[PATCH 00/10] support for booting the compressed U-boot binary on Rockchip based SOC's
This patchset adds the support on Rockchip based RK3399 and RK3328 SOC's that compress the U-BOOT proper along with dtb and ATF in FIT image format. Second stage bootloader(SPL) loads the compressed binaries, uncompress them and handover control to the next stage.
The size difference observed between uncompressed and compressed FIT images is nearly 67 to 70% and used two compression libraries,LZMA and GZIP.
Patch 1/10 generate a GZIP-compressed raw U-boot binary using Makefile Patch 2/10 address to store compressed U-BOOT raw binary using Kconfig Patch 3/10 RAM location to store compressed U-BOOT raw binary for ROCKCHIP based RK3399 and RK3328 SOC's Patch 4/10 uncompress the gzip U-BOOT binary and load the binaries if gzip compression supoort is enabled Patch 5/10 generate a LZMA-compressed raw U-boot binary using Makefile Patch 6/10 uncompress the lzma U-BOOT binary and load the binaries if lzma compression supoort is enabled Patch 7/10 add u-boot-nodtb.bin.gz as an input binary in binman Patch 8/10 add the GZIP compressed uboot raw binary to FIT image Patch 9/10 add u-boot-nodtb.bin.lzma as an input binary in binman Patch 10/10 add the LZMA compressed uboot raw binary to FIT image
Manoj Sai (10): Makefile: Add support to generate GZIP compressed raw u-boot binary spl: Kconfig: Address support for compressed U-BOOT raw binary rockchip: RAM location for the compressed U-BOOT raw binary spl: fit: support for booting a GZIP-compressed U-boot raw binary Makefile: Add support to generate LZMA compressed raw u-boot binary spl: fit: support for booting a LZMA-compressed U-boot raw binary binman: Add support for u-boot-nodtb.bin.gz as an input binary rockchip: Add GZIP compressed uboot raw binary to FIT image binman: Add support for u-boot-nodtb.bin.lzma as an input binary rockchip: Add LZMA compressed uboot raw binary to FIT image
Makefile | 6 ++++ arch/arm/dts/rockchip-u-boot.dtsi | 15 ++++++++ arch/arm/mach-rockchip/Kconfig | 3 ++ common/spl/Kconfig | 15 ++++++++ common/spl/spl_fit.c | 36 +++++++++++++++----- tools/binman/etype/283_u_boot_nodtb_lzma.dts | 11 ++++++ tools/binman/etype/u_boot_nodtb_gzip.py | 28 +++++++++++++++ tools/binman/etype/u_boot_nodtb_lzma.py | 28 +++++++++++++++ tools/binman/ftest.py | 11 ++++++ tools/binman/test/282_u_boot_nodtb_gzip.dts | 11 ++++++ 10 files changed, 156 insertions(+), 8 deletions(-) create mode 100644 tools/binman/etype/283_u_boot_nodtb_lzma.dts create mode 100644 tools/binman/etype/u_boot_nodtb_gzip.py create mode 100644 tools/binman/etype/u_boot_nodtb_lzma.py create mode 100644 tools/binman/test/282_u_boot_nodtb_gzip.dts
Add support for generating a GZIP-compressed raw U-boot binary.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- Makefile | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/Makefile b/Makefile index 444baaefd0..6e15ebd116 100644 --- a/Makefile +++ b/Makefile @@ -1312,6 +1312,9 @@ endif u-boot-nodtb.bin: u-boot FORCE $(call if_changed,objcopy_uboot) $(BOARD_SIZE_CHECK) +ifeq ($(CONFIG_SPL_GZIP),y) + @gzip -k u-boot-nodtb.bin +endif
u-boot.ldr: u-boot $(CREATE_LDR_ENV)
Hi Manoj,
On Fri, 30 Jun 2023 at 13:12, Manoj Sai abbaraju.manojsai@amarulasolutions.com wrote:
Please can you use binman to do that?
We are trying to remove the extra build rules in the Makefile.
+endif
u-boot.ldr: u-boot $(CREATE_LDR_ENV) -- 2.25.1
Hi Simon,
Can you please suggest or briefly explain to me the steps to be followed to generate the compressed u-boot-nodtb.bin.gz and u-boot-nodtb.bin.lzma file with the help of binman , when compression support is enabled . Can you provide me with any reference patch to get it done?
Thanks and regards, Manoj sai Amarula Solutions India Pvt. Ltd
On Sun, Jul 2, 2023 at 9:04 PM Simon Glass sjg@chromium.org wrote:
Hi Manoj,
+endif
Hi Manoj,
On Tue, 18 Jul 2023 at 01:13, Manoj Sai abbaraju.manojsai@amarulasolutions.com wrote:
Hi Simon,
Yes, please see here:
https://u-boot.readthedocs.io/en/latest/develop/package/binman.html#compress...
Hi Manoj,
+endif
Add the support that ,if compression support is enabled in SPL a location needs to be defined as the source address where compressed U-BOOT raw binary will be stored.
spl_load_fit_image function takes care that, compressed U-Boot raw binary which is placed at this address, will be uncompressed to default CONFIG_SYS_TEXT_BASE location.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- common/spl/Kconfig | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 2c042ad306..5dd1f3c469 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1547,6 +1547,21 @@ config SPL_AT91_MCK_BYPASS The external source has to provide a stable clock on the XIN pin. If this option is disabled, the SoC expects a crystal oscillator that needs driving on both XIN and XOUT lines. +choice + prompt "Location for compressed U-BOOT raw binary" + depends on SPL_GZIP || SPL_LZMA + default SPL_UBOOT_COMPRESSED_BINARY_FIT_USER_DEFINED_AREA + +config SPL_UBOOT_COMPRESSED_BINARY_FIT_USER_DEFINED_AREA + bool "compressed U-BOOT raw binary user-defined location" +endchoice + +config SPL_UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR + hex "Address of memory where compressed U-BOOT raw binary is stored" + depends on SPL_UBOOT_COMPRESSED_BINARY_FIT_USER_DEFINED_AREA + help + The FIT image containing the compressed U-BOOT raw binary will be stored + in an area defined at compilation time. This is the address for this area. endmenu
config TPL
Hi Manoj,
blank line here
+choice
compressed U-Boot binary
missing help
This is too long and there is a lot ot redundancy.. How about SPL_GZIP_FROM_ADDR
missing help
blank line
+endchoice
But you only have one thing in the choice, so can you just drop the choice and use a bool instead?
How about SPL_GZIP_LOADADDR?
U-Boot (please fix throughout)
help
endmenu
config TPL
2.25.1
Hi Manoj,
blank line here
+choice
missing help
missing help
blank line
+endchoice
Hi simon ,
We modified to use the CONFIG_SYS_LOAD_ADDR as the source RAM address to store the compressed U-Boot binary which will be defined in a machine defconfig file in place of defining a new RAM address and with the help of this change, able to load and boot the compressed U-boot.
-spl_load_fit_image function , will uncompress the U-BOOT binary which is placed in the CONFIG_SYS_LOAD_ADDR to default CONFIG_SYS_TEXT_BASE location and able to load and boot the compressed U-boot.
These two patches will be removed in the next v2 patchset which are related to adding new RAM address to store compressed U-boot. 1) https://patchwork.ozlabs.org/project/uboot/patch/20230630121146.513345-3-abb... 2) https://patchwork.ozlabs.org/project/uboot/patch/20230630121146.513345-4-abb...
Regards, A . Manoj sai
help
endmenu
config TPL
2.25.1
Add the support that ,if compression support is enabled in SPL a RAM location needs to be defined as the source address where compressed U-BOOT raw binary will be stored.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com --- arch/arm/mach-rockchip/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 9d6d20bf8e..d8d9c1964d 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -520,6 +520,9 @@ config ROCKCHIP_SPI_IMAGE config LNX_KRNL_IMG_TEXT_OFFSET_BASE default TEXT_BASE
+config SPL_UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR + default 0x5000000 if ROCKCHIP_RK3399 || ROCKCHIP_RK3328 + source "arch/arm/mach-rockchip/px30/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3066/Kconfig"
Hi Manoj,
But isn't that where U-Boot runs from? So if you load it there, how can you uncompress it to the same place? Reviewed-by: Simon Glass sjg@chromium.org Anyway I agree this is a sensible default.
source "arch/arm/mach-rockchip/px30/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3066/Kconfig" -- 2.25.1
If GZIP Compression support is enabled, GZIP compressed U-Boot raw binary will be at a specified RAM location which is defined at UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR and will be assign it as the source address.
gunzip function in spl_load_fit_image ,will decompress the GZIP compressed U-Boot raw binary which is placed at source address to the default CONFIG_SYS_TEXT_BASE location.
spl_load_fit_image function will load the decompressed U-Boot raw binary, which is placed at the CONFIG_SYS_TEXT_BASE location.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- common/spl/spl_fit.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 730639f756..e2101099ef 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -281,7 +281,12 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return 0; }
- src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { + src_ptr = map_sysmem(ALIGN(CONFIG_VAL(UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR), + ARCH_DMA_MINALIGN), len); + } else { + src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); + } length = len;
overhead = get_aligned_image_overhead(info, offset); @@ -319,11 +324,14 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, board_fit_image_post_process(fit, node, &src, &length);
load_ptr = map_sysmem(load_addr, length); - if (IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP) { - size = length; - if (gunzip(load_ptr, CONFIG_SYS_BOOTM_LEN, src, &size)) { - puts("Uncompressing error\n"); - return -EIO; + + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { + size = length; + if (gunzip(load_ptr, CONFIG_SYS_BOOTM_LEN, src, &size)) { + puts("Uncompressing error\n"); + return -EIO; + } } length = size; } else {
El Fri, Jun 30, 2023 at 05:41:40PM +0530, Manoj Sai deia:
} else {
length = len;
size = length;
return -EIO;
- if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) {
You just repeated the same condition in a new if here ?
size = length;
return -EIO;
} length = size; } else {}
-- 2.25.1
Add support for generating LZMA compressed raw u-boot binary.
diff --git a/Makefile b/Makefile index 6e15ebd116..d4f453cce1 100644 --- a/Makefile +++ b/Makefile @@ -1315,6 +1315,9 @@ u-boot-nodtb.bin: u-boot FORCE ifeq ($(CONFIG_SPL_GZIP),y) @gzip -k u-boot-nodtb.bin endif +ifeq ($(CONFIG_SPL_LZMA),y) + @lzma -k u-boot-nodtb.bin +endif
Hi Manoj,
+endif
Again, this should be in binman.
If LZMA Compression support is enabled, LZMA compressed U-Boot raw binary will be at a specified RAM location which is defined at UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR and will be assign it as the source address.
lzmaBuffToBuffDecompress function in spl_load_fit_image ,will decompress the LZMA compressed U-Boot raw binary which is placed at source address to the default CONFIG_SYS_TEXT_BASE location.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- common/spl/spl_fit.c | 20 ++++++++++++++++---- 1 file changed, 16 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index e2101099ef..b4e95d3fb5 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -17,6 +17,9 @@ #include <asm/cache.h> #include <asm/global_data.h> #include <linux/libfdt.h> +#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -239,14 +242,15 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, bool external_data = false;
if (IS_ENABLED(CONFIG_SPL_FPGA) || - (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP))) { + (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP)) || + (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_LZMA))) { if (fit_image_get_type(fit, node, &type)) puts("Cannot get image type.\n"); else debug("%s ", genimg_get_type_name(type)); }
- if (IS_ENABLED(CONFIG_SPL_GZIP)) { + if (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA)) { fit_image_get_comp(fit, node, &image_comp); debug("%s ", genimg_get_comp_name(image_comp)); } @@ -281,7 +285,8 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return 0; }
- if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP) || + (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA)) { src_ptr = map_sysmem(ALIGN(CONFIG_VAL(UBOOT_COMPRESSED_BINARY_FIT_USER_DEF_ADDR), ARCH_DMA_MINALIGN), len); } else { @@ -325,13 +330,20 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector,
- if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP) || + (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA)) { if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) { size = length; if (gunzip(load_ptr, CONFIG_SYS_BOOTM_LEN, src, &size)) { puts("Uncompressing error\n"); return -EIO; } + } else if ((IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA)) { + size = CONFIG_SYS_BOOTM_LEN; + if (lzmaBuffToBuffDecompress(load_ptr, &size, src, length)) { + puts("Uncompressing error\n"); + return -EIO; + } } length = size; } else {
Hi Manoj,
This needs a refactor. You could do:
if (IS_ENABLED(CONFIG_SPL_FPGA) || (IS_ENABLED(CONFIG_SPL_OS_BOOT) && (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA))
But I think it is better to creating a static inline functoin in spl.h, like:
static bool spl_compress_enabled() { return IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA); }
and then use that in this patch.
I think you should drop the ALIGN() and tell the user that the address must be cached-aligned, in the Kconfig help, since it will be confusing if it uses a different request from what was requested.
return -EIO;
-- 2.25.1
Can you use the existing image_decomp() instead?
Add an entry type for u-boot-nodtb.bin.gz, which is a GZIP compressed raw u-boot binary and a simple test.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- tools/binman/etype/u_boot_nodtb_gzip.py | 28 +++++++++++++++++++++ tools/binman/ftest.py | 5 ++++ tools/binman/test/282_u_boot_nodtb_gzip.dts | 11 ++++++++ 3 files changed, 44 insertions(+) create mode 100644 tools/binman/etype/u_boot_nodtb_gzip.py create mode 100644 tools/binman/test/282_u_boot_nodtb_gzip.dts
diff --git a/tools/binman/etype/u_boot_nodtb_gzip.py b/tools/binman/etype/u_boot_nodtb_gzip.py new file mode 100644 index 0000000000..e8afd3de57 --- /dev/null +++ b/tools/binman/etype/u_boot_nodtb_gzip.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2023 Amarula Solutions India +# Written by Suniel Mahesh sunil@amarulasolutions.com +# Reference from Simon Glass sjg@chromium.org +# +# Entry-type module for 'u-boot-nodtb.bin.gz' +# + +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_nodtb_gzip(Entry_blob): + """U-Boot compressed flat binary without device tree appended + + Properties / Entry arguments: + - filename: Filename to include ('u-boot-nodtb.bin.gz') + + This is the U-Boot compressed raw binary, before allowing it to relocate + itself at runtime it should be decompressed. It does not include a device + tree blob at the end of it so normally cannot work without it. You can add a + u-boot-dtb entry after this one, or use a u-boot entry instead, normally + expands to a section containing u-boot and u-boot-dtb + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-nodtb.bin.gz' diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 43b4f850a6..933ebcbd35 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -42,6 +42,7 @@ from u_boot_pylib import tout # Contents of test files, corresponding to different entry types U_BOOT_DATA = b'1234' U_BOOT_IMG_DATA = b'img' +U_BOOT_NODTB_GZ_DATA = b'uboot nodtb gz' U_BOOT_SPL_DATA = b'56780123456789abcdefghijklm' U_BOOT_TPL_DATA = b'tpl9876543210fedcbazywvuts' U_BOOT_VPL_DATA = b'vpl76543210fedcbazywxyz_' @@ -6676,6 +6677,10 @@ fdt fdtmap Extract the devicetree blob from the fdtmap ['fit']) self.assertIn("Node '/fit': Missing tool: 'mkimage'", str(e.exception))
+ def testUBootnodtbBinGz(self): + """Test that u-boot-nodtb.bin.gz can be put in a file""" + data = self._DoReadFile('279_u_boot_nodtb_gzip.dts') + self.assertEqual(U_BOOT_NODTB_GZ_DATA, data)
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/282_u_boot_nodtb_gzip.dts b/tools/binman/test/282_u_boot_nodtb_gzip.dts new file mode 100644 index 0000000000..79eecea202 --- /dev/null +++ b/tools/binman/test/282_u_boot_nodtb_gzip.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-nodtb-bin-gz { + }; + }; +};
Hi Manoj,
A better way to do this is to have binman do the compression.
Binman supports a 'compressed' property for blobs, so you should be able to add:
compress = 'gzip';
to your node
- """U-Boot compressed flat binary without device tree appended
- Properties / Entry arguments:
- This is the U-Boot compressed raw binary, before allowing it to relocate
- itself at runtime it should be decompressed. It does not include a device
- tree blob at the end of it so normally cannot work without it. You can add a
- u-boot-dtb entry after this one, or use a u-boot entry instead, normally
- expands to a section containing u-boot and u-boot-dtb
- def __init__(self, section, etype, node):
- def GetDefaultFilename(self):
- def testUBootnodtbBinGz(self):
#size-cells = <1>;
binman {
2.25.1
If you still really want to add an entry type for a compressed U-Boot, please let me know.
Add GZIP compressed uboot raw binary to FIT image.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- arch/arm/dts/rockchip-u-boot.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 2878b80926..6e95738923 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -48,11 +48,21 @@ type = "standalone"; os = "U-Boot"; arch = "arm64"; +#if defined(CONFIG_SPL_GZIP) + compression = "gzip"; +#else compression = "none"; +#endif load = <CONFIG_TEXT_BASE>; entry = <CONFIG_TEXT_BASE>; +#if defined(CONFIG_SPL_GZIP) + u-boot-nodtb-gzip { + }; +#else u-boot-nodtb { }; +#endif + #ifdef CONFIG_SPL_FIT_SIGNATURE hash { algo = "sha256";
Hi Manoj,
u-boot-nodtb-gzip {
You should be able to do:
+#if defined(CONFIG_SPL_GZIP) compress = "gzip"; #endif
#ifdef CONFIG_SPL_FIT_SIGNATURE hash { algo = "sha256"; -- 2.25.1
Add an entry type for u-boot-nodtb.bin.lzma, which is a LZMA compressed raw u-boot binary and a simple test.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- tools/binman/etype/283_u_boot_nodtb_lzma.dts | 11 ++++++++ tools/binman/etype/u_boot_nodtb_lzma.py | 28 ++++++++++++++++++++ tools/binman/ftest.py | 6 +++++ 3 files changed, 45 insertions(+) create mode 100644 tools/binman/etype/283_u_boot_nodtb_lzma.dts create mode 100644 tools/binman/etype/u_boot_nodtb_lzma.py
diff --git a/tools/binman/etype/283_u_boot_nodtb_lzma.dts b/tools/binman/etype/283_u_boot_nodtb_lzma.dts new file mode 100644 index 0000000000..d9a834acf6 --- /dev/null +++ b/tools/binman/etype/283_u_boot_nodtb_lzma.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-nodtb-bin-lzma { + }; + }; +}; diff --git a/tools/binman/etype/u_boot_nodtb_lzma.py b/tools/binman/etype/u_boot_nodtb_lzma.py new file mode 100644 index 0000000000..c2874aa6e9 --- /dev/null +++ b/tools/binman/etype/u_boot_nodtb_lzma.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2023 Amarula Solutions India +# Written by Suniel Mahesh sunil@amarulasolutions.com +# Reference from Simon Glass sjg@chromium.org +# +# Entry-type module for 'u-boot-nodtb.bin.lzma' +# + +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_nodtb_lzma(Entry_blob): + """U-Boot compressed flat binary without device tree appended + + Properties / Entry arguments: + - filename: Filename to include ('u-boot-nodtb.bin.lzma') + + This is the U-Boot compressed raw binary, before allowing it to relocate + itself at runtime it should be decompressed. It does not include a device + tree blob at the end of it so normally cannot work without it. You can add a + u-boot-dtb entry after this one, or use a u-boot entry instead, normally + expands to a section containing u-boot and u-boot-dtb + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-nodtb.bin.lzma' diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 933ebcbd35..d1715523d2 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -43,6 +43,7 @@ from u_boot_pylib import tout U_BOOT_DATA = b'1234' U_BOOT_IMG_DATA = b'img' U_BOOT_NODTB_GZ_DATA = b'uboot nodtb gz' +U_BOOT_NODTB_LZMA_DATA = b'uboot nodtb lzma' U_BOOT_SPL_DATA = b'56780123456789abcdefghijklm' U_BOOT_TPL_DATA = b'tpl9876543210fedcbazywvuts' U_BOOT_VPL_DATA = b'vpl76543210fedcbazywxyz_' @@ -6682,5 +6683,10 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('279_u_boot_nodtb_gzip.dts') self.assertEqual(U_BOOT_NODTB_GZ_DATA, data)
+ def testUBootnodtbBinLzma(self): + """Test that u-boot-nodtb.bin.lzma can be put in a file""" + data = self._DoReadFile('280_u_boot_nodtb_lzma.dts') + self.assertEqual(U_BOOT_NODTB_LZMA_DATA, data) + if __name__ == "__main__": unittest.main()
Hi Manoj,
The same comment applies to this patch.
#size-cells = <1>;
binman {
- def testUBootnodtbBinLzma(self):
if __name__ == "__main__": unittest.main() -- 2.25.1
Add LZMA compressed uboot raw binary to FIT image.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- arch/arm/dts/rockchip-u-boot.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 6e95738923..f8a6179c04 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -50,6 +50,8 @@ arch = "arm64"; #if defined(CONFIG_SPL_GZIP) compression = "gzip"; +#elif defined(CONFIG_SPL_LZMA) + compression = "lzma"; #else compression = "none"; #endif @@ -58,6 +60,9 @@ #if defined(CONFIG_SPL_GZIP) u-boot-nodtb-gzip { }; +#elif defined(CONFIG_SPL_LZMA) + u-boot-nodtb-lzma { + }; #else u-boot-nodtb { };
How much does this size difference and decompression affect boot times?
Instead of adding Makefile targets and custom binman etypes adding support for on-the-fly compression to the fit etype if probably a better option. E.g. when fit node has compression <> none, compress the data content inside binman instead of relaying on binman nodes and Makefile output.
Regards, Jonas
This patchset adds the support on Rockchip based ARM64 SOC's that compress the U-BOOT proper along with dtb and ATF in FIT image format.Second stage bootloader(SPL) loads the compressed binaries, uncompress them and handover control to the next stage.
Changes for V2 :-
- Removed the need to create gzip and lzma compressed U-boot-nodtb files using Makefile and added a changeset that "compress" field to u-boot-nodtb node and "compression" field to u-boot Node in the FIT image, with the help of this change binman will create the compressed Binaries.
Size Comparision between compressed and uncompressed binaries :-
size of uncompressed binary :- 9.4 MB (94,26,432 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9426432 Jul 25 07:42 u-boot-rockchip.bin
size of GZIP compressed binary :- 9.0 MB (89,85,088 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 8985088 Jul 25 07:42 u-boot-rockchip.bin
size of LZMA compressed binary :- 9.0 MB (90,06,080 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9006080 Jul 25 07:47 u-boot-rockchip.bin
- modified to use the CONFIG_SYS_LOAD_ADDR as the source RAM address to store the compressed U-Boot binary which will be defined in the machine defconfig file in place of creating a new RAM address for a specific board using Kconfig. so patchset related to adding a new RAM address to store compressed binary has been removed in V2 patchset.
- Removed the patchset related to adding the u-boot-nodtb.bin.gz and u-boot-nodtb.bin.lzma as input binary to binman.
-- Test results of Booting time using bootstage command in Uboot command prompt on roc-rk3399-pc board :-
1) Uncompressed U-BOOT : Total boot time ≈ 12.3 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 1,824,330 1,824,330 board_init_f 2,921,678 1,097,348 board_init_r 5,179,369 2,257,691 eth_common_init 5,478,307 298,938 eth_initialize 5,478,484 177 main_loop 5,478,641 157 usb_start 12,017,936 6,539,295 cli_loop
Accumulated time: 15,899 dm_r 694,371 dm_f
2) GZIP Compressed U-BOOT : Total boot time ≈ 13.5 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 2,591,355 2,591,355 board_init_f 3,689,407 1,098,052 board_init_r 5,947,314 2,257,907 eth_common_init 6,246,250 298,936 eth_initialize 6,246,427 177 main_loop 6,246,585 158 usb_start 12,785,936 6,539,351 cli_loop
Accumulated time: 15,902 dm_r 694,779 dm_f
2) LZMA Compressed U-BOOT : Total boot time ≈ 23.5 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 6,376,405 6,376,405 board_init_f 7,471,967 1,095,562 board_init_r 9,726,257 2,254,290 eth_common_init 10,024,873 298,616 eth_initialize 10,025,049 176 main_loop 10,025,208 159 usb_start 16,564,906 6,539,698 cli_loop
Accumulated time: 15,851 dm_r 693,323 dm_f
Patch 1/4 generate a GZIP-compressed U-boot binary using binman if CONFIG_SPL_GZIP selected Patch 2/4 generate a LZMA-compressed U-boot binary using binman if CONFIG_SPL_LZMA selected Patch 3/4 uncompress the gzip U-BOOT binary and load the binaries if gzip compression supoort is enabled Patch 4/4 uncompress the lzma U-BOOT binary and load the binaries if lzma compression supoort is enabled
Manoj Sai (4): rockchip: Add support to generate GZIP compressed U-boot binary rockchip: Add support to generate LZMA compressed U-boot binary spl: fit: support for booting a GZIP-compressed U-boot binary spl: fit: support for booting a LZMA-compressed U-boot binary
arch/arm/dts/rockchip-u-boot.dtsi | 11 +++++++++++ common/spl/spl_fit.c | 21 +++++++++++++++++---- include/spl.h | 10 ++++++++++ 3 files changed, 38 insertions(+), 4 deletions(-)
Add support for generating a GZIP-compressed U-boot binary with the help of binman, if CONFIG_SPL_GZIP is selected.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com --- arch/arm/dts/rockchip-u-boot.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 2878b80926..524d638e5b 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -48,10 +48,17 @@ type = "standalone"; os = "U-Boot"; arch = "arm64"; +#if defined(CONFIG_SPL_GZIP) + compression = "gzip"; +#else compression = "none"; +#endif load = <CONFIG_TEXT_BASE>; entry = <CONFIG_TEXT_BASE>; u-boot-nodtb { +#if defined(CONFIG_SPL_GZIP) + compress = "gzip"; +#endif }; #ifdef CONFIG_SPL_FIT_SIGNATURE hash {
On Mon, 24 Jul 2023 at 21:51, Manoj Sai abbaraju.manojsai@amarulasolutions.com wrote:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
compress = "gzip";
Hi Manoj,
This patch need rebase, and could you please address the comment from Jonas in new version is possible.
Thanks,
- Kever
compress = "gzip";
Add support for generating a LZMA-compressed U-boot binary with the help of binman, if CONFIG_SPL_LZMA is selected.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com --- arch/arm/dts/rockchip-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 524d638e5b..34282bdfb2 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -50,6 +50,8 @@ arch = "arm64"; #if defined(CONFIG_SPL_GZIP) compression = "gzip"; +#elif defined(CONFIG_SPL_LZMA) + compression = "lzma"; #else compression = "none"; #endif @@ -58,6 +60,8 @@ u-boot-nodtb { #if defined(CONFIG_SPL_GZIP) compress = "gzip"; +#elif defined(CONFIG_SPL_LZMA) + compress = "lzma"; #endif }; #ifdef CONFIG_SPL_FIT_SIGNATURE
Thanks, - Kever
#else compression = "none"; #endifcompression = "lzma";
#endif }; #ifdef CONFIG_SPL_FIT_SIGNATUREcompress = "lzma";
If GZIP Compression support is enabled, GZIP compressed U-Boot binary will be at a specified RAM location which is defined at CONFIG_SYS_LOAD_ADDR and will be assign it as the source address.
gunzip function in spl_load_fit_image ,will decompress the GZIP compressed U-Boot binary which is placed at source address(CONFIG_SYS_LOAD_ADDR) to the default CONFIG_SYS_TEXT_BASE location.
spl_load_fit_image function will load the decompressed U-Boot binary, which is placed at the CONFIG_SYS_TEXT_BASE location.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- common/spl/spl_fit.c | 7 +++++-- include/spl.h | 10 ++++++++++ 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 730639f756..d728ac71fc 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -239,7 +239,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, bool external_data = false;
if (IS_ENABLED(CONFIG_SPL_FPGA) || - (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP))) { + (IS_ENABLED(CONFIG_SPL_OS_BOOT) && spl_decompression_enabled())) { if (fit_image_get_type(fit, node, &type)) puts("Cannot get image type.\n"); else @@ -281,7 +281,10 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return 0; }
- src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) + src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); + else + src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); length = len;
overhead = get_aligned_image_overhead(info, offset); diff --git a/include/spl.h b/include/spl.h index 92bcaa90a4..088479e357 100644 --- a/include/spl.h +++ b/include/spl.h @@ -897,4 +897,14 @@ struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size);
void board_boot_order(u32 *spl_boot_list); void spl_save_restore_data(void); + +/* + * spl_decompression_enabled() - check decompression support is enabled for SPL build + * + * Returns true if decompression support is enabled, else False + */ +static inline bool spl_decompression_enabled(void) +{ + return (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA)); +} #endif
We could really use sandbox_spl test cases for these sorts of thing.
if (fit_image_get_type(fit, node, &type)) puts("Cannot get image type.\n"); else(IS_ENABLED(CONFIG_SPL_OS_BOOT) && spl_decompression_enabled())) {
Should probably use the new spl_decompression_enabled() instead of IS_ENABLED(CONFIG_SPL_GZIP) and the extra wrapping parentheses should not be needed.
else
length = len;
- spl_decompression_enabled() - check decompression support is enabled for SPL build
- Returns true if decompression support is enabled, else False
- return (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA));
IS_ENABLED(CONFIG_SPL_LZMA) should probably be added in the patch that add support for LZMA and the wrapping parentheses should not be needed.
Regards, Jonas
+} #endif
Hi Manoj,
Could update a new patch version and address the comment from Jonas?
Thanks,
- Kever
else
length = len;
Regards, Jonas
+} #endif
Thanks, - Kever
else
length = len;
+} #endif
If LZMA Compression support is enabled, LZMA compressed U-Boot binary will be placed at a specified RAM location which is defined at CONFIG_SYS_LOAD_ADDR and will be assigned as the source address.
image_decomp() function, will decompress the LZMA compressed U-Boot binary which is placed at source address(CONFIG_SYS_LOAD_ADDR) to the default CONFIG_SYS_TEXT_BASE location.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com --- common/spl/spl_fit.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index d728ac71fc..208d2f761e 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -246,7 +246,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, debug("%s ", genimg_get_type_name(type)); }
- if (IS_ENABLED(CONFIG_SPL_GZIP)) { + if (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA)) { fit_image_get_comp(fit, node, &image_comp); debug("%s ", genimg_get_comp_name(image_comp)); } @@ -280,8 +280,8 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, __func__, fit_get_name(fit, node, NULL)); return 0; } - - if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP)) + if ((IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP) || + (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA)) src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); else src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); @@ -329,6 +329,16 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return -EIO; } length = size; + } else if (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA) { + size = CONFIG_SYS_BOOTM_LEN; + ulong loadEnd; + + if (image_decomp(IH_COMP_LZMA, CONFIG_SYS_LOAD_ADDR, 0, 0, + load_ptr, src, length, size, &loadEnd)) { + puts("Uncompressing error\n"); + return -EIO; + } + length = loadEnd - CONFIG_SYS_LOAD_ADDR; } else { memcpy(load_ptr, src, length); }
- if (IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA)) {
This should probably change to use new spl_decompression_enabled(), such change should be made in the GZIP patch.
Could probably be simplified to something like:
if (spl_decompression_enabled() && (image_comp == IH_COMP_GZIP || image_comp == IH_COMP_LZMA))
Also what happens if I run a SPL without compression enabled, but have a FIT with image parts that is compressed?
Regards, Jonas
- } else if (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA) {
ulong loadEnd;
return -EIO;
} else { memcpy(load_ptr, src, length); }length = loadEnd - CONFIG_SYS_LOAD_ADDR;
Changes for V2 :-
size of GZIP compressed binary :- 9.0 MB (89,85,088 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 8985088 Jul 25 07:42 u-boot-rockchip.bin size of LZMA compressed binary :- 9.0 MB (90,06,080 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9006080 Jul 25 07:47 u-boot-rockchip.bin
- Uncompressed U-BOOT : Total boot time ≈ 12.3 seconds
- GZIP Compressed U-BOOT : Total boot time ≈ 13.5 seconds
- LZMA Compressed U-BOOT : Total boot time ≈ 23.5 seconds
Boot times seem very slow with compression enabled, please try with caches enabled, see RFC patch at [1]. Enable caches have a huge impact for FIT checksum validation using CONFIG_SPL_FIT_SIGNATURE=y.
Possible to also include ZSTD support?
nit: patch 1 and 2 should come after patch 3 and 4.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230702110055.3686457-1-jo...
Regards, Jonas
Changes for V2 :-
size of uncompressed binary :- 9.4 MB (94,26,432 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9426432 Jul 25 07:42 u-boot-rockchip.bin size of GZIP compressed binary :- 9.0 MB (89,85,088 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 8985088 Jul 25 07:42 u-boot-rockchip.bin size of LZMA compressed binary :- 9.0 MB (90,06,080 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9006080 Jul 25 07:47 u-boot-rockchip.bin
Hi Jonas , Enabled zstd support , facing build issues related to zstd . Had you faced this build error , pasted below :
aarch64-linux-gnu-ld.bfd: lib/zstd/decompress/zstd_decompress.o: in function `ZSTD_DDictHashSet_getIndex': /media/manoj/7d4c36e9-ddbb-4e7a-bd1e-cb96766bde37/ssd-Workspace/libreCompTask/tasks/compression-Task/mainline-apply-Uboot-cmp-2023/testfldr/u-boot/lib/zstd/decompress/zstd_decompress.c:88: undefined reference to `xxh64' aarch64-linux-gnu-ld.bfd: lib/zstd/decompress/zstd_decompress.o: in function `ZSTD_decodeFrameHeader': /media/manoj/7d4c36e9-ddbb-4e7a-bd1e-cb96766bde37/ssd-Workspace/libreCompTask/tasks/compression-Task/mainline-apply-Uboot-cmp-2023/testfldr/u-boot/lib/zstd/decompress/zstd_decompress.c:666: undefined reference to `xxh64_reset' aarch64-linux-gnu-ld.bfd: lib/zstd/decompress/zstd_decompress.o: in function `ZSTD_decompressFrame': /media/manoj/7d4c36e9-ddbb-4e7a-bd1e-cb96766bde37/ssd-Workspace/libreCompTask/tasks/compression-Task/mainline-apply-Uboot-cmp-2023/testfldr/u-boot/lib/zstd/decompress/zstd_decompress.c:888: undefined reference to `xxh64_update' aarch64-linux-gnu-ld.bfd: /media/manoj/7d4c36e9-ddbb-4e7a-bd1e-cb96766bde37/ssd-Workspace/libreCompTask/tasks/compression-Task/mainline-apply-Uboot-cmp-2023/testfldr/u-boot/lib/zstd/decompress/zstd_decompress.c:904: undefined reference to `xxh64_digest' make[1]: *** [scripts/Makefile.spl:527: spl/u-boot-spl] Error 1 make: *** [Makefile:2059: spl/u-boot-spl] Error 2
I'm missing anything to enable in configs ? any suggestions to these build error
Thanks and Regards , A.manojsai
Regards, Jonas
Changes for V3 :-
1. Replaced spl_decompression_enabled() function instead of checking IS_ENABLED(CONFIG_SPL_GZIP) and IS_ENABLED(CONFIG_SPL_LZMA) in spl_fit.c
2. Removed extra wrapping parentheses in spl_decompression_enabled().
size of uncompressed binary :- 9.0M (94,21,824 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9421824 Sep 10 22:22 u-boot-rockchip.bin
size of GZIP compressed binary :- 8.6M (89,85,088 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 8985088 Jul 25 07:42 u-boot-rockchip.bin
size of LZMA compressed binary :- 8.6 M (90,06,592 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9006592 Jul 25 07:47 u-boot-rockchip.bin
1) Uncompressed U-BOOT : Total boot time ≈ 12.063971 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 1,833,884 1,833,884 board_init_f 2,959,528 1,125,644 board_init_r 5,224,521 2,264,993 eth_common_init 5,523,428 298,907 eth_initialize 5,523,606 178 main_loop 5,523,764 158 usb_start 12,063,971 6,540,207 cli_loop
2) GZIP Compressed U-BOOT : Total time ≈ 12.824968 seconds
=> bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 2,594,709 2,594,709 board_init_f 3,719,969 1,125,260 board_init_r 5,985,450 2,265,481 eth_common_init 6,284,371 298,921 eth_initialize 6,284,549 178 main_loop 6,284,708 159 usb_start 12,824,968 6,540,260 cli_loop
3) LZMA Compressed U-BOOT : Total time ≈ 17.025004 seconds
=> bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 6,852,254 6,852,254 board_init_f 7,940,143 1,087,889 board_init_r 10,190,458 2,250,315 eth_common_init 10,487,254 296,796 eth_initialize 10,487,432 178 main_loop 10,487,590 158 usb_start 17,025,004 6,537,414 cli_loop
As per suggestion from Mr.Jonas Karlman (jonas@kwiboo.se) through Patchset V2,that check boot time with enabling CONFIG_SPL_FIT_SIGNATURE that might impact boot time.
Tried to check the boot time with CONFIG_FIT_SIGNATURE enabled, I didnt find any significant boot time improvement with enabling CONFIG_SPL_FIT_SIGNATURE.
Comparision of GZIP and LZMA compressed U-boot Boot time with and without Enable of CONFIG_FIT_SIGNATURE :-
- GZIP Compressed U-BOOT and CONFIG_FIT_SIGNATURE enabled :- Total time ≈ 13.283998 seconds
=> bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 3,052,571 3,052,571 board_init_f 4,179,787 1,127,216 board_init_r 6,445,472 2,265,685 eth_common_init 6,744,416 298,944 eth_initialize 6,744,593 177 main_loop 6,744,751 158 usb_start 13,283,998 6,539,247 cli_loop
- GZIP Compressed U-BOOT and CONFIG_FIT_SIGNATURE disabled :- Total time ≈ 12.824968 seconds
- LZMA Compressed U-BOOT and CONFIG_FIT_SIGNATURE enabled :- Total time ≈ 17.005996 seconds
=> bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 6,775,071 6,775,071 board_init_f 7,902,443 1,127,372 board_init_r 10,167,546 2,265,103 eth_common_init 10,466,418 298,872 eth_initialize 10,466,595 177 main_loop 10,466,753 158 usb_start 17,005,996 6,539,243 cli_loop
- LZMA Compressed U-BOOT and CONFIG_FIT_SIGNATURE disabled :- Total time ≈ 17.025004 seconds
Manoj Sai (4): spl: fit: support for booting a GZIP-compressed U-boot binary spl: fit: support for booting a LZMA-compressed U-boot binary rockchip: Add support to generate GZIP compressed U-boot binary rockchip: Add support to generate LZMA compressed U-boot binary
arch/arm/dts/rockchip-u-boot.dtsi | 11 +++++++++++ common/spl/spl_fit.c | 20 +++++++++++++++++--- include/spl.h | 10 ++++++++++ 3 files changed, 38 insertions(+), 3 deletions(-)
-- 2.25.1
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v3: - Replaced spl_decompression_enabled() function instead of checking IS_ENABLED(CONFIG_SPL_GZIP).
- Removed checking IS_ENABLED(CONFIG_SPL_LZMA) in spl_decompression_enabled() function.
Changes in v2: - New patch for v2
common/spl/spl_fit.c | 9 ++++++--- include/spl.h | 10 ++++++++++ 2 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 730639f756..eb97259f57 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -239,14 +239,14 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, bool external_data = false;
if (IS_ENABLED(CONFIG_SPL_FPGA) || - (IS_ENABLED(CONFIG_SPL_OS_BOOT) && IS_ENABLED(CONFIG_SPL_GZIP))) { + (IS_ENABLED(CONFIG_SPL_OS_BOOT) && spl_decompression_enabled())) { if (fit_image_get_type(fit, node, &type)) puts("Cannot get image type.\n"); else debug("%s ", genimg_get_type_name(type)); }
- if (IS_ENABLED(CONFIG_SPL_GZIP)) { + if (spl_decompression_enabled()) { fit_image_get_comp(fit, node, &image_comp); debug("%s ", genimg_get_comp_name(image_comp)); } @@ -281,7 +281,10 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return 0; }
- src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); + if (spl_decompression_enabled() && image_comp == IH_COMP_GZIP) + src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); + else + src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); length = len;
overhead = get_aligned_image_overhead(info, offset); diff --git a/include/spl.h b/include/spl.h index 93e906431e..3a7e448cc7 100644 --- a/include/spl.h +++ b/include/spl.h @@ -897,4 +897,14 @@ struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size);
void board_boot_order(u32 *spl_boot_list); void spl_save_restore_data(void); + +/* + * spl_decompression_enabled() - check decompression support is enabled for SPL build + * + * Returns true if decompression support is enabled, else False + */ +static inline bool spl_decompression_enabled(void) +{ + return IS_ENABLED(CONFIG_SPL_GZIP); +} #endif
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v3: - added IS_ENABLED(CONFIG_SPL_LZMA) to spl_decompression_enabled() function. - Removed extra parentheses.
common/spl/spl_fit.c | 13 ++++++++++++- include/spl.h | 2 +- 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index eb97259f57..75895ef15c 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -281,7 +281,8 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return 0; }
- if (spl_decompression_enabled() && image_comp == IH_COMP_GZIP) + if (spl_decompression_enabled() && + (image_comp == IH_COMP_GZIP || image_comp == IH_COMP_LZMA)) src_ptr = map_sysmem(ALIGN(CONFIG_SYS_LOAD_ADDR, ARCH_DMA_MINALIGN), len); else src_ptr = map_sysmem(ALIGN(load_addr, ARCH_DMA_MINALIGN), len); @@ -329,6 +330,16 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, return -EIO; } length = size; + } else if (IS_ENABLED(CONFIG_SPL_LZMA) && image_comp == IH_COMP_LZMA) { + size = CONFIG_SYS_BOOTM_LEN; + ulong loadEnd; + + if (image_decomp(IH_COMP_LZMA, CONFIG_SYS_LOAD_ADDR, 0, 0, + load_ptr, src, length, size, &loadEnd)) { + puts("Uncompressing error\n"); + return -EIO; + } + length = loadEnd - CONFIG_SYS_LOAD_ADDR; } else { memcpy(load_ptr, src, length); } diff --git a/include/spl.h b/include/spl.h index 3a7e448cc7..9de93a34cd 100644 --- a/include/spl.h +++ b/include/spl.h @@ -905,6 +905,6 @@ void spl_save_restore_data(void); */ static inline bool spl_decompression_enabled(void) { - return IS_ENABLED(CONFIG_SPL_GZIP); + return IS_ENABLED(CONFIG_SPL_GZIP) || IS_ENABLED(CONFIG_SPL_LZMA); } #endif
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v3: - None
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index be2658e8ef..8f248f941f 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -56,10 +56,17 @@ #else arch = "arm"; #endif +#if defined(CONFIG_SPL_GZIP) + compression = "gzip"; +#else compression = "none"; +#endif load = <CONFIG_TEXT_BASE>; entry = <CONFIG_TEXT_BASE>; u-boot-nodtb { +#if defined(CONFIG_SPL_GZIP) + compress = "gzip"; +#endif }; #ifdef CONFIG_SPL_FIT_SIGNATURE hash {
diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 8f248f941f..c8c928c7e5 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -58,6 +58,8 @@ #endif #if defined(CONFIG_SPL_GZIP) compression = "gzip"; +#elif defined(CONFIG_SPL_LZMA) + compression = "lzma"; #else compression = "none"; #endif @@ -66,6 +68,8 @@ u-boot-nodtb { #if defined(CONFIG_SPL_GZIP) compress = "gzip"; +#elif defined(CONFIG_SPL_LZMA) + compress = "lzma"; #endif }; #ifdef CONFIG_SPL_FIT_SIGNATURE
Changes for V3 :-
size of uncompressed binary :- 9.0M (94,21,824 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9421824 Sep 10 22:22 u-boot-rockchip.bin size of GZIP compressed binary :- 8.6M (89,85,088 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 8985088 Jul 25 07:42 u-boot-rockchip.bin size of LZMA compressed binary :- 8.6 M (90,06,592 bytes) manoj:u-boot$ ls -lb u-boot-rockchip.bin -rw-rw-r-- 1 manoj manoj 9006592 Jul 25 07:47 u-boot-rockchip.bin
- Uncompressed U-BOOT : Total boot time ≈ 12.063971 seconds
- GZIP Compressed U-BOOT : Total time ≈ 12.824968 seconds
- LZMA Compressed U-BOOT : Total time ≈ 17.025004 seconds
I may not have been that clear in my last mail, it is the following rfc/patch that may improve performance. That prfc/patch does improve performance for sha256 validation when CONFIG_SPL_FIT_SIGNATURE is enabled.
[RFC] rockchip: spl: Enable caches to speed up checksum validation https://patchwork.ozlabs.org/project/uboot/patch/20230702110055.3686457-1-jo...
Would be great to get confirmation if D-cache enabled in SPL also benefit this series, and not just checksum validation. (that rfc/patch unfortunately did not get much feedback)
Regards, Jonas
=> bootstage report
-- 2.25.1
Changes for V3 :-
1. Replaced spl_decompression_enabled() function instead of checking IS_ENABLED(CONFIG_SPL_GZIP) and IS_ENABLED(CONFIG_SPL_LZMA) in spl_fit.c.
Changes for V4 :-
1. As per the suggestion from Mr.Jonas Karlman (jonas@kwiboo.se) from PATCH v2 and v3 ,check boot time with the following RFC patch with CONFIG_SPL_FIT_SIGNATURE enabled that might impact boot time and As seen there is an improvement in boot time with both compress enabled and disabled , I have added the logs of it below.
1) Uncompressed U-BOOT : Total boot time = 12.063971 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 1,833,884 1,833,884 board_init_f 2,959,528 1,125,644 board_init_r 5,224,521 2,264,993 eth_common_init 5,523,428 298,907 eth_initialize 5,523,606 178 main_loop 5,523,764 158 usb_start 12,063,971 6,540,207 cli_loop
2) GZIP Compressed U-BOOT : Total time = 12.824968 seconds
3) LZMA Compressed U-BOOT : Total time = 17.025004 seconds
Test results of booting time using RFC patch from Mr.Jonas Karlman(jonas@kwiboo.se) with CONFIG_SPL_FIT_SIGNATURE enabled on roc-rk3399-pc board :-
1. Uncompressed U-BOOT : Total boot time = 10.728 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 477,024 477,024 board_init_f 1,623,670 1,146,646 board_init_r 3,889,493 2,265,823 eth_common_init 4,188,402 298,909 eth_initialize 4,188,579 177 main_loop 4,188,738 159 usb_start 10,728,000 6,539,262 cli_loop
2. GZIP Compressed U-BOOT : Total time = 10.708 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 457,663 457,663 board_init_f 1,604,222 1,146,559 board_init_r 3,869,505 2,265,283 eth_common_init 4,168,410 298,905 eth_initialize 4,168,587 177 main_loop 4,168,745 158 usb_start 10,707,997 6,539,252 cli_loop
3. LZMA Compressed U-BOOT : Total time = 10.86 seconds => bootstage report Timer summary in microseconds (10 records): Mark Elapsed Stage 0 0 reset 612,427 612,427 board_init_f 1,756,176 1,143,749 board_init_r 4,021,522 2,265,346 eth_common_init 4,320,433 298,911 eth_initialize 4,320,610 177 main_loop 4,320,768 158 usb_start 10,860,001 6,539,233 cli_loop
As I can seen there is an improvement in boot time with Enable caches in SPL to speed up FIT checksum validation, with the following RFC patch from Mr.Jonas. [RFC] rockchip: spl: Enable caches to speed up checksum validation https://patchwork.ozlabs.org/project/uboot/patch/20230702110055.3686457-1-jo...
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v4: - None
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Suniel Mahesh sunil@amarulasolutions.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v4: - None
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes in v4: - None
participants (6)
Jonas Karlman
Kever Yang
Manoj Sai
Xavier Drudis Ferran
