[U-Boot] [PATCH] fuelgauge: max17042: fix i2c read issue which causes infinity loop.
Issues: - reading i2c data by passing u16 pointer causes errors in read data. - max17042 status register fields have not only Power On Reset meaning so using proper mask is required.
Changes: - read i2c data to type u32 instead of u16 - avoids buffer overflow - compare FG status register using mask not just one bit value
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com --- drivers/power/fuel_gauge/fg_max17042.c | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/power/fuel_gauge/fg_max17042.c b/drivers/power/fuel_gauge/fg_max17042.c index c285747..2cbf8cf 100644 --- a/drivers/power/fuel_gauge/fg_max17042.c +++ b/drivers/power/fuel_gauge/fg_max17042.c @@ -28,11 +28,14 @@ static int fg_write_regs(struct pmic *p, u8 addr, u16 *data, int num)
static int fg_read_regs(struct pmic *p, u8 addr, u16 *data, int num) { + unsigned int dat = 0; int ret = 0; int i;
- for (i = 0; i < num; i++, addr++) - ret |= pmic_reg_read(p, addr, (u32 *) (data + i)); + for (i = 0; i < num; i++, addr++) { + ret |= pmic_reg_read(p, addr, &dat); + *(data + i) = (u16) dat; + }
return ret; } @@ -178,7 +181,7 @@ static int power_check_battery(struct pmic *p, struct pmic *bat) ret |= pmic_reg_read(p, MAX17042_STATUS, &val); debug("fg status: 0x%x\n", val);
- if (val == MAX17042_POR) + if (val && MAX17042_POR) por_fuelgauge_init(p);
ret |= pmic_reg_read(p, MAX17042_VERSION, &val);
Dear Przemyslaw Marczak,
On 11/12/13 00:19, Przemyslaw Marczak wrote:
Issues:
Changes:
- unsigned int dat = 0;
initial value is unnecessary.
int ret = 0; int i;
- for (i = 0; i < num; i++, addr++) {
I think, need check return value. if failed to read then you should not update data. and such a case, do we need to read end of num? why don't you return error directly? I think this code should be..
ret = pmic_reg_read(p, addr, &dat); if (ret) return ret;
*(data + i) = (u16)dat;
please remove space between ) and dat.
return ret;
then it can be return 0; and initial value ( = 0) is unnecessary.
- if (val && MAX17042_POR)
if (val & MAX17042_POR) ?
Thanks, Minkyu Kang.
Changes: - read i2c data to type u32 instead of u16 - avoids buffer overflow - compare FG status register using mask not just one bit value - add checking return value to functions fg read/write - add model lock and model check count - add debug msg
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com
--- Changes v2: - add checking return value to functions fg read/write - add model lock and model check count - add status msg - change logical AND to bitwise AND when checking status register
drivers/power/fuel_gauge/fg_max17042.c | 120 +++++++++++++++++++++++--------- 1 file changed, 86 insertions(+), 34 deletions(-)
diff --git a/drivers/power/fuel_gauge/fg_max17042.c b/drivers/power/fuel_gauge/fg_max17042.c index c285747..154ca6a 100644 --- a/drivers/power/fuel_gauge/fg_max17042.c +++ b/drivers/power/fuel_gauge/fg_max17042.c @@ -20,21 +20,30 @@ static int fg_write_regs(struct pmic *p, u8 addr, u16 *data, int num) int ret = 0; int i;
- for (i = 0; i < num; i++, addr++) - ret |= pmic_reg_write(p, addr, *(data + i)); + for (i = 0; i < num; i++, addr++) { + ret = pmic_reg_write(p, addr, *(data + i)); + if (ret) + return ret; + }
- return ret; + return 0; }
static int fg_read_regs(struct pmic *p, u8 addr, u16 *data, int num) { + unsigned int dat; int ret = 0; int i;
- for (i = 0; i < num; i++, addr++) - ret |= pmic_reg_read(p, addr, (u32 *) (data + i)); + for (i = 0; i < num; i++, addr++) { + ret = pmic_reg_read(p, addr, &dat); + if (ret) + return ret;
- return ret; + *(data + i) = (u16)dat; + } + + return 0; }
static int fg_write_and_verify(struct pmic *p, u8 addr, u16 data) @@ -57,9 +66,13 @@ static int fg_write_and_verify(struct pmic *p, u8 addr, u16 data) static void por_fuelgauge_init(struct pmic *p) { u16 r_data0[16], r_data1[16], r_data2[16]; - u32 rewrite_count = 5, i = 0; - unsigned int val; - int ret = 0; + u32 rewrite_count = 5; + u32 check_count; + u32 lock_count; + u32 i = 0; + u32 val; + s32 ret = 0; + char *status_msg;
/* Delay 500 ms */ mdelay(500); @@ -67,29 +80,55 @@ static void por_fuelgauge_init(struct pmic *p) pmic_reg_write(p, MAX17042_CONFIG, 0x2310);
rewrite_model: + check_count = 5; + lock_count = 5; + + if (!rewrite_count--) { + status_msg = "init failed!"; + goto error; + } + /* Unlock Model Access */ pmic_reg_write(p, MAX17042_MLOCKReg1, MODEL_UNLOCK1); pmic_reg_write(p, MAX17042_MLOCKReg2, MODEL_UNLOCK2);
/* Write/Read/Verify the Custom Model */ - ret |= fg_write_regs(p, MAX17042_MODEL1, cell_character0, + ret = fg_write_regs(p, MAX17042_MODEL1, cell_character0, ARRAY_SIZE(cell_character0)); - ret |= fg_write_regs(p, MAX17042_MODEL2, cell_character1, + if (ret) + goto rewrite_model; + + ret = fg_write_regs(p, MAX17042_MODEL2, cell_character1, ARRAY_SIZE(cell_character1)); - ret |= fg_write_regs(p, MAX17042_MODEL3, cell_character2, + if (ret) + goto rewrite_model; + + ret = fg_write_regs(p, MAX17042_MODEL3, cell_character2, ARRAY_SIZE(cell_character2)); + if (ret) + goto rewrite_model;
- if (ret) { - printf("%s: Cell parameters write failed!\n", __func__); - return; +check_model: + if (!check_count--) { + if (rewrite_count) + goto rewrite_model; + else + status_msg = "check failed!"; + + goto error; }
- ret |= fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); - ret |= fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); - ret |= fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); + ret = fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); + if (ret) + goto check_model; + + ret = fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); + if (ret) + goto check_model;
+ ret = fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); if (ret) - printf("%s: Cell parameters read failed!\n", __func__); + goto check_model;
for (i = 0; i < 16; i++) { if ((cell_character0[i] != r_data0[i]) @@ -98,29 +137,37 @@ rewrite_model: goto rewrite_model; }
+lock_model: + if (!lock_count--) { + if (rewrite_count) + goto rewrite_model; + else + status_msg = "lock failed!"; + + goto error; + } + /* Lock model access */ pmic_reg_write(p, MAX17042_MLOCKReg1, MODEL_LOCK1); pmic_reg_write(p, MAX17042_MLOCKReg2, MODEL_LOCK2);
/* Verify the model access is locked */ - ret |= fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); - ret |= fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); - ret |= fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); + ret = fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); + if (ret) + goto lock_model;
- if (ret) { - printf("%s: Cell parameters read failed!\n", __func__); - return; - } + ret = fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); + if (ret) + goto lock_model; + + ret = fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); + if (ret) + goto lock_model;
for (i = 0; i < ARRAY_SIZE(r_data0); i++) { /* Check if model locked */ - if (r_data0[i] || r_data1[i] || r_data2[i]) { - /* Rewrite model data - prevent from endless loop */ - if (rewrite_count--) { - puts("FG - Lock model access failed!\n"); - goto rewrite_model; - } - } + if (r_data0[i] || r_data1[i] || r_data2[i]) + goto lock_model; }
/* Write Custom Parameters */ @@ -137,6 +184,11 @@ rewrite_model:
/* Delay at least 350 ms */ mdelay(350); + + status_msg = "OK!"; +error: + debug("%s: model init status: %s\n", p->name, status_msg); + return; }
static int power_update_battery(struct pmic *p, struct pmic *bat) @@ -178,7 +230,7 @@ static int power_check_battery(struct pmic *p, struct pmic *bat) ret |= pmic_reg_read(p, MAX17042_STATUS, &val); debug("fg status: 0x%x\n", val);
- if (val == MAX17042_POR) + if (val & MAX17042_POR) por_fuelgauge_init(p);
Hello,
On 12/30/2013 11:24 AM, Przemyslaw Marczak wrote:
Issues:
Changes:
- add debug msg
Changes v2:
- add status msg
To test this patch, it is required to apply trats i2c fix by Piotr Wilczek: "[PATCH] board:trats1:trats2: fix adapter number" which can be found at u-boot list. In other way FG will be not initialized.
Regards,
Hello Minkyu,
On 12/30/2013 11:31 AM, Przemyslaw Marczak wrote:
Hello,
Issues:
Changes:
- add debug msg
Changes v2:
- add status msg
Regards,
Could you review this patch, please? Is it possible to apply this before the release? It is useful fix.
Thank you,
On 13/01/14 18:27, Przemyslaw Marczak wrote:
Hello Minkyu,
Hello,
Issues:
Changes:
- add debug msg
Changes v2:
- add status msg
Regards,
Thank you,
This patch was delegated to Tom.
Hello,
Hello Minkyu,
Hello,
Issues:
Changes:
- add debug msg
Changes v2:
- add status msg
Regards,
Thank you,
Ok, thank you,
On Mon, Dec 30, 2013 at 11:24:32AM +0100, Przemyslaw Marczak wrote:
Issues:
Changes:
- add debug msg
Minkyu Kang
Przemyslaw Marczak
