[U-Boot-Users] Debugging U-Boot with BDI2000
Hello!
I'm quite new to U-Boot and trying to get started with the Bootloader-Stuff for some weeks now. My Board is similar to Accelent IDP or CSB226(PXA250 with 32 MB Strataflash and 32 MB SDRAM). U-Boot seems to crash on my board before it can output something through the serial line. So I wanted step through U-Boot right from the very first instruction using BDI2000 while booting. The problem is that the information the bdi user manual gives, is quite confusing. I tried out various configurations for BDI2000, but really don't know what to do with the vector table in the "Mini IC" and the debug handler stuff. The situation now is as following: The target is in debug mode right from the start and the PC is pointing to 0xffff0004. "go" or "ti" doesn't work because of access to an invalid memory address. (My configuration file now contains a blank [INIT] section and no vector table/debug handler stuff in the [TARGET] part)
I'd be very thankful if someone could answer my questions:
1) Is it possible to debug U-Boot with BDI2000 (Linux host) at all? (eg. step through the instructions)
2) Do somebody have a working configuration file for BDI2000 (Linux host) to be used with a PXA250-target?
Hope, you can give me at least a hint.
Regards, Glenson Muthedan.
In message 3F604A6E.7030308@gmx.de you wrote:
- Is it possible to debug U-Boot with BDI2000 (Linux host) at all?
Yes, of course!!!
- Do somebody have a working configuration file for BDI2000 (Linux
Configuration files for some targets are included with the BDI2000 firmware - see the floppy disk, or the .zip file you received with the device.
But a configuration file for _some_ PXA250 board is only an EXAMPLE, you cannot use it unchanged on different hardware. You must create a NEW configuration file which matches exactly the hardware as implemented on your board.
This is not a trivial task, but the knowledge you need to do this is necessary to successfully port and debug U-Boot anyway.
Did you try using U-Boot + one of my -ptx patches? Should work better on PXA than vanilla because of the memory layout problems.
I currently use this one:
[TARGET] CPUTYPE PXA250 ; the target CPU type JTAGCLOCK 1 ; use 8 MHz JTAG clock DBGHANDLER 0xFE000800 ; ENDIAN LITTLE ; memory model (LITTLE | BIG) BREAKMODE HARD ; SOFT or HARD; HARD does only allow two ; breakpoints, but does work on flash ;VECTOR CATCH 0xDE ; trap all vectors ;VTABLO 0xE59FF014 ; Use fixed vectors "ldr pc, [pc, #14]"
I started with the Lubbock config which came with the BDI and it worked quite fine.
Yes, works perfectly.
I send you my CSB config with separate mail.
Robert
Glenson Muthedan
Robert Schwebel
