[PATCH] arm64: zynqmp: zynqmp-zcu106-rev1.0: Fix DP PLL configuration
This patch fixes the DP audio and video PLL configurations for the zynqmp-zcu106-rev1.0 evaluation board.
The Linux DP driver expects the DP to be using the following PLL config: - DP video PLL should use the VPLL (0x0) - DP audio PLL should use the RPLL (0x3)
Register 0xFD1A0070 configures the DP video PLL. Register 0xFD1A0074 configures the DP audio PLL.
Signed-off-by: Neal Frager neal.frager@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c index 2ac4e035d887..3dc9bf8f3a83 100644 --- a/board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c +++ b/board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c @@ -81,8 +81,8 @@ static unsigned long psu_clock_init_data(void) psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000F00U); psu_mask_write(0xFD1A00A0, 0x01003F07U, 0x01000200U); - psu_mask_write(0xFD1A0070, 0x013F3F07U, 0x01010203U); - psu_mask_write(0xFD1A0074, 0x013F3F07U, 0x01013C00U); + psu_mask_write(0xFD1A0070, 0x013F3F07U, 0x01010500U); + psu_mask_write(0xFD1A0074, 0x013F3F07U, 0x01013C03U); psu_mask_write(0xFD1A007C, 0x013F3F07U, 0x01011303U); psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U);
Ășt 10. 5. 2022 v 16:18 odesĂlatel Michal Simek monstr@monstr.eu napsal:
-- 2.36.0
Applied. M
Michal Simek
