[U-Boot] [PATCH V2 0/3] OMAP5/DRA7: EMIF fixes for lowpower usecases
1) Currently the DDR3 memory on DRA7 ES1.0 evm board is enabled using software leveling. This was done since hardware leveling was not working. Now that the right sequence to do hw leveling is identified, use it. This is required for EMIF clockdomain to idle and come back during lowpower usecases
2) When core power domain hits oswr, then DDR3 memories does not come back while resuming. This is because when EMIF registers are lost, then the controller takes care of copying the values from the shadow registers. If the shadow registers are not updated with the right values, then this results in incorrect settings while resuming. So updating the shadow registers with the corresponding status registers here during the boot.
Sricharan R (3): ARM: DRA7: Add is_dra7xx cpu check definition ARM: DRA: EMIF: Change DDR3 settings to use hw leveling ARM: DRA7/OMAP5: EMIF: Add workaround for bug 0039
arch/arm/cpu/armv7/omap-common/emif-common.c | 142 +++++++++++++---- arch/arm/cpu/armv7/omap5/hw_data.c | 9 +- arch/arm/cpu/armv7/omap5/hwinit.c | 12 +- arch/arm/cpu/armv7/omap5/sdram.c | 214 ++++++++++++++++++-------- arch/arm/include/asm/arch-omap5/omap.h | 1 + arch/arm/include/asm/emif.h | 14 +- arch/arm/include/asm/omap_common.h | 8 + 7 files changed, 301 insertions(+), 99 deletions(-)
Sricharan R
