[PATCH v2 1/3] fdtdec: optionally add property no-map to created reserved memory node
Add boolean input argument @no_map to helper function fdtdec_add_reserved_memory() to add "no-map" property for an added reserved memory node. This is needed for example when the reserved memory relates to secure memory that the dear Linux kernel shall not even map unless what non-secure world speculative accesses of the CPU can violate the memory firmware configuration.
No function change. A later change will update to OPTEE library to add no-map property to OP-TEE reserved memory nodes.
Signed-off-by: Etienne Carriere etienne.carriere@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com - fix dm fdtdec test and arch/riscv/lib/fdt_fixup.c with fdtdec_add_reserved_memory() new parameter
(no changes since v1)
arch/riscv/lib/fdt_fixup.c | 2 +- include/fdtdec.h | 5 +++-- lib/fdtdec.c | 10 ++++++++-- lib/optee/optee.c | 2 +- test/dm/fdtdec.c | 6 +++--- 5 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index 5b2420243f..d02062fd5b 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -75,7 +75,7 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) pmp_mem.start = addr; pmp_mem.end = addr + size - 1; err = fdtdec_add_reserved_memory(dst, basename, &pmp_mem, - &phandle); + &phandle, false); if (err < 0 && err != -FDT_ERR_EXISTS) { log_err("failed to add reserved memory: %d\n", err); return err; diff --git a/include/fdtdec.h b/include/fdtdec.h index bc79389260..f127c7d386 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -1016,7 +1016,7 @@ static inline int fdtdec_set_phandle(void *blob, int node, uint32_t phandle) * }; * uint32_t phandle; * - * fdtdec_add_reserved_memory(fdt, "framebuffer", &fb, &phandle); + * fdtdec_add_reserved_memory(fdt, "framebuffer", &fb, &phandle, false); * * This results in the following subnode being added to the top-level * /reserved-memory node: @@ -1043,11 +1043,12 @@ static inline int fdtdec_set_phandle(void *blob, int node, uint32_t phandle) * @param carveout information about the carveout region * @param phandlep return location for the phandle of the carveout region * can be NULL if no phandle should be added + * @param no_map add "no-map" property if true * @return 0 on success or a negative error code on failure */ int fdtdec_add_reserved_memory(void *blob, const char *basename, const struct fdt_memory *carveout, - uint32_t *phandlep); + uint32_t *phandlep, bool no_map);
/** * fdtdec_get_carveout() - reads a carveout from an FDT diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 30a1c6a217..bf40d87cb3 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1303,7 +1303,7 @@ static int fdtdec_init_reserved_memory(void *blob)
int fdtdec_add_reserved_memory(void *blob, const char *basename, const struct fdt_memory *carveout, - uint32_t *phandlep) + uint32_t *phandlep, bool no_map) { fdt32_t cells[4] = {}, *ptr = cells; uint32_t upper, lower, phandle; @@ -1403,6 +1403,12 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, if (err < 0) return err;
+ if (no_map) { + err = fdt_setprop(blob, node, "no-map", NULL, 0); + if (err < 0) + return err; + } + /* return the phandle for the new node for the caller to use */ if (phandlep) *phandlep = phandle; @@ -1468,7 +1474,7 @@ int fdtdec_set_carveout(void *blob, const char *node, const char *prop_name, fdt32_t value; void *prop;
- err = fdtdec_add_reserved_memory(blob, name, carveout, &phandle); + err = fdtdec_add_reserved_memory(blob, name, carveout, &phandle, false); if (err < 0) { debug("failed to add reserved memory: %d\n", err); return err; diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 457d4cca8a..963c2ff430 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -192,7 +192,7 @@ int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) ret = fdtdec_add_reserved_memory(new_blob, nodename, &carveout, - NULL); + NULL, false); free(oldname);
if (ret < 0) diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index 716993f706..4119003041 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -80,7 +80,7 @@ static int dm_test_fdtdec_add_reserved_memory(struct unit_test_state *uts) resv.start = 0x1000; resv.end = 0x1fff; ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region", - &resv, &phandle)); + &resv, &phandle, false));
/* Test /reserve-memory and its subnode should exist */ parent = fdt_path_offset(blob, "/reserved-memory"); @@ -101,7 +101,7 @@ static int dm_test_fdtdec_add_reserved_memory(struct unit_test_state *uts) resv.start = 0x2000; resv.end = 0x2fff; ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region1", - &resv, &phandle1)); + &resv, &phandle1, false)); subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region1"); ut_assert(subnode > 0);
@@ -115,7 +115,7 @@ static int dm_test_fdtdec_add_reserved_memory(struct unit_test_state *uts) resv.start = 0x1000; resv.end = 0x1fff; ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region2", - &resv, &phandle1)); + &resv, &phandle1, false)); subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region2"); ut_assert(subnode < 0);
Add a test to verify that the no-map property is added in reserved-memory node when fdtdec_add_reserved_memory() no-map parameter is set to true.
- Add no-map property test into fdtdec test
test/dm/fdtdec.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index 4119003041..017157a2ec 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -101,10 +101,13 @@ static int dm_test_fdtdec_add_reserved_memory(struct unit_test_state *uts) resv.start = 0x2000; resv.end = 0x2fff; ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region1", - &resv, &phandle1, false)); + &resv, &phandle1, true)); subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region1"); ut_assert(subnode > 0);
+ /* check that no-map property is present */ + ut_assert(fdt_getprop(blob, subnode, "no-map", NULL) > 0); + /* phandles must be different */ ut_assert(phandle != phandle1);
OP-TEE reserved memory node must set property "no-map" to prevent Linux kernel from mapping secure memory unless what non-secure world speculative accesses of the CPU can violate the memory firmware configuration.
Fixes: 6ccb05eae01b ("image: fdt: copy possible optee nodes to a loaded devicetree") Signed-off-by: Etienne Carriere etienne.carriere@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
lib/optee/optee.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 963c2ff430..9e6606568f 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -192,7 +192,7 @@ int optee_copy_fdt_nodes(const void *old_blob, void *new_blob) ret = fdtdec_add_reserved_memory(new_blob, nodename, &carveout, - NULL, false); + NULL, true); free(oldname);
if (ret < 0)
There is an issue with series-changes tag, i will resend a v3
&phandle);
if (err < 0 && err != -FDT_ERR_EXISTS) { log_err("failed to add reserved memory: %d\n", err); return err;&phandle, false);
uint32_t phandle;
- This results in the following subnode being added to the top-level
- /reserved-memory node:
- @param carveout information about the carveout region
- @param phandlep return location for the phandle of the carveout region
- @param no_map add "no-map" property if true
- @return 0 on success or a negative error code on failure
- fdtdec_get_carveout() - reads a carveout from an FDT
uint32_t *phandlep)
- if (no_map) {
if (err < 0)
return err;
- /* return the phandle for the new node for the caller to use */ if (phandlep) *phandlep = phandle;
- err = fdtdec_add_reserved_memory(blob, name, carveout, &phandle, false); if (err < 0) { debug("failed to add reserved memory: %d\n", err); return err;
NULL);
NULL, false); free(oldname); if (ret < 0)
&resv, &phandle));
&resv, &phandle1));
subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region1"); ut_assert(subnode > 0);&resv, &phandle1, false));
&resv, &phandle1));
subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region2"); ut_assert(subnode < 0);&resv, &phandle1, false));
Patrice CHOTARD
Patrice Chotard
