[U-Boot] [PATCH v3] AT91: fix at91sam9260.h for AT91SAM9XE
Define the different location of the GPBRs for the 9XE Define the proper CPU Name
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- arch/arm/include/asm/arch-at91/at91sam9260.h | 18 ++++++++++++++---- 1 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91sam9260.h b/arch/arm/include/asm/arch-at91/at91sam9260.h index ec04318..cb34a94 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9260.h +++ b/arch/arm/include/asm/arch-at91/at91sam9260.h @@ -59,7 +59,15 @@ #define AT91_RTT_BASE 0xfffffd20 #define AT91_PIT_BASE 0xfffffd30 #define AT91_WDT_BASE 0xfffffd40 -#define AT91_GPR_BASE 0xfffffd50 +/* + * The AT91SAM9XE has the GPBRs at a different address than + * the AT91SAM9260/9G20. + */ +#ifdef CONFIG_AT91SAM9XE +# define AT91_GPR_BASE 0xfffffd60 +#else +# define AT91_GPR_BASE 0xfffffd50 +#endif
#ifdef CONFIG_AT91_LEGACY
@@ -140,10 +148,12 @@ /* * Cpu Name */ -#if defined(CONFIG_AT91SAM9260) -#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9260" +#if defined(CONFIG_AT91SAM9XE) +# define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9XE" +#elif defined(CONFIG_AT91SAM9260) +# define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9260" #elif defined(CONFIG_AT91SAM9G20) -#define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G20" +# define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G20" #endif
#endif
Applied to u-boot-atmel/next Thanks, Reinhard
Reinhard Meyer
