[PATCH] clk: introduce u-boot,ignore-clk-defaults
Current code has a force clk_set_defaults in multiple stages, U-Boot reuse the same device tree and Linux Kernel device tree, but we not register all the clks as Linux Kernel, so clk_set_defaults will fail and cause the clk provider registeration fail.
So introduce a new property to ignore the default settings which could be used by any node that wanna ignore default settings.
Signed-off-by: Peng Fan peng.fan@nxp.com --- doc/device-tree-bindings/device.txt | 3 +++ drivers/clk/clk-uclass.c | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/doc/device-tree-bindings/device.txt b/doc/device-tree-bindings/device.txt index 73ce2a3b5b..fe34ced268 100644 --- a/doc/device-tree-bindings/device.txt +++ b/doc/device-tree-bindings/device.txt @@ -28,6 +28,9 @@ the acpi,compatible property. Linux will only load the driver if the device can be detected (e.g. on I2C bus). Note that this is an out-of-tree Linux feature.
+Common device bindings that could be shared listed below: + - u-boot,ignore-clk-defaults : ignore the assigned-clock-parents + and assigned-clock-rates for a device that has the property.
Example ------- diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 493018b33e..6bf3179e7b 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -376,6 +376,9 @@ int clk_set_defaults(struct udevice *dev, enum clk_defaults_stage stage) if (!dev_has_ofnode(dev)) return 0;
+ if (ofnode_get_property(dev_ofnode(dev), "u-boot,ignore-clk-defaults", NULL)) + return 0; + /* * To avoid setting defaults twice, don't set them before relocation. * However, still set them for SPL. And still set them if explicitly
I wonder if this binding could be made standard, instead of 'u-boot,'?
- and assigned-clock-rates for a device that has the property.
Example
-- 2.30.0
Feels like something we should see about, yes.
Simon,
Sorry, could you explain more? You mean put it in linux device tree in linux kernel repo?
Thanks, Peng.
Example
-- 2.30.0
Hi Peng,
On Fri, 15 Oct 2021 at 02:58, Peng Fan (OSS) peng.fan@oss.nxp.com wrote:
Simon,
Yes, if you think it would be useful there. Just a suggestion.
Example
- if (ofnode_get_property(dev_ofnode(dev), "u-boot,ignore-clk-defaults", NULL))
- To avoid setting defaults twice, don't set them before relocation.
- However, still set them for SPL. And still set them if explicitly
Why not just have the property ignore errors?
In the long term, it may be better to standardize that e.g. ENOENT means that the clock doesn't exist. That way we can skip setting the defaults. ENOSYS should probably be treated the same way (warn, but don't fail).
--Sean
Subject: Re: [PATCH] clk: introduce u-boot,ignore-clk-defaults
I2C
Example
NULL))
explicitly
I think the force err return was done by Simon?
I am not sure whether people expect force error for ENOENT/ENOSYS in U-Boot. For i.MX, I not expect force error.
Regards, Peng.
--Sean
Hi Peng, Sean,
I2C
Example
NULL))
explicitly
Yes that is me, indeed. It's just that we should not silently ignore errors. If we know the clock is optional, then the driver that knows that can handle it. But if we start having things quietly fail, debugging becomes a pain.
On 10/14/21 10:19 PM, Simon Glass wrote:
Hi Peng, Sean,
I2C
Example
NULL))
- /* * To avoid setting defaults twice, don't set them before relocation. * However, still set them for SPL. And still set them if
explicitly
Can't we have them loudly fail instead?
--Sean
Hi Sean,
Hi Peng, Sean,
I2C
Example
NULL))
explicitly
That is how it works today, as I understand it. But some boards want the defaults to be there but not to implement them in U-Boot. This seems fair enough to me. Perhaps we could add something to each node instead, to disable it?
--Sean
On 10/25/21 11:18 AM, Simon Glass wrote:
Hi Sean,
Hi Peng, Sean,
I2C
Example
NULL))
explicitly
u-boot,assigned-clock-status = "disabled";
--Sean
Hi Sean,
Hi Peng, Sean,
On 10/13/21 5:37 AM, Peng Fan (OSS) wrote: > From: Peng Fan peng.fan@nxp.com > > Current code has a force clk_set_defaults in multiple stages, U-Boot > reuse the same device tree and Linux Kernel device tree, but we not > register all the clks as Linux Kernel, so clk_set_defaults will fail > and cause the clk provider registeration fail. > > So introduce a new property to ignore the default settings which could > be used by any node that wanna ignore default settings. > > Signed-off-by: Peng Fan peng.fan@nxp.com > --- > doc/device-tree-bindings/device.txt | 3 +++ > drivers/clk/clk-uclass.c | 3 +++ > 2 files changed, 6 insertions(+) > > diff --git a/doc/device-tree-bindings/device.txt > b/doc/device-tree-bindings/device.txt > index 73ce2a3b5b..fe34ced268 100644 > --- a/doc/device-tree-bindings/device.txt > +++ b/doc/device-tree-bindings/device.txt > @@ -28,6 +28,9 @@ the acpi,compatible property. > Linux will only load the driver if the device can be detected (e.g. on I2C > bus). Note that this is an out-of-tree Linux feature. > > +Common device bindings that could be shared listed below: > + - u-boot,ignore-clk-defaults : ignore the assigned-clock-parents > + and assigned-clock-rates for a device that has the property. > > Example > ------- > diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index > 493018b33e..6bf3179e7b 100644 > --- a/drivers/clk/clk-uclass.c > +++ b/drivers/clk/clk-uclass.c > @@ -376,6 +376,9 @@ int clk_set_defaults(struct udevice *dev, enum clk_defaults_stage stage) > if (!dev_has_ofnode(dev)) > return 0; > > + if (ofnode_get_property(dev_ofnode(dev), "u-boot,ignore-clk-defaults", NULL)) > + return 0; > + > /* > * To avoid setting defaults twice, don't set them before relocation. > * However, still set them for SPL. And still set them if > explicitly >
Actually, I think that was Peng's idea in the first place :)
--Sean
participants (5)
Peng Fan
Peng Fan (OSS)
Sean Anderson
