[U-Boot] [PATCH 1/4] rtc: ds3232/ds3231: Add support to generate 32KHz output for driver module
This patch add an implementation of the rtc_enable_32khz_output() that uses the driver model i2c APIs.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- depends on: - http://patchwork.ozlabs.org/project/uboot/list/?series=118772 - http://patchwork.ozlabs.org/project/uboot/list/?series=117226
drivers/rtc/Kconfig | 10 ++++++++++ drivers/rtc/ds3231.c | 21 +++++++++++++++++++++ include/rtc.h | 6 ++++++ 3 files changed, 37 insertions(+)
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index fd0009b..040d241 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -31,6 +31,12 @@ config TPL_DM_RTC drivers to perform the actual functions. See rtc.h for a description of the API.
+config RTC_ENABLE_32KHZ_OUTPUT + bool "Enable RTC 32Khz output" + help + Some real-time clocks support the output of 32kHz square waves (such as ds3231), + the config symbol choose Real Time Clock device 32Khz output feature. + config RTC_PCF2127 bool "Enable PCF2127 driver" depends on DM_RTC @@ -41,6 +47,10 @@ config RTC_PCF2127 has a selectable I2C-bus or SPI-bus, a backup battery switch-over circuit, a programmable watchdog function, a timestamp function, and many other features.
+config DS3231_BUS_NUM + hex "I2C bus of the DS3231 device" + default 0 + config RTC_DS1307 bool "Enable DS1307 driver" depends on DM_RTC diff --git a/drivers/rtc/ds3231.c b/drivers/rtc/ds3231.c index 79b026a..dbd77a6 100644 --- a/drivers/rtc/ds3231.c +++ b/drivers/rtc/ds3231.c @@ -148,11 +148,13 @@ void rtc_reset (void) /* * Enable 32KHz output */ +#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT void rtc_enable_32khz_output(void) { rtc_write(RTC_STAT_REG_ADDR, RTC_STAT_BIT_BB32KHZ | RTC_STAT_BIT_EN32KHZ); } +#endif
/* * Helper functions @@ -251,6 +253,25 @@ static int ds3231_probe(struct udevice *dev) return 0; }
+#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT +void rtc_enable_32khz_output(void) +{ + int ret; + struct udevice *dev; + +#ifdef CONFIG_DS3231_BUS_NUM + ret = i2c_get_chip_for_busnum(CONFIG_DS3231_BUS_NUM, + CONFIG_SYS_I2C_RTC_ADDR, 1, &dev); +#else + ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_RTC_ADDR, 1, &dev); +#endif + if (!ret) + dm_i2c_reg_write(dev, RTC_STAT_REG_ADDR, + RTC_STAT_BIT_BB32KHZ | + RTC_STAT_BIT_EN32KHZ); +} +#endif + static const struct rtc_ops ds3231_rtc_ops = { .get = ds3231_rtc_get, .set = ds3231_rtc_set, diff --git a/include/rtc.h b/include/rtc.h index b255bdc..df7de09 100644 --- a/include/rtc.h +++ b/include/rtc.h @@ -166,11 +166,17 @@ int rtc_read32(struct udevice *dev, unsigned int reg, u32 *valuep); */ int rtc_write32(struct udevice *dev, unsigned int reg, u32 value);
+#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT +void rtc_enable_32khz_output(void); +#endif + #else int rtc_get (struct rtc_time *); int rtc_set (struct rtc_time *); void rtc_reset (void); +#ifdef CONFIG_RTC_ENABLE_32KHZ_OUTPUT void rtc_enable_32khz_output(void); +#endif
/** * rtc_read8() - Read an 8-bit register
This patch is updating ls2088aqds board init code to support DM_I2C.
board/freescale/ls2080aqds/eth.c | 75 +++++++++++++++++++++++++++++++++ board/freescale/ls2080aqds/ls2080aqds.c | 8 ++++ include/configs/ls2080aqds.h | 3 ++ 3 files changed, 86 insertions(+)
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index f706fd4..b1d6827 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -107,7 +107,16 @@ static void sgmii_configure_repeater(int serdes_port) int *riser_phy_addr = &xqsgii_riser_phy_addr[0];
/* Set I2c to Slot 1 */ +#ifndef CONFIG_DM_I2C i2c_write(0x77, 0, 0, &a, 1); +#else + struct udevice *udev; + + ret = i2c_get_chip_for_busnum(0, 0x77, 1, &udev); + if (!ret) + dm_i2c_write(udev, 0, &a, 1); +#endif +
for (dpmac = 0; dpmac < 8; dpmac++) { /* Check the PHY status */ @@ -120,7 +129,14 @@ static void sgmii_configure_repeater(int serdes_port) mii_bus = 1; dpmac_id = dpmac + 9; a = 0xb; +#ifndef CONFIG_DM_I2C i2c_write(0x76, 0, 0, &a, 1); +#else + ret = i2c_get_chip_for_busnum(0, 0x76, 1, &udev); + if (!ret) + dm_i2c_write(udev, 0, &a, 1); +#endif + break; }
@@ -153,6 +169,7 @@ static void sgmii_configure_repeater(int serdes_port)
for (i = 0; i < 4; i++) { for (j = 0; j < 4; j++) { +#ifndef CONFIG_DM_I2C a = 0x18; i2c_write(i2c_addr[dpmac], 6, 1, &a, 1); a = 0x38; @@ -176,6 +193,31 @@ static void sgmii_configure_repeater(int serdes_port) i2c_write(i2c_addr[dpmac], 0x2d, 1, &a, 1); a = 0x20; i2c_write(i2c_addr[dpmac], 4, 1, &a, 1); +#else + i2c_get_chip_for_busnum(0, i2c_addr[dpmac], + 1, &udev); + + a = 0x18; + dm_i2c_write(udev, 6, &a, 1); + a = 0x38; + dm_i2c_write(udev, 4, &a, 1); + a = 0x4; + dm_i2c_write(udev, 8, &a, 1); + + dm_i2c_write(udev, 0xf, &ch_a_eq[i], 1); + dm_i2c_write(udev, 0x11, &ch_a_ctl2[j], 1); + + dm_i2c_write(udev, 0x16, &ch_b_eq[i], 1); + dm_i2c_write(udev, 0x18, &ch_b_ctl2[j], 1); + + a = 0x14; + dm_i2c_write(udev, 0x23, &a, 1); + a = 0xb5; + dm_i2c_write(udev, 0x2d, &a, 1); + a = 0x20; + dm_i2c_write(udev, 4, &a, 1); + +#endif mdelay(100); ret = miiphy_read(dev[mii_bus], riser_phy_addr[dpmac], @@ -231,7 +273,15 @@ static void qsgmii_configure_repeater(int dpmac) unsigned short value;
switch (dpmac) { case 1: @@ -282,6 +332,7 @@ static void qsgmii_configure_repeater(int dpmac)
for (i = 0; i < 4; i++) { for (j = 0; j < 4; j++) { +#ifndef CONFIG_DM_I2C a = 0x18; i2c_write(i2c_phy_addr, 6, 1, &a, 1); a = 0x38; @@ -301,6 +352,30 @@ static void qsgmii_configure_repeater(int dpmac) i2c_write(i2c_phy_addr, 0x2d, 1, &a, 1); a = 0x20; i2c_write(i2c_phy_addr, 4, 1, &a, 1); +#else + i2c_get_chip_for_busnum(0, i2c_phy_addr, 1, &udev); + a = 0x18; + dm_i2c_write(udev, 6, &a, 1); + a = 0x38; + dm_i2c_write(udev, 4, &a, 1); + a = 0x4; + dm_i2c_write(udev, 8, &a, 1); + + dm_i2c_write(udev, 0xf, &ch_a_eq[i], 1); + dm_i2c_write(udev, 0x11, &ch_a_ctl2[j], 1); + + dm_i2c_write(udev, 0x16, &ch_b_eq[i], 1); + dm_i2c_write(udev, 0x18, &ch_b_ctl2[j], 1); + + a = 0x14; + dm_i2c_write(udev, 0x23, &a, 1); + a = 0xb5; + dm_i2c_write(udev, 0x2d, &a, 1); + a = 0x20; + dm_i2c_write(udev, 4, &a, 1); + +#endif + mdelay(100); ret = miiphy_read(dev, phy_addr, 0x11, &value); if (ret > 0) diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index a0a3301..21038a5 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -161,7 +161,15 @@ int select_i2c_ch_pca9547(u8 ch) { int ret;
+#ifndef CONFIG_DM_I2C ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); +#else + struct udevice *dev; + + ret = i2c_get_chip_for_busnum(0, I2C_MUX_PCA_ADDR_PRI, 1, &dev); + if (!ret) + ret = dm_i2c_write(dev, 0, &ch, 1); +#endif if (ret) { puts("PCA: failed to select proper channel\n"); return ret; diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 18f30b5..05ff770 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -16,7 +16,9 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_QSPI #define CONFIG_QIXIS_I2C_ACCESS +#ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C_EARLY_INIT +#endif #define CONFIG_SYS_I2C_IFDR_DIV 0x7e #endif
@@ -324,6 +326,7 @@ unsigned long get_board_ddr_clk(void); */ #define RTC #define CONFIG_RTC_DS3231 1 +#define CONFIG_RTC_ENABLE_32KHZ_OUTPUT #define CONFIG_SYS_I2C_RTC_ADDR 0x68
/* EEPROM */
Dear Chuanhua Han,
In message 20190724025904.469-2-chuanhua.han@nxp.com you wrote: ...
- struct udevice *udev;
Please - no declarations in the in the middle of the code (even if #ifdef'ed).
Thanks.
Dear Chuanhua,
I have a generic question about error handling in your code:
a = 0x18;
a = 0x38;
a = 0x4;
a = 0x14;
a = 0xb5;
a = 0x20;
You use a large number of functions without ever checking their return codes. But all these functions can fail for a number of reasons. Should you not always check for errors?
-----Original Message----- From: Wolfgang Denk wd@denx.de Sent: 2019年7月24日 14:55 To: Chuanhua Han chuanhua.han@nxp.com Cc: albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de; lukma@denx.de; trini@konsulko.com Subject: [EXT] Re: [PATCH 2/4] armv8: ls2088aqds: The ls2088aqds board supports the I2C driver model.
Caution: EXT Email
Dear Chuanhua,
a = 0x18;
a = 0x38;
a = 0x4;
- 1);
1);
- 1);
a = 0x14;
a = 0xb5;
a = 0x20;
yes,should to check for errors!
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de He had quite a powerful intellect, but it was as powerful like a locomotive, and ran on rails and was therefore almost impossible to steer. - Terry Pratchett, _Lords and Ladies_
Enable related configs on all ls2088aqds boards to support ds3231 rtc DM function.
configs/ls2088aqds_tfa_defconfig | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index e798c59..95921b0 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -1,12 +1,12 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y +CONFIG_SYS_MALLOC_F_LEN=0x6000 CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_TFABOOT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y -# CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y @@ -63,3 +63,11 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0 +CONFIG_DM_GPIO=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_DM_RTC=y +CONFIG_DS3231_BUS_NUM=0
This patch adds the ds3232-rtc node under the i2c0->i2c-mux@77->i2c@0 for ls2088aqds boards.
arch/arm/dts/fsl-ls2080a-qds.dts | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/arch/arm/dts/fsl-ls2080a-qds.dts b/arch/arm/dts/fsl-ls2080a-qds.dts index 2a0a528..13461b5 100644 --- a/arch/arm/dts/fsl-ls2080a-qds.dts +++ b/arch/arm/dts/fsl-ls2080a-qds.dts @@ -19,6 +19,25 @@ }; };
+&i2c0 { + status = "okay"; + pca9547@77 { + compatible = "nxp,pca9547"; + reg = <0x77>; + #address-cells = <1>; + #size-cells = <0>; + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x00>; + rtc@68 { + compatible = "dallas,ds3232"; + reg = <0x68>; + }; + }; + }; +}; + &dspi { bus-num = <0>; status = "okay";
Chuanhua Han
