[U-Boot] [PATCH] 4xx: Fix compilation warnings and MQ registers dump in SPD DDR2 code
This patch fixes printf format string compilation warnings in several debug statements. It also fixes the dump of DDR controller MQ registers found on some 44x and 46x platforms. The current register dump code uses incorrect DCRs to access these registers.
Signed-off-by: Felix Radensky felix@embedded-sol.com --- cpu/ppc4xx/44x_spd_ddr2.c | 42 +++++++++++++++++++++++++----------------- 1 files changed, 25 insertions(+), 17 deletions(-)
diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index 33788cc..2ab2336 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -60,6 +60,14 @@ "SDRAM_" #mnemonic, SDRAM_##mnemonic, data); \ } while (0)
+#define PPC4xx_IBM_DDR2_DUMP_MQ_REGISTER(mnemonic) \ + do { \ + u32 data; \ + data = mfdcr(SDRAM_##mnemonic); \ + printf("%20s[%02x] = 0x%08X\n", \ + "SDRAM_" #mnemonic, SDRAM_##mnemonic, data); \ + } while (0) + #if defined(CONFIG_440) /* * This DDR2 setup code can dynamically setup the TLB entries for the DDR2 @@ -714,11 +722,11 @@ static void check_mem_type(unsigned long *dimm_populated, spd_ddr_init_hang (); break; case 7: - debug("DIMM slot %d: DDR1 SDRAM detected\n", dimm_num); + debug("DIMM slot %lu: DDR1 SDRAM detected\n", dimm_num); dimm_populated[dimm_num] = SDRAM_DDR1; break; case 8: - debug("DIMM slot %d: DDR2 SDRAM detected\n", dimm_num); + debug("DIMM slot %lu: DDR2 SDRAM detected\n", dimm_num); dimm_populated[dimm_num] = SDRAM_DDR2; break; default: @@ -796,7 +804,7 @@ static void check_frequency(unsigned long *dimm_populated, else cycle_time = (((tcyc_reg & 0xF0) >> 4) * 100) + ((tcyc_reg & 0x0F)*10); - debug("cycle_time=%d [10 picoseconds]\n", cycle_time); + debug("cycle_time=%lu [10 picoseconds]\n", cycle_time);
if (cycle_time > (calc_cycle_time + 10)) { /* @@ -1407,7 +1415,7 @@ static void program_mode(unsigned long *dimm_populated,
mfsdr(SDR0_DDR0, sdr_ddrpll); sdram_freq = MULDIV64((board_cfg.freqPLB), SDR0_DDR0_DDRM_DECODE(sdr_ddrpll), 1); - debug("sdram_freq=%d\n", sdram_freq); + debug("sdram_freq=%lu\n", sdram_freq);
/*------------------------------------------------------------------ * Handle the timing. We need to find the worst case timing of all @@ -1437,7 +1445,7 @@ static void program_mode(unsigned long *dimm_populated,
/* t_wr_ns = max(t_wr_ns, (unsigned long)dimm_spd[dimm_num][36] >> 2); */ /* not used in this loop. */ cas_bit = spd_read(iic0_dimm_addr[dimm_num], 18); - debug("cas_bit[SPD byte 18]=%02x\n", cas_bit); + debug("cas_bit[SPD byte 18]=%02lx\n", cas_bit);
/* For a particular DIMM, grab the three CAS values it supports */ for (cas_index = 0; cas_index < 3; cas_index++) { @@ -1469,7 +1477,7 @@ static void program_mode(unsigned long *dimm_populated, (((tcyc_reg & 0xF0) >> 4) * 100) + ((tcyc_reg & 0x0F)*10); } - debug("cas_index=%d: cycle_time_ns_x_100=%d\n", cas_index, + debug("cas_index=%lu: cycle_time_ns_x_100=%lu\n", cas_index, cycle_time_ns_x_100[cas_index]); }
@@ -1580,9 +1588,9 @@ static void program_mode(unsigned long *dimm_populated, cycle_3_0_clk = MULDIV64(ONE_BILLION, 100, max_3_0_tcyc_ns_x_100) + 10; cycle_4_0_clk = MULDIV64(ONE_BILLION, 100, max_4_0_tcyc_ns_x_100) + 10; cycle_5_0_clk = MULDIV64(ONE_BILLION, 100, max_5_0_tcyc_ns_x_100) + 10; - debug("cycle_3_0_clk=%d\n", cycle_3_0_clk); - debug("cycle_4_0_clk=%d\n", cycle_4_0_clk); - debug("cycle_5_0_clk=%d\n", cycle_5_0_clk); + debug("cycle_3_0_clk=%lu\n", cycle_3_0_clk); + debug("cycle_4_0_clk=%lu\n", cycle_4_0_clk); + debug("cycle_5_0_clk=%lu\n", cycle_5_0_clk);
if (sdram_ddr1 == TRUE) { /* DDR1 */ if ((cas_2_0_available == TRUE) && (sdram_freq <= cycle_2_0_clk)) { @@ -2797,13 +2805,13 @@ calibration_loop: }
mfsdram(SDRAM_DLCR, val); - debug("%s[%d] DLCR: 0x%08X\n", __FUNCTION__, __LINE__, val); + debug("%s[%d] DLCR: 0x%08lX\n", __FUNCTION__, __LINE__, val); mfsdram(SDRAM_RQDC, val); - debug("%s[%d] RQDC: 0x%08X\n", __FUNCTION__, __LINE__, val); + debug("%s[%d] RQDC: 0x%08lX\n", __FUNCTION__, __LINE__, val); mfsdram(SDRAM_RFDC, val); - debug("%s[%d] RFDC: 0x%08X\n", __FUNCTION__, __LINE__, val); + debug("%s[%d] RFDC: 0x%08lX\n", __FUNCTION__, __LINE__, val); mfsdram(SDRAM_RDCC, val); - debug("%s[%d] RDCC: 0x%08X\n", __FUNCTION__, __LINE__, val); + debug("%s[%d] RDCC: 0x%08lX\n", __FUNCTION__, __LINE__, val); } #else /* calibration test with hardvalues */ /*-----------------------------------------------------------------------------+ @@ -3196,10 +3204,10 @@ inline void ppc4xx_ibm_ddr2_register_dump(void)
#if (defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT)) - PPC4xx_IBM_DDR2_DUMP_REGISTER(R0BAS); - PPC4xx_IBM_DDR2_DUMP_REGISTER(R1BAS); - PPC4xx_IBM_DDR2_DUMP_REGISTER(R2BAS); - PPC4xx_IBM_DDR2_DUMP_REGISTER(R3BAS); + PPC4xx_IBM_DDR2_DUMP_MQ_REGISTER(R0BAS); + PPC4xx_IBM_DDR2_DUMP_MQ_REGISTER(R1BAS); + PPC4xx_IBM_DDR2_DUMP_MQ_REGISTER(R2BAS); + PPC4xx_IBM_DDR2_DUMP_MQ_REGISTER(R3BAS); #endif /* (defined(CONFIG_440SP) || ... */ #if defined(CONFIG_405EX) PPC4xx_IBM_DDR2_DUMP_REGISTER(BESR);
Applied to ppc4xx. Thanks.
Best regards, Stefan
Felix Radensky
Stefan Roese
