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) { - printf("get_mac_reg: previous command not complete\n"); - goto done; - } - - smc911x_reg_write(MAC_CSR_CMD, MAC_RD_CMD(reg)); - udelay(10000); - - if (mac_busy(MAC_TIMEOUT) == 1) { - printf("get_mac_reg: timeout waiting for response from MAC\n"); - goto done; - } - - reg_val = smc911x_reg_read(MAC_CSR_DATA); - -done: - return (reg_val); -} - -static ulong eeprom_enable_access(void) -{ - ulong gpio; - - gpio = smc911x_reg_read(GPIO_CFG); - debug("%s: gpio= 0x%08lx ---> 0x%08lx\n", __func__, gpio, - (gpio & 0xFF0FFFFFUL)); - - smc911x_reg_write(GPIO_CFG, (gpio & 0xFF0FFFFFUL)); - return gpio; -} - -static void eeprom_disable_access(ulong gpio) -{ - debug("%s: gpio= 0x%08lx\n", __func__, gpio); - smc911x_reg_write(GPIO_CFG, gpio); -} - -static int eeprom_is_mac_address_loaded(void) -{ - int ret; - - ret = smc911x_reg_read(MAC_CSR_CMD) & E2P_CMD_MAC_ADDR_LOADED_; - debug("%s: ret = %x\n", __func__, ret); - - return ret; -} - -static int eeprom_read_location(unchar address, u8 *data) -{ - ulong timeout = 100000; - ulong temp = 0; - - if ((temp = smc911x_reg_read(E2P_CMD)) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start, E2P_CMD=0x%08lX\n", __func__, temp); - return 0; - } - - smc911x_reg_write(E2P_CMD, - (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_READ_ | - ((ulong) address))); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) { - printf("Timeout\n"); - return 0; - } - (*data) = (unchar) (smc911x_reg_read(E2P_DATA)); - debug("%s: ret = %x\n", __func__, (*data)); - - return 1; -} - -static int eeprom_enable_erase_and_write(void) -{ - ulong timeout = 100000; - - if (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start\n", __func__); - return 0; - } - smc911x_reg_write(E2P_CMD, (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_EWEN_)); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) { - printf("Timeout[1]\n"); - return 0; - } - - return 1; -} - -static int eeprom_disable_erase_and_write(void) -{ - ulong timeout = 100000; - - if (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start\n", __func__); - return 0; - } - smc911x_reg_write(E2P_CMD, (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_EWDS_)); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) { - printf("Timeout[2]\n"); - return 0; - } - - return 1; -} - -static int eeprom_write_location(unchar address, unchar data) -{ - ulong timeout = 100000; - - debug("%s: address: %x data = %x\n", __func__, address, data); - - if (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start\n", __func__); - return 0; - } - - smc911x_reg_write(E2P_DATA, ((ulong) data)); - smc911x_reg_write(E2P_CMD, - (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_WRITE_ | - ((ulong) address))); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) { - printf("Timeout[3]\n"); - return 0; - } - - return 1; -} - -static int eeprom_erase_all(void) -{ - ulong timeout = 100000; - - if (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start\n", __func__); - return 0; - } - - smc911x_reg_write(E2P_CMD, (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_ERAL_)); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) { - printf("Timeout[4]\n"); - return 0; - } - - return 1; -} - -static int eeprom_reload(void) -{ - ulong timeout = 100000; - - if (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_) { - printf("%s: Busy at start\n", __func__); - return -1; - } - smc911x_reg_write(E2P_CMD, - (E2P_CMD_EPC_BUSY_ | E2P_CMD_EPC_CMD_RELOAD_)); - - while ((timeout > 0) && (smc911x_reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY_)) { - udelay(10); - timeout--; - } - - if (timeout == 0) - return 0; - - return 1; -} - -static int eeprom_save_mac_address(ulong dwHi16, ulong dwLo32) -{ - int result = 0; - - debug("%s: dwHI: 0x%08lx dwLO: %08lx, \n", __func__, dwHi16, dwLo32); - - if (!eeprom_enable_erase_and_write()) - goto DONE; - if (!eeprom_erase_all()) - goto DONE; - if (!eeprom_write_location(0, 0xA5)) - goto DONE; - if (!eeprom_write_location(1, LOBYTE(LOWORD(dwLo32)))) - goto DONE; - if (!eeprom_write_location(2, HIBYTE(LOWORD(dwLo32)))) - goto DONE; - if (!eeprom_write_location(3, LOBYTE(HIWORD(dwLo32)))) - goto DONE; - if (!eeprom_write_location(4, HIBYTE(HIWORD(dwLo32)))) - goto DONE; - if (!eeprom_write_location(5, LOBYTE(LOWORD(dwHi16)))) - goto DONE; - if (!eeprom_write_location(6, HIBYTE(LOWORD(dwHi16)))) - goto DONE; - if (!eeprom_disable_erase_and_write()) - goto DONE; - - result = 1; - -DONE: - return result; -} - -static int do_eeprom_dump(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - unchar data = 0, index = 0; - ulong gpio_old_val; - - gpio_old_val = eeprom_enable_access(); - - printf("EEPROM content: \n"); - for (index = 0; index < 8; index++) { - if (eeprom_read_location(index, &data)) - printf("%02x ", data); - else - printf("FAILED"); - } - - eeprom_disable_access(gpio_old_val); - printf("\n"); - - return 0; -} - -static int do_eeprom_erase_all(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - eeprom_erase_all(); - - return 0; -} - -static int do_eeprom_save_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong hi16, lo32; - unchar ethaddr[6], i; - ulong gpio; - char *tmp, *end; - - tmp = argv[1]; - for (i = 0; i < 6; i++) { - ethaddr[i] = tmp ? simple_strtoul(tmp, &end, 16) : 0; - if (tmp) - tmp = (*end) ? end + 1 : end; - } - - hi16 = (ethaddr[5] << 8) | (ethaddr[4]); - lo32 = (ethaddr[3] << 24) | (ethaddr[2] << 16) | - (ethaddr[1] << 8) | (ethaddr[0]); - - gpio = eeprom_enable_access(); - - eeprom_save_mac_address(hi16, lo32); - - eeprom_reload(); - - /* Check new values */ - if (eeprom_is_mac_address_loaded()) { - ulong mac_hi16, mac_lo32; - - mac_hi16 = get_mac_reg(MAC_ADDRH); - mac_lo32 = get_mac_reg(MAC_ADDRL); - printf("New MAC address: %lx, %lx\n", mac_hi16, mac_lo32); - } else { - printf("Address is not reloaded \n"); - } - eeprom_disable_access(gpio); - - return 0; -} - -U_BOOT_CMD(smcee, 1, 0, do_eeprom_erase_all, - "smcee - Erase content of SMC EEPROM",); - -U_BOOT_CMD(smced, 1, 0, do_eeprom_dump, - "smced - Dump content of SMC EEPROM",); - -U_BOOT_CMD(smcew, 2, 0, do_eeprom_save_mac, - "smcew - Write MAC address to SMC EEPROM\n", - "aa:bb:cc:dd:ee:ff new mac address"); diff --git a/board/micronas/vct/top.c b/board/micronas/vct/top.c deleted file mode 100644 index fa039ee03d..0000000000 --- a/board/micronas/vct/top.c +++ /dev/null @@ -1,275 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> -#include "vct.h" - -typedef union _TOP_PINMUX_t -{ - u32 reg; - struct { - u32 res : 24; /* reserved */ - u32 drive : 2; /* Driver strength */ - u32 slew : 1; /* Slew rate */ - u32 strig : 1; /* Schmitt trigger input*/ - u32 pu_pd : 2; /* Pull up/ pull down */ - u32 funsel : 2; /* Pin function */ - } Bits; -} TOP_PINMUX_t; - -#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) - -static TOP_PINMUX_t top_read_pin(int pin) -{ - TOP_PINMUX_t reg; - - switch (pin) { - case 2: - case 3: - case 6: - case 9: - reg.reg = 0xdeadbeef; - break; - case 4: - reg.reg = reg_read(FWSRAM_TOP_SCL_CFG(FWSRAM_BASE)); - break; - case 5: - reg.reg = reg_read(FWSRAM_TOP_SDA_CFG(FWSRAM_BASE)); - break; - case 7: - reg.reg = reg_read(FWSRAM_TOP_TDO_CFG(FWSRAM_BASE)); - break; - case 8: - reg.reg = reg_read(FWSRAM_TOP_GPIO2_0_CFG(FWSRAM_BASE)); - break; - case 10: - case 11: - case 12: - case 13: - case 14: - case 15: - case 16: - reg.reg = reg_read(FWSRAM_BASE + FWSRAM_TOP_GPIO2_1_CFG_OFFS + - ((pin - 10) * 4)); - break; - default: - reg.reg = reg_read(TOP_BASE + (pin * 4)); - break; - } - - return reg; -} - -static void top_write_pin(int pin, TOP_PINMUX_t reg) -{ - - switch (pin) { - case 4: - reg_write(FWSRAM_TOP_SCL_CFG(FWSRAM_BASE), reg.reg); - break; - case 5: - reg_write(FWSRAM_TOP_SDA_CFG(FWSRAM_BASE), reg.reg); - break; - case 7: - reg_write(FWSRAM_TOP_TDO_CFG(FWSRAM_BASE), reg.reg); - break; - case 8: - reg_write(FWSRAM_TOP_GPIO2_0_CFG(FWSRAM_BASE), reg.reg); - break; - case 10: - case 11: - case 12: - case 13: - case 14: - case 15: - case 16: - reg_write(FWSRAM_BASE + FWSRAM_TOP_GPIO2_1_CFG_OFFS + - ((pin - 10) * 4), reg.reg); - break; - default: - reg_write(TOP_BASE + (pin * 4), reg.reg); - break; - } -} - -int top_set_pin(int pin, int func) -{ - TOP_PINMUX_t reg; - - /* check global range */ - if ((pin < 0) || (pin > 170) || (func < 0) || (func > 3)) - return -1; /* pin number or function out of valid range */ - - /* check undefined values; */ - if ((pin == 2) || (pin == 3) || (pin == 6) || (pin == 9)) - return -1; /* pin number out of valid range */ - - reg = top_read_pin(pin); - reg.Bits.funsel = func; - top_write_pin(pin, reg); - - return 0; -} - -#endif - -#if defined(CONFIG_VCT_PLATINUMAVC) - -int top_set_pin(int pin, int func) -{ - TOP_PINMUX_t reg; - - /* check global range */ - if ((pin < 0) || (pin > 158)) - return -1; /* pin number or function out of valid range */ - - reg.reg = reg_read(TOP_BASE + (pin * 4)); - reg.Bits.funsel = func; - reg_write(TOP_BASE + (pin * 4), reg.reg); - - return 0; -} - -#endif - -void vct_pin_mux_initialize(void) -{ -#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) - top_set_pin(34, 01); /* EBI_CS0 */ - top_set_pin(33, 01); /* EBI_CS1 */ - top_set_pin(32, 01); /* EBI_CS2 */ - top_set_pin(100, 02); /* EBI_CS3 */ - top_set_pin(101, 02); /* EBI_CS4 */ - top_set_pin(102, 02); /* EBI_CS5 */ - top_set_pin(103, 02); /* EBI_CS6 */ - top_set_pin(104, 02); /* EBI_CS7 top_set_pin(104,03); EBI_GENIO3 */ - top_set_pin(35, 01); /* EBI_ALE */ - top_set_pin(36, 01); /* EBI_ADDR15 */ - top_set_pin(37, 01); /* EBI_ADDR14 top_set_pin(78,03); EBI_ADDR14 */ - top_set_pin(38, 01); /* EBI_ADDR13 */ - top_set_pin(39, 01); /* EBI_ADDR12 */ - top_set_pin(40, 01); /* EBI_ADDR11 */ - top_set_pin(41, 01); /* EBI_ADDR10 */ - top_set_pin(42, 01); /* EBI_ADDR9 */ - top_set_pin(43, 01); /* EBI_ADDR8 */ - top_set_pin(44, 01); /* EBI_ADDR7 */ - top_set_pin(45, 01); /* EBI_ADDR6 */ - top_set_pin(46, 01); /* EBI_ADDR5 */ - top_set_pin(47, 01); /* EBI_ADDR4 */ - top_set_pin(48, 01); /* EBI_ADDR3 */ - top_set_pin(49, 01); /* EBI_ADDR2 */ - top_set_pin(50, 01); /* EBI_ADDR1 */ - top_set_pin(51, 01); /* EBI_ADDR0 */ - top_set_pin(52, 01); /* EBI_DIR */ - top_set_pin(53, 01); /* EBI_DAT15 top_set_pin(81,01); EBI_DAT15 */ - top_set_pin(54, 01); /* EBI_DAT14 top_set_pin(82,01); EBI_DAT14 */ - top_set_pin(55, 01); /* EBI_DAT13 top_set_pin(83,01); EBI_DAT13 */ - top_set_pin(56, 01); /* EBI_DAT12 top_set_pin(84,01); EBI_DAT12 */ - top_set_pin(57, 01); /* EBI_DAT11 top_set_pin(85,01); EBI_DAT11 */ - top_set_pin(58, 01); /* EBI_DAT10 top_set_pin(86,01); EBI_DAT10 */ - top_set_pin(59, 01); /* EBI_DAT9 top_set_pin(87,01); EBI_DAT9 */ - top_set_pin(60, 01); /* EBI_DAT8 top_set_pin(88,01); EBI_DAT8 */ - top_set_pin(61, 01); /* EBI_DAT7 */ - top_set_pin(62, 01); /* EBI_DAT6 */ - top_set_pin(63, 01); /* EBI_DAT5 */ - top_set_pin(64, 01); /* EBI_DAT4 */ - top_set_pin(65, 01); /* EBI_DAT3 */ - top_set_pin(66, 01); /* EBI_DAT2 */ - top_set_pin(67, 01); /* EBI_DAT1 */ - top_set_pin(68, 01); /* EBI_DAT0 */ - top_set_pin(69, 01); /* EBI_IORD */ - top_set_pin(70, 01); /* EBI_IOWR */ - top_set_pin(71, 01); /* EBI_WE */ - top_set_pin(72, 01); /* EBI_OE */ - top_set_pin(73, 01); /* EBI_IORDY */ - top_set_pin(95, 02); /* EBI_EBI_DMACK*/ - top_set_pin(112, 02); /* EBI_IRQ0 */ - top_set_pin(111, 02); /* EBI_IRQ1 top_set_pin(111,03); EBI_DMARQ */ - top_set_pin(107, 02); /* EBI_IRQ2 */ - top_set_pin(108, 02); /* EBI_IRQ3 */ - top_set_pin(30, 01); /* EBI_GENIO1 top_set_pin(99,03); EBI_GENIO1 */ - top_set_pin(31, 01); /* EBI_GENIO2 top_set_pin(98,03); EBI_GENIO2 */ - top_set_pin(105, 02); /* EBI_GENIO3 top_set_pin(104,03); EBI_GENIO3 */ - top_set_pin(106, 02); /* EBI_GENIO4 top_set_pin(144,02); EBI_GENIO4 */ - top_set_pin(109, 02); /* EBI_GENIO5 top_set_pin(142,02); EBI_GENIO5 */ - top_set_pin(110, 02); /* EBI_BURST_CLK */ -#endif - -#if defined(CONFIG_VCT_PLATINUMAVC) - top_set_pin(19, 01); /* EBI_CS0 */ - top_set_pin(18, 01); /* EBI_CS1 */ - top_set_pin(17, 01); /* EBI_CS2 */ - top_set_pin(92, 02); /* EBI_CS3 */ - top_set_pin(93, 02); /* EBI_CS4 */ - top_set_pin(95, 02); /* EBI_CS6 */ - top_set_pin(96, 02); /* EBI_CS7 top_set_pin(104,03); EBI_GENIO3 */ - top_set_pin(20, 01); /* EBI_ALE */ - top_set_pin(21, 01); /* EBI_ADDR15 */ - top_set_pin(22, 01); /* EBI_ADDR14 top_set_pin(78,03); EBI_ADDR14 */ - top_set_pin(23, 01); /* EBI_ADDR13 */ - top_set_pin(24, 01); /* EBI_ADDR12 */ - top_set_pin(25, 01); /* EBI_ADDR11 */ - top_set_pin(26, 01); /* EBI_ADDR10 */ - top_set_pin(27, 01); /* EBI_ADDR9 */ - top_set_pin(28, 01); /* EBI_ADDR8 */ - top_set_pin(29, 01); /* EBI_ADDR7 */ - top_set_pin(30, 01); /* EBI_ADDR6 */ - top_set_pin(31, 01); /* EBI_ADDR5 */ - top_set_pin(32, 01); /* EBI_ADDR4 */ - top_set_pin(33, 01); /* EBI_ADDR3 */ - top_set_pin(34, 01); /* EBI_ADDR2 */ - top_set_pin(35, 01); /* EBI_ADDR1 */ - top_set_pin(36, 01); /* EBI_ADDR0 */ - top_set_pin(37, 01); /* EBI_DIR */ - top_set_pin(38, 01); /* EBI_DAT15 top_set_pin(81,01); EBI_DAT15 */ - top_set_pin(39, 01); /* EBI_DAT14 top_set_pin(82,01); EBI_DAT14 */ - top_set_pin(40, 01); /* EBI_DAT13 top_set_pin(83,01); EBI_DAT13 */ - top_set_pin(41, 01); /* EBI_DAT12 top_set_pin(84,01); EBI_DAT12 */ - top_set_pin(42, 01); /* EBI_DAT11 top_set_pin(85,01); EBI_DAT11 */ - top_set_pin(43, 01); /* EBI_DAT10 top_set_pin(86,01); EBI_DAT10 */ - top_set_pin(44, 01); /* EBI_DAT9 top_set_pin(87,01); EBI_DAT9 */ - top_set_pin(45, 01); /* EBI_DAT8 top_set_pin(88,01); EBI_DAT8 */ - top_set_pin(46, 01); /* EBI_DAT7 */ - top_set_pin(47, 01); /* EBI_DAT6 */ - top_set_pin(48, 01); /* EBI_DAT5 */ - top_set_pin(49, 01); /* EBI_DAT4 */ - top_set_pin(50, 01); /* EBI_DAT3 */ - top_set_pin(51, 01); /* EBI_DAT2 */ - top_set_pin(52, 01); /* EBI_DAT1 */ - top_set_pin(53, 01); /* EBI_DAT0 */ - top_set_pin(54, 01); /* EBI_IORD */ - top_set_pin(55, 01); /* EBI_IOWR */ - top_set_pin(56, 01); /* EBI_WE */ - top_set_pin(57, 01); /* EBI_OE */ - top_set_pin(58, 01); /* EBI_IORDY */ - top_set_pin(87, 02); /* EBI_EBI_DMACK*/ - top_set_pin(106, 02); /* EBI_IRQ0 */ - top_set_pin(105, 02); /* EBI_IRQ1 top_set_pin(111,03); EBI_DMARQ */ - top_set_pin(101, 02); /* EBI_IRQ2 */ - top_set_pin(102, 02); /* EBI_IRQ3 */ - top_set_pin(15, 01); /* EBI_GENIO1 top_set_pin(99,03); EBI_GENIO1 */ - top_set_pin(16, 01); /* EBI_GENIO2 top_set_pin(98,03); EBI_GENIO2 */ - top_set_pin(99, 02); /* EBI_GENIO3 top_set_pin(104,03); EBI_GENIO3 */ - top_set_pin(100, 02); /* EBI_GENIO4 top_set_pin(144,02); EBI_GENIO4 */ - top_set_pin(103, 02); /* EBI_GENIO5 top_set_pin(142,02); EBI_GENIO5 */ - top_set_pin(104, 02); /* EBI_BURST_CLK */ -#endif - - /* I2C: Configure I2C-2 as GPIO to enable soft-i2c */ - top_set_pin(0, 2); /* SCL2 on GPIO 11 */ - top_set_pin(1, 2); /* SDA2 on GPIO 10 */ - - /* UART pins */ -#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) - top_set_pin(141, 1); - top_set_pin(143, 1); -#endif -#if defined(CONFIG_VCT_PLATINUMAVC) - top_set_pin(107, 1); - top_set_pin(109, 1); -#endif -} diff --git a/board/micronas/vct/vct.c b/board/micronas/vct/vct.c deleted file mode 100644 index e73d16db3e..0000000000 --- a/board/micronas/vct/vct.c +++ /dev/null @@ -1,119 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <netdev.h> -#include <asm/mipsregs.h> -#include "vct.h" - -#if defined(CONFIG_VCT_PREMIUM) -#define BOARD_NAME "PremiumD" -#elif defined(CONFIG_VCT_PLATINUM) -#define BOARD_NAME "PlatinumD" -#elif defined(CONFIG_VCT_PLATINUMAVC) -#define BOARD_NAME "PlatinumAVC" -#else -#error "vct: No board variant defined!" -#endif - -#if defined(CONFIG_VCT_ONENAND) -#define BOARD_NAME_ADD " OneNAND" -#else -#define BOARD_NAME_ADD " NOR" -#endif - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - /* - * First initialize the PIN mulitplexing - */ - vct_pin_mux_initialize(); - - /* - * Init the EBI very early so that FLASH can be accessed - */ - ebi_initialize(); - - return 0; -} - -void _machine_restart(void) -{ - reg_write(DCGU_EN_WDT_RESET(DCGU_BASE), DCGU_MAGIC_WDT); - reg_write(WDT_TORR(WDT_BASE), 0x00); - reg_write(WDT_CR(WDT_BASE), 0x1D); - - /* - * Now wait for the watchdog to trigger the reset - */ - udelay(1000000); -} - -/* - * SDRAM is already configured by the bootstrap code, only return the - * auto-detected size here - */ -int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, - CONFIG_SYS_MBYTES_SDRAM << 20); - - return 0; -} - -int checkboard(void) -{ - char buf[64]; - int i = env_get_f("serial#", buf, sizeof(buf)); - u32 config0 = read_c0_prid(); - - if ((config0 & 0xff0000) == PRID_COMP_LEGACY - && (config0 & 0xff00) == PRID_IMP_LX4280) { - puts("Board: MDED \n"); - printf("CPU: LX4280 id: 0x%02x, rev: 0x%02x\n", - (config0 >> 8) & 0xFF, config0 & 0xFF); - } else if ((config0 & 0xff0000) == PRID_COMP_MIPS - && (config0 & 0xff00) == PRID_IMP_VGC) { - u32 jedec_id = *((u32 *) 0xBEBC71A0); - if ((((jedec_id) >> 12) & 0xFF) == 0x40) { - puts("Board: VGCA \n"); - } else if ((((jedec_id) >> 12) & 0xFF) == 0x48 - || (((jedec_id) >> 12) & 0xFF) == 0x49) { - puts("Board: VGCB \n"); - } - printf("CPU: MIPS 4K id: 0x%02x, rev: 0x%02x\n", - (config0 >> 8) & 0xFF, config0 & 0xFF); - } else if (config0 == 0x19378) { - printf("CPU: MIPS 24K id: 0x%02x, rev: 0x%02x\n", - (config0 >> 8) & 0xFF, config0 & 0xFF); - } else { - printf("Unsupported cpu %d, proc_id=0x%x\n", config0 >> 24, - config0); - } - - printf("Board: Micronas VCT " BOARD_NAME BOARD_NAME_ADD); - if (i > 0) { - puts(", serial# "); - puts(buf); - } - putc('\n'); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC911X - rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); -#endif - return rc; -} diff --git a/board/micronas/vct/vct.h b/board/micronas/vct/vct.h deleted file mode 100644 index 22b35b2c5b..0000000000 --- a/board/micronas/vct/vct.h +++ /dev/null @@ -1,92 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#include <asm/io.h> - -#include "bcu.h" -#include "dcgu.h" -#include "ebi.h" -#include "scc.h" - -#ifdef CONFIG_VCT_PREMIUM -/* Global start address of all memory mapped registers */ -#define REG_GLOBAL_START_ADDR 0xbf800000 -#define TOP_BASE 0x000c8000 - -#include "vcth/reg_ebi.h" -#include "vcth/reg_dcgu.h" -#include "vcth/reg_wdt.h" -#include "vcth/reg_gpio.h" -#include "vcth/reg_fwsram.h" -#include "vcth/reg_scc.h" -#include "vcth/reg_usbh.h" -#endif - -#ifdef CONFIG_VCT_PLATINUM -/* Global start address of all memory mapped registers */ -#define REG_GLOBAL_START_ADDR 0xbf800000 -#define TOP_BASE 0x000c8000 - -#include "vcth2/reg_ebi.h" -#include "vcth/reg_dcgu.h" -#include "vcth/reg_wdt.h" -#include "vcth/reg_gpio.h" -#include "vcth/reg_fwsram.h" -#include "vcth/reg_scc.h" -#include "vcth/reg_usbh.h" -#endif - -#ifdef CONFIG_VCT_PLATINUMAVC -/* Global start address of all memory mapped registers */ -#define REG_GLOBAL_START_ADDR 0xbdc00000 -#define TOP_BASE 0x00050000 - -#include "vctv/reg_ebi.h" -#include "vctv/reg_dcgu.h" -#include "vctv/reg_wdt.h" -#include "vctv/reg_gpio.h" -#endif - -#ifndef _VCT_H -#define _VCT_H - -/* - * Defines - */ -#define PRID_COMP_LEGACY 0x000000 -#define PRID_COMP_MIPS 0x010000 -#define PRID_IMP_LX4280 0xc200 -#define PRID_IMP_VGC 0x9000 - -/* - * Prototypes - */ -int ebi_initialize(void); -int ebi_init_nor_flash(void); -int ebi_init_onenand(void); -int ebi_init_smc911x(void); -u32 smc911x_reg_read(u32 addr); -void smc911x_reg_write(u32 addr, u32 data); -int top_set_pin(int pin, int func); -void vct_pin_mux_initialize(void); - -/* - * static inlines - */ -static inline void reg_write(u32 addr, u32 data) -{ - void *reg = (void *)(addr + REG_GLOBAL_START_ADDR); - __raw_writel(data, reg); -} - -static inline u32 reg_read(u32 addr) -{ - const void *reg = (const void *)(addr + REG_GLOBAL_START_ADDR); - return __raw_readl(reg); -} - -#endif /* _VCT_H */ diff --git a/board/micronas/vct/vcth/reg_dcgu.h b/board/micronas/vct/vcth/reg_dcgu.h deleted file mode 100644 index a598ad04bf..0000000000 --- a/board/micronas/vct/vcth/reg_dcgu.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008-2009 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define DCGU_BASE 0x00084000 - -/* Relative offsets of the register adresses */ - -#define DCGU_CLK_EN1_OFFS 0x00000010 -#define DCGU_CLK_EN1(base) ((base) + DCGU_CLK_EN1_OFFS) -#define DCGU_CLK_EN2_OFFS 0x00000014 -#define DCGU_CLK_EN2(base) ((base) + DCGU_CLK_EN2_OFFS) -#define DCGU_RESET_UNIT1_OFFS 0x00000018 -#define DCGU_RESET_UNIT1(base) ((base) + DCGU_RESET_UNIT1_OFFS) -#define DCGU_USBPHY_STAT_OFFS 0x00000054 -#define DCGU_USBPHY_STAT(base) ((base) + DCGU_USBPHY_STAT_OFFS) -#define DCGU_EN_WDT_RESET_OFFS 0x00000064 -#define DCGU_EN_WDT_RESET(base) ((base) + DCGU_EN_WDT_RESET_OFFS) - -/* The magic value to write in order to activate the WDT */ -#define DCGU_MAGIC_WDT 0x1909 diff --git a/board/micronas/vct/vcth/reg_ebi.h b/board/micronas/vct/vcth/reg_ebi.h deleted file mode 100644 index a2a36489dc..0000000000 --- a/board/micronas/vct/vcth/reg_ebi.h +++ /dev/null @@ -1,228 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _REG_EBI_PREMIUM_H_ -#define _REG_EBI_PREMIUM_H_ - -#define EBI_BASE 0x00000000 - -/* Relative offsets of the register adresses */ - -#define EBI_CPU_IO_ACCS_OFFS 0x00000000 -#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) -#define EBI_IO_ACCS_DATA_OFFS 0x00000004 -#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) -#define EBI_CTRL_OFFS 0x00000008 -#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) -#define EBI_IRQ_MASK_OFFS 0x00000010 -#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) -#define EBI_TAG1_SYS_ID_OFFS 0x00000030 -#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) -#define EBI_TAG2_SYS_ID_OFFS 0x00000040 -#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) -#define EBI_TAG3_SYS_ID_OFFS 0x00000050 -#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) -#define EBI_TAG4_SYS_ID_OFFS 0x00000060 -#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) -#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 -#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) -#define EBI_STATUS_OFFS 0x00000080 -#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) -#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 -#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) -#define EBI_SIG_LEVEL_OFFS 0x00000088 -#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) -#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C -#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) -#define EBI_EXT_ADDR_OFFS 0x000000A0 -#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) -#define EBI_IRQ_STATUS_OFFS 0x000000B0 -#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) -#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 -#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) -#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 -#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) -#define EBI_DEV1_CONFIG1_OFFS 0x00000108 -#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) -#define EBI_DEV1_CONFIG2_OFFS 0x0000010C -#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) -#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 -#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) -#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 -#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) -#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 -#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) -#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C -#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) -#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 -#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) -#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 -#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) -#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C -#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) -#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 -#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) -#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 -#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) -#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 -#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) -#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C -#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) -#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 -#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) -#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 -#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) -#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 -#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) -#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 -#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) -#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 -#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) -#define EBI_DEV2_CONFIG1_OFFS 0x00000208 -#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) -#define EBI_DEV2_CONFIG2_OFFS 0x0000020C -#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) -#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 -#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) -#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 -#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) -#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 -#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) -#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C -#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) -#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 -#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) -#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 -#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) -#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C -#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) -#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 -#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) -#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 -#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) -#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 -#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) -#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C -#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) -#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 -#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) -#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 -#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) -#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 -#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) -#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 -#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) -#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 -#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) -#define EBI_DEV3_CONFIG1_OFFS 0x00000308 -#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) -#define EBI_DEV3_CONFIG2_OFFS 0x0000030C -#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) -#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 -#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) -#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 -#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) -#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 -#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) -#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C -#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) -#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 -#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) -#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 -#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) -#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C -#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) -#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 -#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) -#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 -#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) -#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 -#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) -#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C -#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) -#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 -#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) -#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 -#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) -#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 -#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) -#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 -#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) -#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 -#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) -#define EBI_DEV4_CONFIG1_OFFS 0x00000408 -#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) -#define EBI_DEV4_CONFIG2_OFFS 0x0000040C -#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) -#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 -#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) -#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 -#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) -#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 -#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) -#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C -#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) -#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 -#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) -#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 -#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) -#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C -#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) -#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 -#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) -#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 -#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) -#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 -#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) -#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C -#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) -#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 -#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) -#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 -#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) -#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 -#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) -#define EBI_CNT_FL_PROGR_OFFS 0x00000904 -#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) -#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C -#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) -#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 -#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) -#define EBI_CNT_ACK_OFFS 0x00000918 -#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) -#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 -#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) -#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 -#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) -#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 -#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) -#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 -#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) -#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 -#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) -#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 -#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) -#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 -#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) -#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 -#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) -#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 -#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) -#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 -#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) -#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 -#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) -#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 -#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) -#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 -#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) -#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 -#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) -#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 -#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) - -#endif diff --git a/board/micronas/vct/vcth/reg_fwsram.h b/board/micronas/vct/vcth/reg_fwsram.h deleted file mode 100644 index 6dafa1b304..0000000000 --- a/board/micronas/vct/vcth/reg_fwsram.h +++ /dev/null @@ -1,59 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -/* - * Premium & Platinum register addresses/definitions seem to be - * identical, so we only need to use one file for both platforms. - */ - -#ifndef _REG_FWSRAM_H_ -#define _REG_FWSRAM_H_ - -#define FWSRAM_BASE 0x00030000 - -/* Relative offsets of the register adresses */ - -#define FWSRAM_SR_ADDR_OFFSET_OFFS 0x00002000 -#define FWSRAM_SR_ADDR_OFFSET(base) ((base) + FWSRAM_SR_ADDR_OFFSET_OFFS) -#define FWSRAM_TOP_BOOT_LOG_OFFS 0x00002004 -#define FWSRAM_TOP_BOOT_LOG(base) ((base) + FWSRAM_TOP_BOOT_LOG_OFFS) -#define FWSRAM_TOP_ROM_KBIST_OFFS 0x00002008 -#define FWSRAM_TOP_ROM_KBIST(base) ((base) + FWSRAM_TOP_ROM_KBIST_OFFS) -#define FWSRAM_TOP_CID1_H_OFFS 0x0000200C -#define FWSRAM_TOP_CID1_H(base) ((base) + FWSRAM_TOP_CID1_H_OFFS) -#define FWSRAM_TOP_CID1_L_OFFS 0x00002010 -#define FWSRAM_TOP_CID1_L(base) ((base) + FWSRAM_TOP_CID1_L_OFFS) -#define FWSRAM_TOP_CID2_H_OFFS 0x00002014 -#define FWSRAM_TOP_CID2_H(base) ((base) + FWSRAM_TOP_CID2_H_OFFS) -#define FWSRAM_TOP_CID2_L_OFFS 0x00002018 -#define FWSRAM_TOP_CID2_L(base) ((base) + FWSRAM_TOP_CID2_L_OFFS) -#define FWSRAM_TOP_TDO_CFG_OFFS 0x0000203C -#define FWSRAM_TOP_TDO_CFG(base) ((base) + FWSRAM_TOP_TDO_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_0_CFG_OFFS 0x00002040 -#define FWSRAM_TOP_GPIO2_0_CFG(base) ((base) + FWSRAM_TOP_GPIO2_0_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_1_CFG_OFFS 0x00002044 -#define FWSRAM_TOP_GPIO2_1_CFG(base) ((base) + FWSRAM_TOP_GPIO2_1_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_2_CFG_OFFS 0x00002048 -#define FWSRAM_TOP_GPIO2_2_CFG(base) ((base) + FWSRAM_TOP_GPIO2_2_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_3_CFG_OFFS 0x0000204C -#define FWSRAM_TOP_GPIO2_3_CFG(base) ((base) + FWSRAM_TOP_GPIO2_3_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_4_CFG_OFFS 0x00002050 -#define FWSRAM_TOP_GPIO2_4_CFG(base) ((base) + FWSRAM_TOP_GPIO2_4_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_5_CFG_OFFS 0x00002054 -#define FWSRAM_TOP_GPIO2_5_CFG(base) ((base) + FWSRAM_TOP_GPIO2_5_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_6_CFG_OFFS 0x00002058 -#define FWSRAM_TOP_GPIO2_6_CFG(base) ((base) + FWSRAM_TOP_GPIO2_6_CFG_OFFS) -#define FWSRAM_TOP_GPIO2_7_CFG_OFFS 0x0000205C -#define FWSRAM_TOP_GPIO2_7_CFG(base) ((base) + FWSRAM_TOP_GPIO2_7_CFG_OFFS) -#define FWSRAM_TOP_SCL_CFG_OFFS 0x00002060 -#define FWSRAM_TOP_SCL_CFG(base) ((base) + FWSRAM_TOP_SCL_CFG_OFFS) -#define FWSRAM_TOP_SDA_CFG_OFFS 0x00002064 -#define FWSRAM_TOP_SDA_CFG(base) ((base) + FWSRAM_TOP_SDA_CFG_OFFS) -#define FWSRAM_NO_MCM_FLASH_OFFS 0x00002068 -#define FWSRAM_NO_MCM_FLASH(base) ((base) + FWSRAM_NO_MCM_FLASH_OFFS) - -#endif diff --git a/board/micronas/vct/vcth/reg_gpio.h b/board/micronas/vct/vcth/reg_gpio.h deleted file mode 100644 index 0660200ffa..0000000000 --- a/board/micronas/vct/vcth/reg_gpio.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define GPIO1_BASE 0x00088000 -#define GPIO2_BASE 0x0008c000 - -/* Instances */ -#define GPIO_INSTANCES 2 - -/* Relative offsets of the register adresses */ -#define GPIO_SWPORTA_DR_OFFS 0x00000000 -#define GPIO_SWPORTA_DR(base) ((base) + GPIO_SWPORTA_DR_OFFS) -#define GPIO_SWPORTA_DDR_OFFS 0x00000004 -#define GPIO_SWPORTA_DDR(base) ((base) + GPIO_SWPORTA_DDR_OFFS) -#define GPIO_EXT_PORTA_OFFS 0x00000050 -#define GPIO_EXT_PORTA(base) ((base) + GPIO_EXT_PORTA_OFFS) diff --git a/board/micronas/vct/vcth/reg_scc.h b/board/micronas/vct/vcth/reg_scc.h deleted file mode 100644 index 928ad72434..0000000000 --- a/board/micronas/vct/vcth/reg_scc.h +++ /dev/null @@ -1,88 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _REG_SCC_PREMIUM_H_ -#define _REG_SCC_PREMIUM_H_ - -#define SCC0_BASE 0x00110000 -#define SCC1_BASE 0x00110080 -#define SCC2_BASE 0x00110100 -#define SCC3_BASE 0x00110180 -#define SCC4_BASE 0x00110200 -#define SCC5_BASE 0x00110280 -#define SCC6_BASE 0x00110300 -#define SCC7_BASE 0x00110380 -#define SCC8_BASE 0x00110400 -#define SCC9_BASE 0x00110480 -#define SCC10_BASE 0x00110500 -#define SCC11_BASE 0x00110580 -#define SCC12_BASE 0x00110600 -#define SCC13_BASE 0x00110680 -#define SCC14_BASE 0x00110700 -#define SCC15_BASE 0x00110780 -#define SCC16_BASE 0x00110800 -#define SCC17_BASE 0x00110880 -#define SCC18_BASE 0x00110900 -#define SCC19_BASE 0x00110980 -#define SCC20_BASE 0x00110a00 -#define SCC21_BASE 0x00110a80 -#define SCC22_BASE 0x00110b00 -#define SCC23_BASE 0x00110b80 -#define SCC24_BASE 0x00110c00 -#define SCC25_BASE 0x00110c80 -#define SCC26_BASE 0x00110d00 -#define SCC27_BASE 0x00110d80 -#define SCC28_BASE 0x00110e00 -#define SCC29_BASE 0x00110e80 -#define SCC30_BASE 0x00110f00 -#define SCC31_BASE 0x00110f80 -#define SCC32_BASE 0x00111000 -#define SCC33_BASE 0x00111080 -#define SCC34_BASE 0x00111100 -#define SCC35_BASE 0x00111180 -#define SCC36_BASE 0x00111200 -#define SCC37_BASE 0x00111280 -#define SCC38_BASE 0x00111300 -#define SCC39_BASE 0x00111380 -#define SCC40_BASE 0x00111400 - -/* Relative offsets of the register adresses */ - -#define SCC_ENABLE_OFFS 0x00000000 -#define SCC_ENABLE(base) ((base) + SCC_ENABLE_OFFS) -#define SCC_RESET_OFFS 0x00000004 -#define SCC_RESET(base) ((base) + SCC_RESET_OFFS) -#define SCC_VCID_OFFS 0x00000008 -#define SCC_VCID(base) ((base) + SCC_VCID_OFFS) -#define SCC_MCI_CFG_OFFS 0x0000000C -#define SCC_MCI_CFG(base) ((base) + SCC_MCI_CFG_OFFS) -#define SCC_PACKET_CFG1_OFFS 0x00000010 -#define SCC_PACKET_CFG1(base) ((base) + SCC_PACKET_CFG1_OFFS) -#define SCC_PACKET_CFG2_OFFS 0x00000014 -#define SCC_PACKET_CFG2(base) ((base) + SCC_PACKET_CFG2_OFFS) -#define SCC_PACKET_CFG3_OFFS 0x00000018 -#define SCC_PACKET_CFG3(base) ((base) + SCC_PACKET_CFG3_OFFS) -#define SCC_DMA_CFG_OFFS 0x0000001C -#define SCC_DMA_CFG(base) ((base) + SCC_DMA_CFG_OFFS) -#define SCC_CMD_OFFS 0x00000020 -#define SCC_CMD(base) ((base) + SCC_CMD_OFFS) -#define SCC_PRIO_OFFS 0x00000024 -#define SCC_PRIO(base) ((base) + SCC_PRIO_OFFS) -#define SCC_DEBUG_OFFS 0x00000028 -#define SCC_DEBUG(base) ((base) + SCC_DEBUG_OFFS) -#define SCC_STATUS_OFFS 0x0000002C -#define SCC_STATUS(base) ((base) + SCC_STATUS_OFFS) -#define SCC_IMR_OFFS 0x00000030 -#define SCC_IMR(base) ((base) + SCC_IMR_OFFS) -#define SCC_ISR_OFFS 0x00000034 -#define SCC_ISR(base) ((base) + SCC_ISR_OFFS) -#define SCC_DMA_OFFSET_OFFS 0x00000038 -#define SCC_DMA_OFFSET(base) ((base) + SCC_DMA_OFFSET_OFFS) -#define SCC_RS_CTLSTS_OFFS 0x0000003C -#define SCC_RS_CTLSTS(base) ((base) + SCC_RS_CTLSTS_OFFS) - -#endif diff --git a/board/micronas/vct/vcth/reg_usbh.h b/board/micronas/vct/vcth/reg_usbh.h deleted file mode 100644 index 57f94025e7..0000000000 --- a/board/micronas/vct/vcth/reg_usbh.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2009 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define USBH_BASE 0x00080000 - -/* Relative offsets of the register adresses */ - -#define USBH_CAPLENGTH_OFFS 0x00000100 -#define USBH_CAPLENGTH(base) ((base) + USBH_CAPLENGTH_OFFS) -#define USBH_USBCMD_OFFS 0x00000140 -#define USBH_USBCMD(base) ((base) + USBH_USBCMD_OFFS) -#define USBH_BURSTSIZE_OFFS 0x00000160 -#define USBH_BURSTSIZE(base) ((base) + USBH_BURSTSIZE_OFFS) -#define USBH_USBMODE_OFFS 0x000001A8 -#define USBH_USBMODE(base) ((base) + USBH_USBMODE_OFFS) -#define USBH_USBHMISC_OFFS 0x00000200 -#define USBH_USBHMISC(base) ((base) + USBH_USBHMISC_OFFS) diff --git a/board/micronas/vct/vcth/reg_wdt.h b/board/micronas/vct/vcth/reg_wdt.h deleted file mode 100644 index 84572a1c77..0000000000 --- a/board/micronas/vct/vcth/reg_wdt.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define WDT_BASE 0x000b0000 -#define WDT_CR_OFFS 0x00000000 -#define WDT_CR(base) ((base) + WDT_CR_OFFS) -#define WDT_TORR_OFFS 0x00000004 -#define WDT_TORR(base) ((base) + WDT_TORR_OFFS) diff --git a/board/micronas/vct/vcth2/reg_ebi.h b/board/micronas/vct/vcth2/reg_ebi.h deleted file mode 100644 index ed9368db8b..0000000000 --- a/board/micronas/vct/vcth2/reg_ebi.h +++ /dev/null @@ -1,276 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _REG_EBI_PREMIUM_H_ -#define _REG_EBI_PREMIUM_H_ - -#define EBI_BASE 0x00000000 - -/* Relative offsets of the register adresses */ - -#define EBI_CPU_IO_ACCS_OFFS 0x00000000 -#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) -#define EBI_IO_ACCS_DATA_OFFS 0x00000004 -#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) -#define EBI_CPU_IO_ACCS2_OFFS 0x00000008 -#define EBI_CPU_IO_ACCS2(base) ((base) + EBI_CPU_IO_ACCS2_OFFS) -#define EBI_IO_ACCS2_DATA_OFFS 0x0000000C -#define EBI_IO_ACCS2_DATA(base) ((base) + EBI_IO_ACCS2_DATA_OFFS) -#define EBI_CTRL_OFFS 0x00000010 -#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) -#define EBI_IRQ_MASK_OFFS 0x00000018 -#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) -#define EBI_IRQ_MASK2_OFFS 0x0000001C -#define EBI_IRQ_MASK2(base) ((base) + EBI_IRQ_MASK2_OFFS) -#define EBI_TAG1_SYS_ID_OFFS 0x00000030 -#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) -#define EBI_TAG2_SYS_ID_OFFS 0x00000040 -#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) -#define EBI_TAG3_SYS_ID_OFFS 0x00000050 -#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) -#define EBI_TAG4_SYS_ID_OFFS 0x00000060 -#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) -#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 -#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) -#define EBI_STATUS_OFFS 0x00000080 -#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) -#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 -#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) -#define EBI_SIG_LEVEL_OFFS 0x00000088 -#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) -#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C -#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) -#define EBI_CRC_GEN_OFFS 0x00000090 -#define EBI_CRC_GEN(base) ((base) + EBI_CRC_GEN_OFFS) -#define EBI_EXT_ADDR_OFFS 0x000000A0 -#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) -#define EBI_IRQ_STATUS_OFFS 0x000000B0 -#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) -#define EBI_IRQ_STATUS2_OFFS 0x000000B4 -#define EBI_IRQ_STATUS2(base) ((base) + EBI_IRQ_STATUS2_OFFS) -#define EBI_EXT_MASTER_SRAM_HIGH_OFFS 0x000000C0 -#define EBI_EXT_MASTER_SRAM_HIGH(base) ((base) + EBI_EXT_MASTER_SRAM_HIGH_OFFS) -#define EBI_EXT_MASTER_SRAM_LOW_OFFS 0x000000C4 -#define EBI_EXT_MASTER_SRAM_LOW(base) ((base) + EBI_EXT_MASTER_SRAM_LOW_OFFS) -#define EBI_ECC0_OFFS 0x000000D0 -#define EBI_ECC0(base) ((base) + EBI_ECC0_OFFS) -#define EBI_ECC1_OFFS 0x000000D4 -#define EBI_ECC1(base) ((base) + EBI_ECC1_OFFS) -#define EBI_ECC2_OFFS 0x000000D8 -#define EBI_ECC2(base) ((base) + EBI_ECC2_OFFS) -#define EBI_ECC3_OFFS 0x000000DC -#define EBI_ECC3(base) ((base) + EBI_ECC3_OFFS) -#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 -#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) -#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 -#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) -#define EBI_DEV1_CONFIG1_OFFS 0x00000108 -#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) -#define EBI_DEV1_CONFIG2_OFFS 0x0000010C -#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) -#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 -#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) -#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 -#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) -#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 -#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) -#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C -#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) -#define EBI_DEV1_DMA_ECC_CTRL_OFFS 0x00000120 -#define EBI_DEV1_DMA_ECC_CTRL(base) ((base) + EBI_DEV1_DMA_ECC_CTRL_OFFS) -#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 -#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) -#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 -#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) -#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C -#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) -#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 -#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) -#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 -#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) -#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 -#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) -#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C -#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) -#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 -#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) -#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 -#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) -#define EBI_DEV1_TIM4_UDMA1_OFFS 0x00000148 -#define EBI_DEV1_TIM4_UDMA1(base) ((base) + EBI_DEV1_TIM4_UDMA1_OFFS) -#define EBI_DEV1_TIM4_UDMA2_OFFS 0x0000014C -#define EBI_DEV1_TIM4_UDMA2(base) ((base) + EBI_DEV1_TIM4_UDMA2_OFFS) -#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 -#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) -#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 -#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) -#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 -#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) -#define EBI_DEV2_CONFIG1_OFFS 0x00000208 -#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) -#define EBI_DEV2_CONFIG2_OFFS 0x0000020C -#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) -#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 -#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) -#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 -#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) -#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 -#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) -#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C -#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) -#define EBI_DEV2_DMA_ECC_CTRL_OFFS 0x00000220 -#define EBI_DEV2_DMA_ECC_CTRL(base) ((base) + EBI_DEV2_DMA_ECC_CTRL_OFFS) -#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 -#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) -#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 -#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) -#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C -#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) -#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 -#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) -#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 -#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) -#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 -#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) -#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C -#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) -#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 -#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) -#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 -#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) -#define EBI_DEV2_TIM4_UDMA1_OFFS 0x00000248 -#define EBI_DEV2_TIM4_UDMA1(base) ((base) + EBI_DEV2_TIM4_UDMA1_OFFS) -#define EBI_DEV2_TIM4_UDMA2_OFFS 0x0000024C -#define EBI_DEV2_TIM4_UDMA2(base) ((base) + EBI_DEV2_TIM4_UDMA2_OFFS) -#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 -#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) -#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 -#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) -#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 -#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) -#define EBI_DEV3_CONFIG1_OFFS 0x00000308 -#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) -#define EBI_DEV3_CONFIG2_OFFS 0x0000030C -#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) -#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 -#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) -#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 -#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) -#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 -#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) -#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C -#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) -#define EBI_DEV3_DMA_ECC_CTRL_OFFS 0x00000320 -#define EBI_DEV3_DMA_ECC_CTRL(base) ((base) + EBI_DEV3_DMA_ECC_CTRL_OFFS) -#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 -#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) -#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 -#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) -#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C -#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) -#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 -#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) -#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 -#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) -#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 -#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) -#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C -#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) -#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 -#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) -#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 -#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) -#define EBI_DEV3_TIM4_UDMA1_OFFS 0x00000348 -#define EBI_DEV3_TIM4_UDMA1(base) ((base) + EBI_DEV3_TIM4_UDMA1_OFFS) -#define EBI_DEV3_TIM4_UDMA2_OFFS 0x0000034C -#define EBI_DEV3_TIM4_UDMA2(base) ((base) + EBI_DEV3_TIM4_UDMA2_OFFS) -#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 -#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) -#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 -#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) -#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 -#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) -#define EBI_DEV4_CONFIG1_OFFS 0x00000408 -#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) -#define EBI_DEV4_CONFIG2_OFFS 0x0000040C -#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) -#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 -#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) -#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 -#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) -#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 -#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) -#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C -#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) -#define EBI_DEV4_DMA_ECC_CTRL_OFFS 0x00000420 -#define EBI_DEV4_DMA_ECC_CTRL(base) ((base) + EBI_DEV4_DMA_ECC_CTRL_OFFS) -#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 -#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) -#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 -#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) -#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C -#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) -#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 -#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) -#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 -#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) -#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 -#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) -#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C -#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) -#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 -#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) -#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 -#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) -#define EBI_DEV4_TIM4_UDMA1_OFFS 0x00000448 -#define EBI_DEV4_TIM4_UDMA1(base) ((base) + EBI_DEV4_TIM4_UDMA1_OFFS) -#define EBI_DEV4_TIM4_UDMA2_OFFS 0x0000044C -#define EBI_DEV4_TIM4_UDMA2(base) ((base) + EBI_DEV4_TIM4_UDMA2_OFFS) -#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 -#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) -#define EBI_INTERLEAVE_CNT_OFFS 0x00000900 -#define EBI_INTERLEAVE_CNT(base) ((base) + EBI_INTERLEAVE_CNT_OFFS) -#define EBI_CNT_FL_PROGR_OFFS 0x00000904 -#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) -#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C -#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) -#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 -#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) -#define EBI_CNT_ACK_OFFS 0x00000918 -#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) -#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 -#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) -#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 -#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) -#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 -#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) -#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 -#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) -#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 -#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) -#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 -#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) -#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 -#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) -#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 -#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) -#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 -#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) -#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 -#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) -#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 -#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) -#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 -#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) -#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 -#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) -#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 -#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) -#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 -#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) - -#endif diff --git a/board/micronas/vct/vctv/reg_dcgu.h b/board/micronas/vct/vctv/reg_dcgu.h deleted file mode 100644 index 9e5c6fd64f..0000000000 --- a/board/micronas/vct/vctv/reg_dcgu.h +++ /dev/null @@ -1,11 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define DCGU_BASE 0x0004c000 -#define DCGU_EN_WDT_RESET_OFFS 0x000000FC -#define DCGU_EN_WDT_RESET(base) ((base) + DCGU_EN_WDT_RESET_OFFS) - -/* The magic value to write in order to activate the WDT */ -#define DCGU_MAGIC_WDT 0x1909 diff --git a/board/micronas/vct/vctv/reg_ebi.h b/board/micronas/vct/vctv/reg_ebi.h deleted file mode 100644 index d9b4770a17..0000000000 --- a/board/micronas/vct/vctv/reg_ebi.h +++ /dev/null @@ -1,276 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - * - * Copyright (C) 2006 Micronas GmbH - */ - -#ifndef _REG_EBI_PLATINUMAVC_H_ -#define _REG_EBI_PLATINUMAVC_H_ - -#define EBI_BASE 0x00014000 - -/* Relative offsets of the register adresses */ - -#define EBI_CPU_IO_ACCS_OFFS 0x00000000 -#define EBI_CPU_IO_ACCS(base) ((base) + EBI_CPU_IO_ACCS_OFFS) -#define EBI_IO_ACCS_DATA_OFFS 0x00000004 -#define EBI_IO_ACCS_DATA(base) ((base) + EBI_IO_ACCS_DATA_OFFS) -#define EBI_CPU_IO_ACCS2_OFFS 0x00000008 -#define EBI_CPU_IO_ACCS2(base) ((base) + EBI_CPU_IO_ACCS2_OFFS) -#define EBI_IO_ACCS2_DATA_OFFS 0x0000000C -#define EBI_IO_ACCS2_DATA(base) ((base) + EBI_IO_ACCS2_DATA_OFFS) -#define EBI_CTRL_OFFS 0x00000010 -#define EBI_CTRL(base) ((base) + EBI_CTRL_OFFS) -#define EBI_IRQ_MASK_OFFS 0x00000018 -#define EBI_IRQ_MASK(base) ((base) + EBI_IRQ_MASK_OFFS) -#define EBI_IRQ_MASK2_OFFS 0x0000001C -#define EBI_IRQ_MASK2(base) ((base) + EBI_IRQ_MASK2_OFFS) -#define EBI_TAG1_SYS_ID_OFFS 0x00000030 -#define EBI_TAG1_SYS_ID(base) ((base) + EBI_TAG1_SYS_ID_OFFS) -#define EBI_TAG2_SYS_ID_OFFS 0x00000040 -#define EBI_TAG2_SYS_ID(base) ((base) + EBI_TAG2_SYS_ID_OFFS) -#define EBI_TAG3_SYS_ID_OFFS 0x00000050 -#define EBI_TAG3_SYS_ID(base) ((base) + EBI_TAG3_SYS_ID_OFFS) -#define EBI_TAG4_SYS_ID_OFFS 0x00000060 -#define EBI_TAG4_SYS_ID(base) ((base) + EBI_TAG4_SYS_ID_OFFS) -#define EBI_GEN_DMA_CTRL_OFFS 0x00000070 -#define EBI_GEN_DMA_CTRL(base) ((base) + EBI_GEN_DMA_CTRL_OFFS) -#define EBI_STATUS_OFFS 0x00000080 -#define EBI_STATUS(base) ((base) + EBI_STATUS_OFFS) -#define EBI_STATUS_DMA_CNT_OFFS 0x00000084 -#define EBI_STATUS_DMA_CNT(base) ((base) + EBI_STATUS_DMA_CNT_OFFS) -#define EBI_SIG_LEVEL_OFFS 0x00000088 -#define EBI_SIG_LEVEL(base) ((base) + EBI_SIG_LEVEL_OFFS) -#define EBI_CTRL_SIG_ACTLV_OFFS 0x0000008C -#define EBI_CTRL_SIG_ACTLV(base) ((base) + EBI_CTRL_SIG_ACTLV_OFFS) -#define EBI_CRC_GEN_OFFS 0x00000090 -#define EBI_CRC_GEN(base) ((base) + EBI_CRC_GEN_OFFS) -#define EBI_EXT_ADDR_OFFS 0x000000A0 -#define EBI_EXT_ADDR(base) ((base) + EBI_EXT_ADDR_OFFS) -#define EBI_IRQ_STATUS_OFFS 0x000000B0 -#define EBI_IRQ_STATUS(base) ((base) + EBI_IRQ_STATUS_OFFS) -#define EBI_IRQ_STATUS2_OFFS 0x000000B4 -#define EBI_IRQ_STATUS2(base) ((base) + EBI_IRQ_STATUS2_OFFS) -#define EBI_EXT_MASTER_SRAM_HIGH_OFFS 0x000000C0 -#define EBI_EXT_MASTER_SRAM_HIGH(base) ((base) + EBI_EXT_MASTER_SRAM_HIGH_OFFS) -#define EBI_EXT_MASTER_SRAM_LOW_OFFS 0x000000C4 -#define EBI_EXT_MASTER_SRAM_LOW(base) ((base) + EBI_EXT_MASTER_SRAM_LOW_OFFS) -#define EBI_ECC0_OFFS 0x000000D0 -#define EBI_ECC0(base) ((base) + EBI_ECC0_OFFS) -#define EBI_ECC1_OFFS 0x000000D4 -#define EBI_ECC1(base) ((base) + EBI_ECC1_OFFS) -#define EBI_ECC2_OFFS 0x000000D8 -#define EBI_ECC2(base) ((base) + EBI_ECC2_OFFS) -#define EBI_ECC3_OFFS 0x000000DC -#define EBI_ECC3(base) ((base) + EBI_ECC3_OFFS) -#define EBI_DEV1_DMA_EXT_ADDR_OFFS 0x00000100 -#define EBI_DEV1_DMA_EXT_ADDR(base) ((base) + EBI_DEV1_DMA_EXT_ADDR_OFFS) -#define EBI_DEV1_EXT_ACC_OFFS 0x00000104 -#define EBI_DEV1_EXT_ACC(base) ((base) + EBI_DEV1_EXT_ACC_OFFS) -#define EBI_DEV1_CONFIG1_OFFS 0x00000108 -#define EBI_DEV1_CONFIG1(base) ((base) + EBI_DEV1_CONFIG1_OFFS) -#define EBI_DEV1_CONFIG2_OFFS 0x0000010C -#define EBI_DEV1_CONFIG2(base) ((base) + EBI_DEV1_CONFIG2_OFFS) -#define EBI_DEV1_FIFO_CONFIG_OFFS 0x00000110 -#define EBI_DEV1_FIFO_CONFIG(base) ((base) + EBI_DEV1_FIFO_CONFIG_OFFS) -#define EBI_DEV1_FLASH_CONF_ST_OFFS 0x00000114 -#define EBI_DEV1_FLASH_CONF_ST(base) ((base) + EBI_DEV1_FLASH_CONF_ST_OFFS) -#define EBI_DEV1_DMA_CONFIG1_OFFS 0x00000118 -#define EBI_DEV1_DMA_CONFIG1(base) ((base) + EBI_DEV1_DMA_CONFIG1_OFFS) -#define EBI_DEV1_DMA_CONFIG2_OFFS 0x0000011C -#define EBI_DEV1_DMA_CONFIG2(base) ((base) + EBI_DEV1_DMA_CONFIG2_OFFS) -#define EBI_DEV1_DMA_ECC_CTRL_OFFS 0x00000120 -#define EBI_DEV1_DMA_ECC_CTRL(base) ((base) + EBI_DEV1_DMA_ECC_CTRL_OFFS) -#define EBI_DEV1_TIM1_RD1_OFFS 0x00000124 -#define EBI_DEV1_TIM1_RD1(base) ((base) + EBI_DEV1_TIM1_RD1_OFFS) -#define EBI_DEV1_TIM1_RD2_OFFS 0x00000128 -#define EBI_DEV1_TIM1_RD2(base) ((base) + EBI_DEV1_TIM1_RD2_OFFS) -#define EBI_DEV1_TIM1_WR1_OFFS 0x0000012C -#define EBI_DEV1_TIM1_WR1(base) ((base) + EBI_DEV1_TIM1_WR1_OFFS) -#define EBI_DEV1_TIM1_WR2_OFFS 0x00000130 -#define EBI_DEV1_TIM1_WR2(base) ((base) + EBI_DEV1_TIM1_WR2_OFFS) -#define EBI_DEV1_TIM_EXT_OFFS 0x00000134 -#define EBI_DEV1_TIM_EXT(base) ((base) + EBI_DEV1_TIM_EXT_OFFS) -#define EBI_DEV1_TIM2_CFI_RD1_OFFS 0x00000138 -#define EBI_DEV1_TIM2_CFI_RD1(base) ((base) + EBI_DEV1_TIM2_CFI_RD1_OFFS) -#define EBI_DEV1_TIM2_CFI_RD2_OFFS 0x0000013C -#define EBI_DEV1_TIM2_CFI_RD2(base) ((base) + EBI_DEV1_TIM2_CFI_RD2_OFFS) -#define EBI_DEV1_TIM3_DMA1_OFFS 0x00000140 -#define EBI_DEV1_TIM3_DMA1(base) ((base) + EBI_DEV1_TIM3_DMA1_OFFS) -#define EBI_DEV1_TIM3_DMA2_OFFS 0x00000144 -#define EBI_DEV1_TIM3_DMA2(base) ((base) + EBI_DEV1_TIM3_DMA2_OFFS) -#define EBI_DEV1_TIM4_UDMA1_OFFS 0x00000148 -#define EBI_DEV1_TIM4_UDMA1(base) ((base) + EBI_DEV1_TIM4_UDMA1_OFFS) -#define EBI_DEV1_TIM4_UDMA2_OFFS 0x0000014C -#define EBI_DEV1_TIM4_UDMA2(base) ((base) + EBI_DEV1_TIM4_UDMA2_OFFS) -#define EBI_DEV1_ACK_RM_CNT_OFFS 0x00000150 -#define EBI_DEV1_ACK_RM_CNT(base) ((base) + EBI_DEV1_ACK_RM_CNT_OFFS) -#define EBI_DEV2_DMA_EXT_ADDR_OFFS 0x00000200 -#define EBI_DEV2_DMA_EXT_ADDR(base) ((base) + EBI_DEV2_DMA_EXT_ADDR_OFFS) -#define EBI_DEV2_EXT_ACC_OFFS 0x00000204 -#define EBI_DEV2_EXT_ACC(base) ((base) + EBI_DEV2_EXT_ACC_OFFS) -#define EBI_DEV2_CONFIG1_OFFS 0x00000208 -#define EBI_DEV2_CONFIG1(base) ((base) + EBI_DEV2_CONFIG1_OFFS) -#define EBI_DEV2_CONFIG2_OFFS 0x0000020C -#define EBI_DEV2_CONFIG2(base) ((base) + EBI_DEV2_CONFIG2_OFFS) -#define EBI_DEV2_FIFO_CONFIG_OFFS 0x00000210 -#define EBI_DEV2_FIFO_CONFIG(base) ((base) + EBI_DEV2_FIFO_CONFIG_OFFS) -#define EBI_DEV2_FLASH_CONF_ST_OFFS 0x00000214 -#define EBI_DEV2_FLASH_CONF_ST(base) ((base) + EBI_DEV2_FLASH_CONF_ST_OFFS) -#define EBI_DEV2_DMA_CONFIG1_OFFS 0x00000218 -#define EBI_DEV2_DMA_CONFIG1(base) ((base) + EBI_DEV2_DMA_CONFIG1_OFFS) -#define EBI_DEV2_DMA_CONFIG2_OFFS 0x0000021C -#define EBI_DEV2_DMA_CONFIG2(base) ((base) + EBI_DEV2_DMA_CONFIG2_OFFS) -#define EBI_DEV2_DMA_ECC_CTRL_OFFS 0x00000220 -#define EBI_DEV2_DMA_ECC_CTRL(base) ((base) + EBI_DEV2_DMA_ECC_CTRL_OFFS) -#define EBI_DEV2_TIM1_RD1_OFFS 0x00000224 -#define EBI_DEV2_TIM1_RD1(base) ((base) + EBI_DEV2_TIM1_RD1_OFFS) -#define EBI_DEV2_TIM1_RD2_OFFS 0x00000228 -#define EBI_DEV2_TIM1_RD2(base) ((base) + EBI_DEV2_TIM1_RD2_OFFS) -#define EBI_DEV2_TIM1_WR1_OFFS 0x0000022C -#define EBI_DEV2_TIM1_WR1(base) ((base) + EBI_DEV2_TIM1_WR1_OFFS) -#define EBI_DEV2_TIM1_WR2_OFFS 0x00000230 -#define EBI_DEV2_TIM1_WR2(base) ((base) + EBI_DEV2_TIM1_WR2_OFFS) -#define EBI_DEV2_TIM_EXT_OFFS 0x00000234 -#define EBI_DEV2_TIM_EXT(base) ((base) + EBI_DEV2_TIM_EXT_OFFS) -#define EBI_DEV2_TIM2_CFI_RD1_OFFS 0x00000238 -#define EBI_DEV2_TIM2_CFI_RD1(base) ((base) + EBI_DEV2_TIM2_CFI_RD1_OFFS) -#define EBI_DEV2_TIM2_CFI_RD2_OFFS 0x0000023C -#define EBI_DEV2_TIM2_CFI_RD2(base) ((base) + EBI_DEV2_TIM2_CFI_RD2_OFFS) -#define EBI_DEV2_TIM3_DMA1_OFFS 0x00000240 -#define EBI_DEV2_TIM3_DMA1(base) ((base) + EBI_DEV2_TIM3_DMA1_OFFS) -#define EBI_DEV2_TIM3_DMA2_OFFS 0x00000244 -#define EBI_DEV2_TIM3_DMA2(base) ((base) + EBI_DEV2_TIM3_DMA2_OFFS) -#define EBI_DEV2_TIM4_UDMA1_OFFS 0x00000248 -#define EBI_DEV2_TIM4_UDMA1(base) ((base) + EBI_DEV2_TIM4_UDMA1_OFFS) -#define EBI_DEV2_TIM4_UDMA2_OFFS 0x0000024C -#define EBI_DEV2_TIM4_UDMA2(base) ((base) + EBI_DEV2_TIM4_UDMA2_OFFS) -#define EBI_DEV2_ACK_RM_CNT_OFFS 0x00000250 -#define EBI_DEV2_ACK_RM_CNT(base) ((base) + EBI_DEV2_ACK_RM_CNT_OFFS) -#define EBI_DEV3_DMA_EXT_ADDR_OFFS 0x00000300 -#define EBI_DEV3_DMA_EXT_ADDR(base) ((base) + EBI_DEV3_DMA_EXT_ADDR_OFFS) -#define EBI_DEV3_EXT_ACC_OFFS 0x00000304 -#define EBI_DEV3_EXT_ACC(base) ((base) + EBI_DEV3_EXT_ACC_OFFS) -#define EBI_DEV3_CONFIG1_OFFS 0x00000308 -#define EBI_DEV3_CONFIG1(base) ((base) + EBI_DEV3_CONFIG1_OFFS) -#define EBI_DEV3_CONFIG2_OFFS 0x0000030C -#define EBI_DEV3_CONFIG2(base) ((base) + EBI_DEV3_CONFIG2_OFFS) -#define EBI_DEV3_FIFO_CONFIG_OFFS 0x00000310 -#define EBI_DEV3_FIFO_CONFIG(base) ((base) + EBI_DEV3_FIFO_CONFIG_OFFS) -#define EBI_DEV3_FLASH_CONF_ST_OFFS 0x00000314 -#define EBI_DEV3_FLASH_CONF_ST(base) ((base) + EBI_DEV3_FLASH_CONF_ST_OFFS) -#define EBI_DEV3_DMA_CONFIG1_OFFS 0x00000318 -#define EBI_DEV3_DMA_CONFIG1(base) ((base) + EBI_DEV3_DMA_CONFIG1_OFFS) -#define EBI_DEV3_DMA_CONFIG2_OFFS 0x0000031C -#define EBI_DEV3_DMA_CONFIG2(base) ((base) + EBI_DEV3_DMA_CONFIG2_OFFS) -#define EBI_DEV3_DMA_ECC_CTRL_OFFS 0x00000320 -#define EBI_DEV3_DMA_ECC_CTRL(base) ((base) + EBI_DEV3_DMA_ECC_CTRL_OFFS) -#define EBI_DEV3_TIM1_RD1_OFFS 0x00000324 -#define EBI_DEV3_TIM1_RD1(base) ((base) + EBI_DEV3_TIM1_RD1_OFFS) -#define EBI_DEV3_TIM1_RD2_OFFS 0x00000328 -#define EBI_DEV3_TIM1_RD2(base) ((base) + EBI_DEV3_TIM1_RD2_OFFS) -#define EBI_DEV3_TIM1_WR1_OFFS 0x0000032C -#define EBI_DEV3_TIM1_WR1(base) ((base) + EBI_DEV3_TIM1_WR1_OFFS) -#define EBI_DEV3_TIM1_WR2_OFFS 0x00000330 -#define EBI_DEV3_TIM1_WR2(base) ((base) + EBI_DEV3_TIM1_WR2_OFFS) -#define EBI_DEV3_TIM_EXT_OFFS 0x00000334 -#define EBI_DEV3_TIM_EXT(base) ((base) + EBI_DEV3_TIM_EXT_OFFS) -#define EBI_DEV3_TIM2_CFI_RD1_OFFS 0x00000338 -#define EBI_DEV3_TIM2_CFI_RD1(base) ((base) + EBI_DEV3_TIM2_CFI_RD1_OFFS) -#define EBI_DEV3_TIM2_CFI_RD2_OFFS 0x0000033C -#define EBI_DEV3_TIM2_CFI_RD2(base) ((base) + EBI_DEV3_TIM2_CFI_RD2_OFFS) -#define EBI_DEV3_TIM3_DMA1_OFFS 0x00000340 -#define EBI_DEV3_TIM3_DMA1(base) ((base) + EBI_DEV3_TIM3_DMA1_OFFS) -#define EBI_DEV3_TIM3_DMA2_OFFS 0x00000344 -#define EBI_DEV3_TIM3_DMA2(base) ((base) + EBI_DEV3_TIM3_DMA2_OFFS) -#define EBI_DEV3_TIM4_UDMA1_OFFS 0x00000348 -#define EBI_DEV3_TIM4_UDMA1(base) ((base) + EBI_DEV3_TIM4_UDMA1_OFFS) -#define EBI_DEV3_TIM4_UDMA2_OFFS 0x0000034C -#define EBI_DEV3_TIM4_UDMA2(base) ((base) + EBI_DEV3_TIM4_UDMA2_OFFS) -#define EBI_DEV3_ACK_RM_CNT_OFFS 0x00000350 -#define EBI_DEV3_ACK_RM_CNT(base) ((base) + EBI_DEV3_ACK_RM_CNT_OFFS) -#define EBI_DEV4_DMA_EXT_ADDR_OFFS 0x00000400 -#define EBI_DEV4_DMA_EXT_ADDR(base) ((base) + EBI_DEV4_DMA_EXT_ADDR_OFFS) -#define EBI_DEV4_EXT_ACC_OFFS 0x00000404 -#define EBI_DEV4_EXT_ACC(base) ((base) + EBI_DEV4_EXT_ACC_OFFS) -#define EBI_DEV4_CONFIG1_OFFS 0x00000408 -#define EBI_DEV4_CONFIG1(base) ((base) + EBI_DEV4_CONFIG1_OFFS) -#define EBI_DEV4_CONFIG2_OFFS 0x0000040C -#define EBI_DEV4_CONFIG2(base) ((base) + EBI_DEV4_CONFIG2_OFFS) -#define EBI_DEV4_FIFO_CONFIG_OFFS 0x00000410 -#define EBI_DEV4_FIFO_CONFIG(base) ((base) + EBI_DEV4_FIFO_CONFIG_OFFS) -#define EBI_DEV4_FLASH_CONF_ST_OFFS 0x00000414 -#define EBI_DEV4_FLASH_CONF_ST(base) ((base) + EBI_DEV4_FLASH_CONF_ST_OFFS) -#define EBI_DEV4_DMA_CONFIG1_OFFS 0x00000418 -#define EBI_DEV4_DMA_CONFIG1(base) ((base) + EBI_DEV4_DMA_CONFIG1_OFFS) -#define EBI_DEV4_DMA_CONFIG2_OFFS 0x0000041C -#define EBI_DEV4_DMA_CONFIG2(base) ((base) + EBI_DEV4_DMA_CONFIG2_OFFS) -#define EBI_DEV4_DMA_ECC_CTRL_OFFS 0x00000420 -#define EBI_DEV4_DMA_ECC_CTRL(base) ((base) + EBI_DEV4_DMA_ECC_CTRL_OFFS) -#define EBI_DEV4_TIM1_RD1_OFFS 0x00000424 -#define EBI_DEV4_TIM1_RD1(base) ((base) + EBI_DEV4_TIM1_RD1_OFFS) -#define EBI_DEV4_TIM1_RD2_OFFS 0x00000428 -#define EBI_DEV4_TIM1_RD2(base) ((base) + EBI_DEV4_TIM1_RD2_OFFS) -#define EBI_DEV4_TIM1_WR1_OFFS 0x0000042C -#define EBI_DEV4_TIM1_WR1(base) ((base) + EBI_DEV4_TIM1_WR1_OFFS) -#define EBI_DEV4_TIM1_WR2_OFFS 0x00000430 -#define EBI_DEV4_TIM1_WR2(base) ((base) + EBI_DEV4_TIM1_WR2_OFFS) -#define EBI_DEV4_TIM_EXT_OFFS 0x00000434 -#define EBI_DEV4_TIM_EXT(base) ((base) + EBI_DEV4_TIM_EXT_OFFS) -#define EBI_DEV4_TIM2_CFI_RD1_OFFS 0x00000438 -#define EBI_DEV4_TIM2_CFI_RD1(base) ((base) + EBI_DEV4_TIM2_CFI_RD1_OFFS) -#define EBI_DEV4_TIM2_CFI_RD2_OFFS 0x0000043C -#define EBI_DEV4_TIM2_CFI_RD2(base) ((base) + EBI_DEV4_TIM2_CFI_RD2_OFFS) -#define EBI_DEV4_TIM3_DMA1_OFFS 0x00000440 -#define EBI_DEV4_TIM3_DMA1(base) ((base) + EBI_DEV4_TIM3_DMA1_OFFS) -#define EBI_DEV4_TIM3_DMA2_OFFS 0x00000444 -#define EBI_DEV4_TIM3_DMA2(base) ((base) + EBI_DEV4_TIM3_DMA2_OFFS) -#define EBI_DEV4_TIM4_UDMA1_OFFS 0x00000448 -#define EBI_DEV4_TIM4_UDMA1(base) ((base) + EBI_DEV4_TIM4_UDMA1_OFFS) -#define EBI_DEV4_TIM4_UDMA2_OFFS 0x0000044C -#define EBI_DEV4_TIM4_UDMA2(base) ((base) + EBI_DEV4_TIM4_UDMA2_OFFS) -#define EBI_DEV4_ACK_RM_CNT_OFFS 0x00000450 -#define EBI_DEV4_ACK_RM_CNT(base) ((base) + EBI_DEV4_ACK_RM_CNT_OFFS) -#define EBI_INTERLEAVE_CNT_OFFS 0x00000900 -#define EBI_INTERLEAVE_CNT(base) ((base) + EBI_INTERLEAVE_CNT_OFFS) -#define EBI_CNT_FL_PROGR_OFFS 0x00000904 -#define EBI_CNT_FL_PROGR(base) ((base) + EBI_CNT_FL_PROGR_OFFS) -#define EBI_CNT_EXT_PAGE_SZ_OFFS 0x0000090C -#define EBI_CNT_EXT_PAGE_SZ(base) ((base) + EBI_CNT_EXT_PAGE_SZ_OFFS) -#define EBI_CNT_WAIT_RDY_OFFS 0x00000914 -#define EBI_CNT_WAIT_RDY(base) ((base) + EBI_CNT_WAIT_RDY_OFFS) -#define EBI_CNT_ACK_OFFS 0x00000918 -#define EBI_CNT_ACK(base) ((base) + EBI_CNT_ACK_OFFS) -#define EBI_GENIO1_CONFIG1_OFFS 0x00000A00 -#define EBI_GENIO1_CONFIG1(base) ((base) + EBI_GENIO1_CONFIG1_OFFS) -#define EBI_GENIO1_CONFIG2_OFFS 0x00000A04 -#define EBI_GENIO1_CONFIG2(base) ((base) + EBI_GENIO1_CONFIG2_OFFS) -#define EBI_GENIO1_CONFIG3_OFFS 0x00000A08 -#define EBI_GENIO1_CONFIG3(base) ((base) + EBI_GENIO1_CONFIG3_OFFS) -#define EBI_GENIO2_CONFIG1_OFFS 0x00000A10 -#define EBI_GENIO2_CONFIG1(base) ((base) + EBI_GENIO2_CONFIG1_OFFS) -#define EBI_GENIO2_CONFIG2_OFFS 0x00000A14 -#define EBI_GENIO2_CONFIG2(base) ((base) + EBI_GENIO2_CONFIG2_OFFS) -#define EBI_GENIO2_CONFIG3_OFFS 0x00000A18 -#define EBI_GENIO2_CONFIG3(base) ((base) + EBI_GENIO2_CONFIG3_OFFS) -#define EBI_GENIO3_CONFIG1_OFFS 0x00000A20 -#define EBI_GENIO3_CONFIG1(base) ((base) + EBI_GENIO3_CONFIG1_OFFS) -#define EBI_GENIO3_CONFIG2_OFFS 0x00000A24 -#define EBI_GENIO3_CONFIG2(base) ((base) + EBI_GENIO3_CONFIG2_OFFS) -#define EBI_GENIO3_CONFIG3_OFFS 0x00000A28 -#define EBI_GENIO3_CONFIG3(base) ((base) + EBI_GENIO3_CONFIG3_OFFS) -#define EBI_GENIO4_CONFIG1_OFFS 0x00000A30 -#define EBI_GENIO4_CONFIG1(base) ((base) + EBI_GENIO4_CONFIG1_OFFS) -#define EBI_GENIO4_CONFIG2_OFFS 0x00000A34 -#define EBI_GENIO4_CONFIG2(base) ((base) + EBI_GENIO4_CONFIG2_OFFS) -#define EBI_GENIO4_CONFIG3_OFFS 0x00000A38 -#define EBI_GENIO4_CONFIG3(base) ((base) + EBI_GENIO4_CONFIG3_OFFS) -#define EBI_GENIO5_CONFIG1_OFFS 0x00000A40 -#define EBI_GENIO5_CONFIG1(base) ((base) + EBI_GENIO5_CONFIG1_OFFS) -#define EBI_GENIO5_CONFIG2_OFFS 0x00000A44 -#define EBI_GENIO5_CONFIG2(base) ((base) + EBI_GENIO5_CONFIG2_OFFS) -#define EBI_GENIO5_CONFIG3_OFFS 0x00000A48 -#define EBI_GENIO5_CONFIG3(base) ((base) + EBI_GENIO5_CONFIG3_OFFS) - -#endif diff --git a/board/micronas/vct/vctv/reg_gpio.h b/board/micronas/vct/vctv/reg_gpio.h deleted file mode 100644 index b1859a47c4..0000000000 --- a/board/micronas/vct/vctv/reg_gpio.h +++ /dev/null @@ -1,18 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define GPIO1_BASE 0x00044000 -#define GPIO2_BASE 0x00048000 - -/* Instances */ -#define GPIO_INSTANCES 2 - -/* Relative offsets of the register adresses */ -#define GPIO_SWPORTA_DR_OFFS 0x00000000 -#define GPIO_SWPORTA_DR(base) ((base) + GPIO_SWPORTA_DR_OFFS) -#define GPIO_SWPORTA_DDR_OFFS 0x00000004 -#define GPIO_SWPORTA_DDR(base) ((base) + GPIO_SWPORTA_DDR_OFFS) -#define GPIO_EXT_PORTA_OFFS 0x00000050 -#define GPIO_EXT_PORTA(base) ((base) + GPIO_EXT_PORTA_OFFS) diff --git a/board/micronas/vct/vctv/reg_wdt.h b/board/micronas/vct/vctv/reg_wdt.h deleted file mode 100644 index 2bad0752e8..0000000000 --- a/board/micronas/vct/vctv/reg_wdt.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -#define WDT_BASE 0x00040000 -#define WDT_CR_OFFS 0x00000000 -#define WDT_CR(base) ((base) + WDT_CR_OFFS) -#define WDT_TORR_OFFS 0x00000004 -#define WDT_TORR(base) ((base) + WDT_TORR_OFFS) diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig deleted file mode 100644 index 2a35ace0e0..0000000000 --- a/configs/vct_platinum_defconfig +++ /dev/null @@ -1,27 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUM=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_IMLS=y -CONFIG_CMD_EEPROM=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_SNTP=y -CONFIG_CMD_FAT=y -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x00000000 -CONFIG_SMC911X_32_BIT=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig deleted file mode 100644 index ded3de0499..0000000000 --- a/configs/vct_platinum_onenand_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUM=y -CONFIG_VCT_ONENAND=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_EEPROM=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_I2C=y -CONFIG_CMD_ONENAND=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_SNTP=y -CONFIG_CMD_FAT=y -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y -CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x00000000 -CONFIG_SMC911X_32_BIT=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig deleted file mode 100644 index 4afb03ee9e..0000000000 --- a/configs/vct_platinum_onenand_small_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUM=y -CONFIG_VCT_ONENAND=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_ONENAND=y -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_ONENAND=y -# CONFIG_NET is not set -CONFIG_MTD_DEVICE=y -CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig deleted file mode 100644 index 8a3f94aadf..0000000000 --- a/configs/vct_platinum_small_defconfig +++ /dev/null @@ -1,27 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUM=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -CONFIG_CMD_IMLS=y -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_FLASH=y -# CONFIG_NET is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig deleted file mode 100644 index 3783becc8a..0000000000 --- a/configs/vct_platinumavc_defconfig +++ /dev/null @@ -1,19 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUMAVC=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="VCT# " -CONFIG_CMD_IMLS=y -CONFIG_CMD_EEPROM=y -CONFIG_CMD_I2C=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_NS16550=y -# CONFIG_REGEX is not set diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig deleted file mode 100644 index e7e9c6cde1..0000000000 --- a/configs/vct_platinumavc_onenand_defconfig +++ /dev/null @@ -1,25 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUMAVC=y -CONFIG_VCT_ONENAND=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_EEPROM=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_I2C=y -CONFIG_CMD_ONENAND=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y -CONFIG_SYS_NS16550=y -# CONFIG_REGEX is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig deleted file mode 100644 index 776472666c..0000000000 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUMAVC=y -CONFIG_VCT_ONENAND=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_ONENAND=y -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_ONENAND=y -# CONFIG_NET is not set -CONFIG_MTD_DEVICE=y -CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig deleted file mode 100644 index 0d8cd07f9f..0000000000 --- a/configs/vct_platinumavc_small_defconfig +++ /dev/null @@ -1,27 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PLATINUMAVC=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -CONFIG_CMD_IMLS=y -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_FLASH=y -# CONFIG_NET is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig deleted file mode 100644 index 2396b24d55..0000000000 --- a/configs/vct_premium_defconfig +++ /dev/null @@ -1,27 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PREMIUM=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_IMLS=y -CONFIG_CMD_EEPROM=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_SNTP=y -CONFIG_CMD_FAT=y -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x00000000 -CONFIG_SMC911X_32_BIT=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig deleted file mode 100644 index f1d01d9c90..0000000000 --- a/configs/vct_premium_onenand_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PREMIUM=y -CONFIG_VCT_ONENAND=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_EEPROM=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_I2C=y -CONFIG_CMD_ONENAND=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_SNTP=y -CONFIG_CMD_FAT=y -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -CONFIG_ENV_IS_IN_ONENAND=y -CONFIG_MTD_DEVICE=y -CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x00000000 -CONFIG_SMC911X_32_BIT=y -CONFIG_SYS_NS16550=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig deleted file mode 100644 index 751f881942..0000000000 --- a/configs/vct_premium_onenand_small_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PREMIUM=y -CONFIG_VCT_ONENAND=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_ONENAND=y -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -CONFIG_CMD_JFFS2=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="onenand0=onenand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=onenand:128k(u-boot),128k(env),20m(kernel),-(rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_CMD_UBIFS is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_ONENAND=y -# CONFIG_NET is not set -CONFIG_MTD_DEVICE=y -CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig deleted file mode 100644 index a8eba61827..0000000000 --- a/configs/vct_premium_small_defconfig +++ /dev/null @@ -1,27 +0,0 @@ -CONFIG_MIPS=y -CONFIG_TARGET_VCT=y -CONFIG_VCT_PREMIUM=y -CONFIG_VCT_SMALL_IMAGE=y -CONFIG_BOOTDELAY=5 -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_ELF is not set -CONFIG_CMD_IMLS=y -# CONFIG_CMD_CRC32 is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_SOURCE is not set -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set -# CONFIG_ISO_PARTITION is not set -CONFIG_ENV_IS_IN_FLASH=y -# CONFIG_NET is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_NS16550=y diff --git a/include/configs/vct.h b/include/configs/vct.h deleted file mode 100644 index 571071593a..0000000000 --- a/include/configs/vct.h +++ /dev/null @@ -1,202 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2008 Stefan Roese sr@denx.de, DENX Software Engineering - */ - -/* - * This file contains the configuration parameters for the VCT board - * family: - * - * vct_premium - * vct_premium_small - * vct_premium_onenand - * vct_premium_onenand_small - * vct_platinum - * vct_platinum_small - * vct_platinum_onenand - * vct_platinum_onenand_small - * vct_platinumavc - * vct_platinumavc_small - * vct_platinumavc_onenand - * vct_platinumavc_onenand_small - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CPU_CLOCK_RATE 324000000 /* Clock for the MIPS core */ -#define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2) - -#define CONFIG_SKIP_LOWLEVEL_INIT /* SDRAM is initialized by the bootstrap code */ - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (256 << 10) -#define CONFIG_SYS_MALLOC_LEN (1 << 20) -#define CONFIG_SYS_BOOTPARAMS_LEN (128 << 10) -#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 - -#if !defined(CONFIG_VCT_NAND) && !defined(CONFIG_VCT_ONENAND) -#define CONFIG_VCT_NOR -#endif - -/* - * UART - */ -#ifdef CONFIG_VCT_PLATINUMAVC -#define UART_1_BASE 0xBDC30000 -#else -#define UART_1_BASE 0xBF89C000 -#endif - -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_COM1 UART_1_BASE -#define CONFIG_SYS_NS16550_CLK 921600 - -/* - * SDRAM - */ -#define CONFIG_SYS_SDRAM_BASE 0x80000000 -#define CONFIG_SYS_MBYTES_SDRAM 128 -#define CONFIG_SYS_MEMTEST_START 0x80200000 -#define CONFIG_SYS_MEMTEST_END 0x80400000 -#define CONFIG_SYS_LOAD_ADDR 0x80400000 /* default load address */ - -#if defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM) -#define CONFIG_NET_RETRY_COUNT 20 -#endif - -/* - * Commands - */ -#if defined(CONFIG_CMD_USB) - -/* - * USB/EHCI - */ -#define CONFIG_USB_EHCI_VCT /* on VCT platform */ -#define CONFIG_EHCI_MMIO_BIG_ENDIAN -#define CONFIG_EHCI_DESC_BIG_ENDIAN -#define CONFIG_EHCI_IS_TDI -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* re-init HCD after CMD_RESET */ -#endif /* CONFIG_CMD_USB */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_TIMESTAMP /* Print image info with timestamp */ - -/* - * FLASH and environment organization - */ -#if defined(CONFIG_VCT_NOR) -#define CONFIG_FLASH_NOT_MEM_MAPPED - -/* - * We need special accessor functions for the CFI FLASH driver. This - * can be enabled via the CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS option. - */ -#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS - -/* - * For the non-memory-mapped NOR FLASH, we need to define the - * NOR FLASH area. This can't be detected via the addr2info() - * function, since we check for flash access in the very early - * U-Boot code, before the NOR FLASH is detected. - */ -#define CONFIG_FLASH_BASE 0xb0000000 -#define CONFIG_FLASH_END 0xbfffffff - -/* - * CFI driver settings - */ -#define CONFIG_SYS_FLASH_CFI_AMD_RESET 1 /* Use AMD (Spansion) reset cmd */ -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT /* no byte writes on IXP4xx */ - -#define CONFIG_SYS_FLASH_BASE 0xb0000000 -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#ifdef CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE 0x10000 /* size of one complete sector */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) -#endif /* CONFIG_ENV_IS_IN_FLASH */ -#endif /* CONFIG_VCT_NOR */ - -#if defined(CONFIG_VCT_ONENAND) -#define CONFIG_USE_ONENAND_BOARD_INIT -#define CONFIG_SYS_ONENAND_BASE 0x00000000 /* this is not real address */ -#define CONFIG_SYS_FLASH_BASE 0x00000000 -#define CONFIG_ENV_ADDR (128 << 10) /* after compr. U-Boot image */ -#define CONFIG_ENV_SIZE (128 << 10) /* erase size */ -#endif /* CONFIG_VCT_ONENAND */ - -/* - * I2C/EEPROM - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SOFT_SPEED 83000 /* 83 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SOFT_SLAVE 0x7f - -/* - * Software (bit-bang) I2C driver configuration - */ -#define CONFIG_SYS_GPIO_I2C_SCL 11 -#define CONFIG_SYS_GPIO_I2C_SDA 10 - -#ifndef __ASSEMBLY__ -int vct_gpio_dir(int pin, int dir); -void vct_gpio_set(int pin, int val); -int vct_gpio_get(int pin); -#endif - -#define I2C_INIT vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SCL, 1) -#define I2C_ACTIVE vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SDA, 1) -#define I2C_TRISTATE vct_gpio_dir(CONFIG_SYS_GPIO_I2C_SDA, 0) -#define I2C_READ vct_gpio_get(CONFIG_SYS_GPIO_I2C_SDA) -#define I2C_SDA(bit) vct_gpio_set(CONFIG_SYS_GPIO_I2C_SDA, bit) -#define I2C_SCL(bit) vct_gpio_set(CONFIG_SYS_GPIO_I2C_SCL, bit) -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -/* CAT24WC32 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* Bytes of address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* The Catalyst CAT24WC32 has */ - /* 32 byte page write mode using*/ - /* last 5 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -#define CONFIG_BOOTCOMMAND "run test3" - -/* - * UBI configuration - */ - -/* - * We need a small, stripped down image to fit into the first 128k OneNAND - * erase block (gzipped). This image only needs basic commands for FLASH - * (NOR/OneNAND) usage and Linux kernel booting. - */ -#if defined(CONFIG_VCT_SMALL_IMAGE) -#undef CONFIG_SYS_I2C_SOFT -#undef CONFIG_SOURCE -#undef CONFIG_TIMESTAMP -#endif /* CONFIG_VCT_SMALL_IMAGE */ - -#endif /* __CONFIG_H */
Hi Daniel,
On 18.10.19 15:13, Daniel Schwierzeck wrote:
The deadline for migration to CONFIG_DM is v2020.01. The VCT baords would need an almost complete rewrite of all drivers to support driver model.
Unless someone has access to the hardware and volunteers to do the migration, the board should be scheduled for removal.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
It makes me a little bit sad to see this board / platform being removed. But I also don't see any active users any more, so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Sad, but please apply this soon. This brings down, AFAICT, the users of embedded-within-U-Boot environment to just an MPC8xx board and I have some questions/concerns about that and how functional it is/isn't right now.
Daniel Schwierzeck
Stefan Roese
