[U-Boot] [RFC PATCH v3] usb: limit USB_MAX_XFER_BLK to 256
For Some USB mass storage devices, such as: " - Kingston DataTraveler 2.0 001D7D06CF09B04199C7B3EA - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x0930 Product 0x6545 Version 1.16 " When `usb read 0x80000000 0 0x2000`, we met "EHCI timed out on TD - token=0x80008d80".
The devices does not support scsi VPD page, we are not able to get the maximum transfer length for READ(10)/WRITE(10).
So we limit this to 256 blocks as READ(6).
Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com (cherry picked from commit df0052575b2bc9d66ae73584768e1a457ed5d914)
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com
--- This comes from NXP's downstream and has proven to tremendously improve the situation with those odd USB mass storage aka memory sticks. This is why I post it here asking whether or not this may be something benefiting more people. Any feedback and suggestions are welcome.
Changes in v3: - Drop the reference to the NXP internal MLK-xxx tracking number as suggested by Peng.
Changes in v2: - Fixed spelling in comment as suggested by Igor.
common/usb_storage.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 8c889bb1a6..4e284645f5 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -949,7 +949,11 @@ static void usb_stor_set_max_xfer_blk(struct usb_device *udev, * there is enough free heap space left, but the SCSI READ(10) and * WRITE(10) commands are limited to 65535 blocks. */ - blk = USHRT_MAX; + /* + * Some USB mass storage devices have issues, limiting this to 256 + * fixes this. + */ + blk = 256; #else blk = 20; #endif
Changes in v3:
Changes in v2:
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
Seems like the previous comment, right above this new one, contradicts this claim. Please update the original comment.
That said, there was an attempt to fix this properly by using adaptive block length implementation, which would not impact devices that are not broken. This hack above will degrade performance of such good devices. Maybe you can resuscitate that adaptive approach instead ?
I am using an iMX7 with a DataTraveler 3.0 and I’m seeing the same timeout error. However, I have CONFIG_DM_USB=y configured so your patch doesn’t fix my issue. The USB class queries the EHCI driver for its maximum transfer size which is SIZE_MAX. I believe a solution that works with DM is necessary.
=> usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 300mA) Kingston DataTraveler 3.0 50E54942694AE23017A55884
=> usb storage Device 0: Vendor: Kingston Rev: PMAP Prod: DataTraveler 3.0 Type: Removable Hard Disk Capacity: 59184.0 MB = 57.7 GB (121208832 x 512)
Best regards, Sven
Changes in v3:
suggested by Peng.
Changes in v2:
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
#else blk = 20;
#endif
2.20.1
Subject: Re: [RFC PATCH v3] usb: limit USB_MAX_XFER_BLK to 256
Does the patch works for you with non DM usb?
Regards, Peng
Best regards, Sven
welcome.
Changes in v3:
suggested by Peng.
Changes in v2:
usb_device *udev,
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
#else blk = 20;
#endif
2.20.1
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Peng Fan Sent: 2019年4月24日 16:57 To: Sven Schwermer sven@svenschwermer.de; Marcel Ziswiler marcel@ziswiler.com Cc: Marek Vasut marex@denx.de; Marcel Ziswiler marcel.ziswiler@toradex.com; u-boot@lists.denx.de Subject: Re: [U-Boot] [RFC PATCH v3] usb: limit USB_MAX_XFER_BLK to 256
Just a quick hack with DM usb, please help verify whether it could fix your issue.
diff --git a/common/usb_storage.c b/common/usb_storage.c index 8c889bb1a6..0eb63c21f4 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -965,7 +965,7 @@ static void usb_stor_set_max_xfer_blk(struct usb_device *udev, } #endif
- us->max_xfer_blk = blk; + us->max_xfer_blk = 256; }
static int usb_inquiry(struct scsi_cmd *srb, struct us_data *ss)
Regards, Peng.
Regards, Peng
Best regards, Sven
welcome.
Changes in v3:
suggested by Peng.
Changes in v2:
usb_device *udev,
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
#else blk = 20;
#endif
2.20.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.d enx.de%2Flistinfo%2Fu-boot&data=02%7C01%7CPeng.Fan%40nxp.com %7C92e70f2854ce4eda6cf908d6c892e747%7C686ea1d3bc2b4c6fa92cd99c5 c301635%7C0%7C0%7C636916930623480866&sdata=5DyOZrU55x3Y9 1wuaK%2BmKZsFu4PtUMwd81qNC91MshE%3D&reserved=0
Hi Peng,
Yes, this works.
Best regards, Sven
Regards, Peng.
Regards, Peng
Best regards, Sven
welcome.
Changes in v3:
suggested by Peng.
Changes in v2:
usb_device *udev,
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
#else blk = 20;
#endif
2.20.1
Hi Peng,
Yes, this works.
Thanks for verification, so it is same issue.
Thanks, Peng.
Best regards, Sven
issue.
usb_device *udev,
#endif
Regards, Peng.
Regards, Peng
Best regards, Sven
welcome.
Changes in v3:
suggested by Peng.
Changes in v2:
usb_device *udev,
- blk = USHRT_MAX;
* fixes this.
- blk = 256;
#else blk = 20;
#endif
2.20.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flis ts.d
9c5
Marcel Ziswiler
Peng Fan
Sven Schwermer
