[U-Boot] [PATCH v2 00/11] rockchip: add tpl and OPTEE support for rk3229
Add some generic options for TPL support for arm 32bit, and then and TPL support for rk3229(cortex-A7), and then add OPTEE support in SPL.
Tested on latest u-boot-rockchip master.
Changes in v2: - update subject with ARCH_MEM info - Add new image type like ATF - Using new image type for op-tee - Make the its as common file used for all armv7 with op-tee - update defconfig option
Kever Yang (11): lib: add TPL_OF_LIBFDT option for TPL arm: add option for TPL ARCH_MEM in arm 32bit arm: add a separate stack for TPL rockchip: rk322x: enable tpl support sysreset: enable driver support in SPL/TPL image: add os type for OP-TEE spl: add support to booting with OP-TEE rockchip: rk322x: dts: enable uart2 for SPL/TPL rockchip: add fit source file for pack itb with op-tee rockchip: evb-rk3229: add README file for OP-TEE support rockchip: evb-rk322x: update defconfig with tpl and optee support
arch/arm/Kconfig | 29 +++++++++ arch/arm/dts/rk3229-evb.dts | 1 + arch/arm/lib/crt0.S | 4 +- arch/arm/mach-rockchip/Kconfig | 9 +++ arch/arm/mach-rockchip/Makefile | 3 +- arch/arm/mach-rockchip/fit_spl_optee.its | 50 ++++++++++++++++ arch/arm/mach-rockchip/rk322x-board-spl.c | 61 +++++-------------- arch/arm/mach-rockchip/rk322x-board-tpl.c | 90 ++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds | 13 ++++ board/rockchip/evb_rk3229/README | 72 ++++++++++++++++++++++ common/image.c | 1 + common/spl/Kconfig | 7 +++ common/spl/Makefile | 1 + common/spl/spl.c | 8 +++ common/spl/spl_optee.S | 13 ++++ configs/evb-rk3229_defconfig | 26 +++++++- drivers/sysreset/Kconfig | 18 ++++++ drivers/sysreset/Makefile | 2 +- include/configs/rk322x_common.h | 9 ++- include/image.h | 1 + include/spl.h | 9 +++ lib/Kconfig | 10 ++++ 22 files changed, 381 insertions(+), 56 deletions(-) create mode 100644 arch/arm/mach-rockchip/fit_spl_optee.its create mode 100644 arch/arm/mach-rockchip/rk322x-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds create mode 100644 board/rockchip/evb_rk3229/README create mode 100644 common/spl/spl_optee.S
TPL may need use libfdt for dt decode, add option for it.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
lib/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/lib/Kconfig b/lib/Kconfig index f447c53..b43ef22 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -234,6 +234,16 @@ config SPL_OF_LIBFDT particular compatible nodes. The library operates on a flattened version of the device tree.
+config TPL_OF_LIBFDT + bool "Enable the FDT library for TPL" + default y if TPL_OF_CONTROL + help + This enables the FDT library (libfdt). It provides functions for + accessing binary device tree images in memory, such as adding and + removing nodes and properties, scanning through the tree and finding + particular compatible nodes. The library operates on a flattened + version of the device tree. + config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT
Some options like TPL_SYS_THUMB_BUILD, TPL_USE_ARCH_MEMCPY and TPL_USE_ARCH_MEMCPY are needed for TPL build in 32bit arm.
arch/arm/Kconfig | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7390995..4069227 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -244,6 +244,17 @@ config SPL_SYS_THUMB_BUILD density. For ARM architectures that support Thumb2 this flag will result in Thumb2 code generated by GCC.
+config TPL_SYS_THUMB_BUILD + bool "Build TPL using the Thumb instruction set" + default y if SYS_THUMB_BUILD + depends on TPL && !ARM64 + help + Use this flag to build SPL using the Thumb instruction set for + ARM architectures. Thumb instruction set provides better code + density. For ARM architectures that support Thumb2 this flag will + result in Thumb2 code generated by GCC. + + config SYS_L2CACHE_OFF bool "L2cache off" help @@ -280,6 +291,15 @@ config SPL_USE_ARCH_MEMCPY Such implementation may be faster under some conditions but may increase the binary size.
+config TPL_USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy for TPL" + default y if USE_ARCH_MEMCPY + depends on !ARM64 + help + Enable the generation of an optimized version of memcpy. + Such implementation may be faster under some conditions + but may increase the binary size. + config USE_ARCH_MEMSET bool "Use an assembly optimized implementation of memset" default y @@ -298,6 +318,15 @@ config SPL_USE_ARCH_MEMSET Such implementation may be faster under some conditions but may increase the binary size.
+config TPL_USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset for TPL" + default y if USE_ARCH_MEMSET + depends on !ARM64 + help + Enable the generation of an optimized version of memset. + Such implementation may be faster under some conditions + but may increase the binary size. + config ARM64_SUPPORT_AARCH32 bool "ARM64 system support AArch32 execution state" default y if ARM64 && !TARGET_THUNDERX_88XX
TPL stack may different from SPL and sys stack, add support for separate one when the board defines it.
Changes in v2: None
arch/arm/lib/crt0.S | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index fa81317..3c1c603 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -70,7 +70,9 @@ ENTRY(_main) * Set up initial C runtime environment and call board_init_f(0). */
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_NEEDS_SEPARATE_STACK) + ldr r0, =(CONFIG_TPL_STACK) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) ldr r0, =(CONFIG_SPL_STACK) #else ldr r0, =(CONFIG_SYS_INIT_SP_ADDR)
Move original spl to tpl, and add spl to load next stage firmware, adapt all the address and option for them.
Serial-changes: 2 - update upon latest source
Changes in v2: None
arch/arm/mach-rockchip/Kconfig | 9 +++ arch/arm/mach-rockchip/Makefile | 3 +- arch/arm/mach-rockchip/rk322x-board-spl.c | 61 +++++-------------- arch/arm/mach-rockchip/rk322x-board-tpl.c | 90 ++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds | 13 ++++ include/configs/rk322x_common.h | 9 ++- 6 files changed, 134 insertions(+), 51 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk322x-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 967290f..dbc197c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -46,9 +46,18 @@ config ROCKCHIP_RK322X bool "Support Rockchip RK3228/RK3229" select CPU_V7 select SUPPORT_SPL + select SUPPORT_TPL select SPL + select TPL + select TPL_NEEDS_SEPARATE_TEXT_BASE if SPL + select TPL_NEEDS_SEPARATE_STACK if TPL + select SPL_DRIVERS_MISC_SUPPORT + imply SPL_SERIAL_SUPPORT + imply TPL_SERIAL_SUPPORT select ROCKCHIP_BROM_HELPER select DEBUG_UART_BOARD_INIT + select TPL_LIBCOMMON_SUPPORT + select TPL_LIBGENERIC_SUPPORT help The Rockchip RK3229 is a ARM-based SoC with a dual-core Cortex-A7 including NEON and GPU, Mali-400 graphics, several DDR3 options diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index e1b0519..3c14236 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -13,10 +13,11 @@ obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o
obj-tpl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o +obj-tpl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o -obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o spl-boot-order.o obj-spl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-spl.o spl-boot-order.o obj-spl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-spl.o spl-boot-order.o diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index 35f4f97..cab0262 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -5,77 +5,48 @@ */
#include <common.h> -#include <debug_uart.h> #include <dm.h> -#include <ram.h> #include <spl.h> -#include <asm/io.h> -#include <asm/arch/bootrom.h> -#include <asm/arch/cru_rk322x.h> -#include <asm/arch/grf_rk322x.h> -#include <asm/arch/hardware.h> -#include <asm/arch/timer.h> -#include <asm/arch/uart.h> + +DECLARE_GLOBAL_DATA_PTR;
u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; } -DECLARE_GLOBAL_DATA_PTR;
-#define GRF_BASE 0x11000000 -#define SGRF_BASE 0x10140000 - -#define DEBUG_UART_BASE 0x11030000 +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +}
void board_debug_uart_init(void) { -static struct rk322x_grf * const grf = (void *)GRF_BASE; - /* Enable early UART2 channel 1 on the RK322x */ - rk_clrsetreg(&grf->gpio1b_iomux, - GPIO1B1_MASK | GPIO1B2_MASK, - GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | - GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); - /* Set channel C as UART2 input */ - rk_clrsetreg(&grf->con_iomux, - CON_IOMUX_UART2SEL_MASK, - CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); }
-#define SGRF_DDR_CON0 0x10150000 void board_init_f(ulong dummy) { - struct udevice *dev; int ret;
- /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - debug_uart_init(); - printascii("SPL Init"); - ret = spl_early_init(); if (ret) { - debug("spl_early_init() failed: %d\n", ret); + printf("spl_early_init() failed: %d\n", ret); hang(); } + preloader_console_init(); +}
- rockchip_timer_init(); - printf("timer init done\n"); - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - printf("DRAM init failed: %d\n", ret); - return; - } +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name);
/* Disable the ddr secure region setting to make it non-secure */ rk_clrreg(SGRF_DDR_CON0, 0x4000); #if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) back_to_bootrom(BROM_BOOT_NEXTSTAGE); #endif + return 0; } +#endif diff --git a/arch/arm/mach-rockchip/rk322x-board-tpl.c b/arch/arm/mach-rockchip/rk322x-board-tpl.c new file mode 100644 index 0000000..aa14cef --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x-board-tpl.c @@ -0,0 +1,90 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/bootrom.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/hardware.h> +#include <asm/arch/timer.h> +#include <asm/arch/uart.h> + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} +DECLARE_GLOBAL_DATA_PTR; + +#define GRF_BASE 0x11000000 +#define SGRF_BASE 0x10140000 +#define DEBUG_UART_BASE 0x11030000 +#define SECURE_TIMER_BASE 0x110d0020 +#define SGRF_DDR_CON0 0x10150000 + +void board_debug_uart_init(void) +{ + static struct rk322x_grf * const grf = (void *)GRF_BASE; + /* Enable early UART2 channel 1 on the RK322x */ + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->con_iomux, + CON_IOMUX_UART2SEL_MASK, + CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); +} + +void secure_timer_init(void) +{ + writel(0, SECURE_TIMER_BASE + 0x10); + writel(0xffffffff, SECURE_TIMER_BASE); + writel(0xffffffff, SECURE_TIMER_BASE + 4); + writel(1, SECURE_TIMER_BASE + 0x10); +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printascii("TPL Init"); + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + secure_timer_init(); + rockchip_timer_init(); + printf("timer init done\n"); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("DRAM init failed: %d\n", ret); + return; + } + + /* Disable the ddr secure region setting to make it non-secure */ + rk_clrreg(SGRF_DDR_CON0, 0x4000); +#if defined(CONFIG_TPL_ROCKCHIP_BACK_TO_BROM) && !defined(CONFIG_TPL_BOARD_INIT) + back_to_bootrom(BROM_BOOT_NEXTSTAGE); +#endif +} diff --git a/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds b/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds new file mode 100644 index 0000000..841c803 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#undef CONFIG_SPL_TEXT_BASE +#define CONFIG_SPL_TEXT_BASE CONFIG_TPL_TEXT_BASE + +#undef CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_MAX_SIZE CONFIG_TPL_MAX_SIZE + +#include "../../cpu/u-boot-spl.lds" diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index b22169d..5536b58 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -20,11 +20,10 @@
#define CONFIG_SPL_FRAMEWORK #define CONFIG_SYS_NS16550_MEM32 -#define CONFIG_SYS_TEXT_BASE 0x60000000 -#define CONFIG_SYS_INIT_SP_ADDR 0x60100000 -#define CONFIG_SYS_LOAD_ADDR 0x60800800 -#define CONFIG_SPL_STACK 0x10088000 -#define CONFIG_SPL_TEXT_BASE 0x10081004 +#define CONFIG_SYS_TEXT_BASE 0x61000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x61100000 +#define CONFIG_SYS_LOAD_ADDR 0x61800800 +#define CONFIG_SPL_TEXT_BASE 0x60000000
#define CONFIG_ROCKCHIP_MAX_INIT_SIZE (28 << 10) #define CONFIG_ROCKCHIP_CHIP_TAG "RK32"
SPL/TPL also need use sysreset for some feature like panic callback.
Changes in v2: None
drivers/sysreset/Kconfig | 18 ++++++++++++++++++ drivers/sysreset/Makefile | 2 +- 2 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index a6d48e8..a61a7d3 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -13,6 +13,24 @@ config SYSRESET to effect a reset. The uclass will try all available drivers when reset_walk() is called.
+config SPL_SYSRESET + bool "Enable support for system reset drivers in SPL mode" + depends on SYSRESET && SPL_DM + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + +config TPL_SYSRESET + bool "Enable support for system reset drivers in TPL mode" + depends on SYSRESET && TPL_DM + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + if SYSRESET
config SYSRESET_PSCI diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 2e9598e..00be747 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -4,7 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_SYSRESET) += sysreset-uclass.o +obj-$(CONFIG_$(SPL_TPL_)SYSRESET) += sysreset-uclass.o obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o
OP-TEE is an open source trust OS maintained here: https://github.com/OP-TEE/optee_os
Changes in v2: - Add new image type like ATF
common/image.c | 1 + include/image.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/common/image.c b/common/image.c index 4bcf6b3..597c025 100644 --- a/common/image.c +++ b/common/image.c @@ -91,6 +91,7 @@ static const table_entry_t uimage_arch[] = {
static const table_entry_t uimage_os[] = { { IH_OS_INVALID, "invalid", "Invalid OS", }, + { IH_OS_OP_TEE, "op-tee", "OP-TEE" }, { IH_OS_ARM_TRUSTED_FIRMWARE, "arm-trusted-firmware", "ARM Trusted Firmware" }, { IH_OS_LINUX, "linux", "Linux", }, #if defined(CONFIG_LYNXKDI) || defined(USE_HOSTCC) diff --git a/include/image.h b/include/image.h index a128a62..141ed00 100644 --- a/include/image.h +++ b/include/image.h @@ -153,6 +153,7 @@ enum { IH_OS_PLAN9, /* Plan 9 */ IH_OS_OPENRTOS, /* OpenRTOS */ IH_OS_ARM_TRUSTED_FIRMWARE, /* ARM Trusted Firmware */ + IH_OS_OP_TEE, /* OP-TEE */
IH_OS_COUNT, };
OP-TEE is an open source trusted OS, in armv7, its loading and running are like this: loading: - SPL load both OP-TEE and U-Boot running: - SPL run into OP-TEE in secure mode; - OP-TEE run into U-Boot in non-secure mode;
More detail: https://github.com/OP-TEE/optee_os and search for 'boot arguments' for detail entry parameter in: core/arch/arm/kernel/generic_entry_a32.S
Changes in v2: - Using new image type for op-tee
common/spl/Kconfig | 7 +++++++ common/spl/Makefile | 1 + common/spl/spl.c | 8 ++++++++ common/spl/spl_optee.S | 13 +++++++++++++ include/spl.h | 9 +++++++++ 5 files changed, 38 insertions(+) create mode 100644 common/spl/spl_optee.S
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index aef0034..c9a1ebb 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -725,6 +725,13 @@ config SPL_ATF is loaded by SPL(which is considered as BL2 in ATF terminology). More detail at: https://github.com/ARM-software/arm-trusted-firmware
+config SPL_OPTEE + bool "Support OP-TEE Trusted OS" + depends on ARM + help + OP-TEE is an open source Trusted OS which is loaded by SPL. + More detail at: https://github.com/OP-TEE/optee_os + config TPL bool depends on SUPPORT_TPL diff --git a/common/spl/Makefile b/common/spl/Makefile index 9bf8a2d..9918a2e 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_$(SPL_TPL_)UBI) += spl_ubi.o obj-$(CONFIG_$(SPL_TPL_)NET_SUPPORT) += spl_net.o obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o obj-$(CONFIG_$(SPL_TPL_)ATF) += spl_atf.o +obj-$(CONFIG_$(SPL_TPL_)OPTEE) += spl_optee.o obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o diff --git a/common/spl/spl.c b/common/spl/spl.c index 76c1963..2c8942b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -436,6 +436,12 @@ void board_init_r(gd_t *dummy1, ulong dummy2) spl_invoke_atf(&spl_image); break; #endif +#if CONFIG_IS_ENABLED(OPTEE) + case IH_OS_OP_TEE: + debug("Jumping to U-Boot via OP-TEE\n"); + spl_optee_entry(0, 0, 0, (void *)spl_image.entry_point); + break; +#endif #ifdef CONFIG_SPL_OS_BOOT case IH_OS_LINUX: debug("Jumping to Linux\n"); @@ -450,6 +456,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2) debug("SPL malloc() used %#lx bytes (%ld KB)\n", gd->malloc_ptr, gd->malloc_ptr / 1024); #endif + + debug("loaded - jumping to U-Boot...\n"); #ifdef CONFIG_BOOTSTAGE_STASH int ret;
diff --git a/common/spl/spl_optee.S b/common/spl/spl_optee.S new file mode 100644 index 0000000..4f7f8ba --- /dev/null +++ b/common/spl/spl_optee.S @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <linux/linkage.h> +#include <asm/assembler.h> + +ENTRY(spl_optee_entry) + ldr lr, =CONFIG_SYS_TEXT_BASE + mov pc, r3 +ENDPROC(spl_optee_entry) diff --git a/include/spl.h b/include/spl.h index c14448b..551ce43 100644 --- a/include/spl.h +++ b/include/spl.h @@ -288,6 +288,15 @@ int spl_mmc_load_image(struct spl_image_info *spl_image, void spl_invoke_atf(struct spl_image_info *spl_image);
/** + * spl_optee_entry - entry function for optee + * entry arg0, pagestore + * entry arg1, (ARMv7 standard bootarg #1) + * entry arg2, device tree address, (ARMv7 standard bootarg #2) + * entry arg3, non-secure entry address (ARMv7 bootarg #0) + */ +void spl_optee_entry(void *arg0, void *arg1, void *arg2, void *arg3); + +/** * board_return_to_bootrom - allow for boards to continue with the boot ROM * * If a board (e.g. the Rockchip RK3368 boards) provide some
When we use DM_SERIAL for serial driver, we need enable the dts node for the debug console.
Changes in v2: None
arch/arm/dts/rk3229-evb.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index ae0b0a4..fe4abe9 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -83,6 +83,7 @@ };
&uart2 { + u-boot,dm-pre-reloc; status = "okay"; };
We package U-Boot and OP-TEE into one itb file for SPL, so that we can support OP-TEE in SPL.
Changes in v2: - Make the its as common file used for all armv7 with op-tee
arch/arm/mach-rockchip/fit_spl_optee.its | 50 ++++++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+) create mode 100644 arch/arm/mach-rockchip/fit_spl_optee.its
diff --git a/arch/arm/mach-rockchip/fit_spl_optee.its b/arch/arm/mach-rockchip/fit_spl_optee.its new file mode 100644 index 0000000..3aeecb8 --- /dev/null +++ b/arch/arm/mach-rockchip/fit_spl_optee.its @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2017 Rockchip Electronic Co.,Ltd + * + * Simple U-boot fit source file containing U-Boot, dtb and optee + */ + +/dts-v1/; + +/ { + description = "Simple image with OP-TEE support"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot"; + data = /incbin/("../../../u-boot-nodtb.bin"); + type = "standalone"; + os = "U-Boot"; + arch = "arm"; + compression = "none"; + load = <0x61000000>; + }; + optee@1 { + description = "OP-TEE"; + data = /incbin/("../../../tee.bin"); + type = "firmware"; + arch = "arm"; + os = "op-tee"; + compression = "none"; + load = <0x68400000>; + entry = <0x68400000>; + }; + fdt@1 { + description = "dtb"; + data = /incbin/("../../../u-boot.dtb"); + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "conf@1"; + conf@1 { + description = "Rockchip armv7 with OP-TEE"; + firmware = "optee@1"; + loadables = "uboot@1"; + fdt = "fdt@1"; + }; + }; +};
Detail of step by step to bring up the board with OP-TEE support.
Changes in v2: None
board/rockchip/evb_rk3229/README | 72 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+) create mode 100644 board/rockchip/evb_rk3229/README
diff --git a/board/rockchip/evb_rk3229/README b/board/rockchip/evb_rk3229/README new file mode 100644 index 0000000..46c54c2 --- /dev/null +++ b/board/rockchip/evb_rk3229/README @@ -0,0 +1,72 @@ +Get the Source and prebuild binary +================================== + + > mkdir ~/evb_rk3229 + > cd ~/evb_rk3229 + > git clone git://git.denx.de/u-boot.git + > git clone https://github.com/OP-TEE/optee_os.git + > git clone https://github.com/rockchip-linux/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the OP-TEE +=============== + + > cd optee_os + > make clean + > make CROSS_COMPILE_ta_arm32=arm-none-eabi- PLATFORM=rockchip-rk322x + Get tee.bin in this step, copy it to U-Boot root dir: + > cp out/arm-plat-rockchip/core/tee-pager.bin ../u-boot/tee.bin + +Compile the U-Boot +================== + + > cd ../u-boot + > export CROSS_COMPILE=arm-linux-gnueabihf- + > export ARCH=arm + > make evb-rk3229_defconfig + > make + > make u-boot.itb + + Get tpl/u-boot-tpl.bin, spl/u-boot-spl.bin and u-boot.itb in this step. + +Compile the rkdeveloptool +======================= + Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + + Get rkdeveloptool in you Host in this step. + +Both origin binaries and Tool are ready now, choose either option 1 or +option 2 to deploy U-Boot. + +Package the image +================= + + > cd ../u-boot + > tools/mkimage -n rk322x -T rksd -d tpl/u-boot-spl.bin idbloader.img + > cat spl/u-boot-spl.bin >> idbloader.img + + Get idbloader.img in this step. + +Flash the image to eMMC +======================= +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > cd .. + > rkdeveloptool db rkbin/rk32/rk322x_loader_v1.04.232.bin + > rkdeveloptool wl 64 u-boot/idbloader.img + > rkdeveloptool wl 0x4000 u-boot/u-boot.itb + > rkdeveloptool rd + +Flash the image to SD card +========================== + > dd if=u-boot/idbloader.img of=/dev/sdb seek=64 + > dd if=u-boot/u-boot.itb of=/dev/sdb seek=16384 + +You should be able to get U-Boot log message with OP-TEE boot info. + +For more detail, please reference to: +http://opensource.rock-chips.com/wiki_Boot_option
Enable all the options for TPL/SPL and OPTEE.
Changes in v2: - update defconfig option
configs/evb-rk3229_defconfig | 26 +++++++++++++++++++++++--- 1 file changed, 23 insertions(+), 3 deletions(-)
diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index b226f66..025822d 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -4,14 +4,27 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_ROCKCHIP_RK322X=y -CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/rk322x/u-boot-tpl.lds" +CONFIG_TPL_TEXT_BASE=0x10081000 +CONFIG_TPL_MAX_SIZE=28672 +CONFIG_TPL_STACK=0x10088000 +CONFIG_TPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 CONFIG_TARGET_EVB_RK3229=y -CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_SPL_STACK_R_ADDR=0x60600000 CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_SOURCE="arch/arm/mach-rockchip/fit_spl_optee.its" # CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y -CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200 +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x4000 +CONFIG_SPL_OPTEE=y CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_GPT=y @@ -19,14 +32,19 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y +CONFIG_TPL_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -35,12 +53,14 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK322X=y CONFIG_RAM=y CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_BASE=0x11030000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Rockchip"
Hi Philipp,
This patch 4/11 is not correct, it can not pass the buildman,
I will send a new version, pls ignore this version.
Changes in v2:
Kever Yang
