Store U-Boot environnement in eMMC on i.MX8MPlus
Hi all,
I try to store my U-Boot environment in eMMC on i.MX8MPlus, I then remove the CONFIG_ENV_IS_NOWHERE option, and I then put the following options: CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_OFFSET=0x400000 CONFIG_ENV_SIZE=0x2000 CONFIG_SYS_MMC_ENV_PART=0
However during the boot sequence I get stuck here:
U-Boot SPL 2023.01 (Jan 25 2023 - 08:23:12 +0100) DDRINFO: start DRAM init DDRINFO: DRAM rate 3000MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done NormalBoot Trying to boot from BOOTROM Boot Stage: USB boot Find img info 0x&48017200, size 872 Need continue download 1024 Download 1090688, Total size 1092224 NOTICE: BL31: v2.4(release):acddd624b NOTICE: BL31: Built: 08:21:46, Jan 24 2023
whereas if I have the option CONFIG_ENV_IS_NOWHERE=y
U-Boot SPL 2023.01 (Jan 25 2023 - 08:41:47 +0100)
DDRINFO: start DRAM init DDRINFO: DRAM rate 3000MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done NormalBoot Trying to boot from BOOTROM Boot Stage: USB boot Find img info 0x&48016e00, size 872 Need continue download 1024 Download 1089160, Total size 1090696 NOTICE: BL31: v2.4(release):acddd624b NOTICE: BL31: Built: 08:21:46, Jan 24 2023
U-Boot 2023.01 (Jan 25 2023 - 08:41:47 +0100)
CPU: i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz) CPU: Industrial temperature grade (-40C to 105C) at 52C Reset cause: POR Model: IMX8MPLUS DRAM: 1 GiB Core: 187 devices, 26 uclasses, devicetree: separate MMC:FSL_SDHC:0 Loading Environment from nowhere...OK In: serial Out: serial Err: serial
BuildInfo: - ATF acddd62
do you have any idea about this?
Joris OFFOUGA
Joris OFFOUGA
