[PATCH 0/2] efi_loader: allow booting from short dev only DP
Allow creating boot options without file path, e.g.
efidebug boot add -b 0001 'short dev only' host 0:1 '' efidebug boot add -B 0001 'long dev only' host 0:1 ''
Allow booting from a short form device-path without file path, e.g.
/HD(1,GPT,5ef79931-a1aa-4c70-9d67-611e8f69eafd,0x800,0x1000)
Heinrich Schuchardt (2): efi_loader: allow booting from short dev only DP efi_loader: create boot options without file path
lib/efi_loader/efi_bootmgr.c | 9 ++++----- lib/efi_loader/efi_device_path.c | 14 ++++++++------ 2 files changed, 12 insertions(+), 11 deletions(-)
-- 2.36.1
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_bootmgr.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 93f6590530..9b65f34035 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -44,7 +44,7 @@ static const struct efi_runtime_services *rs; static struct efi_device_path *expand_media_path(struct efi_device_path *device_path) { - struct efi_device_path *dp, *full_path; + struct efi_device_path *dp, *rem, *full_path; efi_handle_t handle; efi_status_t ret;
@@ -57,11 +57,10 @@ struct efi_device_path *expand_media_path(struct efi_device_path *device_path) * booting from removable media. */ dp = device_path; - ret = EFI_CALL(efi_locate_device_path( - &efi_simple_file_system_protocol_guid, - &dp, &handle)); + handle = efi_dp_find_obj(dp, &efi_simple_file_system_protocol_guid, + &rem); if (ret == EFI_SUCCESS) { - if (dp->type == DEVICE_PATH_TYPE_END) { + if (rem->type == DEVICE_PATH_TYPE_END) { dp = efi_dp_from_file(NULL, 0, "/EFI/BOOT/" BOOTEFI_NAME); full_path = efi_dp_append(device_path, dp); -- 2.36.1
efidebug boot add -b 0001 'short dev only' host 0:1 '' efidebug boot add -B 0002 'long dev only' host 0:1 ''
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_device_path.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 50a988c561..c511abcd5e 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1002,12 +1002,14 @@ struct efi_device_path *efi_dp_from_file(struct blk_desc *desc, int part, buf = dp_part_fill(buf, desc, part);
/* add file-path: */ - fp = buf; - fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; - fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; - fp->dp.length = (u16)fpsize; - path_to_uefi(fp->str, path); - buf += fpsize; + if (*path) { + fp = buf; + fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; + fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; + fp->dp.length = (u16)fpsize; + path_to_uefi(fp->str, path); + buf += fpsize; + }
*((struct efi_device_path *)buf) = END;
-- 2.36.1
So the "subject" is a bit misleading. Your intension is to expand "efidebug", not uefi functionality.
- fp = buf;
- buf += fpsize;
- if (*path) {
fp = buf;
buf += fpsize;
Please update the function description, too. With your change, the current is no more enough.
-Takahiro Akashi
-- 2.36.1
AKASHI Takahiro
