[U-Boot] [PATCH] imx: add lowlevel init for ARM64
Sometimes we met SERROR, but only to catch it when Linux boots up. Let's enable catching in U-Boot to catch it ealier and ease debug.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/Makefile | 2 +- arch/arm/mach-imx/lowlevel.S | 22 ++++++++++++++++++++++ 2 files changed, 23 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-imx/lowlevel.S
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index c3ed62aed6..37675d0558 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -204,7 +204,7 @@ endif
targets += $(addprefix ../../../,SPL spl/u-boot-spl.cfgout u-boot-dtb.cfgout u-boot.cfgout u-boot.uim spl/u-boot-nand-spl.imx)
-obj-$(CONFIG_ARM64) += sip.o +obj-$(CONFIG_ARM64) += lowlevel.o sip.o
obj-$(CONFIG_MX5) += mx5/ obj-$(CONFIG_MX6) += mx6/ diff --git a/arch/arm/mach-imx/lowlevel.S b/arch/arm/mach-imx/lowlevel.S new file mode 100644 index 0000000000..158fdb7d87 --- /dev/null +++ b/arch/arm/mach-imx/lowlevel.S @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + mrs x0, CurrentEL + cmp x0, #8 + b.eq 1f + ret +1: + msr daifclr, #4 + + /* set HCR_EL2.AMO to catch SERROR */ + mrs x0, hcr_el2 + orr x0, x0, #0x20 + msr hcr_el2, x0 + isb + ret +ENDPROC(lowlevel_init)
Sometimes we met SERROR, but only to catch it when Linux boots up. Let's enable catching in U-Boot to catch it ealier and ease debug. Signed-off-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Hi Peng and Stefano
Unfortunately, this seems to break Ethernet on Colibri iMX8X:
=> dhcp "Error" handler, esr 0xbf000002 elr: 0000000080049664 lr : 000000008004964c (reloc) elr: 00000000ffef6664 lr : 00000000ffef664c x0 : 000000005b040288 x1 : 0000000000000001 x2 : 00000000fd6c5ff4 x3 : 0000000000000020 x4 : 00000000fd6c5ff0 x5 : 0000000000000020 x6 : 00000000ffef079c x7 : 00000000fd6f1600 x8 : 0000000000000044 x9 : 0000000000000008 x10: 00000000fd6d1620 x11: 00000000fd6d3a10 x12: 0000000000000000 x13: 0000000000000200 x14: 00000000fd6c62cc x15: 0000000000000002 x16: 0000000000002080 x17: 0000000000000000 x18: 00000000fd6cada8 x19: 00000000fd6d1160 x20: 0000000000000200 x21: 000000005b040300 x22: 00000000fd6f1000 x23: 00000000fd6cfdf0 x24: 00000000ffff8000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 00000000fd6d15c0 x29: 00000000fd6c6030
Resetting CPU ...
resetting ...
Reverting commit 5955c6eeb453 ("imx: add lowlevel init for ARM64") makes it work again.
Unfortunately, I don't have a MEK in my home office but will check Ethernet operation there on Monday as well.
Anyway, does anybody know what exactly is going on?
Cheers
Marcel
targets += $(addprefix ../../../,SPL spl/u-boot-spl.cfgout u-boot- dtb.cfgout u-boot.cfgout u-boot.uim spl/u-boot-nand-spl.imx)
obj-$(CONFIG_MX5) += mx5/ obj-$(CONFIG_MX6) += mx6/ diff --git a/arch/arm/mach-imx/lowlevel.S b/arch/arm/mach- imx/lowlevel.S new file mode 100644 index 0000000000..158fdb7d87 --- /dev/null +++ b/arch/arm/mach-imx/lowlevel.S @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright 2019 NXP
- mrs x0, CurrentEL
- cmp x0, #8
- b.eq 1f
- ret
+1:
- msr daifclr, #4
- /* set HCR_EL2.AMO to catch SERROR */
- mrs x0, hcr_el2
- orr x0, x0, #0x20
- msr hcr_el2, x0
- isb
- ret
2.16.4
Hi Marcel,
Please apply this patch, Joe has not pick it up. https://patchwork.ozlabs.org/patch/1085432/
Stefano,
Would you pick it up?
Subject: [REGRESSION] [PATCH] imx: add lowlevel init for ARM64
Hi Peng and Stefano
Resetting CPU ...
resetting ...
Regards, Peng.
Cheers
Marcel
- mrs x0, CurrentEL
- cmp x0, #8
- b.eq 1f
- ret
+1:
- msr daifclr, #4
- mrs x0, hcr_el2
- orr x0, x0, #0x20
- msr hcr_el2, x0
- isb
- ret
2.16.4
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flist
s.denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7Cpeng.fan%40nxp.co m%7C
d671eca9f1cc4d06a7d008d6ca7661b1%7C686ea1d3bc2b4c6fa92cd99c5c30 1635%7C
0%7C0%7C636919007134459412&sdata=R6xBpoVJHL7meQkRkBi1I8vg MgOTXlFEA
QfMePrDdSc%3D&reserved=0
On 27/04/19 01:58, Peng Fan wrote:
Hi Marcel,
Stefano,
It is acked by Joe, i assign the patch to me in patchwork and I pick it up.
Regards, Stefano
Hi Peng and Stefano
Resetting CPU ...
resetting ...
Regards, Peng.
Cheers
Marcel
- mrs x0, CurrentEL
- cmp x0, #8
- b.eq 1f
- ret
+1:
- msr daifclr, #4
- mrs x0, hcr_el2
- orr x0, x0, #0x20
- msr hcr_el2, x0
- isb
- ret
2.16.4
On Apr 28, 2019, at 12:52 PM, Stefano Babic sbabic@denx.de wrote:
On 27/04/19 01:58, Peng Fan wrote: Hi Marcel,
Stefano,
Regards, Stefano
Hi Peng and Stefano
Has this been addressed?
Resetting CPU ...
resetting ...
Regards, Peng.
Cheers
Marcel
On Mon, 2019-04-15 at 05:20 +0000, Peng Fan wrote: Sometimes we met SERROR, but only to catch it when Linux boots up. Let's enable catching in U-Boot to catch it ealier and ease debug.
- mrs x0, CurrentEL
- cmp x0, #8
- b.eq 1f
- ret
+1:
- msr daifclr, #4
- mrs x0, hcr_el2
- orr x0, x0, #0x20
- msr hcr_el2, x0
- isb
- ret
2.16.4
Stefano,
Regards, Stefano
Hi Peng and Stefano
Yes, sorry. The following patch as suggested by Peng does fix it:
Thanks!
Resetting CPU ...
resetting ...
Regards, Peng.
Cheers
Marcel
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach- imx/Makefile index c3ed62aed6..37675d0558 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -204,7 +204,7 @@ endif
targets += $(addprefix ../../../,SPL spl/u-boot-spl.cfgout u- boot- dtb.cfgout u-boot.cfgout u-boot.uim spl/u-boot-nand-spl.imx)
- mrs x0, CurrentEL
- cmp x0, #8
- b.eq 1f
- ret
+1:
- msr daifclr, #4
- mrs x0, hcr_el2
- orr x0, x0, #0x20
- msr hcr_el2, x0
- isb
- ret
2.16.4
s.denx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpeng.fan%40nxp.co m%7C d671eca9f1cc4d06a7d008d6ca7661b1%7C686ea1d3bc2b4c6fa92cd99c5c30 1635%7C 0%7C0%7C636919007134459412&sdata=R6xBpoVJHL7meQkRkBi1I8vg MgOTXlFEA
participants (5)
Joe Hershberger
Marcel Ziswiler
Peng Fan
sbabic@denx.de
Stefano Babic
