[U-Boot-Users] [PATCH 12/25] include/configs: Use new CONFIG_CMD_* in various e* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/eXalion.h | 23 ++++++++------- include/configs/ebony.h | 49 +++++++++++++++++--------------- include/configs/ep7312.h | 12 +++++-- include/configs/ep8248.h | 34 ++++++++++++---------- include/configs/ep8260.h | 69 ++++++++++++++++++++++----------------------- include/configs/ep82xxm.h | 45 +++++++++++++++------------- include/configs/evb4510.h | 13 ++++++-- 7 files changed, 131 insertions(+), 114 deletions(-)
diff --git a/include/configs/eXalion.h b/include/configs/eXalion.h index a014c7c..ac1ef95 100644 --- a/include/configs/eXalion.h +++ b/include/configs/eXalion.h @@ -58,17 +58,18 @@
/*#define CONFIG_DRAM_SPEED 66 */ /* MHz */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_FLASH | \ - CFG_CMD_SDRAM | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_FAT | \ - CFG_CMD_ENV | \ - CFG_CMD_PCI ) +/* + * Command line configuration. + */ +#include <config_cmd_default.h>
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_ENV +#define CONFIG_CMD_PCI
/*----------------------------------------------------------------------- @@ -398,7 +399,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/ebony.h b/include/configs/ebony.h index 4a1385c..d86a9ef 100644 --- a/include/configs/ebony.h +++ b/include/configs/ebony.h @@ -208,26 +208,29 @@
#define CONFIG_NETCONSOLE /* include NetConsole support */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_DIAG | \ - CFG_CMD_ELF | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_IRQ | \ - CFG_CMD_MII | \ - CFG_CMD_NET | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SDRAM | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_ELF +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SNTP +
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -236,7 +239,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -286,7 +289,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
@@ -298,7 +301,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/ep7312.h b/include/configs/ep7312.h index bdda629..12be151 100644 --- a/include/configs/ep7312.h +++ b/include/configs/ep7312.h @@ -64,10 +64,14 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT|CONFIG_BOOTP_BOOTFILESIZE)
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_JFFS2)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_JFFS2 +
#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTARGS "devfs=mount root=ramfs console=ttyS0,9600" @@ -78,7 +82,7 @@ /*#define CONFIG_BOOTFILE "impa7" */ #define CONFIG_BOOTCOMMAND "bootp;bootm"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/ep8248.h b/include/configs/ep8248.h index 04147a5..44c4388 100644 --- a/include/configs/ep8248.h +++ b/include/configs/ep8248.h @@ -123,23 +123,25 @@
#define CONFIG_BAUDRATE 38400
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_DHCP \ - | CFG_CMD_ECHO \ - | CFG_CMD_I2C \ - | CFG_CMD_IMMAP \ - | CFG_CMD_MII \ - | CFG_CMD_PING \ - ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +
#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ #define CONFIG_BOOTCOMMAND "bootm FF860000" /* autoboot command */ #define CONFIG_BOOTARGS "root=/dev/mtdblock1 rw mtdparts=phys:7M(root),-(root)ro"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -157,7 +159,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -183,7 +185,7 @@
#define CFG_DIRECT_FLASH_TFTP
-#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) +#if defined(CONFIG_CMD_JFFS2) #define CFG_JFFS2_FIRST_BANK 0 #define CFG_JFFS2_NUM_BANKS CFG_MAX_FLASH_BANKS #define CFG_JFFS2_FIRST_SECTOR 0 @@ -192,7 +194,7 @@ #define CFG_JFFS_CUSTOM_PART #endif /* CFG_CMD_JFFS2 */
-#if (CONFIG_COMMANDS & CFG_CMD_I2C) +#if defined(CONFIG_CMD_I2C) #define CONFIG_HARD_I2C 1 /* To enable I2C support */ #define CFG_I2C_SPEED 100000 /* I2C speed */ #define CFG_I2C_SLAVE 0x7F /* I2C slave address */ @@ -240,7 +242,7 @@ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
#define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/ep8260.h b/include/configs/ep8260.h index 6862519..065f967 100644 --- a/include/configs/ep8260.h +++ b/include/configs/ep8260.h @@ -291,37 +291,39 @@ #define CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> "
-/* What U-Boot subsytems do you want enabled? */ + /* -*/ -#define CONFIG_COMMANDS ( CFG_CMD_ALL & \ - ~( CFG_CMD_BMP | \ - CFG_CMD_BSP | \ - CFG_CMD_DCR | \ - CFG_CMD_DHCP | \ - CFG_CMD_DISPLAY | \ - CFG_CMD_DOC | \ - CFG_CMD_DTT | \ - CFG_CMD_EEPROM | \ - CFG_CMD_EXT2 | \ - CFG_CMD_FDC | \ - CFG_CMD_FDOS | \ - CFG_CMD_HWFLOW | \ - CFG_CMD_IDE | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_KGDB | \ - CFG_CMD_MII | \ - CFG_CMD_MMC | \ - CFG_CMD_NAND | \ - CFG_CMD_PCI | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_REISER | \ - CFG_CMD_SCSI | \ - CFG_CMD_SPI | \ - CFG_CMD_UNIVERSE| \ - CFG_CMD_USB | \ - CFG_CMD_VFD | \ - CFG_CMD_XIMG ) ) + * Command line configuration. + */ +#include <config_cmd_all.h> + +#undef CONFIG_CMD_BMP +#undef CONFIG_CMD_BSP +#undef CONFIG_CMD_DCR +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DISPLAY +#undef CONFIG_CMD_DOC +#undef CONFIG_CMD_DTT +#undef CONFIG_CMD_EEPROM +#undef CONFIG_CMD_EXT2 +#undef CONFIG_CMD_FDC +#undef CONFIG_CMD_FDOS +#undef CONFIG_CMD_HWFLOW +#undef CONFIG_CMD_IDE +#undef CONFIG_CMD_JFFS2 +#undef CONFIG_CMD_KGDB +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_MMC +#undef CONFIG_CMD_NAND +#undef CONFIG_CMD_PCI +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_CMD_REISER +#undef CONFIG_CMD_SCSI +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_UNIVERSE +#undef CONFIG_CMD_USB +#undef CONFIG_CMD_VFD +#undef CONFIG_CMD_XIMG
/* Where do the internal registers live? */ @@ -342,13 +344,10 @@
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_early_init_f */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else # define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -496,7 +495,7 @@ */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */
diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h index a77ccef..5fa7016 100644 --- a/include/configs/ep82xxm.h +++ b/include/configs/ep82xxm.h @@ -108,22 +108,25 @@
#define CFG_VXWORKS_MAC_PTR 0x4300 /* Pass Ethernet MAC to VxWorks */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_DHCP \ - | CFG_CMD_ECHO \ - | CFG_CMD_I2C \ - | CFG_CMD_IMMAP \ - | CFG_CMD_MII \ - | CFG_CMD_PING \ - | CFG_CMD_DATE \ - | CFG_CMD_DTT \ - | CFG_CMD_EEPROM \ - | CFG_CMD_PCI \ - | CFG_CMD_DIAG \ - ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DTT +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_PCI +#define CONFIG_CMD_DIAG +
#define CONFIG_ETHADDR 00:10:EC:00:88:65 #define CONFIG_HAS_ETH1 @@ -138,7 +141,7 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_EXTRA_ENV_SETTINGS "ethprime=FCC3 ETHERNET"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -156,7 +159,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "ep82xxm=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -308,7 +311,7 @@
-#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) +#if defined(CONFIG_CMD_JFFS2) #define CFG_JFFS2_FIRST_BANK 0 #define CFG_JFFS2_NUM_BANKS CFG_MAX_FLASH_BANKS #define CFG_JFFS2_FIRST_SECTOR 0 @@ -317,7 +320,7 @@ #define CFG_JFFS_CUSTOM_PART #endif /* CFG_CMD_JFFS2 */
-#if (CONFIG_COMMANDS & CFG_CMD_I2C) +#if defined(CONFIG_CMD_I2C) #define CONFIG_HARD_I2C 1 /* To enable I2C support */ #define CFG_I2C_SPEED 100000 /* I2C speed */ #define CFG_I2C_SLAVE 0x7F /* I2C slave address */ @@ -358,7 +361,7 @@ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
#define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/evb4510.h b/include/configs/evb4510.h index 88c2c74..42633be 100644 --- a/include/configs/evb4510.h +++ b/include/configs/evb4510.h @@ -74,10 +74,15 @@
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_PING)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING + +
#define CONFIG_ETHADDR 00:40:95:36:35:33 #define CONFIG_NETMASK 255.255.255.0 @@ -89,7 +94,7 @@ #define CONFIG_BOOTCOMMAND "tftp 100000 uImage" /* #define CONFIG_BOOTARGS "console=ttyS0,19200 initrd=0x100a0040,530K root=/dev/ram keepinitrd" */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 19200 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
Jon Loeliger
