[U-Boot] [PATCH v4 08/45] Kconfig: spl: Add SPL support options to Kconfig
There are a lot of SPL options in U-Boot to enable various features and drivers. Currently these do not use Kconfig. Add them to Kconfig along with suitable help, and drop them from the README.
Changes in v4: - Drop SPL_PINCTRL_SUPPORT
Changes in v3: - Move SPL_NET_VCI_STRING into the SPL Kconfig file also
Changes in v2: None
README | 49 ------- common/spl/Kconfig | 411 +++++++++++++++++++++++++++++++++++++++++++++++++++++ net/Kconfig | 3 - 3 files changed, 411 insertions(+), 52 deletions(-)
diff --git a/README b/README index f41a6af..d916ee7 100644 --- a/README +++ b/README @@ -3509,21 +3509,6 @@ FIT uImage format: CONFIG_SPL_INIT_MINIMAL Arch init code should be built for a very small image
- CONFIG_SPL_LIBCOMMON_SUPPORT - Support for common/libcommon.o in SPL binary - - CONFIG_SPL_LIBDISK_SUPPORT - Support for disk/libdisk.o in SPL binary - - CONFIG_SPL_I2C_SUPPORT - Support for drivers/i2c/libi2c.o in SPL binary - - CONFIG_SPL_GPIO_SUPPORT - Support for drivers/gpio/libgpio.o in SPL binary - - CONFIG_SPL_MMC_SUPPORT - Support for drivers/mmc/libmmc.o in SPL binary - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS, Address and partition on the MMC to load U-Boot from @@ -3547,12 +3532,6 @@ FIT uImage format: Partition on the MMC to load U-Boot from when the MMC is being used in fs mode
- CONFIG_SPL_FAT_SUPPORT - Support for fs/fat/libfat.o in SPL binary - - CONFIG_SPL_EXT_SUPPORT - Support for EXT filesystem in SPL binary - CONFIG_SPL_FS_LOAD_PAYLOAD_NAME Filename to read to load U-Boot when reading from filesystem
@@ -3591,18 +3570,10 @@ FIT uImage format: Support for a lightweight UBI (fastmap) scanner and loader
- CONFIG_SPL_MTD_SUPPORT - Support for the MTD subsystem within SPL. Useful for - environment on NAND support within SPL. - CONFIG_SPL_NAND_RAW_ONLY Support to boot only raw u-boot.bin images. Use this only if you need to save space.
- CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT - Set for the SPL on PPC mpc8xxx targets, support for - drivers/ddr/fsl/libddr.o in SPL binary. - CONFIG_SPL_COMMON_INIT_DDR Set for common ddr init with serial presence detect in SPL binary. @@ -3638,29 +3609,9 @@ FIT uImage format: Support for an OMAP3-specific set of functions to return the ID and MFR of the first attached NAND chip, if present.
- CONFIG_SPL_SERIAL_SUPPORT - Support for drivers/serial/libserial.o in SPL binary - - CONFIG_SPL_SPI_FLASH_SUPPORT - Support for drivers/mtd/spi/libspi_flash.o in SPL binary - - CONFIG_SPL_SPI_SUPPORT - Support for drivers/spi/libspi.o in SPL binary - CONFIG_SPL_RAM_DEVICE Support for running image already present in ram, in SPL binary
- CONFIG_SPL_LIBGENERIC_SUPPORT - Support for lib/libgeneric.o in SPL binary - - CONFIG_SPL_ENV_SUPPORT - Support for the environment operating in SPL binary - - CONFIG_SPL_NET_SUPPORT - Support for the net/libnet.o in SPL binary. - It conflicts with SPL env from storage medium specified by - CONFIG_ENV_IS_xxx but CONFIG_ENV_IS_NOWHERE - CONFIG_SPL_PAD_TO Image offset to which the SPL should be padded before appending the SPL payload. By default, this is defined as diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 2d2256a..b56f99b 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1,3 +1,5 @@ +menu "SPL / TPL" + config SUPPORT_SPL bool
@@ -65,3 +67,412 @@ config TPL prompt "Enable TPL" help If you want to build TPL as well as the normal image and SPL, say Y. + +config SPL_CRC32_SUPPORT + bool "Support CRC32" + depends on SPL_FIT + help + Enable this to support CRC32 in FIT images within SPL. This is a + 32-bit checksum value that can be used to verify images. This is + the least secure type of checksum, suitable for detected + accidental image corruption. For secure applications you should + consider SHA1 or SHA256. + +config SPL_MD5_SUPPORT + bool "Support MD5" + depends on SPL_FIT + help + Enable this to support MD5 in FIT images within SPL. An MD5 + checksum is a 128-bit hash value used to check that the image + contents have not been corrupted. Note that MD5 is not considered + secure as it is possible (with a brute-force attack) to adjust the + image while still retaining the same MD5 hash value. For secure + applications where images may be changed maliciously, you should + consider SHA1 or SHA256. + +config SPL_SHA1_SUPPORT + bool "Support SHA1" + depends on SPL_FIT + help + Enable this to support SHA1 in FIT images within SPL. A SHA1 + checksum is a 160-bit (20-byte) hash value used to check that the + image contents have not been corrupted or maliciously altered. + While SHA1 is fairly secure it is coming to the end of its life + due to the expanding computing power avaiable to brute-force + attacks. For more security, consider SHA256. + +config SPL_SHA256_SUPPORT + bool "Support SHA256" + depends on SPL_FIT + help + Enable this to support SHA256 in FIT images within SPL. A SHA256 + checksum is a 256-bit (32-byte) hash value used to check that the + image contents have not been corrupted. SHA256 is recommended for + use in secure applications since (as at 2016) there is no known + feasible attack that could produce a 'collision' with differing + input data. Use this for the highest security. Note that only the + SHA256 variant is supported: SHA512 and others are not currently + supported in U-Boot. + +config SPL_CRYPTO_SUPPORT + bool "Support crypto drivers" + depends on SPL + help + Enable crypto drivers in SPL. These drivers can be used to + accelerate secure boot processing in secure applications. Enable + this option to build the drivers in drivers/crypto as part of an + SPL build. + +config SPL_HASH_SUPPORT + bool "Support hashing drivers" + depends on SPL + help + Enable hashing drivers in SPL. These drivers can be used to + accelerate secure boot processing in secure applications. Enable + this option to build system-specific drivers for hash acceleration + as part of an SPL build. + +config SPL_DMA_SUPPORT + bool "Support DMA drivers" + depends on SPL + help + Enable DMA (direct-memory-access) drivers in SPL. These drivers + can be used to handle memory-to-peripheral data transfer without + the CPU moving the data. Enable this option to build the drivers + in drivers/dma as part of an SPL build. + +config SPL_DRIVERS_MISC_SUPPORT + bool "Support misc drivers" + depends on SPL + help + Enable miscellaneous drivers in SPL. These drivers perform various + tasks that don't fall nicely into other categories, Enable this + option to build the drivers in drivers/misc as part of an SPL + build, for those that support building in SPL (not all drivers do). + +config SPL_ENV_SUPPORT + bool "Support an environment" + depends on SPL + help + Enable environment support in SPL. The U-Boot environment provides + a number of settings (essentially name/value pairs) which can + control many aspects of U-Boot's operation. Normally this is not + needed in SPL as it has a much simpler task with less + configuration. But some boards use this to support 'Falcon' boot + on EXT2 and FAT, where SPL boots directly into Linux without + starting U-Boot first. Enabling this option will make getenv() + and setenv() available in SPL. + +config SPL_ETH_SUPPORT + bool "Support Ethernet" + depends on SPL_ENV_SUPPORT + help + Enable access to the network subsystem and associated Ethernet + drivers in SPL. This permits SPL to load U-Boot over an Ethernet + link rather than from an on-board peripheral. Environment support + is required since the network stack uses a number of environment + variables. See also SPL_NET_SUPPORT. + +config SPL_EXT_SUPPORT + bool "Support EXT filesystems" + depends on SPL + help + Enable support for EXT2/3/4 filesystems with SPL. This permits + U-Boot (or Linux in Falcon mode) to be loaded from an EXT + filesystem from within SPL. Support for the underlying block + device (e.g. MMC or USB) must be enabled separately. + +config SPL_FAT_SUPPORT + bool "Support FAT filesystems" + depends on SPL + help + Enable support for FAT and VFAT filesystems with SPL. This + permits U-Boot (or Linux in Falcon mode) to be loaded from a FAT + filesystem from within SPL. Support for the underlying block + device (e.g. MMC or USB) must be enabled separately. + +config SPL_FPGA_SUPPORT + bool "Support FPGAs" + depends on SPL + help + Enable support for FPGAs in SPL. Field-programmable Gate Arrays + provide software-configurable hardware which is typically used to + implement peripherals (such as UARTs, LCD displays, MMC) or + accelerate custom processing functions, such as image processing + or machine learning. Sometimes it is useful to program the FPGA + as early as possible during boot, and this option can enable that + within SPL. + +config SPL_GPIO_SUPPORT + bool "Support GPIO" + depends on SPL + help + Enable support for GPIOs (General-purpose Input/Output) in SPL. + GPIOs allow U-Boot to read the state of an input line (high or + low) and set the state of an output line. This can be used to + drive LEDs, control power to various system parts and read user + input. GPIOs can be useful in SPL to enable a 'sign-of-life' LED, + for example. Enable this option to build the drivers in + drivers/gpio as part of an SPL build. + +config SPL_I2C_SUPPORT + bool "Support I2C" + depends on SPL + help + Enable support for the I2C (Inter-Integrated Circuit) bus in SPL. + I2C works with a clock and data line which can be driven by a + one or more masters or slaves. It is a fairly complex bus but is + widely used as it only needs two lines for communication. Speeds of + 400kbps are typical but up to 3.4Mbps is supported by some + hardware. I2C can be useful in SPL to configure power management + ICs (PMICs) before raising the CPU clock speed, for example. + Enable this option to build the drivers in drivers/i2c as part of + an SPL build. + +config SPL_LIBCOMMON_SUPPORT + bool "Support common libraries" + depends on SPL + help + Enable support for common U-Boot libraries within SPL. These + libraries include common code to deal with U-Boot images, + environment and USB, for example. This option is enabled on many + boards. Enable this option to build the code in common/ as part of + an SPL build. + +config SPL_LIBDISK_SUPPORT + bool "Support disk paritions" + depends on SPL + help + Enable support for disk partitions within SPL. 'Disk' is something + of a misnomer as it includes non-spinning media such as flash (as + used in MMC and USB sticks). Partitions provide a way for a disk + to be split up into separate regions, with a partition table placed + at the start or end which describes the location and size of each + 'partition'. These partitions are typically uses as individual block + devices, typically with an EXT2 or FAT filesystem in each. This + option enables whatever partition support has been enabled in + U-Boot to also be used in SPL. It brings in the code in disk/. + +config SPL_LIBGENERIC_SUPPORT + bool "Support generic libraries" + depends on SPL + help + Enable support for generic U-Boot libraries within SPL. These + libraries include generic code to deal with device tree, hashing, + printf(), compression and the like. This option is enabled on many + boards. Enable this option to build the code in lib/ as part of an + SPL build. + +config SPL_MMC_SUPPORT + bool "Support MMC" + depends on SPL + help + Enable support for MMC (Multimedia Card) within SPL. This enables + the MMC protocol implementation and allows any enabled drivers to + be used within SPL. MMC can be used with or without disk partition + support depending on the application (SPL_LIBDISK_SUPPORT). Enable + this option to build the drivers in drivers/mmc as part of an SPL + build. + +config SPL_MPC8XXX_INIT_DDR_SUPPORT + bool "Support MPC8XXX DDR init" + depends on SPL + help + Enable support for DDR-SDRAM (double-data-rate synchronous dynamic + random-access memory) on the MPC8XXX family within SPL. This + allows DRAM to be set up before loading U-Boot into that DRAM, + where it can run. + +config SPL_MTD_SUPPORT + bool "Support MTD drivers" + depends on SPL + help + Enable support for MTD (Memory Technology Device) within SPL. MTD + provides a block interface over raw NAND and can also be used with + SPI flash. This allows SPL to load U-Boot from supported MTD + devices. See SPL_NAND_SUPPORT and SPL_ONENAND_SUPPORT for how + to enable specific MTD drivers. + +config SPL_MUSB_NEW_SUPPORT + bool "Support new Mentor Graphics USB" + depends on SPL + help + Enable support for Mentor Graphics USB in SPL. This is a new + driver used by some boards. Enable this option to build + the drivers in drivers/usb/musb-new as part of an SPL build. The + old drivers are in drivers/usb/musb. + +config SPL_NAND_SUPPORT + bool "Support NAND flash" + depends on SPL + help + Enable support for NAND (Negative AND) flash in SPL. NAND flash + can be used to allow SPL to load U-Boot from supported devices. + This enables the drivers in drivers/mtd/nand as part of an SPL + build. + +config SPL_NET_SUPPORT + bool "Support networking" + depends on SPL + help + Enable support for network devices (such as Ethernet) in SPL. + This permits SPL to load U-Boot over a network link rather than + from an on-board peripheral. Environment support is required since + the network stack uses a number of environment variables. See also + SPL_ETH_SUPPORT. + +if SPL_NET_SUPPORT +config SPL_NET_VCI_STRING + string "BOOTP Vendor Class Identifier string sent by SPL" + help + As defined by RFC 2132 the vendor class identifier field can be + sent by the client to identify the vendor type and configuration + of a client. This is often used in practice to allow for the DHCP + server to specify different files to load depending on if the ROM, + SPL or U-Boot itself makes the request +endif # if SPL_NET_SUPPORT + +config SPL_NO_CPU_SUPPORT + bool "Drop CPU code in SPL" + depends on SPL + help + This is specific to the ARM926EJ-S CPU. It disables the standard + start.S start-up code, presumably so that a replacement can be + used on that CPU. You should not enable it unless you know what + you are doing. + +config SPL_NOR_SUPPORT + bool "Support NOR flash" + depends on SPL + help + Enable support for loading U-Boot from memory-mapped NOR (Negative + OR) flash in SPL. NOR flash is slow to write but fast to read, and + a memory-mapped device makes it very easy to access. Loading from + NOR is typically achieved with just a memcpy(). + +config SPL_ONENAND_SUPPORT + bool "Support OneNAND flash" + depends on SPL + help + Enable support for OneNAND (Negative AND) flash in SPL. OneNAND is + a type of NAND flash and therefore can be used to allow SPL to + load U-Boot from supported devices. This enables the drivers in + drivers/mtd/onenand as part of an SPL build. + +config SPL_POST_MEM_SUPPORT + bool "Support POST drivers" + depends on SPL + help + Enable support for POST (Power-on Self Test) in SPL. POST is a + procedure that checks that the hardware (CPU or board) appears to + be functionally correctly. It is a sanity check that can be + performed before booting. This enables the drivers in post/drivers + as part of an SPL build. + +config SPL_POWER_SUPPORT + bool "Support power drivers" + depends on SPL + help + Enable support for power control in SPL. This includes support + for PMICs (Power-management Integrated Circuits) and some of the + features provided by PMICs. In particular, voltage regulators can + be used to enable/disable power and vary its voltage. That can be + useful in SPL to turn on boot peripherals and adjust CPU voltage + so that the clock speed can be increased. This enables the drivers + in drivers/power, drivers/power/pmic and drivers/power/regulator + as part of an SPL build. + +config SPL_SATA_SUPPORT + bool "Support loading from SATA" + depends on SPL + help + Enable support for SATA (Serial AT attachment) in SPL. This allows + use of SATA devices such as hard drives and flash drivers for + loading U-Boot. SATA is used in higher-end embedded systems and + can provide higher performance than MMC , at somewhat higher + expense and power consumption. This enables loading from SATA + using a configured device. + +config SPL_SERIAL_SUPPORT + bool "Support serial" + depends on SPL + help + Enable support for serial in SPL. This allows use of a serial UART + for displaying messages while SPL is running. It also brings in + printf() and panic() functions. This should normally be enabled + unless there are space reasons not to. Even then, consider + enabling USE_TINY_PRINTF which is a small printf() version. + +config SPL_SPI_FLASH_SUPPORT + bool "Support SPI flash drivers" + depends on SPL + help + Enable support for using SPI flash in SPL, and loading U-Boot from + SPI flash. SPI flash (Serial Peripheral Bus flash) is named after + the SPI bus that is used to connect it to a system. It is a simple + but fast bidirectional 4-wire bus (clock, chip select and two data + lines). This enables the drivers in drivers/mtd/spi as part of an + SPL build. This normally requires SPL_SPI_SUPPORT. + +config SPL_SPI_SUPPORT + bool "Support SPI drivers" + depends on SPL + help + Enable support for using SPI in SPL. This is used for connecting + to SPI flash for loading U-Boot. See SPL_SPI_FLASH_SUPPORT for + more details on that. The SPI driver provides the transport for + data between the SPI flash and the CPU. This option can be used to + enable SPI drivers that are needed for other purposes also, such + as a SPI PMIC. + +config SPL_USBETH_SUPPORT + bool "Support USB Ethernet drivers" + depends on SPL + help + Enable access to the USB network subsystem and associated + drivers in SPL. This permits SPL to load U-Boot over a + USB-connected Ethernet link (such as a USB Ethernet dongle) rather + than from an onboard peripheral. Environment support is required + since the network stack uses a number of environment variables. + See also SPL_NET_SUPPORT and SPL_ETH_SUPPORT. + +config SPL_USB_HOST_SUPPORT + bool "Support USB host drivers" + depends on SPL + help + Enable access to USB (Universal Serial Bus) host devices so that + SPL can load U-Boot from a connected USB peripheral, such as a USB + flash stick. While USB takes a little longer to start up than most + buses, it is very flexible since many different types of storage + device can be attached. This option enables the drivers in + drivers/usb/host as part of an SPL build. + +config SPL_USB_SUPPORT + bool "Support loading from USB" + depends on SPL_USB_HOST_SUPPORT + help + Enable support for USB devices in SPL. This allows use of USB + devices such as hard drives and flash drivers for loading U-Boot. + The actual drivers are enabled separately using the normal U-Boot + config options. This enables loading from USB using a configured + device. + +config SPL_WATCHDOG_SUPPORT + bool "Support watchdog drivers" + depends on SPL + help + Enable support for watchdog drivers in SPL. A watchdog is + typically a hardware peripheral which can reset the system when it + detects no activity for a while (such as a software crash). This + enables the drivers in drivers/watchdog as part of an SPL build. + +config SPL_YMODEM_SUPPORT + bool "Support loading using Ymodem" + depends on SPL + help + While loading from serial is slow it can be a useful backup when + there is no other option. The Ymodem protocol provides a reliable + means of transmitting U-Boot over a serial line for using in SPL, + with a checksum to ensure correctness. + +endmenu diff --git a/net/Kconfig b/net/Kconfig index c393269..414c549 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -45,7 +45,4 @@ config BOOTP_VCI_STRING default "U-Boot.arm" if ARM default "U-Boot"
-config SPL_NET_VCI_STRING - string - endif # if NET
This option is not used. Drop it.
Changes in v4: - Really drop CONFIG_SPL_PINCTRL_SUPPORT
Changes in v3: None Changes in v2: - Drop CONFIG_SPL_PINCTRL_SUPPORT
include/configs/rk3288_common.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 3c1f2c9..cf5e5b2 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -63,8 +63,6 @@ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-#define CONFIG_SPL_PINCTRL_SUPPORT - #define CONFIG_SYS_SDRAM_BASE 0 #define CONFIG_NR_DRAM_BANKS 1 #define SDRAM_BANK_SIZE (2UL << 30)
