[U-Boot] [PATCH] Makefile: Don't mess with .text section location for selected arches
Most of architectures have .text section situated in the very beginning of U-Boot binary and thus it is very logical that CONFIG_SYS_TEXT_BASE is used on final linkage step to specify where U-Boot gets linked to.
For that we pass the following construction to the LD: ---------------------------->8----------------------- xxx-ld ... -Ttext $(CONFIG_SYS_TEXT_BASE) ... ---------------------------->8-----------------------
But there could be exceptions. For example: 1. In case of ARCv2 we want to put vectors table in its own section .ivt in front of .text section which means we need either add an offset to CONFIG_SYS_TEXT_BASE to compensate for .ivt or don't pass "-Ttext" to the LD at all and specify link base in linker script directly.
2. Some architectures even though have .text section in the very beginning of the U-Boot image still use different symbols to specify link-base: * NIOS2: CONFIG_SYS_MONITOR_BASE (which I really like because that exactly what makes sense - where out image starts but not beginning of its .text section which just happened to match the whole image beginning) * EXTENSA: CONFIG_SYS_TEXT_ADDR * X86: Which doesn't use CONFIG_SYS_MONITOR_BASE in case of EFI otherwise sets explicit link base in u-boot.lds
I think that's good to allow for flexibility and don't require each and every architecture or even platform to specify CONFIG_SYS_TEXT_BASE as well as use it to set .text section location.
So let's only pass "-Ttext xxx" for those architectures who don't set link-base explicitly in their linker scripts.
This patch iaddresses comments for previously sent https://patchwork.ozlabs.org/patch/867540/.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Marek Vasut marek.vasut@gmail.com Cc: Max Filippov jcmvbkbc@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index cd265f546677..57cb4b87d930 100644 --- a/Makefile +++ b/Makefile @@ -820,7 +820,7 @@ LDFLAGS_u-boot += $(LDFLAGS_FINAL) # Avoid 'Not enough room for program headers' error on binutils 2.28 onwards. LDFLAGS_u-boot += $(call ld-option, --no-dynamic-linker)
-ifneq ($(CONFIG_SYS_TEXT_BASE),) +ifeq ($(CONFIG_ARC)$(CONFIG_NIOS2)$(CONFIG_X86)$(CONFIG_XTENSA),) LDFLAGS_u-boot += -Ttext $(CONFIG_SYS_TEXT_BASE) endif
Alexey Brodkin
