[U-Boot] [PATCH v3 0/4] rockchip: Add a read-only efuse driver for the RK3399 (and derive serial# from fuses on the RK3399-Q7)
As the RK3399-Q7 (Puma) differs from our previous modules in how we can force an external boot (on the RK3399-Q7 this holds the eMMC and SPI in reset, until an external signal is removed) through the 'BIOS disable'-signal of the Qseven specification, we can't derive the unique board id reliably from the eMMC's unique id.
Instead, for the RK3399-Q7, we rely on the efuse block of the RK3399 and use the (assumed to be unique) cpu_id region.
This patch-series adds the required infrastructure and switches the RK3399-Q7 (puma_rk3399) over to this new infrastructure: - adds a rockchip-efuse driver as a misc-device (and permits requests for the clock gate listed in the DTS for the efuse node) - ports the CRC32-based 'serial#' derivation over from Linux - exposes the complete cpu_id field through 'cpuid#'
Changes in v3: - uses uclass_get_device_by_driver() to ensure we don't pick up the wrong misc-device (debug cmd in efuse.c) - uses uclass_get_device_by_driver() to ensure we don't pick up the wrong misc-device (cpuid/serial#/ethaddr in puma-rk3399.c) - rebased to sjg/next
Changes in v2: - added derivation of ethaddr from cpuid
Klaus Goger (1): rockchip: board: puma_rk3399: derive ethaddr from cpuid
Philipp Tomsich (3): rockchip: efuse: add (misc) driver for RK3399 non-secure efuse block rockchip: board: puma_rk3399: add support for serial# and cpuid# via efuses rockchip: defconfig: puma-rk3399: enable RK3399 efuse driver
board/theobroma-systems/puma_rk3399/puma-rk3399.c | 118 ++++++++++++++++ configs/puma-rk3399_defconfig | 2 + drivers/misc/Kconfig | 14 ++ drivers/misc/Makefile | 1 + drivers/misc/rockchip-efuse.c | 162 ++++++++++++++++++++++ include/configs/puma_rk3399.h | 6 + 6 files changed, 303 insertions(+) create mode 100644 drivers/misc/rockchip-efuse.c
This adds a simple driver for reading the efuse block of the RK3399. It should be easy enough to add drivers for other devices (e.g. the RK3328, RK3368, etc.) by passing the device details via driver_data.
Unlike the kernel driver (using the nvmem subsystem), we don't expose the efuse as multiple named cells, but rather as a linear memory that can be read using misc_read(...).
The primary use case (as of today) is the generation of a 'serial#' (and a 'cpuid#') environment variable for the RK3399-Q7 (Puma) system-on-module.
Note that this adds a debug-only (i.e. only if DEBUG is defined) command 'rk3399_dump_efuses' that dumps the efuse block's content. N.B.: The name 'rk3399_dump_efuses' was intentionally chosen to include a SoC-name (together with a comment in the function) to remind whoever adds support for additional SoCs that this function currently makes assumptions regarding the size of the fuse-box based on the RK3399. The hope is that the function is adjusted to reflect any changes resulting from generalising the driver for multiple SoCs and is then renamed.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2: None
drivers/misc/Kconfig | 14 ++++ drivers/misc/Makefile | 1 + drivers/misc/rockchip-efuse.c | 162 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 177 insertions(+) create mode 100644 drivers/misc/rockchip-efuse.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 1aae4bc..ed57414 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -20,6 +20,19 @@ config ALTERA_SYSID Select this to enable a sysid for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
+config ROCKCHIP_EFUSE + bool "Rockchip e-fuse support" + depends on MISC + help + Enable (read-only) access for the e-fuse block found in Rockchip + SoCs: accesses can either be made using byte addressing and a length + or through child-nodes that are generated based on the e-fuse map + retrieved from the DTS. + + This driver currently supports the RK3399 only, but can easily be + extended (by porting the read function from the Linux kernel sources) + to support other recent Rockchip devices. + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC @@ -167,4 +180,5 @@ config I2C_EEPROM depends on MISC help Enable a generic driver for EEPROMs attached via I2C. + endmenu diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 4543cd6..42d946a 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -50,3 +50,4 @@ obj-$(CONFIG_PCA9551_LED) += pca9551_led.o obj-$(CONFIG_FSL_DEVICE_DISABLE) += fsl_devdis.o obj-$(CONFIG_WINBOND_W83627) += winbond_w83627.o obj-$(CONFIG_QFW) += qfw.o +obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o \ No newline at end of file diff --git a/drivers/misc/rockchip-efuse.c b/drivers/misc/rockchip-efuse.c new file mode 100644 index 0000000..f4e31e2 --- /dev/null +++ b/drivers/misc/rockchip-efuse.c @@ -0,0 +1,162 @@ +/* + * eFuse driver for Rockchip devices + * + * Copyright 2017, Theobroma Systems Design und Consulting GmbH + * Written by Philipp Tomsich philipp.tomsich@theobroma-systems.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <command.h> +#include <display_options.h> +#include <dm.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <misc.h> + +#define RK3399_A_SHIFT 16 +#define RK3399_A_MASK 0x3ff +#define RK3399_NFUSES 32 +#define RK3399_BYTES_PER_FUSE 4 +#define RK3399_STROBSFTSEL BIT(9) +#define RK3399_RSB BIT(7) +#define RK3399_PD BIT(5) +#define RK3399_PGENB BIT(3) +#define RK3399_LOAD BIT(2) +#define RK3399_STROBE BIT(1) +#define RK3399_CSB BIT(0) + +struct rockchip_efuse_regs { + u32 ctrl; /* 0x00 efuse control register */ + u32 dout; /* 0x04 efuse data out register */ + u32 rf; /* 0x08 efuse redundancy bit used register */ + u32 _rsvd0; + u32 jtag_pass; /* 0x10 JTAG password */ + u32 strobe_finish_ctrl; + /* 0x14 efuse strobe finish control register */ +}; + +struct rockchip_efuse_platdata { + void __iomem *base; + struct clk *clk; +}; + +#if defined(DEBUG) +static int dump_efuses(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + /* + * N.B.: This function is tailored towards the RK3399 and assumes that + * there's always 32 fuses x 32 bits (i.e. 128 bytes of data) to + * be read. + */ + + struct udevice *dev; + u8 fuses[128]; + int ret; + + /* retrieve the device */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(rockchip_efuse), &dev); + if (ret) { + printf("%s: no misc-device found\n", __func__); + return 0; + } + + ret = misc_read(dev, 0, &fuses, sizeof(fuses)); + if (ret) { + printf("%s: misc_read failed\n", __func__); + return 0; + } + + printf("efuse-contents:\n"); + print_buffer(0, fuses, 1, 128, 16); + + return 0; +} + +U_BOOT_CMD( + rk3399_dump_efuses, 1, 1, dump_efuses, + "Dump the content of the efuses", + "" +); +#endif + +static int rockchip_rk3399_efuse_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct rockchip_efuse_platdata *plat = dev_get_platdata(dev); + struct rockchip_efuse_regs *efuse = + (struct rockchip_efuse_regs *)plat->base; + + unsigned int addr_start, addr_end, addr_offset; + u32 out_value; + u8 bytes[RK3399_NFUSES * RK3399_BYTES_PER_FUSE]; + int i = 0; + u32 addr; + + addr_start = offset / RK3399_BYTES_PER_FUSE; + addr_offset = offset % RK3399_BYTES_PER_FUSE; + addr_end = DIV_ROUND_UP(offset + size, RK3399_BYTES_PER_FUSE); + + /* cap to the size of the efuse block */ + if (addr_end > RK3399_NFUSES) + addr_end = RK3399_NFUSES; + + writel(RK3399_LOAD | RK3399_PGENB | RK3399_STROBSFTSEL | RK3399_RSB, + &efuse->ctrl); + udelay(1); + for (addr = addr_start; addr < addr_end; addr++) { + setbits_le32(&efuse->ctrl, + RK3399_STROBE | (addr << RK3399_A_SHIFT)); + udelay(1); + out_value = readl(&efuse->dout); + clrbits_le32(&efuse->ctrl, RK3399_STROBE); + udelay(1); + + memcpy(&bytes[i], &out_value, RK3399_BYTES_PER_FUSE); + i += RK3399_BYTES_PER_FUSE; + } + + /* Switch to standby mode */ + writel(RK3399_PD | RK3399_CSB, &efuse->ctrl); + + memcpy(buf, bytes + addr_offset, size); + + return 0; +} + +static int rockchip_efuse_read(struct udevice *dev, int offset, + void *buf, int size) +{ + return rockchip_rk3399_efuse_read(dev, offset, buf, size); +} + +static const struct misc_ops rockchip_efuse_ops = { + .read = rockchip_efuse_read, +}; + +static int rockchip_efuse_ofdata_to_platdata(struct udevice *dev) +{ + struct rockchip_efuse_platdata *plat = dev_get_platdata(dev); + + plat->base = (void *)dev_get_addr(dev); + return 0; +} + +static const struct udevice_id rockchip_efuse_ids[] = { + { .compatible = "rockchip,rk3399-efuse" }, + {} +}; + +U_BOOT_DRIVER(rockchip_efuse) = { + .name = "rockchip_efuse", + .id = UCLASS_MISC, + .of_match = rockchip_efuse_ids, + .ofdata_to_platdata = rockchip_efuse_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct rockchip_efuse_platdata), + .ops = &rockchip_efuse_ops, +}; +
Changes in v2: None
Applied to u-boot-rockchip, thanks!
With our efuse driver for the RK3399 ready, we can add the board-specific code that consumes the cpuid from the efuse block and postprocesses it into the system serial (using the same CRC32 based derivation as in Linux).
We expose the cpuid via two distinct environment variables: serial# - the serial number, as derived in Linux cpuid# - the raw 16 byte CPU id field from the fuse block
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
board/theobroma-systems/puma_rk3399/puma-rk3399.c | 79 +++++++++++++++++++++++ include/configs/puma_rk3399.h | 6 ++ 2 files changed, 85 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 6231369..72719f3 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -9,6 +9,7 @@ #include <ram.h> #include <dm/pinctrl.h> #include <dm/uclass-internal.h> +#include <misc.h> #include <asm/arch/periph.h> #include <power/regulator.h> #include <u-boot/sha256.h> @@ -16,6 +17,9 @@ #include <usb.h> #include <dwc3-uboot.h>
+#define RK3399_CPUID_OFF 0x7 +#define RK3399_CPUID_LEN 0x10 + DECLARE_GLOBAL_DATA_PTR;
#define RK3399_CPUID_OFF 0x7 @@ -66,6 +70,81 @@ out: return 0; }
+static void setup_serial(void) +{ +#if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) + struct udevice *dev; + int ret, i; + u8 cpuid[RK3399_CPUID_LEN]; + u8 low[RK3399_CPUID_LEN/2], high[RK3399_CPUID_LEN/2]; + char cpuid_str[RK3399_CPUID_LEN * 2 + 1]; + u64 serialno; + char serialno_str[16]; + + /* the first misc device will be used */ + ret = uclass_get_device(UCLASS_MISC, 0, &dev); + if (ret) { + debug("%s: could not find efuse device\n", __func__); + return; + } + + /* read the cpu_id range from the efuses */ + ret = misc_read(dev, RK3399_CPUID_OFF, &cpuid, sizeof(cpuid)); + if (ret) { + debug("%s: reading cpuid from the efuses failed\n", + __func__); + return; + } + + memset(cpuid_str, 0, sizeof(cpuid_str)); + for (i = 0; i < 16; i++) + sprintf(&cpuid_str[i * 2], "%02x", cpuid[i]); + + debug("cpuid: %s\n", cpuid_str); + + /* + * Mix the cpuid bytes using the same rules as in + * ${linux}/drivers/soc/rockchip/rockchip-cpuinfo.c + */ + for (i = 0; i < 8; i++) { + low[i] = cpuid[1 + (i << 1)]; + high[i] = cpuid[i << 1]; + } + + serialno = crc32_no_comp(0, low, 8); + serialno |= (u64)crc32_no_comp(serialno, high, 8) << 32; + snprintf(serialno_str, sizeof(serialno_str), "%llx", serialno); + + setenv("cpuid#", cpuid_str); + setenv("serial#", serialno_str); +#endif + + return; +} + +int misc_init_r(void) +{ + setup_serial(); + + return 0; +} + +#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + char *serial_string; + u64 serial = 0; + + serial_string = getenv("serial#"); + + if (serial_string) + serial = simple_strtoull(serial_string, NULL, 16); + + serialnr->high = (u32)(serial >> 32); + serialnr->low = (u32)(serial & 0xffffffff); +} +#endif + int dram_init(void) { struct ram_info ram; diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h index f778744..4081362 100644 --- a/include/configs/puma_rk3399.h +++ b/include/configs/puma_rk3399.h @@ -22,4 +22,10 @@
#define SDRAM_BANK_SIZE (2UL << 30)
+#define CONFIG_MISC_INIT_R +#define CONFIG_SERIAL_TAG +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_SYS_WHITE_ON_BLACK + #endif
On 5 May 2017 at 11:21, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
But don't you want to use the same mechanism to make sure you get the right misc driver?
From: Klaus Goger klaus.goger@theobroma-systems.com
Generate a MAC address based on the cpuid available in the efuse block: Use the first 6 byte of the cpuid's SHA256 hash and set the locally administered bits. Also ensure that the multicast bit is cleared.
The MAC address is only generated and set if there is no ethaddr present in the saved environment.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
board/theobroma-systems/puma_rk3399/puma-rk3399.c | 43 +++++++++++++++++++++-- 1 file changed, 41 insertions(+), 2 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 72719f3..8ddca31 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -16,6 +16,7 @@ #include <ram.h> #include <usb.h> #include <dwc3-uboot.h> +#include <u-boot/sha256.h>
#define RK3399_CPUID_OFF 0x7 #define RK3399_CPUID_LEN 0x10 @@ -70,6 +71,42 @@ out: return 0; }
+static void setup_macaddr(void) +{ +#if CONFIG_IS_ENABLED(CMD_NET) + int ret; + const char *cpuid = getenv("cpuid#"); + u8 hash[SHA256_SUM_LEN]; + int size = sizeof(hash); + u8 mac_addr[6]; + + /* Only generate a MAC address, if none is set in the environment */ + if (getenv("ethaddr")) + return; + + if (!cpuid) { + debug("%s: could not retrieve 'cpuid#'\n", __func__); + return; + } + + ret = hash_block("sha256", (void *)cpuid, strlen(cpuid), hash, &size); + if (ret) { + debug("%s: failed to calculate SHA256\n", __func__); + return; + } + + /* Copy 6 bytes of the hash to base the MAC address on */ + memcpy(mac_addr, hash, 6); + + /* Make this a valid MAC address and set it */ + mac_addr[0] &= 0xfe; /* clear multicast bit */ + mac_addr[0] |= 0x02; /* set local assignment bit (IEEE802) */ + eth_setenv_enetaddr("ethaddr", mac_addr); +#endif + + return; +} + static void setup_serial(void) { #if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) @@ -81,8 +118,9 @@ static void setup_serial(void) u64 serialno; char serialno_str[16];
- /* the first misc device will be used */ - ret = uclass_get_device(UCLASS_MISC, 0, &dev); + /* retrieve the device */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(rockchip_efuse), &dev); if (ret) { debug("%s: could not find efuse device\n", __func__); return; @@ -125,6 +163,7 @@ static void setup_serial(void) int misc_init_r(void) { setup_serial(); + setup_macaddr();
return 0; }
With everything in place (i.e. the new efuse driver, the clk-support for the non-secure efuse block, and the board-specific functions to derive 'serial#' from the cpu-id within the efuses), enable this in the RK3399-Q7 defconfig.
configs/puma-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index df736f7..207445d 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -38,6 +38,8 @@ CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
Philipp Tomsich
sjg@google.com
