[U-Boot] [PATCH] pinctrl: uniphier: fix NAND pin-mux setting for PH1-LD11/LD20
The initial version missed to set up the pin number 17.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 3d5ac5f..1fb2898 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -22,9 +22,9 @@ static const unsigned i2c3_muxvals[] = {1, 1}; static const unsigned i2c4_pins[] = {61, 62}; static const unsigned i2c4_muxvals[] = {1, 1}; static const unsigned nand_pins[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, - 15, 16}; + 15, 16, 17}; static const unsigned nand_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, - 0, 0}; + 0, 0, 0}; static const unsigned nand_cs1_pins[] = {}; static const unsigned nand_cs1_muxvals[] = {}; static const unsigned sd_pins[] = {10, 11, 12, 13, 14, 15, 16, 17};
Masahiro Yamada
