[PATCH] arm64: zynqmp: Add psu_init_gpl for vck190/vmk180 SC
Add psu_init_gpl file for getting SPL to work directly from the tree.
.../zynqmp-e-a2197-00-revA/psu_init_gpl.c | 2052 +++++++++++++++++ 1 file changed, 2052 insertions(+) create mode 100644 board/xilinx/zynqmp/zynqmp-e-a2197-00-revA/psu_init_gpl.c
diff --git a/board/xilinx/zynqmp/zynqmp-e-a2197-00-revA/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-e-a2197-00-revA/psu_init_gpl.c new file mode 100644 index 000000000000..348f0e7789a7 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp-e-a2197-00-revA/psu_init_gpl.c @@ -0,0 +1,2052 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static int serdes_illcalib(u32 lane3_protocol, u32 lane3_rate, + u32 lane2_protocol, u32 lane2_rate, + u32 lane1_protocol, u32 lane1_rate, + u32 lane0_protocol, u32 lane0_rate); + +static void dpll_prog(int div2, int ddr_pll_fbdiv, int d_lock_dly, + int d_lock_cnt, int d_lfhf, int d_cp, int d_res); + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00014600U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFF5E0038, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012300U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E672C6CU); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00002D00U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFF5E0028, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0028, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0034, 0x8000FFFFU, 0x00000000U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00014700U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0040, 0x8000FFFFU, 0x00000000U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E0050, 0x063F3F07U, 0x06010C00U); + psu_mask_write(0xFF180360, 0x00000003U, 0x00000001U); + psu_mask_write(0xFF180308, 0x00000006U, 0x00000006U); + psu_mask_write(0xFF5E0100, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010800U); + psu_mask_write(0xFF18030C, 0x00020000U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0124, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000800U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01040F00U); + psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010500U); + psu_mask_write(0xFF5E00CC, 0x013F3F07U, 0x01010400U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011D02U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000F00U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000100U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0xC1081020U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000202U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00516120U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00408410U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x00418096U); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0030051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00030413U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x006A0000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002305U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x00440024U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00310008U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x00000000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000077FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x15161117U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x00040422U); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x060C1A10U); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x00F08000U); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x0A04060CU); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x01040808U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010005U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000401U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040606U); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0004040DU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x440C011CU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x82160010U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x01B65B96U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x0495820AU); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x83FF0003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00C800FFU); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000004U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00001308U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x00070707U); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x00000000U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x0F000000U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x060F0606U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x06060606U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00000000U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x06060606U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x06060606U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000006U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x04000400U); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000000U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000000U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000001U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x87001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F07E38U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x42C21590U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xD05512C0U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04161U); + psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0800C4, 0xFFFFFFFFU, 0x000000E4U); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0000040DU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x0B2E1708U); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x282B0711U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x000F0133U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x82000501U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x012B2B0BU); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x0044260BU); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000C18U); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000044U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000024U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000031U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000056U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x00000056U); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x00000019U); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000016U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800091C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12340800U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x0000000AU); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300BD99U); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF1032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008AAC58U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x0001B39BU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x0001BB9BU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080704, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08070C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00F50CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080804, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08080C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00F50CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08090C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00F504U); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00F504U); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080B08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080B0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0C00BD00U); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080C08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080C0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0C00BD00U); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080D08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080D0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0C00BD00U); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080E08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080E0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0C00BD00U); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080F08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080F0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0C00BD00U); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09091616U); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x000C1800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x71000000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x000C1800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x71000000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x000C1800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x000C1800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x000C1800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + + return 1; +} + +static unsigned long psu_ddr_qos_init_data(void) +{ + psu_mask_write(0xFD360008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD36001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD370008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD37001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD380008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD38001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD390008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD39001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B001C, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180000, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180004, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180008, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18000C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180010, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180014, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180018, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18001C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180020, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180024, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180028, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18002C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180030, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180034, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180038, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180040, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180044, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180048, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180050, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180054, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180058, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180060, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180064, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180068, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18006C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180070, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180074, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180078, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18007C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180080, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180084, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180088, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF18008C, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180090, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180094, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180098, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180100, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180104, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180108, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180110, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180114, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180118, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180120, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180124, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180128, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180130, 0x000000FEU, 0x00000060U); + psu_mask_write(0xFF180134, 0x000000FEU, 0x00000060U); + psu_mask_write(0xFF180204, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFF180208, 0xFFFFFFFFU, 0x00002040U); + psu_mask_write(0xFF18020C, 0x00003FFFU, 0x00000000U); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180160, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_pre_init_data(void) +{ + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012302U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x0000007CU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000040U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF180320, 0x33840000U, 0x00800000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000600U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000006U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000007CU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x05F5DD18U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + return 1; +} + +static unsigned long psu_serdes_init_data(void) +{ + psu_mask_write(0xFD410000, 0x0000001FU, 0x0000000FU); + psu_mask_write(0xFD402860, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD40106C, 0x0000000FU, 0x0000000FU); + psu_mask_write(0xFD4000F4, 0x0000000BU, 0x0000000BU); + psu_mask_write(0xFD401074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40189C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4018F8, 0x000000FFU, 0x0000007DU); + psu_mask_write(0xFD4018FC, 0x000000FFU, 0x0000007DU); + psu_mask_write(0xFD401990, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401924, 0x000000FFU, 0x00000082U); + psu_mask_write(0xFD401928, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401900, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD40192C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401914, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401940, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD405994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD409994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40D994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40107C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40507C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40907C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40D07C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD4019A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40102C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4059A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD405038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40502C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4099A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD409038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40902C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D9A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD40D038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D02C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4019AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4059AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4099AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD40D9AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD401978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D978, 0x00000010U, 0x00000010U); + + serdes_illcalib(0, 0, 0, 0, 0, 0, 5, 0); + psu_mask_write(0xFD410010, 0x00000007U, 0x00000005U); + psu_mask_write(0xFD410040, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD410044, 0x00000003U, 0x00000000U); + + return 1; +} + +static unsigned long psu_resetout_init_data(void) +{ + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U); + mask_poll(0xFD4023E4, 0x00000010U); + + return 1; +} + +static unsigned long psu_resetin_init_data(void) +{ + psu_mask_write(0xFF5E0230, 0x00000001U, 0x00000001U); + + return 1; +} + +static unsigned long psu_afi_config(void) +{ + psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U); + psu_mask_write(0xFF419000, 0x00000300U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + + for (int tp = 0; tp < 20; tp++) + regval = Xil_In32(0xFD070018); + int cur_PLLCR0; + + cur_PLLCR0 = (Xil_In32(0xFD080068U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SL0PLLCR0; + + cur_DX8SL0PLLCR0 = (Xil_In32(0xFD081404U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SL1PLLCR0; + + cur_DX8SL1PLLCR0 = (Xil_In32(0xFD081444U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SL2PLLCR0; + + cur_DX8SL2PLLCR0 = (Xil_In32(0xFD081484U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SL3PLLCR0; + + cur_DX8SL3PLLCR0 = (Xil_In32(0xFD0814C4U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SL4PLLCR0; + + cur_DX8SL4PLLCR0 = (Xil_In32(0xFD081504U) & 0xFFFFFFFFU) >> 0x00000000U; + int cur_DX8SLBPLLCR0; + + cur_DX8SLBPLLCR0 = (Xil_In32(0xFD0817C4U) & 0xFFFFFFFFU) >> 0x00000000U; + Xil_Out32(0xFD080068, 0x02120000); + Xil_Out32(0xFD081404, 0x02120000); + Xil_Out32(0xFD081444, 0x02120000); + Xil_Out32(0xFD081484, 0x02120000); + Xil_Out32(0xFD0814C4, 0x02120000); + Xil_Out32(0xFD081504, 0x02120000); + Xil_Out32(0xFD0817C4, 0x02120000); + int cur_div2; + + cur_div2 = (Xil_In32(0xFD1A002CU) & 0x00010000U) >> 0x00000010U; + int cur_fbdiv; + + cur_fbdiv = (Xil_In32(0xFD1A002CU) & 0x00007F00U) >> 0x00000008U; + dpll_prog(1, 49, 63, 625, 3, 3, 2); + for (int tp = 0; tp < 20; tp++) + regval = Xil_In32(0xFD070018); + unsigned int pll_retry = 10; + unsigned int pll_locked = 0; + + while ((pll_retry > 0) && (!pll_locked)) { + Xil_Out32(0xFD080004, 0x00040010); + Xil_Out32(0xFD080004, 0x00040011); + + while ((Xil_In32(0xFD080030) & 0x1) != 1) + ; + pll_locked = (Xil_In32(0xFD080030) & 0x80000000) + >> 31; + pll_locked &= (Xil_In32(0xFD0807E0) & 0x10000) + >> 16; + pll_locked &= (Xil_In32(0xFD0809E0) & 0x10000) >> 16; + pll_retry--; + } + Xil_Out32(0xFD0800C4, Xil_In32(0xFD0800C4) | (pll_retry << 16)); + if (!pll_locked) + return 0; + + Xil_Out32(0xFD080004U, 0x00040063U); + Xil_Out32(0xFD0800C0U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + Xil_Out32(0xFD070010U, 0x80000018U); + Xil_Out32(0xFD0701B0U, 0x00000005U); + regval = Xil_In32(0xFD070018); + while ((regval & 0x1) != 0x0) + regval = Xil_In32(0xFD070018); + + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + Xil_Out32(0xFD070014U, 0x00000331U); + Xil_Out32(0xFD070010U, 0x80000018U); + regval = Xil_In32(0xFD070018); + while ((regval & 0x1) != 0x0) + regval = Xil_In32(0xFD070018); + + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + Xil_Out32(0xFD070014U, 0x00000B36U); + Xil_Out32(0xFD070010U, 0x80000018U); + regval = Xil_In32(0xFD070018); + while ((regval & 0x1) != 0x0) + regval = Xil_In32(0xFD070018); + + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + Xil_Out32(0xFD070014U, 0x00000C56U); + Xil_Out32(0xFD070010U, 0x80000018U); + regval = Xil_In32(0xFD070018); + while ((regval & 0x1) != 0x0) + regval = Xil_In32(0xFD070018); + + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + Xil_Out32(0xFD070014U, 0x00000E19U); + Xil_Out32(0xFD070010U, 0x80000018U); + regval = Xil_In32(0xFD070018); + while ((regval & 0x1) != 0x0) + regval = Xil_In32(0xFD070018); + + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + regval = Xil_In32(0xFD070018); + Xil_Out32(0xFD070014U, 0x00001616U); + Xil_Out32(0xFD070010U, 0x80000018U); + Xil_Out32(0xFD070010U, 0x80000010U); + Xil_Out32(0xFD0701B0U, 0x00000005U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + prog_reg(0xFD0701B0U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + prog_reg(0xFD080028U, 0x00000001U, 0x00000000U, 0x00000001U); + prog_reg(0xFD080004U, 0x20000000U, 0x0000001DU, 0x00000001U); + prog_reg(0xFD08016CU, 0x00000004U, 0x00000002U, 0x00000001U); + prog_reg(0xFD080168U, 0x000000F0U, 0x00000004U, 0x00000007U); + prog_reg(0xFD080168U, 0x00000F00U, 0x00000008U, 0x00000002U); + prog_reg(0xFD080168U, 0x0000000FU, 0x00000000U, 0x00000001U); + for (int tp = 0; tp < 20; tp++) + regval = Xil_In32(0xFD070018); + + Xil_Out32(0xFD080068, cur_PLLCR0); + Xil_Out32(0xFD081404, cur_DX8SL0PLLCR0); + Xil_Out32(0xFD081444, cur_DX8SL1PLLCR0); + Xil_Out32(0xFD081484, cur_DX8SL2PLLCR0); + Xil_Out32(0xFD0814C4, cur_DX8SL3PLLCR0); + Xil_Out32(0xFD081504, cur_DX8SL4PLLCR0); + Xil_Out32(0xFD0817C4, cur_DX8SLBPLLCR0); + for (int tp = 0; tp < 20; tp++) + regval = Xil_In32(0xFD070018); + + dpll_prog(cur_div2, cur_fbdiv, 63, 625, 3, 3, 2); + for (int tp = 0; tp < 2000; tp++) + regval = Xil_In32(0xFD070018); + + prog_reg(0xFD080004U, 0x20000000U, 0x0000001DU, 0x00000000U); + prog_reg(0xFD080004U, 0x00040000U, 0x00000012U, 0x00000001U); + prog_reg(0xFD080004U, 0x00000040U, 0x00000006U, 0x00000001U); + prog_reg(0xFD080004U, 0x00000020U, 0x00000005U, 0x00000001U); + prog_reg(0xFD080004U, 0x00000010U, 0x00000004U, 0x00000001U); + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + for (int tp = 0; tp < 2000; tp++) + regval = Xil_In32(0xFD070018); + + prog_reg(0xFD080028U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD08016CU, 0x00000004U, 0x00000002U, 0x00000001U); + prog_reg(0xFD080168U, 0x000000F0U, 0x00000004U, 0x00000007U); + prog_reg(0xFD080168U, 0x00000F00U, 0x00000008U, 0x00000003U); + prog_reg(0xFD080168U, 0x0000000FU, 0x00000000U, 0x00000001U); + for (int tp = 0; tp < 2000; tp++) + regval = Xil_In32(0xFD070018); + + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0014FE01); + + regval = Xil_In32(0xFD080030); + while (regval != 0x8000007E) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD080200U, 0x000091C7U); + regval = Xil_In32(0xFD080030); + while (regval != 0x80008FFF) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD080200U, 0x800091C7U); + regval = ((Xil_In32(0xFD080030) & 0x1FFF0000) >> 18); + if (regval != 0) + return 0; + prog_reg(0xFD070320U, 0x00000001U, 0x00000000U, 0x00000000U); + prog_reg(0xFD0701B0U, 0x00000001U, 0x00000000U, 0x00000001U); + prog_reg(0xFD0701A0U, 0x80000000U, 0x0000001FU, 0x00000000U); + prog_reg(0xFD070320U, 0x00000001U, 0x00000000U, 0x00000001U); + Xil_Out32(0xFD070180U, 0x02160010U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + for (int tp = 0; tp < 4000; tp++) + regval = Xil_In32(0xFD070018); + + prog_reg(0xFD080090U, 0x00000FC0U, 0x00000006U, 0x00000007U); + prog_reg(0xFD080090U, 0x00000004U, 0x00000002U, 0x00000001U); + prog_reg(0xFD08070CU, 0x02000000U, 0x00000019U, 0x00000000U); + prog_reg(0xFD08080CU, 0x02000000U, 0x00000019U, 0x00000000U); + prog_reg(0xFD08090CU, 0x02000000U, 0x00000019U, 0x00000000U); + prog_reg(0xFD080A0CU, 0x02000000U, 0x00000019U, 0x00000000U); + prog_reg(0xFD080F0CU, 0x02000000U, 0x00000019U, 0x00000000U); + prog_reg(0xFD080200U, 0x00000010U, 0x00000004U, 0x00000001U); + prog_reg(0xFD080250U, 0x00000002U, 0x00000001U, 0x00000000U); + prog_reg(0xFD080250U, 0x0000000CU, 0x00000002U, 0x00000001U); + prog_reg(0xFD080250U, 0x000000F0U, 0x00000004U, 0x00000000U); + prog_reg(0xFD080250U, 0x00300000U, 0x00000014U, 0x00000001U); + prog_reg(0xFD080250U, 0xF0000000U, 0x0000001CU, 0x00000002U); + prog_reg(0xFD08070CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD08080CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD08090CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080A0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080B0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080C0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080D0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080E0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080F0CU, 0x08000000U, 0x0000001BU, 0x00000000U); + prog_reg(0xFD080254U, 0x000000FFU, 0x00000000U, 0x00000001U); + prog_reg(0xFD080254U, 0x000F0000U, 0x00000010U, 0x0000000AU); + prog_reg(0xFD080250U, 0x00000001U, 0x00000000U, 0x00000001U); + + return 1; +} + +static int serdes_rst_seq(u32 pllsel, u32 lane3_protocol, u32 lane3_rate, + u32 lane2_protocol, u32 lane2_rate, + u32 lane1_protocol, u32 lane1_rate, + u32 lane0_protocol, u32 lane0_rate) +{ + Xil_Out32(0xFD410098, 0x00000000); + Xil_Out32(0xFD401010, 0x00000040); + Xil_Out32(0xFD405010, 0x00000040); + Xil_Out32(0xFD409010, 0x00000040); + Xil_Out32(0xFD40D010, 0x00000040); + Xil_Out32(0xFD402084, 0x00000080); + Xil_Out32(0xFD406084, 0x00000080); + Xil_Out32(0xFD40A084, 0x00000080); + Xil_Out32(0xFD40E084, 0x00000080); + Xil_Out32(0xFD410098, 0x00000004); + mask_delay(50); + if (lane0_rate == 1) + Xil_Out32(0xFD410098, 0x0000000E); + Xil_Out32(0xFD410098, 0x00000006); + if (lane0_rate == 1) { + Xil_Out32(0xFD40000C, 0x00000004); + Xil_Out32(0xFD40400C, 0x00000004); + Xil_Out32(0xFD40800C, 0x00000004); + Xil_Out32(0xFD40C00C, 0x00000004); + Xil_Out32(0xFD410098, 0x00000007); + mask_delay(400); + Xil_Out32(0xFD40000C, 0x0000000C); + Xil_Out32(0xFD40400C, 0x0000000C); + Xil_Out32(0xFD40800C, 0x0000000C); + Xil_Out32(0xFD40C00C, 0x0000000C); + mask_delay(15); + Xil_Out32(0xFD410098, 0x0000000F); + mask_delay(100); + } + if (pllsel == 0) + mask_poll(0xFD4023E4, 0x00000010U); + if (pllsel == 1) + mask_poll(0xFD4063E4, 0x00000010U); + if (pllsel == 2) + mask_poll(0xFD40A3E4, 0x00000010U); + if (pllsel == 3) + mask_poll(0xFD40E3E4, 0x00000010U); + mask_delay(50); + Xil_Out32(0xFD401010, 0x000000C0); + Xil_Out32(0xFD405010, 0x000000C0); + Xil_Out32(0xFD409010, 0x000000C0); + Xil_Out32(0xFD40D010, 0x000000C0); + Xil_Out32(0xFD401010, 0x00000080); + Xil_Out32(0xFD405010, 0x00000080); + Xil_Out32(0xFD409010, 0x00000080); + Xil_Out32(0xFD40D010, 0x00000080); + + Xil_Out32(0xFD402084, 0x000000C0); + Xil_Out32(0xFD406084, 0x000000C0); + Xil_Out32(0xFD40A084, 0x000000C0); + Xil_Out32(0xFD40E084, 0x000000C0); + mask_delay(50); + Xil_Out32(0xFD402084, 0x00000080); + Xil_Out32(0xFD406084, 0x00000080); + Xil_Out32(0xFD40A084, 0x00000080); + Xil_Out32(0xFD40E084, 0x00000080); + mask_delay(50); + Xil_Out32(0xFD401010, 0x00000000); + Xil_Out32(0xFD405010, 0x00000000); + Xil_Out32(0xFD409010, 0x00000000); + Xil_Out32(0xFD40D010, 0x00000000); + Xil_Out32(0xFD402084, 0x00000000); + Xil_Out32(0xFD406084, 0x00000000); + Xil_Out32(0xFD40A084, 0x00000000); + Xil_Out32(0xFD40E084, 0x00000000); + mask_delay(500); + return 1; +} + +static int serdes_bist_static_settings(u32 lane_active) +{ + if (lane_active == 0) { + Xil_Out32(0xFD403004, (Xil_In32(0xFD403004) & 0xFFFFFF1F)); + Xil_Out32(0xFD403068, 0x1); + Xil_Out32(0xFD40306C, 0x1); + Xil_Out32(0xFD4010AC, 0x0020); + Xil_Out32(0xFD403008, 0x0); + Xil_Out32(0xFD40300C, 0xF4); + Xil_Out32(0xFD403010, 0x0); + Xil_Out32(0xFD403014, 0x0); + Xil_Out32(0xFD403018, 0x00); + Xil_Out32(0xFD40301C, 0xFB); + Xil_Out32(0xFD403020, 0xFF); + Xil_Out32(0xFD403024, 0x0); + Xil_Out32(0xFD403028, 0x00); + Xil_Out32(0xFD40302C, 0x00); + Xil_Out32(0xFD403030, 0x4A); + Xil_Out32(0xFD403034, 0x4A); + Xil_Out32(0xFD403038, 0x4A); + Xil_Out32(0xFD40303C, 0x4A); + Xil_Out32(0xFD403040, 0x0); + Xil_Out32(0xFD403044, 0x14); + Xil_Out32(0xFD403048, 0x02); + Xil_Out32(0xFD403004, (Xil_In32(0xFD403004) & 0xFFFFFF1F)); + } + if (lane_active == 1) { + Xil_Out32(0xFD407004, (Xil_In32(0xFD407004) & 0xFFFFFF1F)); + Xil_Out32(0xFD407068, 0x1); + Xil_Out32(0xFD40706C, 0x1); + Xil_Out32(0xFD4050AC, 0x0020); + Xil_Out32(0xFD407008, 0x0); + Xil_Out32(0xFD40700C, 0xF4); + Xil_Out32(0xFD407010, 0x0); + Xil_Out32(0xFD407014, 0x0); + Xil_Out32(0xFD407018, 0x00); + Xil_Out32(0xFD40701C, 0xFB); + Xil_Out32(0xFD407020, 0xFF); + Xil_Out32(0xFD407024, 0x0); + Xil_Out32(0xFD407028, 0x00); + Xil_Out32(0xFD40702C, 0x00); + Xil_Out32(0xFD407030, 0x4A); + Xil_Out32(0xFD407034, 0x4A); + Xil_Out32(0xFD407038, 0x4A); + Xil_Out32(0xFD40703C, 0x4A); + Xil_Out32(0xFD407040, 0x0); + Xil_Out32(0xFD407044, 0x14); + Xil_Out32(0xFD407048, 0x02); + Xil_Out32(0xFD407004, (Xil_In32(0xFD407004) & 0xFFFFFF1F)); + } + + if (lane_active == 2) { + Xil_Out32(0xFD40B004, (Xil_In32(0xFD40B004) & 0xFFFFFF1F)); + Xil_Out32(0xFD40B068, 0x1); + Xil_Out32(0xFD40B06C, 0x1); + Xil_Out32(0xFD4090AC, 0x0020); + Xil_Out32(0xFD40B008, 0x0); + Xil_Out32(0xFD40B00C, 0xF4); + Xil_Out32(0xFD40B010, 0x0); + Xil_Out32(0xFD40B014, 0x0); + Xil_Out32(0xFD40B018, 0x00); + Xil_Out32(0xFD40B01C, 0xFB); + Xil_Out32(0xFD40B020, 0xFF); + Xil_Out32(0xFD40B024, 0x0); + Xil_Out32(0xFD40B028, 0x00); + Xil_Out32(0xFD40B02C, 0x00); + Xil_Out32(0xFD40B030, 0x4A); + Xil_Out32(0xFD40B034, 0x4A); + Xil_Out32(0xFD40B038, 0x4A); + Xil_Out32(0xFD40B03C, 0x4A); + Xil_Out32(0xFD40B040, 0x0); + Xil_Out32(0xFD40B044, 0x14); + Xil_Out32(0xFD40B048, 0x02); + Xil_Out32(0xFD40B004, (Xil_In32(0xFD40B004) & 0xFFFFFF1F)); + } + + if (lane_active == 3) { + Xil_Out32(0xFD40F004, (Xil_In32(0xFD40F004) & 0xFFFFFF1F)); + Xil_Out32(0xFD40F068, 0x1); + Xil_Out32(0xFD40F06C, 0x1); + Xil_Out32(0xFD40D0AC, 0x0020); + Xil_Out32(0xFD40F008, 0x0); + Xil_Out32(0xFD40F00C, 0xF4); + Xil_Out32(0xFD40F010, 0x0); + Xil_Out32(0xFD40F014, 0x0); + Xil_Out32(0xFD40F018, 0x00); + Xil_Out32(0xFD40F01C, 0xFB); + Xil_Out32(0xFD40F020, 0xFF); + Xil_Out32(0xFD40F024, 0x0); + Xil_Out32(0xFD40F028, 0x00); + Xil_Out32(0xFD40F02C, 0x00); + Xil_Out32(0xFD40F030, 0x4A); + Xil_Out32(0xFD40F034, 0x4A); + Xil_Out32(0xFD40F038, 0x4A); + Xil_Out32(0xFD40F03C, 0x4A); + Xil_Out32(0xFD40F040, 0x0); + Xil_Out32(0xFD40F044, 0x14); + Xil_Out32(0xFD40F048, 0x02); + Xil_Out32(0xFD40F004, (Xil_In32(0xFD40F004) & 0xFFFFFF1F)); + } + return 1; +} + +static int serdes_bist_run(u32 lane_active) +{ + if (lane_active == 0) { + psu_mask_write(0xFD410044, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD410040, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD410038, 0x00000007U, 0x00000001U); + Xil_Out32(0xFD4010AC, 0x0020); + Xil_Out32(0xFD403004, (Xil_In32(0xFD403004) | 0x1)); + } + if (lane_active == 1) { + psu_mask_write(0xFD410044, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD410040, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD410038, 0x00000070U, 0x00000010U); + Xil_Out32(0xFD4050AC, 0x0020); + Xil_Out32(0xFD407004, (Xil_In32(0xFD407004) | 0x1)); + } + if (lane_active == 2) { + psu_mask_write(0xFD410044, 0x00000030U, 0x00000000U); + psu_mask_write(0xFD410040, 0x00000030U, 0x00000000U); + psu_mask_write(0xFD41003C, 0x00000007U, 0x00000001U); + Xil_Out32(0xFD4090AC, 0x0020); + Xil_Out32(0xFD40B004, (Xil_In32(0xFD40B004) | 0x1)); + } + if (lane_active == 3) { + psu_mask_write(0xFD410040, 0x000000C0U, 0x00000000U); + psu_mask_write(0xFD410044, 0x000000C0U, 0x00000000U); + psu_mask_write(0xFD41003C, 0x00000070U, 0x00000010U); + Xil_Out32(0xFD40D0AC, 0x0020); + Xil_Out32(0xFD40F004, (Xil_In32(0xFD40F004) | 0x1)); + } + mask_delay(100); + return 1; +} + +static int serdes_bist_result(u32 lane_active) +{ + u32 pkt_cnt_l0, pkt_cnt_h0, err_cnt_l0, err_cnt_h0; + + if (lane_active == 0) { + pkt_cnt_l0 = Xil_In32(0xFD40304C); + pkt_cnt_h0 = Xil_In32(0xFD403050); + err_cnt_l0 = Xil_In32(0xFD403054); + err_cnt_h0 = Xil_In32(0xFD403058); + } + if (lane_active == 1) { + pkt_cnt_l0 = Xil_In32(0xFD40704C); + pkt_cnt_h0 = Xil_In32(0xFD407050); + err_cnt_l0 = Xil_In32(0xFD407054); + err_cnt_h0 = Xil_In32(0xFD407058); + } + if (lane_active == 2) { + pkt_cnt_l0 = Xil_In32(0xFD40B04C); + pkt_cnt_h0 = Xil_In32(0xFD40B050); + err_cnt_l0 = Xil_In32(0xFD40B054); + err_cnt_h0 = Xil_In32(0xFD40B058); + } + if (lane_active == 3) { + pkt_cnt_l0 = Xil_In32(0xFD40F04C); + pkt_cnt_h0 = Xil_In32(0xFD40F050); + err_cnt_l0 = Xil_In32(0xFD40F054); + err_cnt_h0 = Xil_In32(0xFD40F058); + } + if (lane_active == 0) + Xil_Out32(0xFD403004, 0x0); + if (lane_active == 1) + Xil_Out32(0xFD407004, 0x0); + if (lane_active == 2) + Xil_Out32(0xFD40B004, 0x0); + if (lane_active == 3) + Xil_Out32(0xFD40F004, 0x0); + if (err_cnt_l0 > 0 || err_cnt_h0 > 0 || + (pkt_cnt_l0 == 0 && pkt_cnt_h0 == 0)) + return 0; + return 1; +} + +static int serdes_illcalib_pcie_gen1(u32 pllsel, u32 lane3_protocol, + u32 lane3_rate, u32 lane2_protocol, + u32 lane2_rate, u32 lane1_protocol, + u32 lane1_rate, u32 lane0_protocol, + u32 lane0_rate, u32 gen2_calib) +{ + u64 tempbistresult; + u32 currbistresult[4]; + u32 prevbistresult[4]; + u32 itercount = 0; + u32 ill12_val[4], ill1_val[4]; + u32 loop = 0; + u32 iterresult[8]; + u32 meancount[4]; + u32 bistpasscount[4]; + u32 meancountalt[4]; + u32 meancountalt_bistpasscount[4]; + u32 lane0_active; + u32 lane1_active; + u32 lane2_active; + u32 lane3_active; + + lane0_active = (lane0_protocol == 1); + lane1_active = (lane1_protocol == 1); + lane2_active = (lane2_protocol == 1); + lane3_active = (lane3_protocol == 1); + for (loop = 0; loop <= 3; loop++) { + iterresult[loop] = 0; + iterresult[loop + 4] = 0; + meancountalt[loop] = 0; + meancountalt_bistpasscount[loop] = 0; + meancount[loop] = 0; + prevbistresult[loop] = 0; + bistpasscount[loop] = 0; + } + itercount = 0; + if (lane0_active) + serdes_bist_static_settings(0); + if (lane1_active) + serdes_bist_static_settings(1); + if (lane2_active) + serdes_bist_static_settings(2); + if (lane3_active) + serdes_bist_static_settings(3); + do { + if (gen2_calib != 1) { + if (lane0_active == 1) + ill1_val[0] = ((0x04 + itercount * 8) % 0x100); + if (lane0_active == 1) + ill12_val[0] = + ((0x04 + itercount * 8) >= + 0x100) ? 0x10 : 0x00; + if (lane1_active == 1) + ill1_val[1] = ((0x04 + itercount * 8) % 0x100); + if (lane1_active == 1) + ill12_val[1] = + ((0x04 + itercount * 8) >= + 0x100) ? 0x10 : 0x00; + if (lane2_active == 1) + ill1_val[2] = ((0x04 + itercount * 8) % 0x100); + if (lane2_active == 1) + ill12_val[2] = + ((0x04 + itercount * 8) >= + 0x100) ? 0x10 : 0x00; + if (lane3_active == 1) + ill1_val[3] = ((0x04 + itercount * 8) % 0x100); + if (lane3_active == 1) + ill12_val[3] = + ((0x04 + itercount * 8) >= + 0x100) ? 0x10 : 0x00; + + if (lane0_active == 1) + Xil_Out32(0xFD401924, ill1_val[0]); + if (lane0_active == 1) + psu_mask_write(0xFD401990, 0x000000F0U, + ill12_val[0]); + if (lane1_active == 1) + Xil_Out32(0xFD405924, ill1_val[1]); + if (lane1_active == 1) + psu_mask_write(0xFD405990, 0x000000F0U, + ill12_val[1]); + if (lane2_active == 1) + Xil_Out32(0xFD409924, ill1_val[2]); + if (lane2_active == 1) + psu_mask_write(0xFD409990, 0x000000F0U, + ill12_val[2]); + if (lane3_active == 1) + Xil_Out32(0xFD40D924, ill1_val[3]); + if (lane3_active == 1) + psu_mask_write(0xFD40D990, 0x000000F0U, + ill12_val[3]); + } + if (gen2_calib == 1) { + if (lane0_active == 1) + ill1_val[0] = ((0x104 + itercount * 8) % 0x100); + if (lane0_active == 1) + ill12_val[0] = + ((0x104 + itercount * 8) >= + 0x200) ? 0x02 : 0x01; + if (lane1_active == 1) + ill1_val[1] = ((0x104 + itercount * 8) % 0x100); + if (lane1_active == 1) + ill12_val[1] = + ((0x104 + itercount * 8) >= + 0x200) ? 0x02 : 0x01; + if (lane2_active == 1) + ill1_val[2] = ((0x104 + itercount * 8) % 0x100); + if (lane2_active == 1) + ill12_val[2] = + ((0x104 + itercount * 8) >= + 0x200) ? 0x02 : 0x01; + if (lane3_active == 1) + ill1_val[3] = ((0x104 + itercount * 8) % 0x100); + if (lane3_active == 1) + ill12_val[3] = + ((0x104 + itercount * 8) >= + 0x200) ? 0x02 : 0x01; + + if (lane0_active == 1) + Xil_Out32(0xFD401928, ill1_val[0]); + if (lane0_active == 1) + psu_mask_write(0xFD401990, 0x0000000FU, + ill12_val[0]); + if (lane1_active == 1) + Xil_Out32(0xFD405928, ill1_val[1]); + if (lane1_active == 1) + psu_mask_write(0xFD405990, 0x0000000FU, + ill12_val[1]); + if (lane2_active == 1) + Xil_Out32(0xFD409928, ill1_val[2]); + if (lane2_active == 1) + psu_mask_write(0xFD409990, 0x0000000FU, + ill12_val[2]); + if (lane3_active == 1) + Xil_Out32(0xFD40D928, ill1_val[3]); + if (lane3_active == 1) + psu_mask_write(0xFD40D990, 0x0000000FU, + ill12_val[3]); + } + + if (lane0_active == 1) + psu_mask_write(0xFD401018, 0x00000030U, 0x00000010U); + if (lane1_active == 1) + psu_mask_write(0xFD405018, 0x00000030U, 0x00000010U); + if (lane2_active == 1) + psu_mask_write(0xFD409018, 0x00000030U, 0x00000010U); + if (lane3_active == 1) + psu_mask_write(0xFD40D018, 0x00000030U, 0x00000010U); + if (lane0_active == 1) + currbistresult[0] = 0; + if (lane1_active == 1) + currbistresult[1] = 0; + if (lane2_active == 1) + currbistresult[2] = 0; + if (lane3_active == 1) + currbistresult[3] = 0; + serdes_rst_seq(pllsel, lane3_protocol, lane3_rate, + lane2_protocol, lane2_rate, lane1_protocol, + lane1_rate, lane0_protocol, lane0_rate); + if (lane3_active == 1) + serdes_bist_run(3); + if (lane2_active == 1) + serdes_bist_run(2); + if (lane1_active == 1) + serdes_bist_run(1); + if (lane0_active == 1) + serdes_bist_run(0); + tempbistresult = 0; + if (lane3_active == 1) + tempbistresult = tempbistresult | serdes_bist_result(3); + tempbistresult = tempbistresult << 1; + if (lane2_active == 1) + tempbistresult = tempbistresult | serdes_bist_result(2); + tempbistresult = tempbistresult << 1; + if (lane1_active == 1) + tempbistresult = tempbistresult | serdes_bist_result(1); + tempbistresult = tempbistresult << 1; + if (lane0_active == 1) + tempbistresult = tempbistresult | serdes_bist_result(0); + Xil_Out32(0xFD410098, 0x0); + Xil_Out32(0xFD410098, 0x2); + + if (itercount < 32) { + iterresult[0] = + ((iterresult[0] << 1) | + ((tempbistresult & 0x1) == 0x1)); + iterresult[1] = + ((iterresult[1] << 1) | + ((tempbistresult & 0x2) == 0x2)); + iterresult[2] = + ((iterresult[2] << 1) | + ((tempbistresult & 0x4) == 0x4)); + iterresult[3] = + ((iterresult[3] << 1) | + ((tempbistresult & 0x8) == 0x8)); + } else { + iterresult[4] = + ((iterresult[4] << 1) | + ((tempbistresult & 0x1) == 0x1)); + iterresult[5] = + ((iterresult[5] << 1) | + ((tempbistresult & 0x2) == 0x2)); + iterresult[6] = + ((iterresult[6] << 1) | + ((tempbistresult & 0x4) == 0x4)); + iterresult[7] = + ((iterresult[7] << 1) | + ((tempbistresult & 0x8) == 0x8)); + } + currbistresult[0] = + currbistresult[0] | ((tempbistresult & 0x1) == 1); + currbistresult[1] = + currbistresult[1] | ((tempbistresult & 0x2) == 0x2); + currbistresult[2] = + currbistresult[2] | ((tempbistresult & 0x4) == 0x4); + currbistresult[3] = + currbistresult[3] | ((tempbistresult & 0x8) == 0x8); + + for (loop = 0; loop <= 3; loop++) { + if (currbistresult[loop] == 1 && + prevbistresult[loop] == 1) + bistpasscount[loop] = bistpasscount[loop] + 1; + if (bistpasscount[loop] < 4 && + currbistresult[loop] == 0 && itercount > 2) { + if (meancountalt_bistpasscount[loop] < + bistpasscount[loop]) { + meancountalt_bistpasscount[loop] = + bistpasscount[loop]; + meancountalt[loop] = + ((itercount - 1) - + ((bistpasscount[loop] + 1) / 2)); + } + bistpasscount[loop] = 0; + } + if (meancount[loop] == 0 && bistpasscount[loop] >= 4 && + (currbistresult[loop] == 0 || itercount == 63) && + prevbistresult[loop] == 1) + meancount[loop] = + itercount - 1 - + ((bistpasscount[loop] + 1) / 2); + prevbistresult[loop] = currbistresult[loop]; + } + } while (++itercount < 64); + + for (loop = 0; loop <= 3; loop++) { + if (lane0_active == 0 && loop == 0) + continue; + if (lane1_active == 0 && loop == 1) + continue; + if (lane2_active == 0 && loop == 2) + continue; + if (lane3_active == 0 && loop == 3) + continue; + + if (meancount[loop] == 0) + meancount[loop] = meancountalt[loop]; + + if (gen2_calib != 1) { + ill1_val[loop] = ((0x04 + meancount[loop] * 8) % 0x100); + ill12_val[loop] = + ((0x04 + meancount[loop] * 8) >= + 0x100) ? 0x10 : 0x00; + } + if (gen2_calib == 1) { + ill1_val[loop] = + ((0x104 + meancount[loop] * 8) % 0x100); + ill12_val[loop] = + ((0x104 + meancount[loop] * 8) >= + 0x200) ? 0x02 : 0x01; + } + } + if (gen2_calib != 1) { + if (lane0_active == 1) + Xil_Out32(0xFD401924, ill1_val[0]); + if (lane0_active == 1) + psu_mask_write(0xFD401990, 0x000000F0U, ill12_val[0]); + if (lane1_active == 1) + Xil_Out32(0xFD405924, ill1_val[1]); + if (lane1_active == 1) + psu_mask_write(0xFD405990, 0x000000F0U, ill12_val[1]); + if (lane2_active == 1) + Xil_Out32(0xFD409924, ill1_val[2]); + if (lane2_active == 1) + psu_mask_write(0xFD409990, 0x000000F0U, ill12_val[2]); + if (lane3_active == 1) + Xil_Out32(0xFD40D924, ill1_val[3]); + if (lane3_active == 1) + psu_mask_write(0xFD40D990, 0x000000F0U, ill12_val[3]); + } + if (gen2_calib == 1) { + if (lane0_active == 1) + Xil_Out32(0xFD401928, ill1_val[0]); + if (lane0_active == 1) + psu_mask_write(0xFD401990, 0x0000000FU, ill12_val[0]); + if (lane1_active == 1) + Xil_Out32(0xFD405928, ill1_val[1]); + if (lane1_active == 1) + psu_mask_write(0xFD405990, 0x0000000FU, ill12_val[1]); + if (lane2_active == 1) + Xil_Out32(0xFD409928, ill1_val[2]); + if (lane2_active == 1) + psu_mask_write(0xFD409990, 0x0000000FU, ill12_val[2]); + if (lane3_active == 1) + Xil_Out32(0xFD40D928, ill1_val[3]); + if (lane3_active == 1) + psu_mask_write(0xFD40D990, 0x0000000FU, ill12_val[3]); + } + + if (lane0_active == 1) + psu_mask_write(0xFD401018, 0x00000030U, 0x00000000U); + if (lane1_active == 1) + psu_mask_write(0xFD405018, 0x00000030U, 0x00000000U); + if (lane2_active == 1) + psu_mask_write(0xFD409018, 0x00000030U, 0x00000000U); + if (lane3_active == 1) + psu_mask_write(0xFD40D018, 0x00000030U, 0x00000000U); + + Xil_Out32(0xFD410098, 0); + if (lane0_active == 1) { + Xil_Out32(0xFD403004, 0); + Xil_Out32(0xFD403008, 0); + Xil_Out32(0xFD40300C, 0); + Xil_Out32(0xFD403010, 0); + Xil_Out32(0xFD403014, 0); + Xil_Out32(0xFD403018, 0); + Xil_Out32(0xFD40301C, 0); + Xil_Out32(0xFD403020, 0); + Xil_Out32(0xFD403024, 0); + Xil_Out32(0xFD403028, 0); + Xil_Out32(0xFD40302C, 0); + Xil_Out32(0xFD403030, 0); + Xil_Out32(0xFD403034, 0); + Xil_Out32(0xFD403038, 0); + Xil_Out32(0xFD40303C, 0); + Xil_Out32(0xFD403040, 0); + Xil_Out32(0xFD403044, 0); + Xil_Out32(0xFD403048, 0); + Xil_Out32(0xFD40304C, 0); + Xil_Out32(0xFD403050, 0); + Xil_Out32(0xFD403054, 0); + Xil_Out32(0xFD403058, 0); + Xil_Out32(0xFD403068, 1); + Xil_Out32(0xFD40306C, 0); + Xil_Out32(0xFD4010AC, 0); + psu_mask_write(0xFD410044, 0x00000003U, 0x00000001U); + psu_mask_write(0xFD410040, 0x00000003U, 0x00000001U); + psu_mask_write(0xFD410038, 0x00000007U, 0x00000000U); + } + if (lane1_active == 1) { + Xil_Out32(0xFD407004, 0); + Xil_Out32(0xFD407008, 0); + Xil_Out32(0xFD40700C, 0); + Xil_Out32(0xFD407010, 0); + Xil_Out32(0xFD407014, 0); + Xil_Out32(0xFD407018, 0); + Xil_Out32(0xFD40701C, 0); + Xil_Out32(0xFD407020, 0); + Xil_Out32(0xFD407024, 0); + Xil_Out32(0xFD407028, 0); + Xil_Out32(0xFD40702C, 0); + Xil_Out32(0xFD407030, 0); + Xil_Out32(0xFD407034, 0); + Xil_Out32(0xFD407038, 0); + Xil_Out32(0xFD40703C, 0); + Xil_Out32(0xFD407040, 0); + Xil_Out32(0xFD407044, 0); + Xil_Out32(0xFD407048, 0); + Xil_Out32(0xFD40704C, 0); + Xil_Out32(0xFD407050, 0); + Xil_Out32(0xFD407054, 0); + Xil_Out32(0xFD407058, 0); + Xil_Out32(0xFD407068, 1); + Xil_Out32(0xFD40706C, 0); + Xil_Out32(0xFD4050AC, 0); + psu_mask_write(0xFD410044, 0x0000000CU, 0x00000004U); + psu_mask_write(0xFD410040, 0x0000000CU, 0x00000004U); + psu_mask_write(0xFD410038, 0x00000070U, 0x00000000U); + } + if (lane2_active == 1) { + Xil_Out32(0xFD40B004, 0); + Xil_Out32(0xFD40B008, 0); + Xil_Out32(0xFD40B00C, 0); + Xil_Out32(0xFD40B010, 0); + Xil_Out32(0xFD40B014, 0); + Xil_Out32(0xFD40B018, 0); + Xil_Out32(0xFD40B01C, 0); + Xil_Out32(0xFD40B020, 0); + Xil_Out32(0xFD40B024, 0); + Xil_Out32(0xFD40B028, 0); + Xil_Out32(0xFD40B02C, 0); + Xil_Out32(0xFD40B030, 0); + Xil_Out32(0xFD40B034, 0); + Xil_Out32(0xFD40B038, 0); + Xil_Out32(0xFD40B03C, 0); + Xil_Out32(0xFD40B040, 0); + Xil_Out32(0xFD40B044, 0); + Xil_Out32(0xFD40B048, 0); + Xil_Out32(0xFD40B04C, 0); + Xil_Out32(0xFD40B050, 0); + Xil_Out32(0xFD40B054, 0); + Xil_Out32(0xFD40B058, 0); + Xil_Out32(0xFD40B068, 1); + Xil_Out32(0xFD40B06C, 0); + Xil_Out32(0xFD4090AC, 0); + psu_mask_write(0xFD410044, 0x00000030U, 0x00000010U); + psu_mask_write(0xFD410040, 0x00000030U, 0x00000010U); + psu_mask_write(0xFD41003C, 0x00000007U, 0x00000000U); + } + if (lane3_active == 1) { + Xil_Out32(0xFD40F004, 0); + Xil_Out32(0xFD40F008, 0); + Xil_Out32(0xFD40F00C, 0); + Xil_Out32(0xFD40F010, 0); + Xil_Out32(0xFD40F014, 0); + Xil_Out32(0xFD40F018, 0); + Xil_Out32(0xFD40F01C, 0); + Xil_Out32(0xFD40F020, 0); + Xil_Out32(0xFD40F024, 0); + Xil_Out32(0xFD40F028, 0); + Xil_Out32(0xFD40F02C, 0); + Xil_Out32(0xFD40F030, 0); + Xil_Out32(0xFD40F034, 0); + Xil_Out32(0xFD40F038, 0); + Xil_Out32(0xFD40F03C, 0); + Xil_Out32(0xFD40F040, 0); + Xil_Out32(0xFD40F044, 0); + Xil_Out32(0xFD40F048, 0); + Xil_Out32(0xFD40F04C, 0); + Xil_Out32(0xFD40F050, 0); + Xil_Out32(0xFD40F054, 0); + Xil_Out32(0xFD40F058, 0); + Xil_Out32(0xFD40F068, 1); + Xil_Out32(0xFD40F06C, 0); + Xil_Out32(0xFD40D0AC, 0); + psu_mask_write(0xFD410044, 0x000000C0U, 0x00000040U); + psu_mask_write(0xFD410040, 0x000000C0U, 0x00000040U); + psu_mask_write(0xFD41003C, 0x00000070U, 0x00000000U); + } + return 1; +} + +static int serdes_illcalib(u32 lane3_protocol, u32 lane3_rate, + u32 lane2_protocol, u32 lane2_rate, + u32 lane1_protocol, u32 lane1_rate, + u32 lane0_protocol, u32 lane0_rate) +{ + unsigned int rdata = 0; + unsigned int sata_gen2 = 1; + unsigned int temp_ill12 = 0; + unsigned int temp_PLL_REF_SEL_OFFSET; + unsigned int temp_TM_IQ_ILL1; + unsigned int temp_TM_E_ILL1; + unsigned int temp_tx_dig_tm_61; + unsigned int temp_tm_dig_6; + unsigned int temp_pll_fbdiv_frac_3_msb_offset; + + if (lane0_protocol == 2 || lane0_protocol == 1) { + Xil_Out32(0xFD401910, 0xF3); + Xil_Out32(0xFD40193C, 0xF3); + Xil_Out32(0xFD401914, 0xF3); + Xil_Out32(0xFD401940, 0xF3); + } + if (lane1_protocol == 2 || lane1_protocol == 1) { + Xil_Out32(0xFD405910, 0xF3); + Xil_Out32(0xFD40593C, 0xF3); + Xil_Out32(0xFD405914, 0xF3); + Xil_Out32(0xFD405940, 0xF3); + } + if (lane2_protocol == 2 || lane2_protocol == 1) { + Xil_Out32(0xFD409910, 0xF3); + Xil_Out32(0xFD40993C, 0xF3); + Xil_Out32(0xFD409914, 0xF3); + Xil_Out32(0xFD409940, 0xF3); + } + if (lane3_protocol == 2 || lane3_protocol == 1) { + Xil_Out32(0xFD40D910, 0xF3); + Xil_Out32(0xFD40D93C, 0xF3); + Xil_Out32(0xFD40D914, 0xF3); + Xil_Out32(0xFD40D940, 0xF3); + } + + if (sata_gen2 == 1) { + if (lane0_protocol == 2) { + temp_pll_fbdiv_frac_3_msb_offset = Xil_In32(0xFD402360); + Xil_Out32(0xFD402360, 0x0); + temp_PLL_REF_SEL_OFFSET = Xil_In32(0xFD410000); + psu_mask_write(0xFD410000, 0x0000001FU, 0x0000000DU); + temp_TM_IQ_ILL1 = Xil_In32(0xFD4018F8); + temp_TM_E_ILL1 = Xil_In32(0xFD401924); + Xil_Out32(0xFD4018F8, 0x78); + temp_tx_dig_tm_61 = Xil_In32(0xFD4000F4); + temp_tm_dig_6 = Xil_In32(0xFD40106C); + psu_mask_write(0xFD4000F4, 0x0000000BU, 0x00000000U); + psu_mask_write(0xFD40106C, 0x0000000FU, 0x00000000U); + temp_ill12 = Xil_In32(0xFD401990) & 0xF0; + + serdes_illcalib_pcie_gen1(0, 0, 0, 0, 0, 0, 0, 1, 0, 0); + + Xil_Out32(0xFD402360, temp_pll_fbdiv_frac_3_msb_offset); + Xil_Out32(0xFD410000, temp_PLL_REF_SEL_OFFSET); + Xil_Out32(0xFD4018F8, temp_TM_IQ_ILL1); + Xil_Out32(0xFD4000F4, temp_tx_dig_tm_61); + Xil_Out32(0xFD40106C, temp_tm_dig_6); + Xil_Out32(0xFD401928, Xil_In32(0xFD401924)); + temp_ill12 = + temp_ill12 | (Xil_In32(0xFD401990) >> 4 & 0xF); + Xil_Out32(0xFD401990, temp_ill12); + Xil_Out32(0xFD401924, temp_TM_E_ILL1); + } + if (lane1_protocol == 2) { + temp_pll_fbdiv_frac_3_msb_offset = Xil_In32(0xFD406360); + Xil_Out32(0xFD406360, 0x0); + temp_PLL_REF_SEL_OFFSET = Xil_In32(0xFD410004); + psu_mask_write(0xFD410004, 0x0000001FU, 0x0000000DU); + temp_TM_IQ_ILL1 = Xil_In32(0xFD4058F8); + temp_TM_E_ILL1 = Xil_In32(0xFD405924); + Xil_Out32(0xFD4058F8, 0x78); + temp_tx_dig_tm_61 = Xil_In32(0xFD4040F4); + temp_tm_dig_6 = Xil_In32(0xFD40506C); + psu_mask_write(0xFD4040F4, 0x0000000BU, 0x00000000U); + psu_mask_write(0xFD40506C, 0x0000000FU, 0x00000000U); + temp_ill12 = Xil_In32(0xFD405990) & 0xF0; + + serdes_illcalib_pcie_gen1(1, 0, 0, 0, 0, 1, 0, 0, 0, 0); + + Xil_Out32(0xFD406360, temp_pll_fbdiv_frac_3_msb_offset); + Xil_Out32(0xFD410004, temp_PLL_REF_SEL_OFFSET); + Xil_Out32(0xFD4058F8, temp_TM_IQ_ILL1); + Xil_Out32(0xFD4040F4, temp_tx_dig_tm_61); + Xil_Out32(0xFD40506C, temp_tm_dig_6); + Xil_Out32(0xFD405928, Xil_In32(0xFD405924)); + temp_ill12 = + temp_ill12 | (Xil_In32(0xFD405990) >> 4 & 0xF); + Xil_Out32(0xFD405990, temp_ill12); + Xil_Out32(0xFD405924, temp_TM_E_ILL1); + } + if (lane2_protocol == 2) { + temp_pll_fbdiv_frac_3_msb_offset = Xil_In32(0xFD40A360); + Xil_Out32(0xFD40A360, 0x0); + temp_PLL_REF_SEL_OFFSET = Xil_In32(0xFD410008); + psu_mask_write(0xFD410008, 0x0000001FU, 0x0000000DU); + temp_TM_IQ_ILL1 = Xil_In32(0xFD4098F8); + temp_TM_E_ILL1 = Xil_In32(0xFD409924); + Xil_Out32(0xFD4098F8, 0x78); + temp_tx_dig_tm_61 = Xil_In32(0xFD4080F4); + temp_tm_dig_6 = Xil_In32(0xFD40906C); + psu_mask_write(0xFD4080F4, 0x0000000BU, 0x00000000U); + psu_mask_write(0xFD40906C, 0x0000000FU, 0x00000000U); + temp_ill12 = Xil_In32(0xFD409990) & 0xF0; + + serdes_illcalib_pcie_gen1(2, 0, 0, 1, 0, 0, 0, 0, 0, 0); + + Xil_Out32(0xFD40A360, temp_pll_fbdiv_frac_3_msb_offset); + Xil_Out32(0xFD410008, temp_PLL_REF_SEL_OFFSET); + Xil_Out32(0xFD4098F8, temp_TM_IQ_ILL1); + Xil_Out32(0xFD4080F4, temp_tx_dig_tm_61); + Xil_Out32(0xFD40906C, temp_tm_dig_6); + Xil_Out32(0xFD409928, Xil_In32(0xFD409924)); + temp_ill12 = + temp_ill12 | (Xil_In32(0xFD409990) >> 4 & 0xF); + Xil_Out32(0xFD409990, temp_ill12); + Xil_Out32(0xFD409924, temp_TM_E_ILL1); + } + if (lane3_protocol == 2) { + temp_pll_fbdiv_frac_3_msb_offset = Xil_In32(0xFD40E360); + Xil_Out32(0xFD40E360, 0x0); + temp_PLL_REF_SEL_OFFSET = Xil_In32(0xFD41000C); + psu_mask_write(0xFD41000C, 0x0000001FU, 0x0000000DU); + temp_TM_IQ_ILL1 = Xil_In32(0xFD40D8F8); + temp_TM_E_ILL1 = Xil_In32(0xFD40D924); + Xil_Out32(0xFD40D8F8, 0x78); + temp_tx_dig_tm_61 = Xil_In32(0xFD40C0F4); + temp_tm_dig_6 = Xil_In32(0xFD40D06C); + psu_mask_write(0xFD40C0F4, 0x0000000BU, 0x00000000U); + psu_mask_write(0xFD40D06C, 0x0000000FU, 0x00000000U); + temp_ill12 = Xil_In32(0xFD40D990) & 0xF0; + + serdes_illcalib_pcie_gen1(3, 1, 0, 0, 0, 0, 0, 0, 0, 0); + + Xil_Out32(0xFD40E360, temp_pll_fbdiv_frac_3_msb_offset); + Xil_Out32(0xFD41000C, temp_PLL_REF_SEL_OFFSET); + Xil_Out32(0xFD40D8F8, temp_TM_IQ_ILL1); + Xil_Out32(0xFD40C0F4, temp_tx_dig_tm_61); + Xil_Out32(0xFD40D06C, temp_tm_dig_6); + Xil_Out32(0xFD40D928, Xil_In32(0xFD40D924)); + temp_ill12 = + temp_ill12 | (Xil_In32(0xFD40D990) >> 4 & 0xF); + Xil_Out32(0xFD40D990, temp_ill12); + Xil_Out32(0xFD40D924, temp_TM_E_ILL1); + } + rdata = Xil_In32(0xFD410098); + rdata = (rdata & 0xDF); + Xil_Out32(0xFD410098, rdata); + } + + if (lane0_protocol == 2 && lane0_rate == 3) { + psu_mask_write(0xFD40198C, 0x000000F0U, 0x00000020U); + psu_mask_write(0xFD40192C, 0x000000FFU, 0x00000094U); + } + if (lane1_protocol == 2 && lane1_rate == 3) { + psu_mask_write(0xFD40598C, 0x000000F0U, 0x00000020U); + psu_mask_write(0xFD40592C, 0x000000FFU, 0x00000094U); + } + if (lane2_protocol == 2 && lane2_rate == 3) { + psu_mask_write(0xFD40998C, 0x000000F0U, 0x00000020U); + psu_mask_write(0xFD40992C, 0x000000FFU, 0x00000094U); + } + if (lane3_protocol == 2 && lane3_rate == 3) { + psu_mask_write(0xFD40D98C, 0x000000F0U, 0x00000020U); + psu_mask_write(0xFD40D92C, 0x000000FFU, 0x00000094U); + } + + if (lane0_protocol == 1) { + if (lane0_rate == 0) { + serdes_illcalib_pcie_gen1(0, lane3_protocol, lane3_rate, + lane2_protocol, lane2_rate, + lane1_protocol, lane1_rate, + lane0_protocol, 0, 0); + } else { + serdes_illcalib_pcie_gen1(0, lane3_protocol, lane3_rate, + lane2_protocol, lane2_rate, + lane1_protocol, lane1_rate, + lane0_protocol, 0, 0); + serdes_illcalib_pcie_gen1(0, lane3_protocol, lane3_rate, + lane2_protocol, lane2_rate, + lane1_protocol, lane1_rate, + lane0_protocol, lane0_rate, + 1); + } + } + + if (lane0_protocol == 3) + Xil_Out32(0xFD401914, 0xF3); + if (lane0_protocol == 3) + Xil_Out32(0xFD401940, 0xF3); + if (lane0_protocol == 3) + Xil_Out32(0xFD401990, 0x20); + if (lane0_protocol == 3) + Xil_Out32(0xFD401924, 0x37); + + if (lane1_protocol == 3) + Xil_Out32(0xFD405914, 0xF3); + if (lane1_protocol == 3) + Xil_Out32(0xFD405940, 0xF3); + if (lane1_protocol == 3) + Xil_Out32(0xFD405990, 0x20); + if (lane1_protocol == 3) + Xil_Out32(0xFD405924, 0x37); + + if (lane2_protocol == 3) + Xil_Out32(0xFD409914, 0xF3); + if (lane2_protocol == 3) + Xil_Out32(0xFD409940, 0xF3); + if (lane2_protocol == 3) + Xil_Out32(0xFD409990, 0x20); + if (lane2_protocol == 3) + Xil_Out32(0xFD409924, 0x37); + + if (lane3_protocol == 3) + Xil_Out32(0xFD40D914, 0xF3); + if (lane3_protocol == 3) + Xil_Out32(0xFD40D940, 0xF3); + if (lane3_protocol == 3) + Xil_Out32(0xFD40D990, 0x20); + if (lane3_protocol == 3) + Xil_Out32(0xFD40D924, 0x37); + + return 1; +} + +static void dpll_prog(int div2, int ddr_pll_fbdiv, int d_lock_dly, + int d_lock_cnt, int d_lfhf, int d_cp, int d_res) +{ + unsigned int pll_ctrl_regval; + unsigned int pll_status_regval; + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00010000U); + pll_ctrl_regval = pll_ctrl_regval | (div2 << 16); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x00000030)); + pll_ctrl_regval = pll_ctrl_regval & (~0xFE000000U); + pll_ctrl_regval = pll_ctrl_regval | (d_lock_dly << 25); + Xil_Out32(((0xFD1A0000U) + 0x00000030), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x00000030)); + pll_ctrl_regval = pll_ctrl_regval & (~0x007FE000U); + pll_ctrl_regval = pll_ctrl_regval | (d_lock_cnt << 13); + Xil_Out32(((0xFD1A0000U) + 0x00000030), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x00000030)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00000C00U); + pll_ctrl_regval = pll_ctrl_regval | (d_lfhf << 10); + Xil_Out32(((0xFD1A0000U) + 0x00000030), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x00000030)); + pll_ctrl_regval = pll_ctrl_regval & (~0x000001E0U); + pll_ctrl_regval = pll_ctrl_regval | (d_cp << 5); + Xil_Out32(((0xFD1A0000U) + 0x00000030), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x00000030)); + pll_ctrl_regval = pll_ctrl_regval & (~0x0000000FU); + pll_ctrl_regval = pll_ctrl_regval | (d_res << 0); + Xil_Out32(((0xFD1A0000U) + 0x00000030), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00007F00U); + pll_ctrl_regval = pll_ctrl_regval | (ddr_pll_fbdiv << 8); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00000008U); + pll_ctrl_regval = pll_ctrl_regval | (1 << 3); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00000001U); + pll_ctrl_regval = pll_ctrl_regval | (1 << 0); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00000001U); + pll_ctrl_regval = pll_ctrl_regval | (0 << 0); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); + + pll_status_regval = 0x00000000; + while ((pll_status_regval & 0x00000002U) != 0x00000002U) + pll_status_regval = Xil_In32(((0xFD1A0000U) + 0x00000044)); + + pll_ctrl_regval = Xil_In32(((0xFD1A0000U) + 0x0000002C)); + pll_ctrl_regval = pll_ctrl_regval & (~0x00000008U); + pll_ctrl_regval = pll_ctrl_regval | (0 << 3); + Xil_Out32(((0xFD1A0000U) + 0x0000002C), pll_ctrl_regval); +} + +static int serdes_enb_coarse_saturation(void) +{ + Xil_Out32(0xFD402094, 0x00000010); + Xil_Out32(0xFD406094, 0x00000010); + Xil_Out32(0xFD40A094, 0x00000010); + Xil_Out32(0xFD40E094, 0x00000010); + return 1; +} + +static int serdes_fixcal_code(void) +{ + int maskstatus = 1; + unsigned int rdata = 0; + unsigned int match_pmos_code[23]; + unsigned int match_nmos_code[23]; + unsigned int match_ical_code[7]; + unsigned int match_rcal_code[7]; + unsigned int p_code = 0; + unsigned int n_code = 0; + unsigned int i_code = 0; + unsigned int r_code = 0; + unsigned int repeat_count = 0; + unsigned int L3_TM_CALIB_DIG20 = 0; + unsigned int L3_TM_CALIB_DIG19 = 0; + unsigned int L3_TM_CALIB_DIG18 = 0; + unsigned int L3_TM_CALIB_DIG16 = 0; + unsigned int L3_TM_CALIB_DIG15 = 0; + unsigned int L3_TM_CALIB_DIG14 = 0; + int i = 0; + int count = 0; + + rdata = Xil_In32(0xFD40289C); + rdata = rdata & ~0x03; + rdata = rdata | 0x1; + Xil_Out32(0xFD40289C, rdata); + + do { + if (count == 1100000) + break; + rdata = Xil_In32(0xFD402B1C); + count++; + } while ((rdata & 0x0000000E) != 0x0000000E); + + for (i = 0; i < 23; i++) { + match_pmos_code[i] = 0; + match_nmos_code[i] = 0; + } + for (i = 0; i < 7; i++) { + match_ical_code[i] = 0; + match_rcal_code[i] = 0; + } + + do { + Xil_Out32(0xFD410010, 0x00000000); + Xil_Out32(0xFD410014, 0x00000000); + + Xil_Out32(0xFD410010, 0x00000001); + Xil_Out32(0xFD410014, 0x00000000); + + maskstatus = mask_poll(0xFD40EF14, 0x2); + if (maskstatus == 0) { + xil_printf("#SERDES initialization timed out\n\r"); + return maskstatus; + } + + p_code = mask_read(0xFD40EF18, 0xFFFFFFFF); + n_code = mask_read(0xFD40EF1C, 0xFFFFFFFF); + ; + i_code = mask_read(0xFD40EF24, 0xFFFFFFFF); + r_code = mask_read(0xFD40EF28, 0xFFFFFFFF); + ; + + if (p_code >= 0x26 && p_code <= 0x3C) + match_pmos_code[p_code - 0x26] += 1; + + if (n_code >= 0x26 && n_code <= 0x3C) + match_nmos_code[n_code - 0x26] += 1; + + if (i_code >= 0xC && i_code <= 0x12) + match_ical_code[i_code - 0xc] += 1; + + if (r_code >= 0x6 && r_code <= 0xC) + match_rcal_code[r_code - 0x6] += 1; + + } while (repeat_count++ < 10); + + for (i = 0; i < 23; i++) { + if (match_pmos_code[i] >= match_pmos_code[0]) { + match_pmos_code[0] = match_pmos_code[i]; + p_code = 0x26 + i; + } + if (match_nmos_code[i] >= match_nmos_code[0]) { + match_nmos_code[0] = match_nmos_code[i]; + n_code = 0x26 + i; + } + } + + for (i = 0; i < 7; i++) { + if (match_ical_code[i] >= match_ical_code[0]) { + match_ical_code[0] = match_ical_code[i]; + i_code = 0xC + i; + } + if (match_rcal_code[i] >= match_rcal_code[0]) { + match_rcal_code[0] = match_rcal_code[i]; + r_code = 0x6 + i; + } + } + + L3_TM_CALIB_DIG20 = mask_read(0xFD40EC50, 0xFFFFFFF0); + L3_TM_CALIB_DIG20 = L3_TM_CALIB_DIG20 | 0x8 | ((p_code >> 2) & 0x7); + + L3_TM_CALIB_DIG19 = mask_read(0xFD40EC4C, 0xFFFFFF18); + L3_TM_CALIB_DIG19 = L3_TM_CALIB_DIG19 | ((p_code & 0x3) << 6) + | 0x20 | 0x4 | ((n_code >> 3) & 0x3); + + L3_TM_CALIB_DIG18 = mask_read(0xFD40EC48, 0xFFFFFF0F); + L3_TM_CALIB_DIG18 = L3_TM_CALIB_DIG18 | ((n_code & 0x7) << 5) | 0x10; + + L3_TM_CALIB_DIG16 = mask_read(0xFD40EC40, 0xFFFFFFF8); + L3_TM_CALIB_DIG16 = L3_TM_CALIB_DIG16 | ((r_code >> 1) & 0x7); + + L3_TM_CALIB_DIG15 = mask_read(0xFD40EC3C, 0xFFFFFF30); + L3_TM_CALIB_DIG15 = L3_TM_CALIB_DIG15 | ((r_code & 0x1) << 7) + | 0x40 | 0x8 | ((i_code >> 1) & 0x7); + + L3_TM_CALIB_DIG14 = mask_read(0xFD40EC38, 0xFFFFFF3F); + L3_TM_CALIB_DIG14 = L3_TM_CALIB_DIG14 | ((i_code & 0x1) << 7) | 0x40; + + Xil_Out32(0xFD40EC50, L3_TM_CALIB_DIG20); + Xil_Out32(0xFD40EC4C, L3_TM_CALIB_DIG19); + Xil_Out32(0xFD40EC48, L3_TM_CALIB_DIG18); + Xil_Out32(0xFD40EC40, L3_TM_CALIB_DIG16); + Xil_Out32(0xFD40EC3C, L3_TM_CALIB_DIG15); + Xil_Out32(0xFD40EC38, L3_TM_CALIB_DIG14); + return maskstatus; +} + +static int init_serdes(void) +{ + int status = 1; + + status &= psu_resetin_init_data(); + + status &= serdes_fixcal_code(); + status &= serdes_enb_coarse_saturation(); + + status &= psu_serdes_init_data(); + status &= psu_resetout_init_data(); + + return status; +} + +static void init_peripheral(void) +{ + psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU); +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_peripherals_pre_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + status &= init_serdes(); + init_peripheral(); + + status &= psu_afi_config(); + psu_ddr_qos_init_data(); + + if (status == 0) + return 1; + return 0; +}
Michal Simek
