[U-Boot] [PATCH 0/3] Enable networking for BananaPi M3
Hello
This serie fix building sun8i-emac for a83t and then enable networking for BananaPi M3.
Regards
Corentin Labbe (3): configs: Sinovoip_BPI_M3_defconfig: Fix invalid DLDO3 settings net: sun8i-emac: bring back support of A83T configs: Sinovoip_BPI_M3_defconfig: enable sun8i-emac
configs/Sinovoip_BPI_M3_defconfig | 3 ++- drivers/net/sun8i_emac.c | 4 ++++ 2 files changed, 6 insertions(+), 1 deletion(-)
The current dldo3 voltage while sufficient for 100Mbit/s transfers is insufficient for achieving 1Gbit/s. In fact this problem is the same that I reported on Linux month ago.
This patch set DLDO3 to 3.3v which is needed by the PHY.
Signed-off-by: Corentin Labbe clabbe.montjoie@gmail.com --- configs/Sinovoip_BPI_M3_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 79743a9c9a5..b871287b6c3 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -22,7 +22,7 @@ CONFIG_CONSOLE_MUX=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-bananapi-m3" CONFIG_AXP_DCDC5_VOLT=1200 -CONFIG_AXP_DLDO3_VOLT=2500 +CONFIG_AXP_DLDO3_VOLT=3300 CONFIG_AXP_SW_ON=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y
Building sun8i-emac for the A83T variant fail. This is due to different sunxi_ccm_reg members structures of R40 and H3 not present in A83T ones.
This patch fix this problem by adding some ifdef around thses problematic code.
Signed-off-by: Corentin Labbe clabbe.montjoie@gmail.com --- drivers/net/sun8i_emac.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index c9798445c7d..65b32c3b967 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -643,6 +643,7 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) { struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
+#if defined(CONFIG_MACH_SUN8I_H3) if (priv->variant == H3_EMAC) { /* Only H3/H5 have clock controls for internal EPHY */ if (priv->use_internal_phy) { @@ -655,8 +656,10 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) BIT(AHB_RESET_OFFSET_EPHY)); } } +#endif
if (priv->variant == R40_GMAC) { +#if defined(CONFIG_MACH_SUN8I_R40) /* Set clock gating for emac */ setbits_le32(&ccm->ahb_reset1_cfg, BIT(AHB_RESET_OFFSET_GMAC));
@@ -669,6 +672,7 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) CCM_GMAC_CTRL_GPIT_RGMII); setbits_le32(&ccm->gmac_clk_cfg, CCM_GMAC_CTRL_TX_CLK_DELAY(CONFIG_GMAC_TX_DELAY)); +#endif } else { /* Set clock gating for emac */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC));
Since the BPIM3 have a sun8i-emac, this patch enables it on Sinovoip_BPI_M3_defconfig.
Signed-off-by: Corentin Labbe clabbe.montjoie@gmail.com --- configs/Sinovoip_BPI_M3_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index b871287b6c3..9db2d0708c2 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -28,3 +28,4 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_SUN8I_EMAC=y
On Mon, Jun 17, 2019 at 12:31 AM Corentin Labbe clabbe.montjoie@gmail.com wrote:
Hello
Regards
I'm quite sure I already too care of this in
http://git.denx.de/?p=u-boot.git;a=log;h=c23b33f5311abe32db96884318996d2b41d...
Furthermore, sun8i-emac was already converted to use DM clocks and resets. I think you may have a stale branch.
ChenYu
Hello
Regards
http://git.denx.de/?p=u-boot.git;a=log;h=c23b33f5311abe32db96884318996d2b41db4c94
ChenYu
i dont understand why, but my master was two month old (I was sure to have issued some git pull).
Thanks for having fixing that.
Regards
Chen-Yu Tsai
Corentin Labbe
