[U-Boot] [PATCH] net: Make sure IPaddr_t is 32 bits in size
When building u-boot as 64 bit application (e.g. sandbox) ulong might be 64 bits in size. This breaks network code as IPaddr_t is 64 bytes in size then. This patch makes sure that IPaddr_t is always 32 bits in size. Also some warnings introduced by this patch are fixed.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- include/net.h | 2 +- net/net.c | 6 +++--- net/nfs.c | 2 +- net/tftp.c | 2 +- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/net.h b/include/net.h index ad9afbf..9d878e5 100644 --- a/include/net.h +++ b/include/net.h @@ -33,7 +33,7 @@
#define PKTALIGN 32
-typedef ulong IPaddr_t; +typedef u32 IPaddr_t;
/** diff --git a/net/net.c b/net/net.c index d0fe1c4..045405b 100644 --- a/net/net.c +++ b/net/net.c @@ -728,7 +728,7 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) */ if (memcmp(ether, NetEtherNullAddr, 6) == 0) {
- debug("sending ARP for %08lx\n", dest); + debug("sending ARP for %08x\n", dest);
NetArpWaitPacketIP = dest; NetArpWaitPacketMAC = ether; @@ -751,7 +751,7 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len) return 1; /* waiting */ }
- debug("sending UDP to %08lx/%pM\n", dest, ether); + debug("sending UDP to %08x/%pM\n", dest, ether);
pkt = (uchar *)NetTxPacket; pkt += NetSetEther(pkt, ether, PROT_IP); @@ -775,7 +775,7 @@ int PingSend(void)
memcpy(mac, NetEtherNullAddr, 6);
- debug("sending ARP for %08lx\n", NetPingIP); + debug("sending ARP for %08x\n", NetPingIP);
NetArpWaitPacketIP = NetPingIP; NetArpWaitPacketMAC = mac; diff --git a/net/nfs.c b/net/nfs.c index 5e717e3..b5b482c 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -688,7 +688,7 @@ NfsStart (void) }
if (BootFile[0] == '\0') { - sprintf (default_filename, "/nfsroot/%02lX%02lX%02lX%02lX.img", + sprintf(default_filename, "/nfsroot/%02X%02X%02X%02X.img", NetOurIP & 0xFF, (NetOurIP >> 8) & 0xFF, (NetOurIP >> 16) & 0xFF, diff --git a/net/tftp.c b/net/tftp.c index 4999707..7aa3e23 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -708,7 +708,7 @@ void TftpStart(enum proto_t protocol)
TftpRemoteIP = NetServerIP; if (BootFile[0] == '\0') { - sprintf(default_filename, "%02lX%02lX%02lX%02lX.img", + sprintf(default_filename, "%02X%02X%02X%02X.img", NetOurIP & 0xFF, (NetOurIP >> 8) & 0xFF, (NetOurIP >> 16) & 0xFF,
Acked-by: Mike Frysinger vapier@gentoo.org -mike
on 2nd thought, could you clarify why we want it to be 32bits ? it's because that's the size of the address field in an IPv4 packet ...
and add a comment here too ... -mike
When building u-boot as 64 bit application (e.g. sandbox) ulong might be 64 bits in size. This breaks network code as IPaddr_t is 64 bytes in size then and an IPv4 address is 32 bits in size. This patch makes sure that IPaddr_t is always 32 bits in size. Also some warnings introduced by this patch are fixed.
Signed-off-by: Matthias Weisser weisserm@arcor.de Acked-by: Mike Frysinger vapier@gentoo.org --- Changes in v2: Added explicit information about 32 bit size of IPv4 addresses in commit message and source comment.
include/net.h | 3 ++- net/net.c | 6 +++--- net/nfs.c | 2 +- net/tftp.c | 2 +- 4 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/include/net.h b/include/net.h index ad9afbf..fa5d525 100644 --- a/include/net.h +++ b/include/net.h @@ -33,7 +33,8 @@
#define PKTALIGN 32
-typedef ulong IPaddr_t; +/* IPv4 addresses are always 32 bits in size */ +typedef u32 IPaddr_t;
Dear Matthias Weisser,
Applied, thanks.
Matthias Weisser
Mike Frysinger
