[U-Boot] Loading a userland file
I'm trying to get Tiny Core working on the Beaglebone. I'm stuck on getting the Tiny Core userland file "uCore" to load so init works. I'm using this uEnv.txt:
bootfile=/uImage optargs=init=/init rootwait fatload mmc 0 0x43100000 uCore mmcboot=echo Booting from mmc ...; run mmcargs; bootm 0x80200000 0x43100000
I get the following "data abort":
## Booting kernel from Legacy Image at 80200000 ... Image Name: Linux-3.6.0-rc7-00219-g35e0f42 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2878667 Bytes = 2.7 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK data abort pc : [<8ff99480>] lr : [<8ff996ac>] sp : 8fe6abd0 ip : 8fe6d163 fp : 00000001 r10: 00000002 r9 : 00000000 r8 : 8fe6af68 r7 : 8ffbaebc r6 : 43100000 r5 : 8ffbaec0 r4 : 43100000 r3 : 00000000 r2 : 00000010 r1 : 00000000 r0 : 43100000 Flags: nZCv IRQs off FIQs on Mode SVC_32 Resetting CPU ...
If I change mmcboot to:
The kernel loads, but init fails:
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) VFS: Mounted root (ext4 filesystem) readonly on device 179:2. devtmpfs: error mounting -2 Freeing init memory: 144K Failed to execute /init. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel.
Can anyone tell me how to load uCore so init works?
- Grant
0x43100000
(null)
kernel.
- Grant
I've gotten farther along, but I get one of these two errors when loading the ramdisk:
RAMDISK: Couldn't find valid RAM disk image starting at 0.
Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid
Please let me know if you have any pointers.
- Grant
Grant
