[PATCH v2 11/21] dts: mtmips: remove all unusable nodes and properties from mt7628s.dtsi
This patch removes all unused and unusable nodes and properties from mt7628s.dtsi.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v1: splitted from another patch --- arch/mips/dts/mt7628a.dtsi | 68 -------------------------------------- 1 file changed, 68 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index cdc643fe37..3d7b839e6d 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -7,24 +7,6 @@ #size-cells = <1>; compatible = "ralink,mt7628a-soc";
- cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu@0 { - compatible = "mti,mips24KEc"; - device_type = "cpu"; - reg = <0>; - }; - }; - - cpuintc: interrupt-controller { - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - compatible = "mti,cpu-interrupt-controller"; - }; - clk48m: clk48m@0 { compatible = "fixed-clock";
@@ -41,11 +23,6 @@ #address-cells = <1>; #size-cells = <1>;
- sysc: system-controller@0 { - compatible = "ralink,mt7620a-sysc", "syscon"; - reg = <0x0 0x100>; - }; - resetctl-reboot { compatible = "resetctl-reboot";
@@ -223,32 +200,6 @@
resets = <&rstctrl MT7628_TIMER_RST>; reset-names = "wdt"; - - interrupt-parent = <&intc>; - interrupts = <24>; - }; - - intc: interrupt-controller@200 { - compatible = "ralink,rt2880-intc"; - reg = <0x200 0x100>; - - interrupt-controller; - #interrupt-cells = <1>; - - resets = <&rstctrl MT7628_INT_RST>; - reset-names = "intc"; - - interrupt-parent = <&cpuintc>; - interrupts = <2>; - - ralink,intc-registers = <0x9c 0xa0 - 0x6c 0xa4 - 0x80 0x78>; - }; - - memory-controller@300 { - compatible = "ralink,mt7620a-memc"; - reg = <0x300 0x100>; };
gpio@600 { @@ -261,9 +212,6 @@ resets = <&rstctrl MT7628_PIO_RST>; reset-names = "pio";
- interrupt-parent = <&intc>; - interrupts = <6>; - gpio0: bank@0 { reg = <0>; compatible = "mtk,mt7621-gpio-bank"; @@ -311,9 +259,6 @@ resets = <&rstctrl MT7628_UART0_RST>; reset-names = "uart0";
- interrupt-parent = <&intc>; - interrupts = <20>; - reg-shift = <2>; };
@@ -329,9 +274,6 @@ resets = <&rstctrl MT7628_UART1_RST>; reset-names = "uart1";
- interrupt-parent = <&intc>; - interrupts = <21>; - reg-shift = <2>; };
@@ -347,9 +289,6 @@ resets = <&rstctrl MT7628_UART2_RST>; reset-names = "uart2";
- interrupt-parent = <&intc>; - interrupts = <22>; - reg-shift = <2>; }; }; @@ -361,8 +300,6 @@
resets = <&rstctrl MT7628_EPHY_RST>; reset-names = "ephy"; - - syscon = <&sysc>; };
usb_phy: usb-phy@10120000 { @@ -371,8 +308,6 @@
#phy-cells = <0>;
- ralink,sysctl = <&sysc>; - resets = <&rstctrl MT7628_UPHY_RST>; reset-names = "phy";
@@ -386,9 +321,6 @@
phys = <&usb_phy>; phy-names = "usb"; - - interrupt-parent = <&intc>; - interrupts = <18>; };
mmc: mmc@10130000 {
Please don't remove the unused parts. As mentioned before, we try to stay as close to the official DT files from the Linux tree as possible. Goal is to sync with Linux at some time. This is already done on other architectures / boards.
Thanks, Stefan
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
reg = <0x0 0x100>;
interrupts = <24>;
interrupts = <2>;
0x6c 0xa4
0x80 0x78>;
gpio@600 {
interrupts = <6>;
interrupts = <20>;
};reg-shift = <2>;
interrupts = <21>;
};reg-shift = <2>;
interrupts = <22>;
}; };reg-shift = <2>;
@@ -361,8 +300,6 @@
syscon = <&sysc>;
@@ -371,8 +308,6 @@
#phy-cells = <0>;
@@ -386,9 +321,6 @@
interrupts = <18>;
mmc: mmc@10130000 {
Viele Grüße, Stefan
OK. I'll drop this one.
Thanks, Stefan
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
reg = <0x0 0x100>;
interrupts = <24>;
interrupts = <2>;
0x6c 0xa4
0x80 0x78>;
gpio@600 {
interrupts = <6>;
interrupts = <20>;
};reg-shift = <2>;
interrupts = <21>;
};reg-shift = <2>;
interrupts = <22>;
@@ -361,8 +300,6 @@
syscon = <&sysc>;
@@ -371,8 +308,6 @@
#phy-cells = <0>;
@@ -386,9 +321,6 @@
interrupts = <18>;
mmc: mmc@10130000 {
Viele Grüße, Stefan
Stefan Roese
Weijie Gao
