[PATCH] mx28evk: Remove AUART/NAND/SPI variants
To ease maintenance, let's keep only the main mx28evk_defconfig and remove the other variants that have not been migrated to DM.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/freescale/mx28evk/MAINTAINERS | 3 -- configs/mx28evk_auart_console_defconfig | 59 ----------------------- configs/mx28evk_nand_defconfig | 62 ------------------------- configs/mx28evk_spi_defconfig | 57 ----------------------- 4 files changed, 181 deletions(-) delete mode 100644 configs/mx28evk_auart_console_defconfig delete mode 100644 configs/mx28evk_nand_defconfig delete mode 100644 configs/mx28evk_spi_defconfig
diff --git a/board/freescale/mx28evk/MAINTAINERS b/board/freescale/mx28evk/MAINTAINERS index c565010ccf6b..f20baa91c673 100644 --- a/board/freescale/mx28evk/MAINTAINERS +++ b/board/freescale/mx28evk/MAINTAINERS @@ -5,6 +5,3 @@ F: board/freescale/mx28evk/ F: arch/arm/dts/imx28-evk.dts F: include/configs/mx28evk.h F: configs/mx28evk_defconfig -F: configs/mx28evk_auart_console_defconfig -F: configs/mx28evk_nand_defconfig -F: configs/mx28evk_spi_defconfig diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig deleted file mode 100644 index b9c85d616079..000000000000 --- a/configs/mx28evk_auart_console_defconfig +++ /dev/null @@ -1,59 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x40000 -CONFIG_IMX_CONFIG="" -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL=y -CONFIG_SYS_LOAD_ADDR=0x42000000 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_NO_BSS_LIMIT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_USE_BOOTFILE=y -CONFIG_BOOTFILE="uImage" -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig deleted file mode 100644 index 136c1d60699b..000000000000 --- a/configs/mx28evk_nand_defconfig +++ /dev/null @@ -1,62 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_OFFSET=0x300000 -CONFIG_IMX_CONFIG="" -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0x380000 -CONFIG_SYS_LOAD_ADDR=0x42000000 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_NO_BSS_LIMIT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_NAND=y -CONFIG_ENV_RANGE=0x80000 -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_USE_BOOTFILE=y -CONFIG_BOOTFILE="uImage" -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig deleted file mode 100644 index ab8c34c8b164..000000000000 --- a/configs/mx28evk_spi_defconfig +++ /dev/null @@ -1,57 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX28=y -CONFIG_SYS_TEXT_BASE=0x40002000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x4000 -CONFIG_IMX_CONFIG="" -CONFIG_SPL_TEXT_BASE=0x00001000 -CONFIG_TARGET_MX28EVK=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL=y -CONFIG_SYS_LOAD_ADDR=0x42000000 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_ARCH_MISC_INIT=y -# CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_NO_BSS_LIMIT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" -CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" -CONFIG_CMD_UBI=y -CONFIG_ENV_OVERWRITE=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_USE_BOOTFILE=y -CONFIG_BOOTFILE="uImage" -CONFIG_VERSION_VARIABLE=y -CONFIG_MXS_GPIO=y -CONFIG_MMC_MXS=y -CONFIG_MTD=y -CONFIG_MTD_RAW_NAND=y -CONFIG_NAND_MXS=y -CONFIG_MII=y -CONFIG_CONS_INDEX=0 -CONFIG_SPI=y -CONFIG_USB=y -CONFIG_SPLASH_SCREEN=y -CONFIG_OF_LIBFDT=y
board/freescale/mx28evk/MAINTAINERS | 3 -- configs/mx28evk_auart_console_defconfig | 59 ----------------------- configs/mx28evk_nand_defconfig | 62 ------------------------- configs/mx28evk_spi_defconfig | 57 ----------------------- 4 files changed, 181 deletions(-) delete mode 100644 configs/mx28evk_auart_console_defconfig delete mode 100644 configs/mx28evk_nand_defconfig > delete mode 100644 configs/mx28evk_spi_defconfig
Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de
Signed-off-by: Fabio Estevam festevam@denx.de Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de
Fabio Estevam
