[PATCH 1/1] ubifs: Fix journal replay wrt. xattr nodes
backport 1cb51a15b576ee325d527726afff40947218fd5e from Linux --- fs/ubifs/tnc.c | 25 +++++++++++++++++++++++-- 1 file changed, 23 insertions(+), 2 deletions(-)
diff --git a/fs/ubifs/tnc.c b/fs/ubifs/tnc.c index e8b8f16838..3303711477 100644 --- a/fs/ubifs/tnc.c +++ b/fs/ubifs/tnc.c @@ -50,6 +50,11 @@ enum { NOT_ON_MEDIA = 3, };
+static int fallible_read_node(struct ubifs_info *c, const union ubifs_key *key, + struct ubifs_zbranch *zbr, void *node); +static int try_read_node(const struct ubifs_info *c, void *buf, int type, + int len, int lnum, int offs); + /** * insert_old_idx - record an index node obsoleted since the last commit start. * @c: UBIFS file-system description object @@ -402,7 +407,19 @@ static int tnc_read_node_nm(struct ubifs_info *c, struct ubifs_zbranch *zbr, return 0; }
- err = ubifs_tnc_read_node(c, zbr, node); + if (c->replaying) { + err = fallible_read_node(c, &zbr->key, zbr, node); + /* + * When the node was not found, return -ENOENT, 0 otherwise. + * Negative return codes stay as-is. + */ + if (err == 0) + err = -ENOENT; + else if (err == 1) + err = 0; + } else { + err = ubifs_tnc_read_node(c, zbr, node); + } if (err) return err;
@@ -2770,7 +2787,11 @@ struct ubifs_dent_node *ubifs_tnc_next_ent(struct ubifs_info *c, if (nm->name) { if (err) { /* Handle collisions */ - err = resolve_collision(c, key, &znode, &n, nm); + if (c->replaying) + err = fallible_resolve_collision(c, key, &znode, &n, + nm, 0); + else + err = resolve_collision(c, key, &znode, &n, nm); dbg_tnc("rc returned %d, znode %p, n %d", err, znode, n); if (unlikely(err < 0))
On Mon, Mar 28, 2022 at 09:13:43AM +0000, Ville Baillie wrote:
Backport commit 1cb51a15b576 ("ubifs: Fix journal replay wrt. xattr nodes") from the Linux Kernel, which has the following Signed-off-by line: Signed-off-by: Richard Weinberger richard@nod.at
For U-Boot, after comapring with the upstream commit: Signed-off-by: Tom Rini trini@konsulko.com
Note that I reworded the commit message to meet our usual style guidlines and applied to u-boot/master, thanks!
Ville Baillie
