[U-Boot] [PATCH v2] ARM: dt: zynq: Add labels to cpu nodes to allow overriding OPPs.
By adding labels to the cpu nodes in the dtsi, a dts that includes it can change the OPPs by referencing the cpu0 through the label.
[Based on linux (400b6a0cbef55d1ae32808eaa1ef1c28820bf6ac)] Signed-off-by: Moritz Fischer moritz.fischer@ettus.com Cc: Michal Simek michal.simek@xilinx.com Cc: u-boot@lists.denx.de ---
Ok, since I fatfingered v1 ... this one with right subject prefix, and only one patch in 'series'.
Changes from v1: None
Sorry 'bout the noise,
Moritz
--- arch/arm/dts/zynq-7000.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index 6df0329..668f54e 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -16,7 +16,7 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <0>; @@ -30,7 +30,7 @@ >; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <1>;
Moritz
cpu@0 {
cpu@1 {
Applied.
Thanks, Michal
Michal Simek
Moritz Fischer
