[U-Boot] [PATCH 1/1] ipu common: reset ipuv3 correctly
This patch checks self-clear sw_ipu_rst bit in SCR register of SRC controller to be cleared after setting it to high to reset IPUv3. This makes sure that IPUv3 finishes sofware reset. A timeout mechanism is added to stop polling on the bit status in case the bit could not be cleared by the hardware automatically within 10 millisecond.
Signed-off-by: Liu Ying Ying.Liu@freescale.com --- drivers/video/ipu_common.c | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/drivers/video/ipu_common.c b/drivers/video/ipu_common.c index 2020da9..fcc1745 100644 --- a/drivers/video/ipu_common.c +++ b/drivers/video/ipu_common.c @@ -94,6 +94,7 @@ struct ipu_ch_param { temp1; \ })
+#define IPU_SW_RST_TOUT_USEC (10000)
void clk_enable(struct clk *clk) { @@ -392,11 +393,20 @@ void ipu_reset(void) { u32 *reg; u32 value; + int timeout = IPU_SW_RST_TOUT_USEC;
reg = (u32 *)SRC_BASE_ADDR; value = __raw_readl(reg); value = value | SW_IPU_RST; __raw_writel(value, reg); + + while (__raw_readl(reg) & SW_IPU_RST) { + udelay(1); + if (!(timeout--)) { + printf("ipu software reset timeout\n"); + break; + } + }; }
Hi Liu Ying,
Signed-off-by: Liu YingYing.Liu@freescale.com
while (__raw_readl(reg)& SW_IPU_RST) {
udelay(1);
if (!(timeout--)) {
break;
Tested in the normal (successful) case on SABRE Lite.
Is there a situation under which this is known to fail or is that a hypothetical?
applied, thanks!
Anatolij
Anatolij Gustschin
Eric Nelson
Liu Ying
