[GIT PULL] Please pull u-boot-imx-master-20240829
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit ee2af844ba1b27b2e959c4e649e4b769fbeb4074:
Merge tag 'efi-2024-10-rc4' of https://source.denx.de/u-boot/custodians/u-boot-efi (2024-08-24 14:03:28 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240829
for you to fetch changes up to aec0015a52d3faf723fec9ed9fe1d1af0b89e996:
mach-imx: do not use if_changed more than once per target (2024-08-29 08:34:46 -0300)
u-boot-imx-master-20240829 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/22162
- Fix an issue with "tools/buildman/buildman imx8ulp_evk" failing every other time. ---------------------------------------------------------------- Jerome Forissier (1): mach-imx: do not use if_changed more than once per target
arch/arm/mach-imx/Makefile | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
On Thu, Aug 29, 2024 at 09:51:24AM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
