[U-Boot] [PATCH v4 19/29] zynq: Add zynq_zc770 xm012 board support
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013
ZC770 XM012: - 1GB DDR3 - 64MiB Numonyx NOR flash - USB-UART
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Cc: Stefan Roese sr@denx.de --- V4: Removed CONFIG_SYS_NO_FLASH in zynq-common.h V3: none V2: none
boards.cfg | 1 + boards.cfg | 1 + include/configs/zynq-common.h | 16 ++++++++++++++++ include/configs/zynq_zc770.h | 4 ++++ 3 files changed, 21 insertions(+)
diff --git a/boards.cfg b/boards.cfg index fb6b8b0..57a3e5b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -358,6 +358,7 @@ Active arm armv7 zynq xilinx zynq zynq_zc70x - Active arm armv7 zynq xilinx zynq zynq_zed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_microzed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_zc770_xm010 zynq_zc770:ZC770_XM010 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com +Active arm armv7 zynq xilinx zynq zynq_zc770_xm012 zynq_zc770:ZC770_XM012 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7 zynq xilinx zynq zynq_zc770_xm013 zynq_zc770:ZC770_XM013 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jaganna@xilinx.com Active arm armv7:arm720t tegra114 nvidia dalmore dalmore - Tom Warren twarren@nvidia.com Active arm armv7:arm720t tegra20 avionic-design medcom-wide medcom-wide - Thierry Reding thierry.reding@avionic-design.de diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index cf96333..db47c42 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -75,6 +75,22 @@ # define CONFIG_CMD_SF #endif
+/* NOR */ +#ifndef CONFIG_SYS_NO_FLASH +# define CONFIG_SYS_FLASH_BASE 0xE2000000 +# define CONFIG_SYS_FLASH_SIZE (16 * 1024 * 1024) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_MAX_FLASH_SECT 512 +# define CONFIG_SYS_FLASH_ERASE_TOUT 1000 +# define CONFIG_SYS_FLASH_WRITE_TOUT 5000 +# define CONFIG_FLASH_SHOW_PROGRESS 10 +# define CONFIG_SYS_FLASH_CFI +# undef CONFIG_SYS_FLASH_EMPTY_INFO +# define CONFIG_FLASH_CFI_DRIVER +# undef CONFIG_SYS_FLASH_PROTECTION +# define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + /* MMC */ #if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_MMC diff --git a/include/configs/zynq_zc770.h b/include/configs/zynq_zc770.h index 181f9fb..16b9047 100644 --- a/include/configs/zynq_zc770.h +++ b/include/configs/zynq_zc770.h @@ -21,6 +21,10 @@ # define CONFIG_ZYNQ_SDHCI0 # define CONFIG_ZYNQ_SPI
+#elif defined(CONFIG_ZC770_XM012) +# define CONFIG_ZYNQ_SERIAL_UART1 +# undef CONFIG_SYS_NO_FLASH + #elif defined(CONFIG_ZC770_XM013) # define CONFIG_ZYNQ_SERIAL_UART0 # define CONFIG_ZYNQ_GEM1
ZC770 XM012:
- 1GB DDR3
- USB-UART
ok. I have looked at this whole series and I think it is step back. We should rather do step forward and start to use device-tree initialization. I have sent some patches for it here http://lists.denx.de/pipermail/u-boot/2014-January/170051.html
Thanks, Michal
Actually this whole series got approved by Tom, he sent a mail to me directly. Need to ask albert for PL.
I think it's should be fine to ask the albert about the series you sent. Any comments?
ZC770 XM012:
- 1GB DDR3
- USB-UART
Thanks, Michal
-- Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91 w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Microblaze cpu - http://www.monstr.eu/fdt/ Maintainer of Linux kernel - Xilinx Zynq ARM architecture Microblaze U-BOOT custodian and responsible for u-boot arm zynq platform
Interesting. But no problem if that series just go to Tom's tree. I have no problem to rebase my changes on the top of it.
Thanks, Michal
Jagan Teki
Michal Simek
