[U-Boot] [PATCH v2] riscv: cache: Implement i/dcache [status, enable, disable]
AndeStar RISC-V(V5) provide mcache_ctl register which can configure I/D cache as enabled or disabled.
This CSR will be encapsulated by CONFIG_RISCV_NDS. If you want to configure cache on AndeStar V5 AE350 platform. YOu can enable [*] AndeStar V5 ISA support by make menuconfig.
This approach also provide the expansion when the vender specific features are going to join in.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- arch/riscv/Kconfig | 8 ++++ arch/riscv/cpu/ax25/Makefile | 1 + arch/riscv/cpu/ax25/cache.c | 89 ++++++++++++++++++++++++++++++++++++++++++ arch/riscv/cpu/ax25/cpu.c | 4 ++ arch/riscv/cpu/qemu/cpu.c | 2 +- arch/riscv/cpu/start.S | 6 +++ arch/riscv/include/asm/cache.h | 9 +++++ arch/riscv/lib/cache.c | 30 +++++++++----- 8 files changed, 138 insertions(+), 11 deletions(-) create mode 100644 arch/riscv/cpu/ax25/cache.c
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 371921b..a356729 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -74,4 +74,12 @@ config 32BIT config 64BIT bool
+config RISCV_NDS + bool "AndeStar V5 ISA support" + default n + help + Say Y here if you plan to run U-Boot on AndeStar v5 + platforms and use some specific features which are + provided by Andes Technology AndeStar V5 Families. + endmenu diff --git a/arch/riscv/cpu/ax25/Makefile b/arch/riscv/cpu/ax25/Makefile index 2ab0342..318bacc 100644 --- a/arch/riscv/cpu/ax25/Makefile +++ b/arch/riscv/cpu/ax25/Makefile @@ -4,3 +4,4 @@ # Rick Chen, Andes Technology Corporation rick@andestech.com
obj-y := cpu.o +obj-y += cache.o diff --git a/arch/riscv/cpu/ax25/cache.c b/arch/riscv/cpu/ax25/cache.c new file mode 100644 index 0000000..e0bcaa2 --- /dev/null +++ b/arch/riscv/cpu/ax25/cache.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017 Andes Technology Corporation + * Rick Chen, Andes Technology Corporation rick@andestech.com + */ + +#include <common.h> + +void icache_enable(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "ori t0, t1, 0x1\n\t" + "csrw mcache_ctl, t0\n\t" + ); +#endif +#endif +} + +void icache_disable(void) +{ +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "andi t0, t1, ~0x1\n\t" + "csrw mcache_ctl, t0\n\t" + ); +#endif +} + +void dcache_enable(void) +{ +#ifndef CONFIG_SYS_ICACHE_OFF +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "ori t0, t1, 0x2\n\t" + "csrw mcache_ctl, t0\n\t" + ); +#endif +#endif +} + +void dcache_disable(void) +{ +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "andi t0, t1, ~0x2\n\t" + "csrw mcache_ctl, t0\n\t" + ); +#endif +} + +int icache_status(void) +{ + int ret = 0; + +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "andi %0, t1, 0x01\n\t" + : "=r" (ret) + : + : "memory" + ); +#endif + + return ret; +} + +int dcache_status(void) +{ + int ret = 0; + +#ifdef CONFIG_RISCV_NDS + asm volatile ( + "csrr t1, mcache_ctl\n\t" + "andi %0, t1, 0x02\n\t" + : "=r" (ret) + : + : "memory" + ); +#endif + + return ret; +} diff --git a/arch/riscv/cpu/ax25/cpu.c b/arch/riscv/cpu/ax25/cpu.c index fddcc15..76689b2 100644 --- a/arch/riscv/cpu/ax25/cpu.c +++ b/arch/riscv/cpu/ax25/cpu.c @@ -6,6 +6,7 @@
/* CPU specific code */ #include <common.h> +#include <asm/cache.h>
/* * cleanup_before_linux() is called just before we call linux @@ -18,6 +19,9 @@ int cleanup_before_linux(void) disable_interrupts();
/* turn off I/D-cache */ + cache_flush(); + icache_disable(); + dcache_disable();
return 0; } diff --git a/arch/riscv/cpu/qemu/cpu.c b/arch/riscv/cpu/qemu/cpu.c index 6c7a327..25d97d0 100644 --- a/arch/riscv/cpu/qemu/cpu.c +++ b/arch/riscv/cpu/qemu/cpu.c @@ -15,7 +15,7 @@ int cleanup_before_linux(void) { disable_interrupts();
- /* turn off I/D-cache */ + cache_flush();
return 0; } diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 331a534..0e21679 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -46,6 +46,10 @@ _start: /* mask all interrupts */ csrw mie, zero
+/* Enable cache */ +jal icache_enable +jal dcache_enable + /* * Set stackpointer in internal/ex RAM to call board_init_f */ @@ -181,6 +185,8 @@ clbss_l: * initialization, now running from RAM. */ call_board_init_r: + jal invalidate_icache_all + jal flush_dcache_all la t0, board_init_r mv t4, t0 /* offset of board_init_r() */ add t4, t4, t6 /* real address of board_init_r() */ diff --git a/arch/riscv/include/asm/cache.h b/arch/riscv/include/asm/cache.h index ca83dd6..e76ca13 100644 --- a/arch/riscv/include/asm/cache.h +++ b/arch/riscv/include/asm/cache.h @@ -7,6 +7,15 @@ #ifndef _ASM_RISCV_CACHE_H #define _ASM_RISCV_CACHE_H
+/* cache */ +int icache_status(void); +void icache_enable(void); +void icache_disable(void); +int dcache_status(void); +void dcache_enable(void); +void dcache_disable(void); +void cache_flush(void); + /* * The current upper bound for RISCV L1 data cache line sizes is 32 bytes. * We use that value for aligning DMA buffers unless the board config has diff --git a/arch/riscv/lib/cache.c b/arch/riscv/lib/cache.c index d642a38..121db09 100644 --- a/arch/riscv/lib/cache.c +++ b/arch/riscv/lib/cache.c @@ -6,6 +6,15 @@
#include <common.h>
+void invalidate_icache_all(void) +{ + asm volatile ("fence.i" ::: "memory"); +} + +void flush_dcache_all(void) +{ + asm volatile("fence" :::"memory"); +} void flush_dcache_range(unsigned long start, unsigned long end) { } @@ -19,41 +28,42 @@ void invalidate_icache_range(unsigned long start, unsigned long end) invalidate_icache_all(); }
-void invalidate_icache_all(void) +void invalidate_dcache_range(unsigned long start, unsigned long end) { - asm volatile ("fence.i" ::: "memory"); }
-void invalidate_dcache_range(unsigned long start, unsigned long end) +void cache_flush(void) { + invalidate_icache_all(); + flush_dcache_all(); }
-void flush_cache(unsigned long addr, unsigned long size) +__weak void flush_cache(unsigned long addr, unsigned long size) { }
-void icache_enable(void) +__weak void icache_enable(void) { }
-void icache_disable(void) +__weak void icache_disable(void) { }
-int icache_status(void) +__weak int icache_status(void) { return 0; }
-void dcache_enable(void) +__weak void dcache_enable(void) { }
-void dcache_disable(void) +__weak void dcache_disable(void) { }
-int dcache_status(void) +__weak int dcache_status(void) { return 0; }
Hi Rick,
+config RISCV_NDS
- bool "AndeStar V5 ISA support"
- default n
- help
- Copyright (C) 2017 Andes Technology Corporation
- Rick Chen, Andes Technology Corporation rick@andestech.com
- asm volatile (
+#endif +#endif +}
Just wondering, why do you not have the same #ifndef CONFIG_SYS_ICACHE_OFF as above here?
- asm volatile (
+#endif +}
- asm volatile (
+#endif +#endif +}
- asm volatile (
+#endif +}
- int ret = 0;
- asm volatile (
: "=r" (ret)
: "memory"
- return ret;
- int ret = 0;
- asm volatile (
: "=r" (ret)
: "memory"
- return ret;
- cleanup_before_linux() is called just before we call linux
- cache_flush();
- icache_disable();
- dcache_disable();
This is a separate change from the one described in the commit message, please move this into a new patch.
I think we should do the same thing as ARM here. This is the implementation on armv8, for example. This sequence is chosen so that any new entries to the cache just before it is disabled get invalidated as well.
/* * Turn off I-cache and invalidate it */ icache_disable(); invalidate_icache_all();
/* * turn off D-cache * dcache_disable() in turn flushes the d-cache and disables MMU */ dcache_disable(); invalidate_dcache_all();
cache_flush();
I think we should also define a enable_caches() function, like on ARM, to enable the caches. This works as well, but I think it makes sense to copy what other architectures do. What do you think?
- Set stackpointer in internal/ex RAM to call board_init_f
- initialization, now running from RAM.
- jal invalidate_icache_all
- jal flush_dcache_all
Is this required, perhaps this should be called from icache/dcache_enable?
These are not required, include/common.h already has the function prototypes.
- The current upper bound for RISCV L1 data cache line sizes is 32
bytes.
- We use that value for aligning DMA buffers unless the board
#include <common.h>
- asm volatile("fence" :::"memory");
nit: there should be a space after "volatile" and ":::" to match the style from invalidate_icache_all :)
Can you also implement the flush_dcache_range and flush_cache functions? We might run into unexpected behavior if we don't flush the cache here.
- invalidate_icache_all();
- flush_dcache_all();
You are not overwriting this function, so it doesn't have to be defined as weak.
Thanks, Lukas
Auer, Lukas lukas.auer@aisec.fraunhofer.de 於 2018年11月4日 週日 下午10:21寫道:
Hi Rick,
+config RISCV_NDS
default n
help
asm volatile (
+#endif +#endif +}
I only add CONFIG_SYS_XXX_OFF in enable function, not in disable funtion. This can control cache enable or disable when u-boot start-up, on other reason. If you care about this, I can add CONFIG_SYS_XXX_OFF for all.
asm volatile (
+#endif +}
asm volatile (
+#endif +#endif +}
asm volatile (
+#endif +}
int ret = 0;
asm volatile (
: "=r" (ret)
: "memory"
return ret;
int ret = 0;
asm volatile (
: "=r" (ret)
: "memory"
return ret;
cache_flush();
icache_disable();
dcache_disable();
This is RISC-V not armv8. /lib/cache.c is for RISC-V generic cache implement. /cpu/ax25/cache.c is for Andes RISC-V cache implement.
You can add a platform which is armv8 relative as below And modify the necessary flow as you want /cpu/armv8/cache.c
- Turn off I-cache and invalidate it
- turn off D-cache
- dcache_disable() in turn flushes the d-cache and disables MMU
cache_flush(); return 0;
Both coding style are exist in whole U-Boot I can not find enable_caches be used in start.S But it can be found bl dcache_enable in arch\powerpc\cpu\mpc86xx\start.S So I prefer to not modify this flow. Unless it indeed affect your platform and cause some error.
And I modify it as jal icache_enable the coding flow. It is because you do not like CONFIG_SYS_ICACHE_OFF. It may let you make some mistakes. So I move CONFIG_SYS_ICACHE_OFF in /cpi/ax25/cache.c
Yes. It is required. It can not be called to icache/dcache_enable Cache shall be inval and flush after relocation.
I will remove them from cache.h.
bytes.
#include <common.h>
I will modify it.
I do not modify it for the reason: I separate one cache.c to /lib/cache.c /cpu/ax25/cache.c
I plan /lib/cache.c will be maintained by you That is why I do not implement this two function.
If you said that I will implement flush_dcache_range and flush_cache in V2
flush_dcache_all();
Actually I will have a flush_cache(unsigned long addr, unsigned long size) in /cpu/ax25/cache.c in the future.
And I declare it as weak in /lib/cache.c So next time when I send a patch /lib/cache.c can't be modified anymore.
Maybe it is not a good idea. I will recovery it as not weak here in V2.
Thanks, Lukas
Hi Rick,
Hi Rick,
+config RISCV_NDS
default n
help
asm volatile (
+#endif +#endif +}
I was just wondering why, you can leave it as is.
asm volatile (
+#endif +}
asm volatile (
+#endif +#endif +}
asm volatile (
+#endif +}
int ret = 0;
asm volatile (
: "=r" (ret)
: "memory"
return ret;
int ret = 0;
asm volatile (
: "=r" (ret)
: "memory"
return ret;
cache_flush();
icache_disable();
dcache_disable();
Of course this is not armv8. I was referring to the sequence in which the cache is disabled, i.e. first disable, then invalidate. This might not be needed, but is nevertheless a good idea to ensure all entries in the cache are invalidated.
- turn off D-cache
enable_caches is, for example, defined in arch/arm/cpu/armv8/cache_v8.c. It is called by initr_caches() in board_init_r, this means the caches are only enabled once U-Boot has been relocated.
I prefer this way, because I think it is better if the caches are enabled in a file common to all platforms, which also initializes other parts of the system. Of course, this is my personal opinion, if you still prefer this way, you can leave it like this.
I am completely fine with CONFIG_SYS_ICACHE_OFF, in fact, I think it should be used here :)
Ah I see, yes that is definitely required. However, I think this should go into relocate_code of start.S, just so it's clear why the caches are cleared at this point.
32 bytes.
#include <common.h>
I will modify it.
Ok, I can send a patch to implement them.
flush_dcache_all();
That makes sense, the weak doesn't break anything, so you can also leave it I think.
Thanks, Lukas
Hi Rick,
+config RISCV_NDS
This needs better be moved to arch/riscv/cpu/ax25/Kconfig. I have a patch to organize the Kconfig options in a hierarchy way @ http://git.denx.de/?p=u-boot/u-boot-x86.git;a=commitdiff;h=5a650689410482907...
default n
nits: default n is not needed.
If we move this to arch/riscv/cpu/ax25/Kconfig, this option can be selected by the board config.
help
There is no need to #ifdef here.
asm volatile (
+#endif +#endif +}
[snip]
Regards, Bin
Hi Bin
Bin Meng bmeng.cn@gmail.com 於 2018年11月4日 週日 下午10:31寫道:
Hi Rick,
+config RISCV_NDS
I will move this to arch/riscv/cpu/ax25/Kconfig
default n
It may still needed. Or it will fail in auto build with generic RISC-V toolchain. It do not recognize this mcache_ctl csr .
help
asm volatile (
+#endif +#endif +}
[snip]
Regards, Bin
Hi Rick,
On Tue, Nov 6, 2018 at 2:01 PM Rick Chen rickchen36@gmail.com wrote:
Hi Bin
Hi Rick,
+config RISCV_NDS
default n
I mean from Kconfig language perspective, specifying 'default n', or omitting it, does not make any difference. So you need need explicitly write 'default n' here.
help
asm volatile (
+#endif +#endif +}
Regards, Bin
Andes
Auer, Lukas
Bin Meng
Rick Chen
