[U-Boot] [PATCH v2] fs/ext4/ext4fs.c, fs/fs.c fs/fat/fat_write.c: Adjust 64bit math methods
The changes to introduce loff_t into filesize means that we need to do 64bit math on 32bit platforms. Make sure we use the right wrappers for these operations.
Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Suriyan Ramasami suriyan.r@gmail.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@ti.com --- fs/ext4/ext4fs.c | 11 ++++++----- fs/fat/fat_write.c | 10 ++++++---- fs/fs.c | 6 ++++-- 3 files changed, 16 insertions(+), 11 deletions(-)
diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 943b5bc..258b9379 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -25,6 +25,7 @@ #include <ext_common.h> #include <ext4fs.h> #include "ext4_common.h" +#include <div64.h>
int ext4fs_symlinknest; struct ext_filesystem ext_fs; @@ -67,11 +68,11 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos, if (len > filesize) len = filesize;
- blockcnt = ((len + pos) + blocksize - 1) / blocksize; + blockcnt = lldiv(((len + pos) + blocksize - 1), blocksize);
- for (i = pos / blocksize; i < blockcnt; i++) { + for (i = lldiv(pos, blocksize); i < blockcnt; i++) { lbaint_t blknr; - int blockoff = pos % blocksize; + int blockoff = pos - (blocksize * i); int blockend = blocksize; int skipfirst = 0; blknr = read_allocated_block(&(node->inode), i); @@ -82,7 +83,7 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos,
/* Last block. */ if (i == blockcnt - 1) { - blockend = (len + pos) % blocksize; + blockend = (len + pos) - (blocksize * i);
/* The last portion is exactly blocksize. */ if (!blockend) @@ -90,7 +91,7 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos, }
/* First block. */ - if (i == pos / blocksize) { + if (i == lldiv(pos, blocksize)) { skipfirst = blockoff; blockend -= skipfirst; } diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 88dd495..473723b 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -13,6 +13,8 @@ #include <asm/byteorder.h> #include <part.h> #include <linux/ctype.h> +#include <div64.h> +#include <linux/math64.h> #include "fat.c"
static void uppercase(char *str, int len) @@ -770,7 +772,7 @@ static void fill_dentry(fsdata *mydata, dir_entry *dentptr, */ static int check_overflow(fsdata *mydata, __u32 clustnum, loff_t size) { - __u32 startsect, sect_num; + __u32 startsect, sect_num, offset;
if (clustnum > 0) { startsect = mydata->data_begin + @@ -779,13 +781,13 @@ static int check_overflow(fsdata *mydata, __u32 clustnum, loff_t size) startsect = mydata->rootdir_sect; }
- sect_num = size / mydata->sect_size; - if (size % mydata->sect_size) + sect_num = div_u64_rem(size, mydata->sect_size, &offset); + + if (offset != 0) sect_num++;
if (startsect + sect_num > cur_part_info.start + total_sector) return -1; - return 0; }
diff --git a/fs/fs.c b/fs/fs.c index 3da7860..52078139 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -23,6 +23,8 @@ #include <fs.h> #include <sandboxfs.h> #include <asm/io.h> +#include <div64.h> +#include <linux/math64.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -399,7 +401,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], printf("%llu bytes read in %lu ms", len_read, time); if (time > 0) { puts(" ("); - print_size(len_read / time * 1000, "/s"); + print_size(div_u64(len_read, time * 1000), "/s"); puts(")"); } puts("\n"); @@ -469,7 +471,7 @@ int do_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], printf("%llu bytes written in %lu ms", len, time); if (time > 0) { puts(" ("); - print_size(len / time * 1000, "/s"); + print_size(div_u64(len, time * 1000), "/s"); puts(")"); } puts("\n");
Hi Tom,
This fixes things for me, thanks! But please see below.
Actually do you think it would be clearer to use div_u64_rem() here?
/* First block. */
__u32 startsect, sect_num, offset; if (clustnum > 0) { startsect = mydata->data_begin +
if (offset != 0) sect_num++; if (startsect + sect_num > cur_part_info.start + total_sector) return -1;
The old code multiplies by 1000 but the new code divides. I think it should be:
print_size(div_u64(len_read, time) * 1000, "/s");
and here.
-- 1.7.9.5
On Wed, Nov 26, 2014 at 12:36:27PM -0700, Simon Glass wrote:
Hi Tom,
I don't think so only since we don't care about the quotient only the remainder. In the FAT case we needed both (and that's what got me seeing the <linux/math64.h> functions.
/* First block. */
and here.
Whoops, those are bugs, fixed.
