[PATCH 1/4] clk: k210: Fix checking if ulongs are less than 0
Some clock functions return ulong but still have "negative" errors. To deal with this, cast the relevant arguments to long.
Fixes: 609bd60b94 ("clk: k210: Rewrite to remove CCF") Reported-by: Coverity Scan scan-admin@coverity.com Signed-off-by: Sean Anderson seanga2@gmail.com ---
drivers/clk/clk_kendryte.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/clk_kendryte.c b/drivers/clk/clk_kendryte.c index 3148756968..37bd624eca 100644 --- a/drivers/clk/clk_kendryte.c +++ b/drivers/clk/clk_kendryte.c @@ -439,7 +439,7 @@ static const struct k210_clk_params k210_clks[] = { #ifdef CONFIG_CLK_K210_SET_RATE static int k210_pll_enable(struct k210_clk_priv *priv, int id); static int k210_pll_disable(struct k210_clk_priv *priv, int id); -static ulong k210_pll_get_rate(struct k210_clk_priv *priv, int id, ulong rate_in); +static ulong k210_pll_get_rate(struct k210_clk_priv *priv, int id, long rate_in);
/* * The PLL included with the Kendryte K210 appears to be a True Circuits, Inc. @@ -841,7 +841,7 @@ TEST_STATIC int k210_pll_calc_config(u32 rate, u32 rate_in, }
static ulong k210_pll_set_rate(struct k210_clk_priv *priv, int id, ulong rate, - ulong rate_in) + long rate_in) { int err; const struct k210_pll_params *pll = &k210_plls[id]; @@ -890,7 +890,7 @@ static ulong k210_pll_set_rate(struct k210_clk_priv *priv, int id, ulong rate, #endif /* CONFIG_CLK_K210_SET_RATE */
static ulong k210_pll_get_rate(struct k210_clk_priv *priv, int id, - ulong rate_in) + long rate_in) { u64 r, f, od; u32 reg = readl(priv->base + k210_plls[id].off);
Everything here sits in a while (true) loop. However, this introduces a couple of layers of indentation. We can simplify the code by introducing a single goto instead of using continue/break. This will also make adding loops in the next patch easier.
drivers/clk/clk_kendryte.c | 105 ++++++++++++++++++------------------- 1 file changed, 52 insertions(+), 53 deletions(-)
diff --git a/drivers/clk/clk_kendryte.c b/drivers/clk/clk_kendryte.c index 37bd624eca..d2cee2cf97 100644 --- a/drivers/clk/clk_kendryte.c +++ b/drivers/clk/clk_kendryte.c @@ -709,6 +709,10 @@ TEST_STATIC int k210_pll_calc_config(u32 rate, u32 rate_in, * Whether we swapped r and od while enforcing frequency limits */ bool swapped = false; + /* + * Whether the intermediate frequencies are out-of-spec + */ + bool out_of_spec; u64 last_od = od; u64 last_r = r;
@@ -767,76 +771,71 @@ TEST_STATIC int k210_pll_calc_config(u32 rate, u32 rate_in, * aren't in spec, try swapping r and od. If everything is * in-spec, calculate the relative error. */ - while (true) { +again: + out_of_spec = false; + if (r > max_r) { + out_of_spec = true; + } else { /* - * Whether the intermediate frequencies are out-of-spec + * There is no way to only divide once; we need + * to examine the frequency with and without the + * effect of od. */ - bool out_of_spec = false; + u64 vco = DIV_ROUND_CLOSEST_ULL(rate_in * f, r);
- if (r > max_r) { + if (vco > 1750000000 || vco < 340000000) out_of_spec = true; - } else { - /* - * There is no way to only divide once; we need - * to examine the frequency with and without the - * effect of od. - */ - u64 vco = DIV_ROUND_CLOSEST_ULL(rate_in * f, r); + }
- if (vco > 1750000000 || vco < 340000000) - out_of_spec = true; + if (out_of_spec) { + u64 new_r, new_od; + + if (!swapped) { + u64 tmp = r; + + r = od; + od = tmp; + swapped = true; + goto again; }
- if (out_of_spec) { - if (!swapped) { - u64 tmp = r; - - r = od; - od = tmp; - swapped = true; - continue; - } else { - /* - * Try looking ahead to see if there are - * additional factors for the same - * product. - */ - if (i + 1 < ARRAY_SIZE(factors)) { - u64 new_r, new_od; - - i++; - new_r = UNPACK_R(factors[i]); - new_od = UNPACK_OD(factors[i]); - if (r * od == new_r * new_od) { - r = new_r; - od = new_od; - swapped = false; - continue; - } - i--; - } - break; + /* + * Try looking ahead to see if there are additional + * factors for the same product. + */ + if (i + 1 < ARRAY_SIZE(factors)) { + i++; + new_r = UNPACK_R(factors[i]); + new_od = UNPACK_OD(factors[i]); + if (r * od == new_r * new_od) { + r = new_r; + od = new_od; + swapped = false; + goto again; } + i--; }
- error = DIV_ROUND_CLOSEST_ULL(f * inv_ratio, r * od); - /* The lower 16 bits are spurious */ - error = abs((error - BIT(32))) >> 16; + /* We ran out of things to try */ + continue; + }
- if (error < best_error) { - best->r = r; - best->f = f; - best->od = od; - best_error = error; - } - break; + error = DIV_ROUND_CLOSEST_ULL(f * inv_ratio, r * od); + /* The lower 16 bits are spurious */ + error = abs((error - BIT(32))) >> 16; + + if (error < best_error) { + best->r = r; + best->f = f; + best->od = od; + best_error = error; } } while (f < 64 && i + 1 < ARRAY_SIZE(factors) && error != 0);
+ log_debug("best error %lld\n", best_error); if (best_error == S64_MAX) return -EINVAL;
- log_debug("best error %lld\n", best_error); return 0; }
Having to copy-paste the same 3 lines makes adding new test cases error-prone. Use a macro.
test/dm/k210_pll.c | 30 ++++++++++++------------------ 1 file changed, 12 insertions(+), 18 deletions(-)
diff --git a/test/dm/k210_pll.c b/test/dm/k210_pll.c index 54764f269c..5574ac96fa 100644 --- a/test/dm/k210_pll.c +++ b/test/dm/k210_pll.c @@ -69,27 +69,21 @@ static int dm_test_k210_pll(struct unit_test_state *uts) &theirs)); ut_asserteq(-EINVAL, k210_pll_calc_config(1500000000, 20000000, &theirs)); + ut_asserteq(-EINVAL, k210_pll_calc_config(1750000000, 13300000, + &theirs));
/* Verify we get the same output with brute-force */ - ut_assertok(dm_test_k210_pll_calc_config(390000000, 26000000, &ours)); - ut_assertok(k210_pll_calc_config(390000000, 26000000, &theirs)); - ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); +#define compare(rate, rate_in) do { \ + ut_assertok(dm_test_k210_pll_calc_config(rate, rate_in, &ours)); \ + ut_assertok(k210_pll_calc_config(rate, rate_in, &theirs)); \ + ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); \ +} while (0)
- ut_assertok(dm_test_k210_pll_calc_config(26000000, 390000000, &ours)); - ut_assertok(k210_pll_calc_config(26000000, 390000000, &theirs)); - ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); - - ut_assertok(dm_test_k210_pll_calc_config(400000000, 26000000, &ours)); - ut_assertok(k210_pll_calc_config(400000000, 26000000, &theirs)); - ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); - - ut_assertok(dm_test_k210_pll_calc_config(27000000, 26000000, &ours)); - ut_assertok(k210_pll_calc_config(27000000, 26000000, &theirs)); - ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); - - ut_assertok(dm_test_k210_pll_calc_config(26000000, 27000000, &ours)); - ut_assertok(k210_pll_calc_config(26000000, 27000000, &theirs)); - ut_assertok(dm_test_k210_pll_compare(&ours, &theirs)); + compare(390000000, 26000000); + compare(26000000, 390000000); + compare(400000000, 26000000); + compare(27000000, 26000000); + compare(26000000, 27000000);
return 0; }
In some cases, the best config cannot be used because the VCO would be out-of-spec. In these cases, we may need to try a worse combination of r/od in order to find the best representable config. This also adds a few test cases to catch this and other (possible) unlikely errors.
drivers/clk/clk_kendryte.c | 24 ++++++++++++++++++++++++ test/dm/k210_pll.c | 4 ++++ 2 files changed, 28 insertions(+)
diff --git a/drivers/clk/clk_kendryte.c b/drivers/clk/clk_kendryte.c index d2cee2cf97..e90550ef33 100644 --- a/drivers/clk/clk_kendryte.c +++ b/drivers/clk/clk_kendryte.c @@ -816,6 +816,30 @@ again: i--; }
+ /* + * Try looking back to see if there is a worse ratio + * that we could try anyway + */ + while (i > 0) { + i--; + new_r = UNPACK_R(factors[i]); + new_od = UNPACK_OD(factors[i]); + /* + * Don't loop over factors for the same product + * to avoid getting stuck because of the above + * clause + */ + if (r * od != new_r * new_od) { + if (new_r * new_od > last_r * last_od) { + r = new_r; + od = new_od; + swapped = false; + goto again; + } + break; + } + } + /* We ran out of things to try */ continue; } diff --git a/test/dm/k210_pll.c b/test/dm/k210_pll.c index 5574ac96fa..f55379f336 100644 --- a/test/dm/k210_pll.c +++ b/test/dm/k210_pll.c @@ -84,6 +84,10 @@ static int dm_test_k210_pll(struct unit_test_state *uts) compare(400000000, 26000000); compare(27000000, 26000000); compare(26000000, 27000000); + compare(13300000 * 64, 13300000); + compare(21250000, 21250000 * 70); + compare(21250000, 1750000000); + compare(1750000000, 1750000000);
return 0; }
- The PLL included with the Kendryte K210 appears to be a True Circuits, Inc.
Shouldn't this one return a long, in case of error ? It seems that the commit messages hints at such a change, but you are changing the argument type instead. A little confusing. What am I missing ?
ulong rate_in)
long rate_in)
Same here ?
ulong rate_in)
long rate_in)
I would assume that these functions are called if the rate_in argument is correct, so I do not really understand why the argument type needs to be changed...
Perhaps they should return long, but these are basically matching the prototypes in include/clk-uclass.h. And there, get_rate and set_rate take ulong arguments and return ulongs.
ulong rate_in)
{ int err; const struct k210_pll_params *pll = &k210_plls[id];long rate_in)
Same here ?
ulong rate_in)
long rate_in)
Hm, I suppose the better patch would be to check the return of get_rate and set_rate when we call them. I think my intent here was to allow subsequent functions to be no-ops in case of error, but it looks like I act on these values directly. Will fix in v2.
--Sean
Damien Le Moal
Sean Anderson
