[U-Boot-Users] [PATCH 12/14] fs/: Remove lingering references to CFG_CMD_* symbols.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too. Those always evaluated TRUE, and thus were always compiled even when IDE really wasn't defined/wanted.
Signed-off-by: Jon Loeliger jdl@freescale.com --- fs/ext2/dev.c | 2 +- fs/ext2/ext2fs.c | 2 +- fs/jffs2/compr_rtime.c | 2 +- fs/jffs2/compr_rubin.c | 2 +- fs/jffs2/compr_zlib.c | 2 +- fs/jffs2/jffs2_1pass.c | 2 +- fs/jffs2/jffs2_nand_1pass.c | 2 +- fs/jffs2/mini_inflate.c | 2 +- fs/reiserfs/dev.c | 2 +- fs/reiserfs/mode_string.c | 2 +- fs/reiserfs/reiserfs.c | 2 +- 11 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/fs/ext2/dev.c b/fs/ext2/dev.c index 49a55b9..643a1a8 100644 --- a/fs/ext2/dev.c +++ b/fs/ext2/dev.c @@ -123,4 +123,4 @@ int ext2fs_devread (int sector, int byte_offset, int byte_len, char *buf) { } return (1); } -#endif /* CFG_CMD_EXT2FS */ +#endif diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c index e65e39b..513a2f9 100644 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -875,4 +875,4 @@ fail: return (0); }
-#endif /* CFG_CMD_EXT2FS */ +#endif diff --git a/fs/jffs2/compr_rtime.c b/fs/jffs2/compr_rtime.c index cb13211..144263c 100644 --- a/fs/jffs2/compr_rtime.c +++ b/fs/jffs2/compr_rtime.c @@ -88,4 +88,4 @@ void rtime_decompress(unsigned char *data_in, unsigned char *cpage_out, } }
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/jffs2/compr_rubin.c b/fs/jffs2/compr_rubin.c index 7a612c9..f6f3fa1 100644 --- a/fs/jffs2/compr_rubin.c +++ b/fs/jffs2/compr_rubin.c @@ -123,4 +123,4 @@ void dynrubin_decompress(unsigned char *data_in, unsigned char *cpage_out, rubin_do_decompress(bits, data_in+8, cpage_out, dstlen); }
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/jffs2/compr_zlib.c b/fs/jffs2/compr_zlib.c index 78b12a3..29dfe1b 100644 --- a/fs/jffs2/compr_zlib.c +++ b/fs/jffs2/compr_zlib.c @@ -49,4 +49,4 @@ long zlib_decompress(unsigned char *data_in, unsigned char *cpage_out,
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index 0d6d673..5316668 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -1397,4 +1397,4 @@ jffs2_1pass_info(struct part_info * part) return 1; }
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/jffs2/jffs2_nand_1pass.c b/fs/jffs2/jffs2_nand_1pass.c index 08885f0..3a4c649 100644 --- a/fs/jffs2/jffs2_nand_1pass.c +++ b/fs/jffs2/jffs2_nand_1pass.c @@ -1033,4 +1033,4 @@ jffs2_1pass_info(struct part_info * part) return 1; }
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/jffs2/mini_inflate.c b/fs/jffs2/mini_inflate.c index f2b8762..4c50fc3 100644 --- a/fs/jffs2/mini_inflate.c +++ b/fs/jffs2/mini_inflate.c @@ -393,4 +393,4 @@ long decompress_block(unsigned char *dest, unsigned char *source, return stream.error ? -stream.error : stream.decoded; }
-#endif /* CFG_CMD_JFFS2 */ +#endif diff --git a/fs/reiserfs/dev.c b/fs/reiserfs/dev.c index 66f927c..6b36c06 100644 --- a/fs/reiserfs/dev.c +++ b/fs/reiserfs/dev.c @@ -120,4 +120,4 @@ int reiserfs_devread (int sector, int byte_offset, int byte_len, char *buf) return 1; }
-#endif /* CFG_CMD_REISERFS */ +#endif diff --git a/fs/reiserfs/mode_string.c b/fs/reiserfs/mode_string.c index 8bf6bf0..ae98834 100644 --- a/fs/reiserfs/mode_string.c +++ b/fs/reiserfs/mode_string.c @@ -139,4 +139,4 @@ const char *bb_mode_string(int mode)
#endif
-#endif /* CFG_CMD_REISER */ +#endif diff --git a/fs/reiserfs/reiserfs.c b/fs/reiserfs/reiserfs.c index c6ab226..aa96361 100644 --- a/fs/reiserfs/reiserfs.c +++ b/fs/reiserfs/reiserfs.c @@ -983,4 +983,4 @@ reiserfs_open (char *filename) return filemax; }
Jon Loeliger
