[U-Boot] [PATCH] board/BuR/brppt1: fix MMC boot
since commit 'd5abcf94c7123167725fc22ace342f0d455093c1' - ti: boot: Register the MMC controllers in SPL in the same way as in u-boot
MMC boot on brppt1 board is broken, with this commit we make our board working again.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com
include/configs/brppt1.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 10e8f88..76496df 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -110,21 +110,21 @@ #ifdef CONFIG_MMC #define MMCARGS \ "dtbdev=mmc\0" \ -"dtbpart=0:1\0" \ +"dtbpart=1:1\0" \ "mmcroot0=setenv bootargs ${optargs_rot} ${optargs} console=${console}\0" \ "mmcroot1=setenv bootargs ${optargs_rot} ${optargs} console=${console} " \ "root=/dev/mmcblk0p2 rootfstype=ext4\0" \ "mmcboot0=echo booting Updatesystem from mmc (ext4-fs) ...; " \ "setenv simplefb 1; " \ - "ext4load mmc 0:1 ${loadaddr} /${kernel}; " \ - "ext4load mmc 0:1 ${ramaddr} /${ramdisk}; " \ + "ext4load mmc 1:1 ${loadaddr} /${kernel}; " \ + "ext4load mmc 1:1 ${ramaddr} /${ramdisk}; " \ "run mmcroot0; bootz ${loadaddr} ${ramaddr} ${dtbaddr};\0" \ "mmcboot1=echo booting PPT-OS from mmc (ext4-fs) ...; " \ "setenv simplefb 0; " \ - "ext4load mmc 0:2 ${loadaddr} /boot/${kernel}; " \ + "ext4load mmc 1:2 ${loadaddr} /boot/${kernel}; " \ "run mmcroot1; bootz ${loadaddr} - ${dtbaddr};\0" \ -"defboot=ext4load mmc 0:2 ${loadaddr} /boot/PPTImage.md5 && run mmcboot1; " \ - "ext4load mmc 0:1 ${dtbaddr} /$dtb && run mmcboot0; " \ +"defboot=ext4load mmc 1:2 ${loadaddr} /boot/PPTImage.md5 && run mmcboot1; " \ + "ext4load mmc 1:1 ${dtbaddr} /$dtb && run mmcboot0; " \ "run ramboot; run usbscript;\0" \ "bootlimit=1\0" \ "altbootcmd=run mmcboot0;\0" \ @@ -178,7 +178,7 @@ MMCARGS #endif /* !CONFIG_SPL_BUILD*/
#define CONFIG_BOOTCOMMAND \ - "run defboot;" + "mmc dev 1; run defboot;"
#ifdef CONFIG_NAND /* @@ -253,7 +253,7 @@ MMCARGS #elif defined(CONFIG_EMMC_BOOT) #undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
Hannes Schmelzer
