[U-Boot] [PATCH] imx: imx6: Move gpr_init() function to soc.c
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file.
Signed-off-by: Breno Lima breno.lima@nxp.com --- arch/arm/include/asm/mach-imx/sys_proto.h | 2 ++ arch/arm/mach-imx/mx6/soc.c | 17 +++++++++++++++++ board/bachmann/ot1200/ot1200.c | 11 ----------- board/barco/platinum/platinum.h | 11 ----------- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 11 ----------- board/el/el6x/el6x.c | 11 ----------- board/engicam/common/spl.c | 11 ----------- board/freescale/mx6sabreauto/mx6sabreauto.c | 17 ----------------- board/freescale/mx6sabresd/mx6sabresd.c | 17 ----------------- board/gateworks/gw_ventana/gw_ventana_spl.c | 11 ----------- board/kosagi/novena/novena_spl.c | 11 ----------- board/liebherr/mccmon6/spl.c | 11 ----------- board/phytec/pcm058/pcm058.c | 12 ------------ board/phytec/pfla02/pfla02.c | 11 ----------- board/solidrun/mx6cuboxi/mx6cuboxi.c | 11 ----------- board/toradex/apalis_imx6/apalis_imx6.c | 11 ----------- board/toradex/colibri_imx6/colibri_imx6.c | 11 ----------- board/udoo/udoo_spl.c | 11 ----------- board/wandboard/spl.c | 11 ----------- 19 files changed, 19 insertions(+), 200 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index 046df62..436ba9a 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -85,6 +85,8 @@ static inline u8 imx6_is_bmode_from_gpr9(void) }
u32 imx6_src_get_boot_mode(void); +void gpr_init(void); + #endif /* CONFIG_MX6 */
u32 get_nr_cpus(void); diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index 9ede1f5..f8bc05e 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -681,6 +681,23 @@ void imx_setup_hdmi(void) } #endif
+void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + if (is_mx6dqp()) { + /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ + writel(0x77177717, &iomux->gpr[6]); + writel(0x77177717, &iomux->gpr[7]); + } else { + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); + } +} + #ifdef CONFIG_IMX_BOOTAUX int arch_auxiliary_core_up(u32 core_id, u32 boot_private_data) { diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index df10d6a..9465cea 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -169,17 +169,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - int board_early_init_f(void) { ccgr_init(); diff --git a/board/barco/platinum/platinum.h b/board/barco/platinum/platinum.h index d3ea8bd..3013ed9 100644 --- a/board/barco/platinum/platinum.h +++ b/board/barco/platinum/platinum.h @@ -75,15 +75,4 @@ static inline void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static inline void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - #endif /* _PLATINUM_H_ */ diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 8cd0090..2ed66d3 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -955,17 +955,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - /* Define a minimal structure so that the part number can be read via SPL */ struct mfgdata { unsigned char tsize; diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c index 6b98b5c..fb128f5 100644 --- a/board/el/el6x/el6x.c +++ b/board/el/el6x/el6x.c @@ -570,17 +570,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - /* * This section requires the differentiation between iMX6 Sabre boards, but * for now, it will configure only for the mx6q variant. diff --git a/board/engicam/common/spl.c b/board/engicam/common/spl.c index a8a7cf3..29a27ce 100644 --- a/board/engicam/common/spl.c +++ b/board/engicam/common/spl.c @@ -332,17 +332,6 @@ static void ccgr_init(void) #endif }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void spl_dram_init(void) { #ifdef CONFIG_MX6QDL diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index f8f77f6..15ca029 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -798,23 +798,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - if (is_mx6dqp()) { - /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ - writel(0x77177717, &iomux->gpr[6]); - writel(0x77177717, &iomux->gpr[7]); - } else { - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); - } -} - static int mx6q_dcd_table[] = { 0x020e0798, 0x000C0000, 0x020e0758, 0x00000000, diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 9a562b3..5b50bc8 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -747,23 +747,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - if (is_mx6dqp()) { - /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ - writel(0x77177717, &iomux->gpr[6]); - writel(0x77177717, &iomux->gpr[7]); - } else { - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); - } -} - static int mx6q_dcd_table[] = { 0x020e0798, 0x000C0000, 0x020e0758, 0x00000000, diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index 9524da7..c2e370b 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -583,17 +583,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - /* * called from C runtime startup code (arch/arm/lib/crt0.S:_main) * - we have a stack and a place to store GD, both in SRAM diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c index 3645b75..512f06d 100644 --- a/board/kosagi/novena/novena_spl.c +++ b/board/kosagi/novena/novena_spl.c @@ -550,17 +550,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - /* * called from C runtime startup code (arch/arm/lib/crt0.S:_main) * - we have a stack and a place to store GD, both in SRAM diff --git a/board/liebherr/mccmon6/spl.c b/board/liebherr/mccmon6/spl.c index 15844ef..a2f804d 100644 --- a/board/liebherr/mccmon6/spl.c +++ b/board/liebherr/mccmon6/spl.c @@ -260,17 +260,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void spl_dram_init(void) { if (is_cpu_type(MXC_CPU_MX6SOLO)) { diff --git a/board/phytec/pcm058/pcm058.c b/board/phytec/pcm058/pcm058.c index 4257fbc..1538158 100644 --- a/board/phytec/pcm058/pcm058.c +++ b/board/phytec/pcm058/pcm058.c @@ -487,18 +487,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - - static void spl_dram_init(void) { struct mx6_ddr_sysinfo sysinfo = { diff --git a/board/phytec/pfla02/pfla02.c b/board/phytec/pfla02/pfla02.c index 8d2ce63..ec9264d 100644 --- a/board/phytec/pfla02/pfla02.c +++ b/board/phytec/pfla02/pfla02.c @@ -550,17 +550,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void spl_dram_init(struct mx6_ddr3_cfg *mem_ddr) { struct mx6_ddr_sysinfo sysinfo = { diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 7e59fb2..986abc5 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -581,17 +581,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void spl_dram_init(int width) { struct mx6_ddr_sysinfo sysinfo = { diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 2fd9623..ebc6c12 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -1160,17 +1160,6 @@ static void ccgr_init(void) writel(0x000000FB, &ccm->ccosr); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void ddr_init(int *table, int size) { int i; diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index d30391f..669d912 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -1037,17 +1037,6 @@ static void ccgr_init(void) writel(0x000000FB, &ccm->ccosr); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000CF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void ddr_init(int *table, int size) { int i; diff --git a/board/udoo/udoo_spl.c b/board/udoo/udoo_spl.c index e83e7c3..3645969 100644 --- a/board/udoo/udoo_spl.c +++ b/board/udoo/udoo_spl.c @@ -211,17 +211,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
-static void gpr_init(void) -{ - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - - /* enable AXI cache for VDOA/VPU/IPU */ - writel(0xF00000FF, &iomux->gpr[4]); - /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ - writel(0x007F007F, &iomux->gpr[6]); - writel(0x007F007F, &iomux->gpr[7]); -} - static void spl_dram_init(void) { if (is_cpu_type(MXC_CPU_MX6DL)) { diff --git a/board/wandboard/spl.c b/board/wandboard/spl.c index 47082a8..99a0286 100644 --- a/board/wandboard/spl.c +++ b/board/wandboard/spl.c @@ -266,17 +266,6 @@ static void ccgr_init(void) writel(0x000003FF, &ccm->CCGR6); }
Hi Breno,
Fully agree !
I took a loog a couple of days ago and I saw how much cut&paste code is in board/. Thanks, that you did it !
- } else {
- This section requires the differentiation between iMX6 Sabre boards, but
- for now, it will configure only for the mx6q variant.
- } else {
- } else {
- called from C runtime startup code (arch/arm/lib/crt0.S:_main)
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
On 08/24/2017 03:02 PM, Stefano Babic wrote:
Hi Breno,
Fully agree !
- } else {
- } else {
- } else {
Reviewed-by: Lukasz Majewski lukma@denx.de
Hi Breno,
Nice statistics :-) Thanks for the cleanup:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Breno Lima
Fabio Estevam
Stefano Babic
Łukasz Majewski
