[U-Boot-Users] [PATCH 0/3 (v2)] Remove the deprecated CONFIG_OF_FLAT_TREE
The following troika of patches switch the final two boards (mpc7448hpc2 and stxxst) from using CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDT and then remove support for CONFIG_OF_FLAT_TREE.
Since I don't have access to the boards I could not test them. If someone can test the conversions and provide patches, I would appreciate it.
For the stxxtc board, I don't see how it uses CONFIG_OF_* at all, leading me to believe that the FDT support for that board has bit-rotted away already. Again, patches are welcome.
Best regards, gvb
Dear Wolfgang,
I've removed CONFIG_OF_FLAT_TREE as a cleanup. It would be nice to get it into the 1.34 release, but it can wait for 1.35 if anybody is uncomfortable with this. Since it is enabled on only two boards, it doesn't affect most boards either way.
Best regards, gvb
The following changes since commit 1f1554841a4c8e069d331176f0c3059fb2bb8280: Wolfgang Denk (1): Merge branch 'master' of /home/wd/git/u-boot/custodians
git://git.denx.de/u-boot-fdt.git master
Gerald Van Baren (3): Convert mpc7448hpc2 to CONFIG_OF_LIBFDT Change the stxxst to CONFIG_OF_LIBFDT Remove the deprecated CONFIG_OF_FLAT_TREE
README | 9 +- board/freescale/mpc7448hpc2/mpc7448hpc2.c | 21 +- board/tqm8272/tqm8272.c | 4 - common/Makefile | 1 - common/ft_build.c | 471 ----------------------------- cpu/74xx_7xx/cpu.c | 35 +-- drivers/pci/tsi108_pci.c | 33 ++- include/configs/mpc7448hpc2.h | 3 +- include/configs/stxxtc.h | 4 +- include/ft_build.h | 71 ----- 10 files changed, 42 insertions(+), 610 deletions(-) delete mode 100644 common/ft_build.c delete mode 100644 include/ft_build.h
Jerry Van Baren
