[U-Boot-Users] Subject: [PATCH] Remove superfluous preprocessor conditionals from LM73 driver
(1) Remove unused symbol "CFG_EEPROM_PAGE_WRITE_ENABLE".
(2) Use conditional Makefile.o.
Signed-off-by: Larry Johnson lrj@acm.org --- (Patch applies to PPC4xx "master" branch.)
drivers/hwmon/Makefile | 2 +- drivers/hwmon/lm73.c | 9 --------- include/configs/korat.h | 1 - 3 files changed, 1 insertions(+), 11 deletions(-)
diff --git a/drivers/hwmon/Makefile b/drivers/hwmon/Makefile index 32e3f44..065433a 100644 --- a/drivers/hwmon/Makefile +++ b/drivers/hwmon/Makefile @@ -34,7 +34,7 @@ COBJS-y += adm1021.o COBJS-y += ds1621.o COBJS-y += ds1722.o COBJS-y += ds1775.o -COBJS-y += lm73.o +COBJS-$(CONFIG_DTT_LM73) += lm73.o COBJS-y += lm75.o COBJS-y += lm81.o
diff --git a/drivers/hwmon/lm73.c b/drivers/hwmon/lm73.c index f9ae012..db8ef66 100644 --- a/drivers/hwmon/lm73.c +++ b/drivers/hwmon/lm73.c @@ -31,13 +31,6 @@ */
#include <common.h> - -#ifdef CONFIG_DTT_LM73 -#if !defined(CFG_EEPROM_PAGE_WRITE_ENABLE) || \ - (CFG_EEPROM_PAGE_WRITE_BITS < 1) -# error "CFG_EEPROM_PAGE_WRITE_ENABLE must be defined and CFG_EEPROM_PAGE_WRITE_BITS must be greater than 1 to use CONFIG_DTT_LM73" -#endif - #include <i2c.h> #include <dtt.h>
@@ -177,5 +170,3 @@ int dtt_get_temp(int sensor) { return (dtt_read(sensor, DTT_READ_TEMP) + 0x0040) >> 7; } /* dtt_get_temp() */ - -#endif /* CONFIG_DTT_LM73 */ diff --git a/include/configs/korat.h b/include/configs/korat.h index 312b8c5..a0ea0f3 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -156,7 +156,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
Larry Johnson
