[PATCH] topic: zynqmp: Add support for zynqmp-xilinx-xdp platform
XDP - Xilinx Drone Platform is a board for drones or other UAV.
Pinmux the SD card by default, and if the SD card detect line is high (inactive) then pinmux the SD1 interface to EMIO instead. SD is placed on extension card and shares connection with on board wife. That means that when SD card is present in the board wifi can't be used.
There seems to be an issue with DDR access from PL at 2400MT/s, after updating the PMU and ATF firmware this is causing extremely slow DDR access. Reducing the DDR speed from 2400 to 2133 appears to solve that issue, even though the hardware has proven to be 2400 capable.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/Makefile | 1 + .../zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts | 117 ++ .../psu_init_gpl.c | 1038 +++++++++++++++++ configs/xilinx_zynqmp_virt_defconfig | 2 +- 4 files changed, 1157 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts create mode 100644 board/xilinx/zynqmp/zynqmp-topic-miamimp-xilinx-xdp-v1r1/psu_init_gpl.c
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c6af87cf5e89..34fb856d5253 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -281,6 +281,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-mini-emmc1.dtb \ zynqmp-mini-nand.dtb \ zynqmp-mini-qspi.dtb \ + zynqmp-topic-miamimp-xilinx-xdp-v1r1.dtb \ zynqmp-zcu100-revC.dtb \ zynqmp-zcu102-revA.dtb \ zynqmp-zcu102-revB.dtb \ diff --git a/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts b/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts new file mode 100644 index 000000000000..0ee8c62f6b9a --- /dev/null +++ b/arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Topic XDP (Xilinx Drone Platform) + * + * (C) Copyright 2016, Topic Embedded Products BV + * Mike Looijmans mike.looijmans@topic.nl + */ + +/dts-v1/; + +#include "zynqmp.dtsi" +#include "zynqmp-clk-ccf.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/phy/phy.h> + +/ { + model = "Topic Miamimp ZynqMP XDP v1r1"; + compatible = "topic,miamimp-xdp-v1r1", "topic,miamimp-xdp", + "topic,miamimp", "xlnx,zynqmp"; + + aliases { + gpio0 = &gpio; + i2c0 = &i2c0; + i2c1 = &i2c1; + mmc0 = &sdhci0; + mmc1 = &sdhci1; + rtc0 = &rtc; + serial0 = &uart1; + serial1 = &uart0; + serial2 = &dcc; + spi0 = &qspi; + usb0 = &usb0; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>, <0x8 0x00000000 0x0 0x80000000>; + }; +}; + +&dcc { + status = "okay"; +}; + +&gpio { + status = "okay"; +}; + +&gpu { + status = "okay"; +}; + +&qspi { + status = "okay"; + is-dual = <1>; + flash@0 { + compatible = "st,m25p80", "n25q256a"; + m25p,fast-read; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <166000000>; + #address-cells = <1>; + #size-cells = <1>; + is-dual = <1>; + partition@0 { + label = "qspi-boot-bin"; + reg = <0x00000 0x60000>; + }; + partition@60000 { + label = "qspi-u-boot-itb"; + reg = <0x60000 0x100000>; + }; + partition@160000 { + label = "qspi-u-boot-env"; + reg = <0x160000 0x20000>; + }; + partition@200000 { + label = "qspi-rootfs"; + reg = <0x200000 0x1e00000>; + }; + }; +}; + +&rtc { + status = "okay"; +}; + +/* eMMC device */ +&sdhci0 { + status = "okay"; + non-removable; + disable-wp; /* We don't have a write-protect detection */ + bus-width = <8>; + xlnx,mio_bank = <0>; +}; + +/* SD1 with level shifter */ +&sdhci1 { + status = "okay"; + xlnx,mio_bank = <1>; + disable-wp; /* We don't have a write-protect detection */ + bus-width = <4>; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; diff --git a/board/xilinx/zynqmp/zynqmp-topic-miamimp-xilinx-xdp-v1r1/psu_init_gpl.c b/board/xilinx/zynqmp/zynqmp-topic-miamimp-xilinx-xdp-v1r1/psu_init_gpl.c new file mode 100644 index 000000000000..dbed7b789e36 --- /dev/null +++ b/board/xilinx/zynqmp/zynqmp-topic-miamimp-xilinx-xdp-v1r1/psu_init_gpl.c @@ -0,0 +1,1038 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012300U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014000U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000300U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010602U); + psu_mask_write(0xFF5E004C, 0x023F3F07U, 0x02013C00U); + psu_mask_write(0xFF5E0068, 0x013F3F07U, 0x01010400U); + psu_mask_write(0xFF5E006C, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF18030C, 0x00070007U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E0078, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E0124, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E007C, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0080, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000300U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000600U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000C02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000600U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000103U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010C00U); + psu_mask_write(0xFF5E00C4, 0x013F3F07U, 0x01010800U); + psu_mask_write(0xFF5E00C8, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E00CC, 0x013F3F07U, 0x01010400U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011802U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000001U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000C00U); + psu_mask_write(0xFD1A00B4, 0x01003F07U, 0x01000202U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000100U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000402U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x81040010U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000200U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00408410U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x008180BBU); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0040051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020106U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002305U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x07340301U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00200200U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x000006C0U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x11102412U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004041AU); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0708060DU); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030409U); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x06060403U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000606U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D07U); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002030BU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x1207010EU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x020196E5U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048C820BU); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00C800FFU); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000A09U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0909U); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x01010100U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x01010101U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x070F0707U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00001F01U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x07070707U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000007U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x06000604U); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000001U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000000U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000001U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F10010U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x42C21590U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xD05512C0U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A04161U); + psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0800C4, 0xFFFFFFFFU, 0x000000E0U); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x07241008U); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28200008U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x000F0300U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x01762B07U); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00331008U); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000E10U); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000634U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000301U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000020U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x000006C0U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800091C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12341000U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000009U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008AAA58U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x00087BDBU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080704, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08070C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080804, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08080C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD08090C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080B08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080B0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080C08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080C0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080D08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080D0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0E00B004U); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080E08, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080E0C, 0xFFFFFFFFU, 0x3F000008U); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x80803660U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x55556000U); + psu_mask_write(0xFD080F08, 0xFFFFFFFFU, 0xAAAAAAAAU); + psu_mask_write(0xFD080F0C, 0xFFFFFFFFU, 0x0029A4A4U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0C00B000U); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x01100000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x15019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x21100000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01266300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70400000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + + return 1; +} + +static unsigned long psu_ddr_qos_init_data(void) +{ + psu_mask_write(0xFD360008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD36001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD370008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD37001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD380008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD38001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD390008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD39001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3A001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFD3B001C, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B0008, 0x0000000FU, 0x00000000U); + psu_mask_write(0xFF9B001C, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180000, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180004, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180008, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18000C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180010, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180014, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180018, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18001C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180020, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180024, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180028, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18002C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180030, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180034, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180038, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180040, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180044, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180048, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180050, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180054, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180058, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180060, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180064, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180068, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18006C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180070, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180074, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180078, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18007C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180080, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180084, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180088, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18008C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180090, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180094, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180098, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800A8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800AC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180100, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180104, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180108, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180110, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180114, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180118, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180120, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180124, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180128, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF180130, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180134, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180204, 0xFFFFFFFFU, 0x1A000000U); + psu_mask_write(0xFF180208, 0xFFFFFFFFU, 0x00B02000U); + psu_mask_write(0xFF18020C, 0x00003FFFU, 0x00000000U); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x023FEF1EU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x02A00F1EU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x01001FFFU); + psu_mask_write(0xFF180144, 0x02A00F1EU, 0x02A00F1EU); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x01FFFFFFU); + psu_mask_write(0xFF180160, 0x01FFFFFFU, 0x01FFFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFF7FFU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x0007FFF9U); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x03FEDFBFU); + psu_mask_write(0xFF18017C, 0x01FFFFFFU, 0x01FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x01FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x03FFFFF4U); + psu_mask_write(0xFF180404, 0x00000003U, 0x00000000U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_pre_init_data(void) +{ + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01012302U); + psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000001U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x000E807CU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180390, 0x00000004U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000400U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000060U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008001U, 0x00000001U); + psu_mask_write(0xFF180320, 0x33843384U, 0x00801284U); + psu_mask_write(0xFF18031C, 0x00007FFEU, 0x00006450U); + psu_mask_write(0xFF180358, 0x00080000U, 0x00080000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x000003C0U, 0x00000000U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000600U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000018U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000006U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF010034, 0x000000FFU, 0x00000005U); + psu_mask_write(0xFF010018, 0x0000FFFFU, 0x0000008FU); + psu_mask_write(0xFF010000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF010004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x05F5DD18U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF0A0284, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0288, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0010, 0xFFFFFFFFU, 0xDFFF2000U); + mask_delay(1); + psu_mask_write(0xFF0A0010, 0xFFFFFFFFU, 0xDFFF0000U); + mask_delay(5); + psu_mask_write(0xFF0A0010, 0xFFFFFFFFU, 0xDFFF2000U); + psu_mask_write(0xFF0A0284, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0288, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0014, 0x03FF03FFU, 0x03FE0001U); + + mask_delay(1); + psu_mask_write(0xFF0A0014, 0x03FF03FFU, 0x03FE0000U); + + mask_delay(5); + psu_mask_write(0xFF0A0284, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0288, 0x03FFFFFFU, 0x00012000U); + psu_mask_write(0xFF0A0014, 0x03FF03FFU, 0x03FE0000U); + + return 1; +} + +static unsigned long psu_serdes_init_data(void) +{ + psu_mask_write(0xFD410000, 0x0000001FU, 0x0000000DU); + psu_mask_write(0xFD410004, 0x0000001FU, 0x0000000DU); + psu_mask_write(0xFD410008, 0x0000001FU, 0x00000008U); + psu_mask_write(0xFD402860, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD402864, 0x00000081U, 0x00000001U); + psu_mask_write(0xFD402868, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD40A094, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40A368, 0x000000FFU, 0x00000038U); + psu_mask_write(0xFD40A36C, 0x00000007U, 0x00000003U); + psu_mask_write(0xFD40A370, 0x000000FFU, 0x000000F4U); + psu_mask_write(0xFD40A374, 0x000000FFU, 0x00000031U); + psu_mask_write(0xFD40A378, 0x000000FFU, 0x00000002U); + psu_mask_write(0xFD40A37C, 0x00000033U, 0x00000030U); + psu_mask_write(0xFD40906C, 0x00000003U, 0x00000003U); + psu_mask_write(0xFD4080F4, 0x00000003U, 0x00000003U); + psu_mask_write(0xFD4010CC, 0x00000020U, 0x00000020U); + psu_mask_write(0xFD4050CC, 0x00000020U, 0x00000020U); + psu_mask_write(0xFD4090CC, 0x00000020U, 0x00000020U); + psu_mask_write(0xFD401074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D074, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40189C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4018F8, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD4018FC, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD401990, 0x000000FFU, 0x00000011U); + psu_mask_write(0xFD401924, 0x000000FFU, 0x00000004U); + psu_mask_write(0xFD401928, 0x000000FFU, 0x000000FEU); + psu_mask_write(0xFD401900, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD40192C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD401980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401914, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD401918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401940, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD401944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD401994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40589C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4058F8, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD4058FC, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD405990, 0x000000FFU, 0x00000011U); + psu_mask_write(0xFD405924, 0x000000FFU, 0x00000004U); + psu_mask_write(0xFD405928, 0x000000FFU, 0x000000FEU); + psu_mask_write(0xFD405900, 0x000000FFU, 0x00000064U); + psu_mask_write(0xFD40592C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD405980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD405914, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD405918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD405940, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD405944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD405994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40989C, 0x00000080U, 0x00000080U); + psu_mask_write(0xFD4098F8, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD4098FC, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD409990, 0x000000FFU, 0x00000010U); + psu_mask_write(0xFD409924, 0x000000FFU, 0x000000FEU); + psu_mask_write(0xFD409928, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD409900, 0x000000FFU, 0x0000001AU); + psu_mask_write(0xFD40992C, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD409980, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD409914, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD409918, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD409940, 0x000000FFU, 0x000000F7U); + psu_mask_write(0xFD409944, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD409994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40D994, 0x00000007U, 0x00000007U); + psu_mask_write(0xFD40107C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40507C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40907C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD40D07C, 0x0000000FU, 0x00000001U); + psu_mask_write(0xFD4019A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD401038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40102C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4059A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD405038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40502C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4099A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD409038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40902C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D9A4, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFD40D038, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD40D02C, 0x00000040U, 0x00000040U); + psu_mask_write(0xFD4019AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4059AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD4099AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD40D9AC, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD401978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD405978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD409978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD40D978, 0x00000010U, 0x00000010U); + psu_mask_write(0xFD3D001C, 0xFFFFFFFFU, 0x00000001U); + psu_mask_write(0xFD410010, 0x00000077U, 0x00000011U); + psu_mask_write(0xFD410014, 0x00000007U, 0x00000003U); + return 1; +} + +static unsigned long psu_resetout_init_data(void) +{ + psu_mask_write(0xFF5E023C, 0x00000400U, 0x00000000U); + psu_mask_write(0xFF9D0080, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF9D007C, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000140U, 0x00000000U); + psu_mask_write(0xFD1A0100, 0x000C0000U, 0x00000000U); + psu_mask_write(0xFE20C200, 0x00023FFFU, 0x00022457U); + psu_mask_write(0xFE20C630, 0x003FFF00U, 0x00000000U); + psu_mask_write(0xFE20C11C, 0x00000600U, 0x00000600U); + psu_mask_write(0xFE20C12C, 0x00004000U, 0x00004000U); + psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U); + psu_mask_write(0xFD48001C, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD480020, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD480024, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD480028, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD48002C, 0x0000FFFFU, 0x0000FFFFU); + psu_mask_write(0xFD480030, 0x0000FFFFU, 0x000000FFU); + psu_mask_write(0xFD480034, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD480038, 0x0000FFFFU, 0x0000FFFFU); + psu_mask_write(0xFD48003C, 0x0000FFFFU, 0x0000FFF0U); + psu_mask_write(0xFD480040, 0x0000FFFFU, 0x0000FFF0U); + psu_mask_write(0xFD480044, 0x0000FFFFU, 0x0000FFF1U); + psu_mask_write(0xFD480048, 0x0000FFFFU, 0x0000FFF1U); + psu_mask_write(0xFD48006C, 0x00000738U, 0x00000100U); + psu_mask_write(0xFD4800C8, 0x0000FFF0U, 0x00000040U); + psu_mask_write(0xFD4801A4, 0x000007FFU, 0x000000CDU); + psu_mask_write(0xFD4801A8, 0x00003FFFU, 0x00000624U); + psu_mask_write(0xFD4801AC, 0x000007FFU, 0x00000018U); + psu_mask_write(0xFD4801B0, 0x000007FFU, 0x000000B5U); + psu_mask_write(0xFD4801B4, 0x0000FFFFU, 0x00007E20U); + psu_mask_write(0xFD480088, 0x000000FFU, 0x00000001U); + psu_mask_write(0xFD4800D4, 0x000000FFU, 0x00000060U); + psu_mask_write(0xFD4800A4, 0x000003FFU, 0x00000000U); + psu_mask_write(0xFD480184, 0x00000FFFU, 0x00000082U); + psu_mask_write(0xFD480190, 0x00000040U, 0x00000000U); + psu_mask_write(0xFD480194, 0x0000FFE2U, 0x0000FFE2U); + psu_mask_write(0xFD480094, 0x00007E00U, 0x00004A00U); + psu_mask_write(0xFD480174, 0x0000FFFFU, 0x00009000U); + psu_mask_write(0xFD480200, 0xFFFFFFFFU, 0x10EED021U); + psu_mask_write(0xFD480204, 0xFFFFFFFFU, 0x10EE0007U); + psu_mask_write(0xFD480208, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD480060, 0x0000FFFFU, 0x00000400U); + psu_mask_write(0xFD480064, 0x000001FFU, 0x00000106U); + psu_mask_write(0xFD480010, 0x00001000U, 0x00000000U); + psu_mask_write(0xFD480164, 0x00001FFEU, 0x00000000U); + psu_mask_write(0xFD48013C, 0x00000020U, 0x00000000U); + psu_mask_write(0xFD4800AC, 0x00000100U, 0x00000000U); + psu_mask_write(0xFD4800C0, 0x000007FFU, 0x00000000U); + psu_mask_write(0xFD4800B8, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD4800BC, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD4800B0, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD4800B4, 0x0000FFF8U, 0x00000000U); + psu_mask_write(0xFD48031C, 0x00000002U, 0x00000000U); + psu_mask_write(0xFD48008C, 0x0000B000U, 0x00008000U); + psu_mask_write(0xFD1A0100, 0x00020000U, 0x00000000U); + psu_mask_write(0xFF0A0014, 0x03FF03FFU, 0x03FE0001U); + mask_poll(0xFD4023E4, 0x00000010U); + mask_poll(0xFD40A3E4, 0x00000010U); + + return 1; +} + +static unsigned long psu_resetin_init_data(void) +{ + psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000540U); + psu_mask_write(0xFD1A0100, 0x000E0000U, 0x000E0000U); + + return 1; +} + +static unsigned long psu_afi_config(void) +{ + psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U); + psu_mask_write(0xFD615000, 0x00000300U, 0x00000200U); + psu_mask_write(0xFD360000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD370000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD380000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD390000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD3A0000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD3B0000, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD360014, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD370014, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD380014, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD390014, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD3A0014, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD3B0014, 0x00000003U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + unsigned int pll_retry = 10; + unsigned int pll_locked = 0; + + while ((pll_retry > 0) && (!pll_locked)) { + Xil_Out32(0xFD080004, 0x00040010); + Xil_Out32(0xFD080004, 0x00040011); + + while ((Xil_In32(0xFD080030) & 0x1) != 1) + ; + pll_locked = (Xil_In32(0xFD080030) & 0x80000000) + >> 31; + pll_locked &= (Xil_In32(0xFD0807E0) & 0x10000) + >> 16; + pll_locked &= (Xil_In32(0xFD0809E0) & 0x10000) + >> 16; + pll_locked &= (Xil_In32(0xFD080BE0) & 0x10000) + >> 16; + pll_locked &= (Xil_In32(0xFD080DE0) & 0x10000) + >> 16; + pll_retry--; + } + Xil_Out32(0xFD0800C4, Xil_In32(0xFD0800C4) | (pll_retry << 16)); + if (!pll_locked) + return 0; + + Xil_Out32(0xFD080004U, 0x00040063U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + Xil_Out32(0xFD0701B0U, 0x00000001U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0004FE01); + regval = Xil_In32(0xFD080030); + while (regval != 0x80000FFF) + regval = Xil_In32(0xFD080030); + regval = ((Xil_In32(0xFD080030) & 0x1FFF0000) >> 18); + if (regval != 0) + return 0; + + Xil_Out32(0xFD080200U, 0x100091C7U); + int cur_R006_tREFPRD; + + cur_R006_tREFPRD = (Xil_In32(0xFD080018U) & 0x0003FFFFU) >> 0x00000000U; + prog_reg(0xFD080018, 0x3FFFF, 0x0, cur_R006_tREFPRD); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U); + + Xil_Out32(0xFD080004, 0x00060001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80004001) != 0x80004001) + regval = Xil_In32(0xFD080030); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U); + + Xil_Out32(0xFD080200U, 0x800091C7U); + prog_reg(0xFD080018, 0x3FFFF, 0x0, cur_R006_tREFPRD); + + Xil_Out32(0xFD080004, 0x0000C001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80000C01) != 0x80000C01) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD070180U, 0x01000040U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + + return 1; +} + +static int serdes_enb_coarse_saturation(void) +{ + Xil_Out32(0xFD402094, 0x00000010); + Xil_Out32(0xFD406094, 0x00000010); + Xil_Out32(0xFD40A094, 0x00000010); + Xil_Out32(0xFD40E094, 0x00000010); + return 1; +} + +static int serdes_fixcal_code(void) +{ + int maskstatus = 1; + unsigned int rdata = 0; + unsigned int match_pmos_code[23]; + unsigned int match_nmos_code[23]; + unsigned int match_ical_code[7]; + unsigned int match_rcal_code[7]; + unsigned int p_code = 0; + unsigned int n_code = 0; + unsigned int i_code = 0; + unsigned int r_code = 0; + unsigned int repeat_count = 0; + unsigned int L3_TM_CALIB_DIG20 = 0; + unsigned int L3_TM_CALIB_DIG19 = 0; + unsigned int L3_TM_CALIB_DIG18 = 0; + unsigned int L3_TM_CALIB_DIG16 = 0; + unsigned int L3_TM_CALIB_DIG15 = 0; + unsigned int L3_TM_CALIB_DIG14 = 0; + int i = 0; + + rdata = Xil_In32(0xFD40289C); + rdata = rdata & ~0x03; + rdata = rdata | 0x1; + Xil_Out32(0xFD40289C, rdata); + int count = 0; + + do { + if (count == 1100000) + break; + rdata = Xil_In32(0xFD402B1C); + count++; + } while ((rdata & 0x0000000E) != 0x0000000E); + + for (i = 0; i < 23; i++) { + match_pmos_code[i] = 0; + match_nmos_code[i] = 0; + } + for (i = 0; i < 7; i++) { + match_ical_code[i] = 0; + match_rcal_code[i] = 0; + } + + do { + Xil_Out32(0xFD410010, 0x00000000); + Xil_Out32(0xFD410014, 0x00000000); + + Xil_Out32(0xFD410010, 0x00000001); + Xil_Out32(0xFD410014, 0x00000000); + + maskstatus = mask_poll(0xFD40EF14, 0x2); + if (maskstatus == 0) { + xil_printf("#SERDES initialization timed out\n\r"); + return maskstatus; + } + + p_code = mask_read(0xFD40EF18, 0xFFFFFFFF); + n_code = mask_read(0xFD40EF1C, 0xFFFFFFFF); + ; + i_code = mask_read(0xFD40EF24, 0xFFFFFFFF); + r_code = mask_read(0xFD40EF28, 0xFFFFFFFF); + ; + + if (p_code >= 0x26 && p_code <= 0x3C) + match_pmos_code[p_code - 0x26] += 1; + + if (n_code >= 0x26 && n_code <= 0x3C) + match_nmos_code[n_code - 0x26] += 1; + + if (i_code >= 0xC && i_code <= 0x12) + match_ical_code[i_code - 0xc] += 1; + + if (r_code >= 0x6 && r_code <= 0xC) + match_rcal_code[r_code - 0x6] += 1; + + } while (repeat_count++ < 10); + + for (i = 0; i < 23; i++) { + if (match_pmos_code[i] >= match_pmos_code[0]) { + match_pmos_code[0] = match_pmos_code[i]; + p_code = 0x26 + i; + } + if (match_nmos_code[i] >= match_nmos_code[0]) { + match_nmos_code[0] = match_nmos_code[i]; + n_code = 0x26 + i; + } + } + + for (i = 0; i < 7; i++) { + if (match_ical_code[i] >= match_ical_code[0]) { + match_ical_code[0] = match_ical_code[i]; + i_code = 0xC + i; + } + if (match_rcal_code[i] >= match_rcal_code[0]) { + match_rcal_code[0] = match_rcal_code[i]; + r_code = 0x6 + i; + } + } + + L3_TM_CALIB_DIG20 = mask_read(0xFD40EC50, 0xFFFFFFF0); + L3_TM_CALIB_DIG20 = L3_TM_CALIB_DIG20 | 0x8 | ((p_code >> 2) & 0x7); + + L3_TM_CALIB_DIG19 = mask_read(0xFD40EC4C, 0xFFFFFF18); + L3_TM_CALIB_DIG19 = L3_TM_CALIB_DIG19 | ((p_code & 0x3) << 6) + | 0x20 | 0x4 | ((n_code >> 3) & 0x3); + + L3_TM_CALIB_DIG18 = mask_read(0xFD40EC48, 0xFFFFFF0F); + L3_TM_CALIB_DIG18 = L3_TM_CALIB_DIG18 | ((n_code & 0x7) << 5) | 0x10; + + L3_TM_CALIB_DIG16 = mask_read(0xFD40EC40, 0xFFFFFFF8); + L3_TM_CALIB_DIG16 = L3_TM_CALIB_DIG16 | ((r_code >> 1) & 0x7); + + L3_TM_CALIB_DIG15 = mask_read(0xFD40EC3C, 0xFFFFFF30); + L3_TM_CALIB_DIG15 = L3_TM_CALIB_DIG15 | ((r_code & 0x1) << 7) + | 0x40 | 0x8 | ((i_code >> 1) & 0x7); + + L3_TM_CALIB_DIG14 = mask_read(0xFD40EC38, 0xFFFFFF3F); + L3_TM_CALIB_DIG14 = L3_TM_CALIB_DIG14 | ((i_code & 0x1) << 7) | 0x40; + + Xil_Out32(0xFD40EC50, L3_TM_CALIB_DIG20); + Xil_Out32(0xFD40EC4C, L3_TM_CALIB_DIG19); + Xil_Out32(0xFD40EC48, L3_TM_CALIB_DIG18); + Xil_Out32(0xFD40EC40, L3_TM_CALIB_DIG16); + Xil_Out32(0xFD40EC3C, L3_TM_CALIB_DIG15); + Xil_Out32(0xFD40EC38, L3_TM_CALIB_DIG14); + return maskstatus; +} + +static int init_serdes(void) +{ + int status = 1; + + status &= psu_resetin_init_data(); + + status &= serdes_fixcal_code(); + status &= serdes_enb_coarse_saturation(); + + status &= psu_serdes_init_data(); + status &= psu_resetout_init_data(); + + return status; +} + +static void init_peripheral(void) +{ + psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU); +} + +static void psu_init_sdio_pinmux(void) +{ + if (Xil_In32(0xFF0A0064U) & (1U << 19)) { + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000000U); + + psu_mask_write(0xFF18030C, 0x00040000U, 0x00040000U); + + psu_mask_write(0xFF180320, 0x33843384U, 0x02801284U); + } else { + psu_mask_write(0xFF1800B4, 0x000000FEU, 0x00000010U); + } +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_peripherals_pre_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + status &= init_serdes(); + init_peripheral(); + + status &= psu_afi_config(); + psu_ddr_qos_init_data(); + + psu_init_sdio_pinmux(); + + if (status == 0) + return 1; + return 0; +} diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 7886d5a38f29..4f639bf58fe6 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -54,7 +54,7 @@ CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y CONFIG_CMD_UBI=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" -CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA" +CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA zynqmp-topic-miamimp-xilinx-xdp-v1r1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y
pá 5. 6. 2020 v 11:38 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
- dts file for Topic XDP (Xilinx Drone Platform)
- (C) Copyright 2016, Topic Embedded Products BV
- Mike Looijmans mike.looijmans@topic.nl
+/dts-v1/;
aliases {
gpio0 = &gpio;
i2c0 = &i2c0;
i2c1 = &i2c1;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
rtc0 = &rtc;
serial0 = &uart1;
serial1 = &uart0;
serial2 = &dcc;
spi0 = &qspi;
usb0 = &usb0;
chosen {
memory@0 {
+&dcc {
status = "okay";
+&gpio {
status = "okay";
+&gpu {
status = "okay";
+&qspi {
status = "okay";
is-dual = <1>;
flash@0 {
m25p,fast-read;
reg = <0x0>;
#size-cells = <1>;
is-dual = <1>;
partition@0 {
partition@60000 {
partition@160000 {
partition@200000 {
+&rtc {
status = "okay";
status = "okay";
non-removable;
bus-width = <8>;
status = "okay";
bus-width = <4>;
+&uart0 {
status = "okay";
+&uart1 {
status = "okay";
- (c) Copyright 2015 Xilinx, Inc. All rights reserved.
return 1;
return 1;
return 1;
return 1;
return 1;
return 1;
mask_delay(1);
mask_delay(5);
mask_delay(1);
mask_delay(5);
return 1;
return 1;
return 1;
return 1;
return 1;
>> 31;
>> 16;
>> 16;
>> 16;
>> 16;
pll_retry--;
if (!pll_locked)
if (regval != 0)
return 1;
return 1;
int maskstatus = 1;
int i = 0;
int count = 0;
do {
break;
count++;
do {
return maskstatus;
p_code = 0x26 + i;
n_code = 0x26 + i;
i_code = 0xC + i;
r_code = 0x6 + i;
return maskstatus;
int status = 1;
return status;
} else {
int status = 1;
init_peripheral();
if (status == 0)
return 1;
+} diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 7886d5a38f29..4f639bf58fe6 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -54,7 +54,7 @@ CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y CONFIG_CMD_UBI=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" -CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA" +CONFIG_OF_LIST="avnet-ultra96-rev1 zynqmp-a2197-revA zynqmp-e-a2197-00-revA zynqmp-g-a2197-00-revA zynqmp-m-a2197-01-revA zynqmp-m-a2197-02-revA zynqmp-m-a2197-03-revA zynqmp-p-a2197-00-revA zynqmp-zc1232-revA zynqmp-zc1254-revA zynqmp-zc1751-xm015-dc1 zynqmp-zc1751-xm016-dc2 zynqmp-zc1751-xm017-dc3 zynqmp-zc1751-xm018-dc4 zynqmp-zc1751-xm019-dc5 zynqmp-zcu100-revC zynqmp-zcu102-rev1.1 zynqmp-zcu102-rev1.0 zynqmp-zcu102-revA zynqmp-zcu102-revB zynqmp-zcu104-revA zynqmp-zcu104-revC zynqmp-zcu106-revA zynqmp-zcu111-revA zynqmp-zcu1275-revA zynqmp-zcu1275-revB zynqmp-zcu1285-revA zynqmp-zcu208-revA zynqmp-zcu216-revA zynqmp-topic-miamimp-xilinx-xdp-v1r1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y -- 2.27.0
Applied. M
Michal Simek
Michal Simek
