mkenvimage CRC does not match the CRC of fw_setenv
When I run the same file against both utilities, they do not produce the same CRC.
The CRC of fw_setenv matches what uboot has when the environment is created inside the image.
Is this a known issue? If so, I am sorry to bring it up (but maybe remove mkenvimage...)
Thanks
Hello Floyd,
Am Thu, Jan 23, 2025 at 02:04:03PM -0500 schrieb Floyd Brown:
fw_setenv is Linux userland to write to flash on the running system, right? And mkenvimage produces an image file IIRC.
By chance: are your settings for redundant image the same? For fw_setenv this is set in file /etc/fw_env.config on the target system. For mkenvimage you pass -r as parameter or not.
Greets Alex
Alexander Dahl
Floyd Brown
