[U-Boot] [PATCH v2] PCIe, USB: Replace 'end point' references with 'endpoint'
When referring to PCIe and USB 'endpoint' is the standard naming convention.
Signed-off-by: Peter Tyser ptyser@xes-inc.com Acked-by: Stefan Roese sr@denx.de Acked-by: Remy Bohmer linux@bohmer.net --- Changes since v1: Rebased on TOT
board/amcc/yucca/yucca.c | 2 +- board/atum8548/atum8548.c | 2 +- board/freescale/mpc8536ds/mpc8536ds.c | 6 +++--- board/freescale/mpc8544ds/mpc8544ds.c | 6 +++--- board/freescale/mpc8548cds/mpc8548cds.c | 2 +- board/freescale/mpc8568mds/mpc8568mds.c | 2 +- board/freescale/mpc8569mds/mpc8569mds.c | 2 +- board/freescale/mpc8572ds/mpc8572ds.c | 6 +++--- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 4 ++-- board/freescale/p1_p2_rdb/pci.c | 4 ++-- board/freescale/p2020ds/p2020ds.c | 6 +++--- board/tqc/tqm85xx/tqm85xx.c | 2 +- board/xes/common/fsl_8xxx_pci.c | 6 +++--- cpu/ppc4xx/4xx_pcie.c | 4 ++-- drivers/usb/musb/musb_core.h | 2 +- include/usb/ehci-fsl.h | 24 ++++++++++++------------ 16 files changed, 40 insertions(+), 40 deletions(-)
diff --git a/board/amcc/yucca/yucca.c b/board/amcc/yucca/yucca.c index 67a0167..8c65cfb 100644 --- a/board/amcc/yucca/yucca.c +++ b/board/amcc/yucca/yucca.c @@ -609,7 +609,7 @@ int board_pcie_card_present(int port) /* * For the given slot, set endpoint mode, send power to the slot, * turn on the green LED and turn off the yellow LED, enable the - * clock. In end point mode reset bit is read only. + * clock. In endpoint mode reset bit is read only. */ void board_pcie_setup_port(int port, int rootpoint) { diff --git a/board/atum8548/atum8548.c b/board/atum8548/atum8548.c index da6cf47..c11a5c3 100644 --- a/board/atum8548/atum8548.c +++ b/board/atum8548/atum8548.c @@ -219,7 +219,7 @@ void pci_init_board(void) pcie1_hose.region_count = 1; #endif printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs);
first_free_busno = fsl_pci_init_port(&pci_info[num++], diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index f8292cf..81a56b5 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -226,7 +226,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 3); pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); printf (" PCIE3 connected to Slot3 as %s (base address %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie3_hose, first_free_busno); @@ -246,7 +246,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot1 as %s (base address %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie1_hose, first_free_busno); @@ -266,7 +266,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 2); pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf (" PCIE2 connected to Slot 2 as %s (base address %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 35a8063..b35e02f 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -144,7 +144,7 @@ void pci_init_board(void) pcie3_hose.region_count = 1; #endif printf (" PCIE3 connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie3_hose, first_free_busno); @@ -179,7 +179,7 @@ void pci_init_board(void) pcie1_hose.region_count = 1; #endif printf (" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs);
first_free_busno = fsl_pci_init_port(&pci_info[num++], @@ -210,7 +210,7 @@ void pci_init_board(void) pcie2_hose.region_count = 1; #endif printf (" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 38cbc8b..aa3f32b 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -343,7 +343,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs);
first_free_busno = fsl_pci_init_port(&pci_info[num++], diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index 60e22de..4ec13a9 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -408,7 +408,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs);
first_free_busno = fsl_pci_init_port(&pci_info[num++], diff --git a/board/freescale/mpc8569mds/mpc8569mds.c b/board/freescale/mpc8569mds/mpc8569mds.c index 56854ca..1c76b84 100644 --- a/board/freescale/mpc8569mds/mpc8569mds.c +++ b/board/freescale/mpc8569mds/mpc8569mds.c @@ -552,7 +552,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie1_hose, first_free_busno); diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 64e164b..74085c3 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -194,7 +194,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 3); pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); printf (" PCIE3 connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie3_hose, first_free_busno); @@ -226,7 +226,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 2); pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf (" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); @@ -246,7 +246,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie1_hose, first_free_busno); diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 2d4b9ad..784a2ed 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -249,7 +249,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs);
first_free_busno = fsl_pci_init_port(&pci_info[num++], @@ -270,7 +270,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 2); pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf (" PCIE2 connected to Slot as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); diff --git a/board/freescale/p1_p2_rdb/pci.c b/board/freescale/p1_p2_rdb/pci.c index 6fd6963..aa2f64c 100644 --- a/board/freescale/p1_p2_rdb/pci.c +++ b/board/freescale/p1_p2_rdb/pci.c @@ -66,7 +66,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 2); pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf(" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); @@ -85,7 +85,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf(" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie1_hose, first_free_busno); diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index 599caa2..f6eae55 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -222,7 +222,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 2); pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf(" PCIE2 connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie2_hose, first_free_busno); @@ -262,7 +262,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 3); pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); printf(" PCIE3 connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie3_hose, first_free_busno); @@ -281,7 +281,7 @@ void pci_init_board(void) SET_STD_PCIE_INFO(pci_info[num], 1); pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf(" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", + pcie_ep ? "Endpoint" : "Root Complex", pci_info[num].regs); first_free_busno = fsl_pci_init_port(&pci_info[num++], &pcie1_hose, first_free_busno); diff --git a/board/tqc/tqm85xx/tqm85xx.c b/board/tqc/tqm85xx/tqm85xx.c index aa7827e..8c9d586 100644 --- a/board/tqc/tqm85xx/tqm85xx.c +++ b/board/tqc/tqm85xx/tqm85xx.c @@ -636,7 +636,7 @@ static inline void init_pcie1(void)
if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("PCIe: %s, base address %x", - pcie_ep ? "End point" : "Root complex", (uint)pci); + pcie_ep ? "Endpoint" : "Root complex", (uint)pci);
if (pci->pme_msg_det) { pci->pme_msg_det = 0xffffffff; diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index a615820..3a81827 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -256,7 +256,7 @@ void pci_init_board(void)
if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE1)) { printf("\n PCIE1 connected as %s (x%d)", - host ? "Root Complex" : "End Point", width); + host ? "Root Complex" : "Endpoint", width); if (in_be32(&pci->pme_msg_det)) { out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", @@ -305,7 +305,7 @@ void pci_init_board(void)
if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE2)) { printf("\n PCIE2 connected as %s (x%d)", - host ? "Root Complex" : "End Point", width); + host ? "Root Complex" : "Endpoint", width); if (in_be32(&pci->pme_msg_det)) { out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", @@ -354,7 +354,7 @@ void pci_init_board(void)
if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE3)) { printf("\n PCIE3 connected as %s (x%d)", - host ? "Root Complex" : "End Point", width); + host ? "Root Complex" : "Endpoint", width); if (in_be32(&pci->pme_msg_det)) { out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", diff --git a/cpu/ppc4xx/4xx_pcie.c b/cpu/ppc4xx/4xx_pcie.c index d9605c3..f3b9214 100644 --- a/cpu/ppc4xx/4xx_pcie.c +++ b/cpu/ppc4xx/4xx_pcie.c @@ -924,7 +924,7 @@ static inline u64 ppc4xx_get_cfgaddr(int port) }
/* - * 4xx boards as end point and root point setup + * 4xx boards as endpoint and root point setup * and * testing inbound and out bound windows * @@ -940,7 +940,7 @@ static inline u64 ppc4xx_get_cfgaddr(int port) * * Once your board came up as root point , you can verify by reading * /proc/bus/pci/devices. Where you can see the configuration registers - * of end point device attached to the port. + * of endpoint device attached to the port. * * Enpoint cofiguration can be verified by connecting 4xx board to any * host or another 4xx board. Then try to scan the device. In case of diff --git a/drivers/usb/musb/musb_core.h b/drivers/usb/musb/musb_core.h index f0f0301..9a1fb4f 100644 --- a/drivers/usb/musb/musb_core.h +++ b/drivers/usb/musb/musb_core.h @@ -133,7 +133,7 @@ struct musb_regs { u8 rxhubport; } tar[16]; /* - * end point registers + * endpoint registers * ep0 elements are valid when array index is 0 * otherwise epN is valid */ diff --git a/include/usb/ehci-fsl.h b/include/usb/ehci-fsl.h index 3b99456..f48945a 100644 --- a/include/usb/ehci-fsl.h +++ b/include/usb/ehci-fsl.h @@ -112,7 +112,7 @@ struct usb_ehci { u32 perlistbase; /* 0x154 - Periodic List Base - USB Device Address */ u32 ep_list_addr; /* 0x158 - Next Asynchronous List - - End Point Address */ + - Endpoint Address */ u8 res5[0x4]; u32 burstsize; /* 0x160 - Programmable Burst Size */ u32 txfilltuning; /* 0x164 - Host TT Transmit @@ -124,17 +124,17 @@ struct usb_ehci { u32 portsc; /* 0x184 - Port status/control */ u8 res8[0x20]; u32 usbmode; /* 0x1a8 - USB Device Mode */ - u32 epsetupstat; /* 0x1ac - End Point Setup Status */ - u32 epprime; /* 0x1b0 - End Point Init Status */ - u32 epflush; /* 0x1b4 - End Point De-initlialize */ - u32 epstatus; /* 0x1b8 - End Point Status */ - u32 epcomplete; /* 0x1bc - End Point Complete */ - u32 epctrl0; /* 0x1c0 - End Point Control 0 */ - u32 epctrl1; /* 0x1c4 - End Point Control 1 */ - u32 epctrl2; /* 0x1c8 - End Point Control 2 */ - u32 epctrl3; /* 0x1cc - End Point Control 3 */ - u32 epctrl4; /* 0x1d0 - End Point Control 4 */ - u32 epctrl5; /* 0x1d4 - End Point Control 5 */ + u32 epsetupstat; /* 0x1ac - Endpoint Setup Status */ + u32 epprime; /* 0x1b0 - Endpoint Init Status */ + u32 epflush; /* 0x1b4 - Endpoint De-initlialize */ + u32 epstatus; /* 0x1b8 - Endpoint Status */ + u32 epcomplete; /* 0x1bc - Endpoint Complete */ + u32 epctrl0; /* 0x1c0 - Endpoint Control 0 */ + u32 epctrl1; /* 0x1c4 - Endpoint Control 1 */ + u32 epctrl2; /* 0x1c8 - Endpoint Control 2 */ + u32 epctrl3; /* 0x1cc - Endpoint Control 3 */ + u32 epctrl4; /* 0x1d0 - Endpoint Control 4 */ + u32 epctrl5; /* 0x1d4 - Endpoint Control 5 */ u8 res9[0x228]; u32 snoop1; /* 0x400 - Snoop 1 */ u32 snoop2; /* 0x404 - Snoop 2 */
Dear Peter Tyser,
Applied, thanks.
Peter Tyser
